Po
giaur
Połączenie gprs Era tak tak za pomocą kppp
Post autor: giaur »
Próbuję to zrobic, ale cokolwiek bym nie wybral w konfiguracji, zawsze mam to samo:
Sep 19 18:11:13 box pppd[4931]: pppd 2.4.4 started by root, uid 0
Sep 19 18:11:13 box pppd[4931]: using channel 34
Sep 19 18:11:13 box pppd[4931]: Using interface ppp0
Sep 19 18:11:13 box pppd[4931]: Connect: ppp0 <--> /dev/ttyACM0
Sep 19 18:11:13 box pppd[4931]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x368670f7> <pcomp> <accomp>]
Sep 19 18:11:13 box pppd[4931]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x368670f7> <pcomp> <accomp>]
Sep 19 18:11:13 box pppd[4931]: rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <auth pap> <magic 0x6ed5a14> <pcomp> <accomp>]
Sep 19 18:11:13 box pppd[4931]: sent [LCP ConfAck id=0x1 <asyncmap 0x0> <auth pap> <magic 0x6ed5a14> <pcomp> <accomp>]
Sep 19 18:11:13 box pppd[4931]: sent [LCP EchoReq id=0x0 magic=0x368670f7]
Sep 19 18:11:13 box pppd[4931]: sent [PAP AuthReq id=0x1 user="erainternettt" password=<hidden>]
Sep 19 18:11:13 box pppd[4931]: rcvd [LCP EchoRep id=0x0 magic=0x6ed5a17]
Sep 19 18:11:13 box pppd[4931]: rcvd [PAP AuthAck id=0x1]
Sep 19 18:11:13 box pppd[4931]: PAP authentication succeeded
Sep 19 18:11:13 box pppd[4931]: sent [CCP ConfReq id=0x1 <deflate 15> <deflate(old#) 15> <bsd v1 15>]
Sep 19 18:11:13 box pppd[4931]: sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Sep 19 18:11:13 box pppd[4931]: rcvd [LCP ProtRej id=0x1 80 fd 01 01 00 0f 1a 04 78 00 18 04 78 00 15 03 2f]
Sep 19 18:11:13 box pppd[4931]: Protocol-Reject for 'Compression Control Protocol' (0x80fd) received
Sep 19 18:11:13 box pppd[4931]: rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>]
Sep 19 18:11:13 box pppd[4931]: sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Sep 19 18:11:16 box pppd[4931]: sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Sep 19 18:11:16 box pppd[4931]: rcvd [LCP TermReq id=0x2 05 00 00 0a 00 00 00 00 00 00]
Sep 19 18:11:16 box pppd[4931]: LCP terminated by peer (^E^@^@^J^@^@^@^@^@^@)
Sep 19 18:11:16 box pppd[4931]: sent [LCP TermAck id=0x2]
Sep 19 18:11:16 box pppd[4931]: Hangup (SIGHUP)
Sep 19 18:11:16 box pppd[4931]: Modem hangup
Sep 19 18:11:16 box pppd[4931]: Connection terminated.
Sep 19 18:11:16 box pppd[4931]: Exit.
Pytanie - co właściwie jest nie tak?
[ Dodano: 2008-09-19, 18:42 ]
Hmm pewnie nikt nie bedzie wiedzial, wiec odpowiem sobie sam... a moze komus sie przyda. Aby zadziałało, należy dodać polecenie inicjalizujące modem. Dla ery będzie to:
AT+CGDCONT=1,"IP","erainternet"
w polu Init2 (u mnie domyślnie było tu pusto). Po dodaniu tego internet z komórki śmiga. Jestem tylko ciekawy jak zrobić, żebym nie musiał łączyć się z konta roota? Jak uruchomie kppp jak zwykły użytkownik, nie działa modem...
ea66
Post autor: ea66 »
W konsoli roota wpisz:
adduser twoja_nazwa_użytkownika dip
Po kolejnym zalogowaniu będziesz mógł łączyć się z poziomu użytkownika.
