B
Maden
Błąd podczas instalacji sterowników zamkniętych nvidi
Post autor: Maden »
jajko 2.6.26-1-686-bigmem
build-essential zainstalowny
headery również
prawa pliku rozruchowemy nadane
O to log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Oct  3 19:04:15 2008
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  precompiled interfaces  : true
  no ncurses color        : false
  query latest version    : false
  OpenGL header files     : true
  no questions            : false
  silent                  : false
  no recursion            : false
  no backup               : false
  kernel module only      : false
  sanity                  : false
  add this kernel         : false
  no runlevel check       : false
  no network              : false
  no ABI note             : false
  no RPMs                 : false
  no kernel module        : false
  force SELinux           : default
  no X server check       : false
  force tls               : (not specified)
  X install prefix        : (not specified)
  X library install path  : (not specified)
  X module install path   : (not specified)
  OpenGL install prefix   : (not specified)
  OpenGL install libdir   : (not specified)
  utility install prefix  : (not specified)
  utility install libdir  : (not specified)
  doc install prefix      : (not specified)
  kernel name             : (not specified)
  kernel include path     : (not specified)
  kernel source path      : (not specified)
  kernel output path      : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp mirror              : [url]ftp://download.nvidia.com[/url]
  RPM file list           : (not specified)
Using: nvidia-installer ncurses user interface
WARNING: Skipping the runlevel check (the utility `runlevel` failed to run).
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
   ke the installer to attempt to download a kernel interface for your kernel f
   rom the NVIDIA ftp site ([url]ftp://download.nvidia.com[/url])? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
   that the installer will need to compile a new kernel interface.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> The CC version check failed:
   The compiler used to compile the kernel (gcc 4.1) does not exactly match the
   current compiler (gcc 4.3).  The Linux 2.6 kernel module loader rejects kern
   el modules built with a version of gcc that does not exactly match that of t
   he compiler used to build the running kernel.
   If you know what you are doing and want to ignore the gcc version check, sel
   ect "No" to continue installation.  Otherwise, select "Yes" to abort install
   ation, set the CC environment variable to the name of the compiler used to c
   ompile your kernel, and restart installation.  Abort now? (Answer: No)
ERROR: The kernel header file
       '/lib/modules/2.6.26-1-686-bigmem/source/include/linux/kernel.h' does
       not exist.  The most likely reason for this is that the kernel source
       path '/lib/modules/2.6.26-1-686-bigmem/source' is incorrect.  Please
       make sure you have installed the kernel source files for your kernel and
       that they are properly configured; on Red Hat Linux systems, for
       example, be sure you have the 'kernel-source' or 'kernel-devel' RPM
       installed.  If you know the correct kernel source files are installed,
       you may specify the kernel source path with the '--kernel-source-path'
       command line option.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at [url]www.nvidia.com[/url].
Diabelko
Post autor: Diabelko »
Podaje przykład może powinno pomóc przy instalacji sterowników:
cd /lib/modules/2.6.26-1-686-bigmem
grep CONFIG_XEN . -Rl | xargs -i sed -i -e 's/CONFIG_XEN/CONFIG_LUPO/g' {}
export IGNORE_XEN_PRESENCE=1
Bądź odwołuję się też do tego:
http://blog.creonfx.com/linux/how-to-in ... l-with-xen
pozdrawiam
Maden
Post autor: Maden »
n23:~# cd /lib/modules/2.6.26-1-686-bigmem
n23:/lib/modules/2.6.26-1-686-bigmem# grep CONFIG_XEN . -Rl | xargs -i sed -i -e ’s/CONFIG_XEN/CONFIG_LUPO/g’ {}
grep: ./build/.tmp_versions: Nie ma takiego pliku ani katalogu
sed: -e wyrażenie #1, znak 1: nieznane polecenie: `�'
grep: ./build/virt: Nie ma takiego pliku ani katalogu
maly
Post autor: maly »
To jest rozwiązanie dla jajka 2.6.25-2 z Xen.
Podaj model karty graficznej, sterownik nVidii jaki instalujesz, procek?!
p.s. Czym różni się jajko 2.6.26-1-686 od 2.6.26-1-686-bigmem ?!
Maden
Post autor: Maden »
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 0c)
00:01.0 PCI bridge: Intel Corporation Mobile PM965/GM965/GL960 PCI Express Root Port (rev 0c)
00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 4 (rev 03)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 03)
00:1c.5 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 6 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
00:1f.2 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA IDE Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: nVidia Corporation GeForce 8600M GT (rev a1)
04:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5787M Gigabit Ethernet PCI Express (rev 02)
0a:00.0 Memory controller: Intel Corporation Turbo Memory Controller (rev 01)
0c:00.0 Network controller: Intel Corporation PRO/Wireless 4965 AG or AGN Network Connection (rev 61)
0e:06.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
0e:06.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
0e:06.2 System peripheral: Ricoh Co Ltd R5C843 MMC Host Controller (rev 12)
0e:06.3 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev ff)
bigmem = bigmemory czyli widzi mi 4gb nie uzywajac wersji amd64(teoretycznie)
NVIDIA-Linux-x86-173.14.12-pkg1
po spatchowaniu mam taki blad
creation time: Mon Oct  6 22:42:46 2008
installer version: 1.0.7
option status:
  update                  : false
  expert                  : false
  uninstall               : false
  driver info             : false
  silent                  : false
  no backup               : false
  sanity                  : false
  no network              : false
  no ABI note             : false
  no RPMs                 : false
  no cc version check     : false
  tmpdir                  : /tmp
-> Installing NVIDIA driver version 173.14.12.
[ Dodano: 2008-10-12, 11:54 ]
jest problem z tym jajkiem. Zainstalowalem jajko 2.6.26-1-686 i dziala.
