Próbuję odtworzyć film na mplayer z svgalib (bez x-ów).
Film się nie odtwarza - czarny ekran i cisza.
Oto wyjście ddcprobe:
vbe: VESA 2.0 detected.
oem: Intel810(TM) Graphics Chip Accelerated VGA BIOS
memory: 1024kb
memory: 4096kb
mode: 132x25 (text)
mode: 132x43 (text)
mode: 132x50 (text)
mode: 132x60 (text)
mode: 320x200x64k
mode: 640x400x256
mode: 640x480x256
mode: 640x480x32k
mode: 640x480x64k
mode: 640x480x16m
mode: 800x600x16
mode: 800x600x256
mode: 800x600x32k
mode: 800x600x64k
mode: 800x600x16m
mode: 1024x768x256
edid:
edid: 1 1
eisa: STC01ff
serial: 01010101
manufacture: 0 1999
input: sync on green, analog signal.
screensize: 28 21
gamma: 1.000000
dpms: RGB, active off, suspend, standby
timing: 720x400@70 Hz (VGA 640x400, IBM)
timing: 640x480@60 Hz (VGA)
timing: 640x480@75 Hz (VESA)
timing: 800x600@60 Hz (VESA)
timing: 1024x768@87 Hz Interlaced (8514A)
timing: 1024x768@75 Hz (VESA)
ctiming: 800x600@85
monitorname: Sampo Tech.
monitorname: KM-511
monitorrange: 30-58, 50-120
monitorserial: 000001
po wpisaniu kodu
#mplayer -vo svga /home/piotr/jakis_film.VBO
Oto wyjście z &> z mplayer:
MPlayer 1.0rc1-4.1.2-DFSG-free (C) 2000-2006 MPlayer Team
CPU: Intel Celeron 2/Pentium III Coppermine,Geyserville (Family: 6, Model: 8, Stepping: 3)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /home/piotr/VTS_01_4.VOB.
MPEG-PS file format detected.
VIDEO: MPEG2 720x576 (aspect 2) 25.000 fps 9100.0 kbps (1137.5 kbyte/s)
Using VESA driver, 1024KB. VBE2.0
svgalib 1.4.3
Opening video filter: [scale]
Opening video filter: [spp]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
[PP] Using external postprocessing filter, max q = 6.
Could not find matching colorspace - retrying with -vf scale...
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed :(
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Opening audio decoder: [liba52] AC3 decoding with liba52
Using SSE optimized IMDCT transform
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
AO: [oss] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: using unscaled yuv420p -> bgr24 special converter
VO: [svga] 720x576 => 768x576 BGR 24-bit
[VO_SVGA] Vid_mode: 22, 800x600 24bpp.
MPlayer interrupted by signal 2 in module: decode_video
svgalib: Signal 2: Interrupt received (ctrl-c pressed).
Proszę o pomoc w interpretacji wyjścia mplayera.
Dziękuję
piotr
