Zakupiłem nowy sprzęt i mam problem z sterownikami do karty graficznej
Moja konfiguracja to:
Karta grafiki MSI ATI RADEON 4670 512 DDR3
Athlon x2 5000
4G Ramu
na płycie Gigabyte GA-MA56S-S3
pomyj@localhost:~$ lspci -v
00:00.0 RAM memory: nVidia Corporation MCP65 Memory Controller (rev a3)
Subsystem: Giga-byte Technology Device 5001
Flags: bus master, 66MHz, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 ISA bridge: nVidia Corporation MCP65 LPC Bridge (rev a3)
Subsystem: Giga-byte Technology Device 0c11
00:01.1 SMBus: nVidia Corporation MCP65 SMBus (rev a1)
Flags: 66MHz, fast devsel, IRQ 11
I/O ports at ec00 [size=200]
I/O ports at 1c00 [size=200]
I/O ports at 1c40 [size=200]
Kernel driver in use: nForce2_smbus
Kernel modules: i2c-nforce2
00:01.2 RAM memory: nVidia Corporation MCP65 Memory Controller (rev a1)
00:02.0 USB Controller: nVidia Corporation MCP65 USB Controller (rev a3) (prog-if 10)
Subsystem: Giga-byte Technology Device 5004
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 23
Memory at f4006000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
Kernel modules: ohci-hcd
00:02.1 USB Controller: nVidia Corporation MCP65 USB Controller (rev a3) (prog-if 20)
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 22
Memory at f4007000 (32-bit, non-prefetchable) [size=200]
Kernel modules: ehci-hcd
00:07.0 Audio device: nVidia Corporation MCP65 High Definition Audio (rev a1)
Subsystem: Giga-byte Technology Device a002
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 20
Memory at f4000000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:08.0 PCI bridge: nVidia Corporation MCP65 PCI bridge (rev a1) (prog-if 01)
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000b000-0000bfff
00:09.0 IDE interface: nVidia Corporation MCP65 IDE (rev a1) (prog-if 8a [Master SecP PriP])
Subsystem: Giga-byte Technology Device 5002
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=200]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=75]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=200]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=75]
I/O ports at f000 [size=200]
Kernel driver in use: AMD_IDE
Kernel modules: amd74xx
00:0a.0 IDE interface: nVidia Corporation MCP65 SATA Controller (rev a3) (prog-if 85 [Master SecO PriO])
Subsystem: Giga-byte Technology Device b002
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 222
I/O ports at 09f0 [size=200]
I/O ports at 0bf0 [size=134]
I/O ports at 0970 [size=200]
I/O ports at 0b70 [size=134]
I/O ports at e800 [size=200]
Memory at f4004000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ahci
Kernel modules: ahci
00:0d.0 PCI bridge: nVidia Corporation MCP65 PCI Express bridge (rev a1)
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: f2000000-f3ffffff
Prefetchable memory behind bridge: 00000000e0000000-00000000efffffff
Kernel driver in use: pcieport-driver
Kernel modules: shpchp
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Kernel driver in use: k8temp
Kernel modules: k8temp
02:00.0 VGA compatible controller: ATI Technologies Inc Device 9490
Subsystem: Micro-Star International Co., Ltd. Device 1590
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f3000000 (64-bit, non-prefetchable) [size=64K]
I/O ports at c000 [size=200]
[virtual] Expansion ROM at f2000000 [disabled] [size=128K]
Kernel driver in use: fglrx_pci
Kernel modules: fglrx
02:00.1 Audio device: ATI Technologies Inc Device aa38
Subsystem: Micro-Star International Co., Ltd. Device aa38
Memory at f3010000 (64-bit, non-prefetchable) [size=16K]
jajko z repo 2.6.26-1-686-bigmem:
pomyj@localhost:~$ uname -a
Linux localhost 2.6.26-1-686-bigmem #1 SMP Wed Sep 10 17:32:01 UTC 2008 i686 GNU/LinuxProblem taki jak w kilku tematach na forum po instalacji fglrx z repozytorium i uruchomieniu
aticonfig --initialZwiech piszę w "" bo system według moich obserwacji raczej chodzi (np. odpalenie numlockx razem ze startem fluxboksa) tylko pada komunikacja karta --> monitor może to jest kwestia tego iż wyjścia na karcie to Dual DVI (używam przejściówki aby podpiąć starą poczciwą "Bańkę").
To samo dzieje się przy minimalnej konfiguracji Xorga:
Section "ServerLayout"
Identifier "X.org Configured"
Screen "ati"
InputDevice "Mouse0"
InputDevice "Keyboard0"
EndSection
#Section "Module"
# Load "dri"
# Load "glx"
#EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
HorizSync 31.0 - 55.0
VertRefresh 50.0 - 70.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Card0"
Driver "ati"
BusID "PCI:2:0:0"
EndSection
Section "Device"
Identifier "atif"
Driver "fglrx"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "ati"
Device "atif"
# Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1280x1024" "1024x768"
EndSubSection
EndSection
i zainstalowaniu ich X-y odpalają (ciągle używam tego minimalnego xorg.conf).
glxinfo:
pomyj@localhost:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX version: 1.2
GLX extensions:
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: ATI Radeon HD 4670
OpenGL version string: 2.1.7979 Release
OpenGL extensions:
GL_AMDX_vertex_shader_tessellator, GL_AMD_performance_monitor,
GL_AMD_texture_texture4, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects,
GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_envmap_bumpmap,
GL_ATI_fragment_shader, GL_ATI_meminfo, GL_ATI_separate_stencil,
GL_ATI_shader_texture_lod, GL_ATI_texture_compression_3dc,
GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_depth_buffer_float, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_object, GL_EXT_gpu_program_parameters,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_point_parameters,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texgen_reflection, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_texture_shared_exponent, GL_EXT_vertex_array, GL_KTX_buffer_region,
GL_NV_blend_square, GL_NV_texgen_reflection, GL_SGIS_generate_mipmap,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_WIN_swap_hint,
WGL_EXT_swap_control
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None
0x89 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 4 1 Ncon
pomyj@localhost:~$ fglrxinfo
display: :0.0 screen: 0
pomyj@localhost:~$ glxgears
51902 frames in 5.0 seconds = 10380.360 FPS
52328 frames in 5.0 seconds = 10465.546 FPS
52314 frames in 5.0 seconds = 10462.712 FPS
52402 frames in 5.0 seconds = 10480.337 FPS
52442 frames in 5.0 seconds = 10488.257 FPS
52461 frames in 5.0 seconds = 10492.051 FPS
52338 frames in 5.0 seconds = 10467.588 FPS
51884 frames in 5.0 seconds = 10376.676 FPS
pomyj@localhost:~$ fgl_glxgears
Using GLX_SGIX_pbuffer
8464 frames in 5.0 seconds = 1692.800 FPS
11926 frames in 5.0 seconds = 2385.200 FPS
12206 frames in 5.0 seconds = 2441.200 FPS
11896 frames in 5.0 seconds = 2379.200 FPS
11881 frames in 5.0 seconds = 2376.200 FPS
11887 frames in 5.0 seconds = 2377.400 FPS
11822 frames in 5.0 seconds = 2364.400 FPS
Kolejna nieprawidłowość to 2 procesy xorg (przy odpalaniu X ze sterownikami vesa wchodzi normalnie 1 xorg).
Poniżej log xorga:
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-7)
Current Operating System: Linux localhost 2.6.26-1-686-bigmem #1 SMP Wed Sep 10 17:32:01 UTC 2008 i686
Build Date: 30 September 2008 01:48:58AM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 14 20:04:03 2008
(==) ServerLayout "X.org Configured"
(**) |-->Screen "ati" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "atif"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(==) No FontPath specified. Using compiled-in default.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(II) Loader magic: 0x81e38c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(--) using VT number 7
(II) PCI: 00:00:0: chip 10de,0444 card 1458,5001 rev a3 class 05,00,00 hdr 00
(II) PCI: 00:01:0: chip 10de,0441 card 1458,0c11 rev a3 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0446 card 1458,0c11 rev a1 class 0c,05,00 hdr 80
(II) PCI: 00:01:2: chip 10de,0445 card 1458,0c11 rev a1 class 05,00,00 hdr 80
(II) PCI: 00:02:0: chip 10de,0454 card 1458,5004 rev a3 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,0455 card 1458,5004 rev a3 class 0c,03,20 hdr 80
(II) PCI: 00:07:0: chip 10de,044a card 1458,a002 rev a1 class 04,03,00 hdr 80
(II) PCI: 00:08:0: chip 10de,0449 card 0000,0000 rev a1 class 06,04,01 hdr 01
(II) PCI: 00:09:0: chip 10de,0448 card 1458,5002 rev a1 class 01,01,8a hdr 00
(II) PCI: 00:0a:0: chip 10de,045d card 1458,b002 rev a3 class 01,01,85 hdr 80
(II) PCI: 00:0d:0: chip 10de,0458 card 0000,0000 rev a1 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 02:00:0: chip 1002,9490 card 1462,1590 rev 00 class 03,00,00 hdr 80
(II) PCI: 02:00:1: chip 1002,aa38 card 1462,aa38 rev 00 class 04,03,00 hdr 80
(II) PCI: End of PCI scan
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:8:0), (0,1,1), BCTRL: 0x0200 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:13:0), (0,2,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 2 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(--) PCI:*(2:0:0) ATI Technologies Inc unknown chipset (0x9490) rev 0, Mem @ 0xe0000000/28, 0xf3000000/16, I/O @ 0xc000/8
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[21] -1 0 0x0000ec00 - 0x0000ec3f (0x40) IX[B]
[22] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B](B)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
compiled for 7.1.0, module version = 1.0.0
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.53.4
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 1.4.0.90, module version = 1.3.0
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.4.0.90, module version = 1.3.1
(II) Primary Device is: PCI 02:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.53.4
(II) ATI Proprietary Linux Driver Release Identifier: UNSUPPORTED-8.532
(II) ATI Proprietary Linux Driver Build Date: Sep 8 2008 16:31:48
(--) Chipset Supported AMD Graphics Processor (0x9490) found
(II) AMD Video driver is running on a device belonging to a group targeted for this release
(II) AMD Video driver is signed
(II) resource ranges after xf86ClaimFixedResources() call:
[26] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[27] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 0.1.0
(II) fglrx(0): PCI bus 2 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "DPMS"
(II) fglrx(0): Loading PCS database from /etc/ati/amdpcsdb
(II) fglrx(0): 10BitPixelFormat disabled by default
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(--) fglrx(0): Chipset: "ATI Radeon HD 4670" (Chipset = 0x9490)
(--) fglrx(0): (PciSubVendor = 0x1462, PciSubDevice = 0x1590)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xe0000000
(--) fglrx(0): MMIO registers at 0xf3000000
(--) fglrx(0): I/O port at 0x0000c000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.1.0
(EE) fglrx(0): vm86() syscall generated signal 11.
(II) fglrx(0): EAX=0x0000004f, EBX=0x00000000, ECX=0x00000000, EDX=0x00000000
(II) fglrx(0): ESP=0x00001000, EBP=0x00000000, ESI=0x00000000, EDI=0x00002000
(II) fglrx(0): CS=0x0000, SS=0x0100, DS=0x0040, ES=0x0000, FS=0x0000, GS=0x0000
(II) fglrx(0): EIP=0x00000600, EFLAGS=0x00033202
(II) fglrx(0): code at 0x00000600:
f4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 11.9
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: RV730
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): EAX=0x0000004f, EBX=0x00000003, ECX=0x00000000, EDX=0x00000000
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: Searching for BusID PCI:2:0:0
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports PCI:2:0:0
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) fglrx(0): Using adapter: 2:0.0.
(II) fglrx(0): [FB] Find the MC FB aperturs range(MCFBBase = 0xf00000000, MCFBSize = 0x20000000)
(--) fglrx(0): Video RAM: 524288 kByte, Type: GDDR3
(II) fglrx(0): PCIE card detected
(--) fglrx(0): Using per-process page tables (PPPT) as GART.
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) fglrx(0): ***Display: ConnectedDisplayTypes=0x00000010, disabled=0x00000000
(II) fglrx(0): Connected Display1: CRT on secondary DAC [crt2]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: DEL Model: 6124 Serial#: 861291078
(II) fglrx(0): Year: 1998 Week: 13
(II) fglrx(0): EDID Version: 1.1
(II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) fglrx(0): Sync: Separate Composite
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 30 vert.: 23
(II) fglrx(0): Gamma: 2.90
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): redX: 0.625 redY: 0.340 greenX: 0.280 greenY: 0.595
(II) fglrx(0): blueX: 0.155 blueY: 0.070 whiteX: 0.281 whiteY: 0.311
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1600 vsize 1200 refresh: 70 vid: 19113
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 28.3 MHz Image Size: 250 x 184 mm
(II) fglrx(0): h_active: 720 h_sync: 738 h_sync_end 846 h_blank_end 900 h_border: 0
(II) fglrx(0): v_active: 350 v_sync: 388 v_sync_end 390 v_blanking: 449 v_border: 0
(II) fglrx(0): Serial No: 66052H3VBF38
(II) fglrx(0): Monitor name: DELL D1025HE
(II) fglrx(0): Ranges: V min: 50 V max: 150 Hz, H min: 30 H max: 92 kHz,
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 00ffffffffffff0010ac246146425633
(II) fglrx(0): 0d0801010c1e17bee80dc2a057479827
(II) fglrx(0): 12484f244300a94a0101010101010101
(II) fglrx(0): 010101010101100bd0b4205e6310126c
(II) fglrx(0): 6208fab80000001a000000ff00363630
(II) fglrx(0): 3532483356424633380a000000fc0044
(II) fglrx(0): 454c4c20443130323548450a000000fd
(II) fglrx(0): 0032961e5cff000a20202020202000dd
(II) fglrx(0): End of Display1 EDID data --------------------
(WW) fglrx(0): Only one display is connnected,so single mode is enabled
(II) fglrx(0): EAX=0x0000034f, EBX=0x00000003, ECX=0x00000003, EDX=0x00000000
(II) fglrx(0): Primary Controller - CRT on secondary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000001
(==) fglrx(0): Qbs is not supported in this release. Disabled.
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 18 modes found for primary display.
(--) fglrx(0): Virtual size is 1280x1024 (pitch 0)
(**) fglrx(0): *Mode "1280x1024": 85.5 MHz (scaled from 0.0 MHz), 50.9 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "1280x1024"x47.0 85.51 1280 1344 1480 1680 1024 1025 1028 1083 interlace +hsync (50.9 kHz)
(**) fglrx(0): Default mode "1280x1024": 77.8 MHz (scaled from 0.0 MHz), 46.3 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "320x240"x60.0 12.59 320 328 376 400 240 491 493 525 doublescan (31.5 kHz)
(**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x200"x60.0 12.59 320 336 384 400 200 457 459 524 doublescan (31.5 kHz)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.2.0
(==) fglrx(0): NoDRI = NO
(II) Reloading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x4000001f
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): ATI GART size: 255 MB
(II) fglrx(0): [pcie] 261120 kB allocated
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(II) fglrx(0): Direct rendering enabled
(II) fglrx(0): Interrupt handler installed at IRQ 16.
(II) fglrx(0): Exposed events to the /proc interface
(II) fglrx(0): Finished Initialize PPLIB!
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf3000000 - 0xf300ffff (0x10000) MX[B]
[30] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(WW) fglrx(0): could not detect X server version (query_status=-1)
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
(II) fglrx(0): DRIScreenInit for fglrx driver
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:2:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0x3cd000
(II) fglrx(0): [drm] mapped SAREA 0x3cd000 to 0xb7b9d000
(II) fglrx(0): [drm] framebuffer handle = 0x3ce000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 8.53.4
(II) fglrx(0): Date: Sep 8 2008
(II) fglrx(0): Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0): Build-Kernel UTS_RELEASE: 2.6.26-1-686-bigmem
(II) fglrx(0): Build-Kernel MODVERSIONS: yes
(II) fglrx(0): Build-Kernel __SMP__: yes
(II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
(II) fglrx(0): [drm] register handle = 0x003cf000
(II) fglrx(0): DRI initialization successfull!
(II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x01040000
(II) fglrx(0): FBMM initialized for area (0,0)-(1280,3328)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,1024) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1280 x 2304
(==) fglrx(0): Backing store disabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(**) fglrx(0): DPMS enabled
(**) fglrx(0): Textured Video is enabled.
(II) LoadModule: "glesx"
(II) Loading /usr/lib/xorg/modules//glesx.so
(II) Module glesx: vendor="X.Org Foundation"
(II) Loading extension GLESX
(II) fglrx(0): GLESX enableFlags = 26
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Driver provided ScreenToScreenBitBlt replacement
Driver provided FillSolidRects replacement
(II) fglrx(0): GLESX is enabled
(II) LoadModule: "amdxmm"
(II) Loading /usr/lib/xorg/modules//amdxmm.so
(II) Module amdxmm: vendor="X.Org Foundation"
(II) fglrx(0): X context handle = 0x1
(II) fglrx(0): [DRI] installation complete
(==) fglrx(0): Silken mouse enabled
(==) fglrx(0): Using hardware cursor
(==) RandR enabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 10, (OK)
drmOpenByBusid: drmOpenMinor returns 10
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x71
(WW) AIGLX: 3D driver claims to not support visual 0x72
(II) AIGLX: Loaded and initialized /usr/lib/dri/fglrx_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) fglrx(0): Enable the clock gating!
(**) Option "Protocol" "auto"
(**) Mouse0: Device: "/dev/input/mice"
(**) Mouse0: Protocol: "auto"
(**) Option "CorePointer"
(**) Mouse0: always reports core events
(**) Option "Device" "/dev/input/mice"
(==) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5 6 7"
(**) Mouse0: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Mouse0: Buttons: 11
(**) Mouse0: Sensitivity: 1
(**) Option "CoreKeyboard"
(**) Keyboard0: always reports core events
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Keyboard0: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) evaluating device (Keyboard0)
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(--) Mouse0: PnP-detected protocol: "ExplorerPS/2"
(II) Mouse0: ps2EnableDataReporting: succeeded
[config/hal] couldn't initialise context: (null) ((null))
(EE) Error compiling keymap (server-0)
(EE) XKB: Couldn't compile keymap
(II) fglrx(0): Shutdown CMMQS
(II) fglrx(0): [drm] removed 1 reserved context for kernel
(II) fglrx(0): [drm] unmapping 8192 bytes of SAREA 0x3cd000 at 0xb7b9d000
(II) fglrx(0): EAX=0x0000004f, EBX=0x00000003, ECX=0x00000003, EDX=0x00000000
FreeFontPath: FPE "/usr/share/fonts/X11/misc" refcount is 2, should be 1; fixing.
(resztę błędów ostrzeżeń: klawisze, FreeFont itd bede sobie juz sam załatwiał potem chyba że to ma jakiś związek to piszcie).(EE) fglrx(0): vm86() syscall generated signal 11
Rano trafiłem w internecie, na jakimś forum iż tak wolno chodzące programy z KDE to kwestia właśnie grafiki ale nie mogę teraz tego odszukać żeby podać link.
Może to kwestia tylko jakiego błędu w pakietach z KDE ewentualnie brak jakiegoś załadowanego modułu chociaż szczerze wątpię.
Proszę pomóżcie.
Co do sterowników otwartych:
wszystko co trzeba zainstalowane ale wyskakuje:
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 14 18:42:27 2008
(**) | |-->Device "Card0"
(==) AIGLX enabled
(II) LoadModule: "ati"
(II) Loading /usr/lib/xorg/modules/drivers//ati_drv.so
(II) Module ati: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 6.9.0
(II) LoadModule: "radeon"
(II) Loading /usr/lib/xorg/modules/drivers//radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 4.3.0
(II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
(EE) No devices detected.
Fatal server error:
no screens found
Z góry dzięki za wszelkie odpowiedzi.
Pozdrawiam pomyj
