Message from syslogd@serwer at Sun Oct 12 20:13:20 2008 ...
serwer kernel: Oops: 0000 [#1]
serwer kernel: CPU: 0
serwer kernel: EIP: 0060:[<c062b93d>] Not tainted VLI
serwer kernel: EFLAGS: 00210286 (2.6.22.12-htb-htbimq #1)
serwer kernel: EIP is at __ip_route_output_key+0x20d/0x890
serwer kernel: eax: 80000000 ebx: 00000000 ecx: 00000000 edx: 000000e0
serwer kernel: esi: cb44be5c edi: 4dfe21ea ebp: cb44bd64 esp: cb44bd44
serwer kernel: ds: 007b es: 007b fs: 0000 gs: 0033 ss: 0068
serwer kernel: Process rtorrent (pid: 2901, ti=cb44a000 task=cf6ff590 task.ti=cb44a000)
serwer kernel: Stack: fffe451b cb44be98 00000000 0862b2ae 00000001 000014e4 cfc56800 00000000
serwer kernel: 00000000 00000001 00000000 4dfe21ea 25384f59 00000000 00000000 00000008
serwer kernel: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 25054f59
serwer kernel: Call Trace:
serwer kernel: [<c062bfde>] ip_route_output_flow+0x1e/0x250
serwer kernel: [<c064a720>] tcp_v4_connect+0x150/0x640
serwer kernel: [<c0158615>] do_lookup+0x65/0x190
serwer kernel: [<c0158997>] permission+0x137/0x140
serwer kernel: [<c015a826>] __link_path_walk+0x906/0xcb0
serwer kernel: [<c0657af8>] inet_stream_connect+0x1e8/0x270
serwer kernel: [<c0606895>] sys_connect+0xd5/0xf0
serwer kernel: [<c0647d89>] tcp_init_xmit_timers+0x19/0x20
serwer kernel: [<c0647f10>] tcp_keepalive_timer+0x0/0x1d0
serwer kernel: [<c0649e70>] tcp_v4_init_sock+0x20/0x110
serwer kernel: [<c0656cb3>] inet_create+0x1d3/0x2f0
serwer kernel: [<c0639eb8>] tcp_setsockopt+0x38/0x380
serwer kernel: [<c0162a89>] d_instantiate+0x49/0x70
serwer kernel: [<c0608853>] sock_common_setsockopt+0x23/0x30
serwer kernel: [<c0606765>] sys_setsockopt+0x75/0xd0
serwer kernel: [<c06082d8>] sys_socketcall+0x98/0x280
serwer kernel: [<c01027d2>] sysenter_past_esp+0x5f/0x85
serwer kernel: =======================
serwer kernel: Code: 00 00 81 fa e0 00 00 00 0f 84 03 04 00 00 81 fa f0 00 00 00 0f 84 57 02 00 00 84 c0 0f 84 4f 02 00 00 8b 44 24 08 0d 00 00 00 80 <f6> 83 b8 00 00 00 08 0f 44 44 24 08 89 44 24 08 8b ab 08 01 00
serwer kernel: EIP: [<c062b93d>] __ip_route_output_key+0x20d/0x890 SS:ESP 0068:cb44bd44
serwer kernel: [<c0636430>] ip_setsockopt+0x0/0xd50
rtorrent zainstalowałem już kilka miesięcy temu ale dopiero od około kilku dni tak się z nim dzieje.
rtorrent instalowany z svn, build 1016 oraz 1038 tak samo.
Czy to jakiś błąd czy co?
