elliot
Post
autor: elliot »
Witajcie,
Mam problem z moim pendrive'm. Zamontowałem go, ale wyskakuje komunikat: "Nie można zamontować nośnika. Prawdopodobnie brak nośnika w napędzie."
Wpisałem polecenie:
i dysk jest wykryty, bo:
Bus 004 Device 003: ID 0951:1608 Kingston Technology
Co robić?
thalcave
- Junior Member
Post
autor: thalcave »
Jak go montujesz?
Po podłączeniu co wywala dmesg?
elliot
Post
autor: elliot »
Oto co dostaje po wpisaniu dmesg:
[ 76.562608] usb 4-2: new high speed USB device using ehci_hcd and address 2
[ 76.695421] usb 4-2: configuration #1 chosen from 1 choice
[ 76.696654] usb 4-2: New USB device found, idVendor=0951, idProduct=1608
[ 76.696669] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 76.696677] usb 4-2: Product: DataTraveler 2.0
[ 76.696683] usb 4-2: Manufacturer: Kingston
[ 76.696689] usb 4-2: SerialNumber: 200801250000000000000213
[ 76.876706] Initializing USB Mass Storage driver...
[ 76.878493] scsi0 : SCSI emulation for USB Mass Storage devices
[ 76.879046] usbcore: registered new interface driver usb-storage
[ 76.879053] USB Mass Storage support registered.
[ 76.911911] usb-storage: device found at 2
[ 76.911919] usb-storage: waiting for device to settle before scanning
[ 81.908558] usb-storage: device scan complete
[ 81.909539] scsi 0:0:0:0: Direct-Access Kingston DataTraveler 2.0 1.00 PQ: 0 ANSI: 2
[ 82.014486] Driver 'sd' needs updating - please use bus_type methods
[ 82.017966] sd 0:0:0:0: [sda] 3930112 512-byte hardware sectors (2012 MB)
[ 82.018601] sd 0:0:0:0: [sda] Write Protect is off
[ 82.018607] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 82.018610] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 82.021330] sd 0:0:0:0: [sda] 3930112 512-byte hardware sectors (2012 MB)
[ 82.021972] sd 0:0:0:0: [sda] Write Protect is off
[ 82.021977] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 82.021980] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 82.021986] sda:
[ 82.150563] sd 0:0:0:0: [sda] Attached SCSI removable disk
Dodam że na Windows XP pendrive tez nie działa, tylko dostaję pytanie, czy chcę sformatować ten dysk, po czym wyskakuje błąd przy formatowaniu.
thalcave
- Junior Member
Post
autor: thalcave »
wymarze całego pendrive'a. Potem utwórz partycje na nim, sformatuj i powinien działać.
