B
gab_12
Błąd w czasie konfiguracji xorg-a
Post autor: gab_12 »
Mianowicie chciałem skonfigurować xorg-a no i nie stery w czasie konfiguracji a dokładnie po wybraniu klawiatury konfiguracja się kończy z komunikatem:
xserver-xorg postinst warning: overwriting possibly-customised configuration
   file; backup in /etc/X11/xorg.conf.20081015155547
Mój xorg po takiej konfiguracji wygląda nieco ubogo:
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
EndSection
Section "Device"
	Identifier	"Configured Video Device"
EndSection
Section "Monitor"
	Identifier	"Configured Monitor"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Monitor		"Configured Monitor"
EndSection
Nie wiem czy sie przydadzą logi ale dołączam również
/var/log/Xorg.0.log
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-7)
Current Operating System: Linux debian 2.6.24-1-686 #1 SMP Thu May 8 02:16:39 UTC 2008 i686
Build Date: 30 September 2008  01:48:58AM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 15 15:51:24 2008
(==) No Layout section.  Using the first Screen section.
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Configured Monitor"
(==) No device specified for screen "Default Screen".
	Using the first device section listed.
(**) |   |-->Device "Configured Video Device"
(==) |-->Input Device "Configured Mouse"
(==) |-->Input Device "Generic Keyboard"
(==) The core pointer device wasn't specified explicitly in the layout.
	Using the first mouse device.
(==) The core keyboard device wasn't specified explicitly in the layout.
	Using the first keyboard device.
(==) No FontPath specified.  Using compiled-in default.
	Entry deleted from font path.
(WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/100dpi/".
	(Run 'mkfontdir' on "/usr/share/fonts/X11/100dpi/").
(WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/100dpi".
	(Run 'mkfontdir' on "/usr/share/fonts/X11/100dpi").
(==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/75dpi,
	/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to "/etc/X11/rgb"
(II) Loader magic: 0x81e38c0
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 2.0
	X.Org XInput driver : 2.0
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
	compiled for 1.4.2, module version = 1.0.0
	ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 1002,5a31 card 1002,5a31 rev 01 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1002,5a3f card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:13:0: chip 1002,4374 card 1043,1187 rev 80 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 1002,4375 card 1043,1187 rev 80 class 0c,03,10 hdr 00
(II) PCI: 00:13:2: chip 1002,4373 card 1043,1187 rev 80 class 0c,03,20 hdr 00
(II) PCI: 00:14:0: chip 1002,4372 card 1043,1187 rev 81 class 0c,05,00 hdr 80
(II) PCI: 00:14:1: chip 1002,4376 card 1043,1187 rev 80 class 01,01,8a hdr 00
(II) PCI: 00:14:3: chip 1002,4377 card 0000,0000 rev 80 class 06,01,00 hdr 80
(II) PCI: 00:14:4: chip 1002,4371 card 0000,0000 rev 80 class 06,04,01 hdr 81
(II) PCI: 00:14:5: chip 1002,4370 card 1043,1183 rev 80 class 04,01,00 hdr 80
(II) PCI: 00:14:6: chip 1002,4378 card 1043,1186 rev 80 class 07,03,00 hdr 80
(II) PCI: 01:05:0: chip 1002,5a62 card 1043,1182 rev 00 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 10ec,8139 card 1043,1045 rev 10 class 02,00,00 hdr 00
(II) PCI: 02:01:0: chip 1180,0476 card a000,0000 rev b3 class 06,07,00 hdr 82
(II) PCI: 02:01:1: chip 1180,0822 card 1043,1187 rev 17 class 08,05,00 hdr 80
(II) PCI: 02:01:2: chip 1180,0592 card 1043,1187 rev 08 class 08,80,00 hdr 80
(II) PCI: 02:03:0: chip 14e4,4318 card 1043,120f rev 02 class 02,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 1 I/O range:
	[0] -1	0	0x00009000 - 0x00009fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xfe100000 - 0xfe1fffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xbdf00000 - 0xddefffff (0x20000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:20:3), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:20:4), (0,2,6), BCTRL: 0x0003 (VGA_EN is cleared)
(II) Bus 2 I/O range:
	[0] -1	0	0x0000a000 - 0x0000bfff (0x2000) IX[B]
(II) Bus 2 non-prefetchable memory range:
	[0] -1	0	0xfe200000 - 0xfeafffff (0x900000) MX[B]
(II) Bus 2 prefetchable memory range:
	[0] -1	0	0xddf00000 - 0xdfefffff (0x2000000) MX[B]
(II) PCI-to-CardBus bridge:
(II) Bus 3: bridge is at (2:1:0), (2,3,6), BCTRL: 0x0580 (VGA_EN is cleared)
(II) Bus 3 I/O range:
	[0] -1	0	0x0000a000 - 0x0000a0ff (0x100) IX[B]
	[1] -1	0	0x0000a400 - 0x0000a4ff (0x100) IX[B]
(--) PCI:*(1:5:0) ATI Technologies Inc RC410 [Radeon Xpress 200M] rev 0, Mem @ 0xc0000000/28, 0xfe1f0000/16, I/O @ 0x9800/8, BIOS @ 0xfe1c0000/17
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe0000000 to 0xdfffffff
(II) Active PCI resource ranges:
	[0] -1	0	0xfeafc000 - 0xfeafdfff (0x2000) MX[B]
	[1] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
	[2] -1	0	0xfeaff800 - 0xfeaff8ff (0x100) MX[B]
	[3] -1	0	0xfeaffc00 - 0xfeaffcff (0x100) MX[B]
	[4] -1	0	0xfebfc800 - 0xfebfc8ff (0x100) MX[B]
	[5] -1	0	0xfebfcc00 - 0xfebfccff (0x100) MX[B]
	[6] -1	0	0x60000000 - 0x600003ff (0x400) MX[B]
	[7] -1	0	0xfebfd000 - 0xfebfdfff (0x1000) MX[B]
	[8] -1	0	0xfebfe000 - 0xfebfefff (0x1000) MX[B]
	[9] -1	0	0xfebff000 - 0xfebfffff (0x1000) MX[B]
	[10] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[B]O
	[11] -1	0	0xfe1c0000 - 0xfe1dffff (0x20000) MX[B](B)
	[12] -1	0	0xfe1f0000 - 0xfe1fffff (0x10000) MX[B](B)
	[13] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
	[14] -1	0	0x0000b800 - 0x0000b8ff (0x100) IX[B]
	[15] -1	0	0x0000ff00 - 0x0000ff0f (0x10) IX[B]
	[16] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
	[17] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
	[18] -1	0	0x000003f4 - 0x000003f4 (0x1) IX[B]
	[19] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
	[20] -1	0	0x00000b00 - 0x00000b0f (0x10) IX[B]
	[21] -1	0	0x00009800 - 0x000098ff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xfeafc000 - 0xfeafdfff (0x2000) MX[B]
	[5] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
	[6] -1	0	0xfeaff800 - 0xfeaff8ff (0x100) MX[B]
	[7] -1	0	0xfeaffc00 - 0xfeaffcff (0x100) MX[B]
	[8] -1	0	0xfebfc800 - 0xfebfc8ff (0x100) MX[B]
	[9] -1	0	0xfebfcc00 - 0xfebfccff (0x100) MX[B]
	[10] -1	0	0x60000000 - 0x600003ff (0x400) MX[B]
	[11] -1	0	0xfebfd000 - 0xfebfdfff (0x1000) MX[B]
	[12] -1	0	0xfebfe000 - 0xfebfefff (0x1000) MX[B]
	[13] -1	0	0xfebff000 - 0xfebfffff (0x1000) MX[B]
	[14] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[B]O
	[15] -1	0	0xfe1c0000 - 0xfe1dffff (0x20000) MX[B](B)
	[16] -1	0	0xfe1f0000 - 0xfe1fffff (0x10000) MX[B](B)
	[17] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
	[18] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[19] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[20] -1	0	0x0000b800 - 0x0000b8ff (0x100) IX[B]
	[21] -1	0	0x0000ff00 - 0x0000ff0f (0x10) IX[B]
	[22] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
	[23] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
	[24] -1	0	0x000003f4 - 0x000003f4 (0x1) IX[B]
	[25] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
	[26] -1	0	0x00000b00 - 0x00000b0f (0x10) IX[B]
	[27] -1	0	0x00009800 - 0x000098ff (0x100) IX[B](B)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
	compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
	compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Matched radeon from file name radeon.ids in autoconfig
(==) Matched radeon for the autoconfigured driver
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "radeon"
(II) Loading /usr/lib/xorg/modules/drivers//radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 4.3.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
	compiled for 1.4.0.90, module version = 1.3.0
	ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
	compiled for 1.4.0.90, module version = 1.3.1
(II) RADEON: Driver for ATI Radeon chipsets:
	ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
	ATI Radeon Mobility X300 (M24) 3152 (PCIE),
	ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X600 (RV380) 3E50 (PCIE),
	ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
	ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
	ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
	ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
	ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
	ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
	ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
	ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
	ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
	ATI Radeon 8500 AIW BB (AGP), ATI Radeon 8500 AIW BC (AGP),
	ATI Radeon IGP320M (U1) 4336, ATI Radeon IGP330M/340M/350M (U2) 4337,
	ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
	ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
	ATI Radeon X800PRO (R420) JI (AGP),
	ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
	ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
	ATI Radeon Mobility 9800 (M18) JN (AGP),
	ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
	ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
	ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
	ATI Radeon Mobility M7 LW (AGP),
	ATI Mobility FireGL 7800 M7 LX (AGP),
	ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
	ATI FireGL Mobility 9000 (M9) Ld (AGP),
	ATI Radeon Mobility 9000 (M9) Lf (AGP),
	ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
	ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
	ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
	ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
	ATI Radeon 9800XT NJ (AGP),
	ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
	ATI Radeon Mobility 9600 (M10) NQ (AGP),
	ATI Radeon Mobility 9600 (M11) NR (AGP),
	ATI Radeon Mobility 9600 (M10) NS (AGP),
	ATI FireGL Mobility T2 (M10) NT (AGP),
	ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
	ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
	ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
	ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
	ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
	ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
	ATI Radeon Mobility X300 (M22) 5460 (PCIE),
	ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
	ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
	ATI Radeon X800PRO (R423) UI (PCIE),
	ATI Radeon X800LE (R423) UJ (PCIE),
	ATI Radeon X800SE (R423) UK (PCIE),
	ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
	ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
	ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
	ATI FireGL unknown (R423) UR (PCIE),
	ATI FireGL unknown (R423) UT (PCIE),
	ATI Mobility FireGL V5000 (M26) (PCIE),
	ATI Mobility Radeon X700 XL (M26) (PCIE),
	ATI Mobility Radeon X700 (M26) (PCIE),
	ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
	ATI Radeon Mobility 9100 IGP (U3) 5835,
	ATI Radeon XPRESS 200 5954 (PCIE),
	ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
	ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
	ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
	ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
	ATI Radeon XPRESS 200M 5975 (PCIE),
	ATI Radeon XPRESS 200 5A41 (PCIE),
	ATI Radeon XPRESS 200M 5A42 (PCIE),
	ATI Radeon XPRESS 200 5A61 (PCIE),
	ATI Radeon XPRESS 200M 5A62 (PCIE),
	ATI Radeon X300 (RV370) 5B60 (PCIE),
	ATI Radeon X600 (RV370) 5B62 (PCIE),
	ATI Radeon X550 (RV370) 5B63 (PCIE),
	ATI FireGL V3100 (RV370) 5B64 (PCIE),
	ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
	ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
	ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
	ATI Mobility Radeon X800 XT (M28) (PCIE),
	ATI Mobility FireGL V5100 (M28) (PCIE),
	ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
	ATI Radeon X850 XT PE (R480) (PCIE),
	ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
	ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
	ATI Radeon X850 XT (R480) (PCIE),
	ATI Radeon X800XT (R423) 5D57 (PCIE),
	ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
	ATI Radeon X700 PRO (RV410) (PCIE),
	ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
	ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
	ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
	ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
	ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
	ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
	ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
	ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
	ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
	ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
	ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
	ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
	ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
	ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
	ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
	ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
	ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
	ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
	ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
	ATI Mobility Radeon X1700, ATI Radeon X2300HD,
	ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
	ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
	ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
	ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
	ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI ATI FireGL V7400,
	ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
	ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
	ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
	ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
	ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
	ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI RV610,
	ATI ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
	ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610, ATI RV670,
	ATI Radeon HD3870, ATI Radeon HD3850, ATI RV670,
	ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE, ATI Radeon HD 3470,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI Mobility Radeon HD 3430,
	ATI Mobility Radeon HD 3400 Series, ATI FireMV 2450, ATI FireMV 2260,
	ATI FireMV 2260, ATI ATI Radeon HD 3600 Series,
	ATI ATI Radeon HD 3650 AGP, ATI ATI Radeon HD 3600 PRO,
	ATI ATI Radeon HD 3600 XT, ATI ATI Radeon HD 3600 PRO,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
(II) Primary Device is: PCI 01:05:0
(--) Assigning device section with no busID to primary device
(--) Chipset ATI Radeon XPRESS 200M 5A62 (PCIE) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
	[18] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
	[19] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
	[20] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
	[21] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[22] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[23] -1	0	0x0000b800 - 0x0000b8ff (0x100) IX[B]
	[24] -1	0	0x0000ff00 - 0x0000ff0f (0x10) IX[B]
	[25] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
	[26] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
	[27] -1	0	0x000003f4 - 0x000003f4 (0x1) IX[B]
	[28] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
	[29] -1	0	0x00000b00 - 0x00000b0f (0x10) IX[B]
	[30] -1	0	0x00009800 - 0x000098ff (0x100) IX[B](B)
	[31] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
	[32] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) RADEON(0): MMIO registers at 0x00000000fe1f0000: size 64KB
(II) RADEON(0): PCI bus 1 card 5 func 0
(II) RADEON(0): Creating default Display subsection in Screen section
	"Default Screen" for depth/fbbpp 24/32
(==) RADEON(0): Depth 24, (==) framebuffer bpp 32
(II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) RADEON(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 0.1.0
(II) RADEON(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(==) RADEON(0): RGB weight 888
(II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
(--) RADEON(0): Chipset: "ATI Radeon XPRESS 200M 5A62 (PCIE)" (ChipID = 0x5a62)
(--) RADEON(0): Linear framebuffer at 0x00000000c0000000
(--) RADEON(0): BIOS at 0xfe1c0000
(II) RADEON(0): PCI card detected
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) RADEON(0): initializing int10
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(II) RADEON(0): Legacy BIOS detected
(II) RADEON(0): Direct rendering not officially supported on RN50/RC410/R600
(II) RADEON(0): Detected total video RAM=131072K, accessible=262144K (PCI BAR=262144K)
(--) RADEON(0): Mapped VideoRAM: 131072 kByte (128 bit DDR SDRAM)
(II) RADEON(0): Color tiling enabled by default
(II) RADEON(0): Max desktop size set to 2560x1200
(II) RADEON(0): For a larger or smaller max desktop size, add a Virtual line to your xorg.conf
(II) RADEON(0): If you are having trouble with 3D, reduce the desktop size by adjusting the Virtual line to your xorg.conf
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) RADEON(0): ref_freq: 1432, min_out_pll: 20000, max_out_pll: 40000, min_in_pll: 100, max_in_pll: 1350, xclk: 26600, sclk: 266.000000, mclk: 300.000000
(II) RADEON(0): PLL parameters: rf=1432 rd=6 min=20000 max=40000; xclk=26600
(WW) RADEON(0): LCD DDC Info Table found!
(II) RADEON(0): Bios Connector table:
(II) RADEON(0): Port0: DDCType-0x68, DACType-2, TMDSType-1, ConnectorType-1
(II) RADEON(0): Port4: DDCType-0x1a0, DACType-0, TMDSType-0, ConnectorType-7
(II) RADEON(0): Output VGA-0 using monitor section Configured Monitor
(II) RADEON(0): I2C bus "VGA-0" initialized.
(II) RADEON(0): Output LVDS has no monitor section
(II) RADEON(0): Panel ID string: AUO
(II) RADEON(0): Panel Size from BIOS: 1280x800
(II) RADEON(0): BIOS provided dividers will be used.
(WW) RADEON(0): LVDS Info:
XRes: 1280, YRes: 800, DotClock: 68900
HBlank: 128, HOverPlus: 16, HSyncWidth: 32
VBlank: 16, VOverPlus: 4, VSyncWidth: 4
(II) RADEON(0): I2C bus "LVDS" initialized.
 Monitor   -- AUTO
 Connector -- VGA
 DAC Type  -- TVDAC/ExtDAC
 TMDS Type -- None
 DDC Type  -- 0x68
(II) RADEON(0): Port1:
 Monitor   -- AUTO
 Connector -- LVDS
 DAC Type  -- None
 TMDS Type -- None
 DDC Type  -- 0x1a0
(II) RADEON(0): Output: VGA-0, Detected Monitor Type: 0
finished output detect: 0
(II) RADEON(0): I2C device "LVDS:ddc2" registered at address 0xA0.
(II) RADEON(0): Output: LVDS, Detected Monitor Type: 2
(II) RADEON(0): EDID data from the display on output: LVDS ----------------------
(II) RADEON(0): Manufacturer: AUO  Model: 1874  Serial#: 0
(II) RADEON(0): Year: 2005  Week: 1
(II) RADEON(0): EDID Version: 1.3
(II) RADEON(0): Digital Display Input
(II) RADEON(0): Max H-Image Size [cm]: horiz.: 33  vert.: 21
(II) RADEON(0): Gamma: 2.20
(II) RADEON(0): No DPMS capabilities specified; RGB/Color Display
(II) RADEON(0): First detailed timing is preferred mode
(II) RADEON(0): redX: 0.600 redY: 0.340   greenX: 0.310 greenY: 0.560
(II) RADEON(0): blueX: 0.150 blueY: 0.115   whiteX: 0.313 whiteY: 0.329
(II) RADEON(0): Manufacturer's mask: 0
(II) RADEON(0): Supported additional Video Mode:
(II) RADEON(0): clock: 68.9 MHz   Image Size:  331 x 207 mm
(II) RADEON(0): h_active: 1280  h_sync: 1301  h_sync_end 1333 h_blank_end 1408 h_border: 0
(II) RADEON(0): v_active: 800  v_sync: 804  v_sync_end 808 v_blanking: 816 v_border: 0
(II) RADEON(0):  AUO
(II) RADEON(0):  B154EW01 V8
(II) RADEON(0): EDID (in hex):
(II) RADEON(0): 	00ffffffffffff0006af741800000000
(II) RADEON(0): 	010f0103802115780a85a599574f8f26
(II) RADEON(0): 	1d505400000001010101010101010101
(II) RADEON(0): 	010101010101ea1a0080502010301520
(II) RADEON(0): 	44004bcf100000180000000f00000000
(II) RADEON(0): 	00000000000000000002000000fe0041
(II) RADEON(0): 	554f0a202020202020202020000000fe
(II) RADEON(0): 	004231353445573031205638200a00ce
finished output detect: 1
finished all detect
before xf86InitialConfiguration
(II) RADEON(0):  AUO
in RADEONProbeOutputModes
(II) RADEON(0): EDID vendor "AUO", prod id 6260
(II) RADEON(0): Output VGA-0 disconnected
(II) RADEON(0): Output LVDS connected
(II) RADEON(0): Output LVDS using initial mode 1280x800
after xf86InitialConfiguration
(==) RADEON(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
	ABI class: X.Org ANSI C Emulation, version 0.3
(==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(==) RADEON(0): Using XAA acceleration architecture
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 1.2.0
(==) RADEON(0): Assuming overlay scaler buffer width is 1536
(II) RADEON(0): No MM_TABLE found - assuming CARD is not TV-in capable.
(!!) RADEON(0): For information on using the multimedia capabilities
	of this adapter, please see [url]http://gatos.sf.net[/url].
(!!) RADEON(0): MergedFB support has been removed and replaced with xrandr 1.2 support
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
	[0] 0	0	0xfe1f0000 - 0xfe1fffff (0x10000) MX[B]
	[1] 0	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B]
	[2] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[3] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[4] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[5] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[6] -1	0	0xfeafc000 - 0xfeafdfff (0x2000) MX[B]
	[7] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
	[8] -1	0	0xfeaff800 - 0xfeaff8ff (0x100) MX[B]
	[9] -1	0	0xfeaffc00 - 0xfeaffcff (0x100) MX[B]
	[10] -1	0	0xfebfc800 - 0xfebfc8ff (0x100) MX[B]
	[11] -1	0	0xfebfcc00 - 0xfebfccff (0x100) MX[B]
	[12] -1	0	0x60000000 - 0x600003ff (0x400) MX[B]
	[13] -1	0	0xfebfd000 - 0xfebfdfff (0x1000) MX[B]
	[14] -1	0	0xfebfe000 - 0xfebfefff (0x1000) MX[B]
	[15] -1	0	0xfebff000 - 0xfebfffff (0x1000) MX[B]
	[16] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[B]O
	[17] -1	0	0xfe1c0000 - 0xfe1dffff (0x20000) MX[B](B)
	[18] -1	0	0xfe1f0000 - 0xfe1fffff (0x10000) MX[B](B)
	[19] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
	[20] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B](OprU)
	[21] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B](OprU)
	[22] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B](OprU)
	[23] 0	0	0x00009800 - 0x000098ff (0x100) IX[B]
	[24] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[25] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[26] -1	0	0x0000b800 - 0x0000b8ff (0x100) IX[B]
	[27] -1	0	0x0000ff00 - 0x0000ff0f (0x10) IX[B]
	[28] -1	0	0x00000374 - 0x00000374 (0x1) IX[B]
	[29] -1	0	0x00000170 - 0x00000177 (0x8) IX[B]
	[30] -1	0	0x000003f4 - 0x000003f4 (0x1) IX[B]
	[31] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
	[32] -1	0	0x00000b00 - 0x00000b0f (0x10) IX[B]
	[33] -1	0	0x00009800 - 0x000098ff (0x100) IX[B](B)
	[34] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
	[35] 0	0	0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) RADEON(0): RADEONScreenInit c0000000 0 0
(==) RADEON(0): Write-combining range (0xc0000000,0x8000000)
Entering TV Save
Save TV timing tables
saveTimingTables: reading timing tables
TV Save done
(II) RADEON(0): Dynamic Clock Scaling Disabled
(II) RADEON(0): RADEONInitMemoryMap() :
(II) RADEON(0):   mem_size         : 0x08000000
(II) RADEON(0):   MC_FB_LOCATION   : 0x5fff5800
(II) RADEON(0):   MC_AGP_LOCATION  : 0xffffffc0
(II) RADEON(0): Depth moves disabled by default
(II) RADEON(0): Memory manager initialized to (0,0) (1280,8191)
(II) RADEON(0): Reserved area from (0,1200) to (1280,1202)
(II) RADEON(0): Largest offscreen area available: 1280 x 6989
init memmap
init common
init crtc1
init pll1
restore memmap
(II) RADEON(0): RADEONRestoreMemMapRegisters() :
(II) RADEON(0):   MC_FB_LOCATION   : 0x5fff5800 0x5fff5800
restore common
restore crtc1
restore pll1
restore LVDS
(==) RADEON(0): Backing store disabled
(WW) RADEON(0): Direct rendering disabled
(II) RADEON(0): XAA Render acceleration unsupported on Radeon 9500/9700 and newer. Please use EXA instead.
(II) RADEON(0): Render acceleration disabled
(II) RADEON(0): num pipes is 3
(II) RADEON(0): Using XFree86 Acceleration Architecture (XAA)
	Screen to screen bit blits
	Solid filled rectangles
	8x8 mono pattern filled rectangles
	Indirect CPU to Screen color expansion
	Solid Lines
	Scanline Image Writes
	Setting up tile and stipple cache:
		32 128x128 slots
		32 256x256 slots
		16 512x512 slots
(II) RADEON(0): Acceleration enabled
(II) RADEON(0): DPMS enabled
(==) RADEON(0): Silken mouse enabled
(II) RADEON(0): Using hardware cursor 0 (scanline 1202)
(II) RADEON(0): Using hardware cursor 1 (scanline 1205)
(II) RADEON(0): Largest offscreen area available: 1280 x 6982
(II) RADEON(0): No video input capabilities detected and no information is provided - disabling multimedia i2c
(II) Loading sub module "theatre_detect"
(II) LoadModule: "theatre_detect"
(II) Loading /usr/lib/xorg/modules/multimedia//theatre_detect_drv.so
(II) Module theatre_detect: vendor="X.Org Foundation"
(II) RADEON(0): no multimedia table present, disabling Rage Theatre.
(II) RADEON(0): Set up overlay video
(II) RADEON(0): Textured video requires CP on R5xx/IGP
(II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(--) RandR disabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
(II) AIGLX: Screen 0 is not DRI capable
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions//libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(II) RADEON(0): Setting screen physical size to 331 x 207
(WW) Configured Mouse: No Device specified, looking for one...
(II) Configured Mouse: Setting Device option to "/dev/input/mice"
(--) Configured Mouse: Device: "/dev/input/mice"
(==) Configured Mouse: Protocol: "Auto"
(**) Option "CorePointer"
(**) Configured Mouse: always reports core events
(==) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(**) Configured Mouse: Sensitivity: 1
(**) Option "CoreKeyboard"
(**) Generic Keyboard: always reports core events
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Generic Keyboard: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(--) Configured Mouse: PnP-detected protocol: "ExplorerPS/2"
(II) Configured Mouse: ps2EnableDataReporting: succeeded
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
	compiled for 4.3.99.902, module version = 1.0.0
(II) Synaptics touchpad driver version 0.14.6 (1406)
(--) SynPS/2 Synaptics TouchPad auto-dev sets device to /dev/input/event8
(**) Option "Device" "/dev/input/event8"
(--) SynPS/2 Synaptics TouchPad touchpad found
(**) SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: MOUSE)
(II) RADEON(0):   MC_AGP_LOCATION  : 0x003f0000
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore Timing Tables
Restore TV standard
Leaving Restore TV
init memmap
init common
init crtc1
init pll1
restore memmap
restore common
restore crtc1
restore pll1
restore LVDS
finished PLL2
finished PLL1
Entering Restore TV
Restore TV PLL
Restore TVHV
Restore TV Restarts
Restore TV standard
Leaving Restore TV
init memmap
init common
init crtc1
init pll1
restore memmap
restore common
restore crtc1
restore pll1
restore LVDS
Przeglądałem rożne fora i google ale nie potrafię rozwiązać tego problemu.
Proszę o pomoc.
Adrian_Wir
Post autor: Adrian_Wir »
A konfigurowałeś przez
dpkg-reconfigure xserver-xorg
Spróbuj użyć
X -configure
Po tym najprawdopodobniej będziesz musiał uzupełnić xorg.conf o wpisy dotyczące klawiatury
gab_12 pisze:Przeglądałem rożne fora i google ale nie potrafię rozwiązać tego problemu.
A przejrzałeś tematy przyklejone w dziale, w którym założyłeś swój temat?
To zerknij do nich. Uzyskasz odpowiedź i rozwiązanie zapewne swojego problemu :-D
gab_12
No właśnie po wydaniu komendy dpkg-reconfigure xserver-xorg dostaje ten komunikat i nie kończy sie konfiguracja
A po wydaniu X -configure otrzymuje
debian:/home/amon# X -configure
Fatal server error:
Server is already active for display 0
	If this server is no longer running, remove /tmp/.X0-lock
	and start again.
gab_12, miałeś się zapoznać z tematami przyklejonymi:
http://debian.linux.pl/viewtopic.php?t=8847
gab_12 pisze:Server is already active for display 0
Przetłumacz to sobie:
http://translate.google.pl/translate_t?hl=pl
gab_12
Właśnie miałem napisać że problem się częściowo rozwiązał po przeczytaniu tego tematu http://debian.linux.pl/viewtopic.php?t=8847 ale fnmirk mnie ubiegł. Ale bardzo dziękuję za pomoc.
Napisałem częściowo ponieważ nie wiem czemu nie mam polskich znaków po wyjściu z X-ów jak i również w atermie
[Dodano: 2008-10-16, 12:15]
I nie wiem dlaczego tak się dzieje ale po restarcie komputera jeśli loguje się przez gnome do x-ów wtedy nie mam polskich znaków w atermie i w konsoli. Ale jeśli przed załadowaniem x-ów, z konsoli zaloguje się jako użytkownik lub jako root to są polskie znaki i w konsoli i jeśli uruchomię x-y. Jednakże po wylogowaniu się w konsoli znowu znikają polskie ale w x-ach, a konkretnie w atermie nadal są polskie znaki. Jak dla mnie to jest nieco niezrozumiałe nie wiem co mam z tym zrobić.
