niedawno zainstalowałem Debiana (testing) i nie mogę sobie poradzić z taką kwestią:
podczas ładowania systemu (a nawet zamykania) Debian regularnie robi sobie zwiechy... tz. zatrzymuje się i cisza.
Rusza dopiero po wciśnięciu, a niekiedy przytrzymaniu klawisza enter.
Zatrzymuje sie najczęściej na wpisach:
ide0: BM-DMA at 0x3080-0x3087, BIOS settings: hda :D MA, hdb:PIO
ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LMAC] -> GSI 10 (level, low) -> IRQ 10
ata2: SATA max UDMA/133 cmd 0x30b8 ctl 0x30b0 bmdma 0x3098 irq 5
hub 1-0:1.0: unable to enumerate USB device on port 6Kod: Zaznacz cały
bootlogdPrzykładowy log:
Aug 27 14:27:27 debian kernel: imklog 3.18.1, log source = /proc/kmsg started.
Aug 27 14:27:27 debian kernel: ioport range 0x1400-0x147f has been reserved
Aug 27 14:27:27 debian kernel: [    0.162921] system 00:04: ioport range 0x1480-0x14ff has been reserved
Aug 27 14:27:27 debian kernel: [    0.162928] system 00:04: ioport range 0x1800-0x187f has been reserved
Aug 27 14:27:27 debian kernel: [    0.162935] system 00:04: ioport range 0x1880-0x18ff has been reserved
Aug 27 14:27:27 debian kernel: [    0.162942] system 00:04: ioport range 0x2000-0x203f has been reserved
Aug 27 14:27:27 debian kernel: [    0.162952] system 00:05: ioport range 0x360-0x361 has been reserved
Aug 27 14:27:27 debian kernel: [    0.162959] system 00:05: ioport range 0x380-0x383 has been reserved
Aug 27 14:27:27 debian kernel: [    0.162966] system 00:05: ioport range 0x4d0-0x4d1 has been reserved
Aug 27 14:27:27 debian kernel: [    0.193338] PCI: Bridge: 0000:00:02.0
Aug 27 14:27:27 debian kernel: [    0.193345]   IO window: 4000-4fff
Aug 27 14:27:27 debian kernel: [    0.193351]   MEM window: 0xb4000000-0xb7ffffff
Aug 27 14:27:27 debian kernel: [    0.193356]   PREFETCH window: 0x00000000d0000000-0x00000000d01fffff
Aug 27 14:27:27 debian kernel: [    0.193364] PCI: Bridge: 0000:00:03.0
Aug 27 14:27:27 debian kernel: [    0.193368]   IO window: disabled.
Aug 27 14:27:27 debian kernel: [    0.193373]   MEM window: 0xb8000000-0xbbffffff
Aug 27 14:27:27 debian kernel: [    0.193379]   PREFETCH window: disabled.
Aug 27 14:27:27 debian kernel: [    0.193385] PCI: Bridge: 0000:00:10.0
Aug 27 14:27:27 debian kernel: [    0.193389]   IO window: disabled.
Aug 27 14:27:27 debian kernel: [    0.193395]   MEM window: disabled.
Aug 27 14:27:27 debian kernel: [    0.193400]   PREFETCH window: disabled.
Aug 27 14:27:27 debian kernel: [    0.193419] PCI: Setting latency timer of device 0000:00:02.0 to 64
Aug 27 14:27:27 debian kernel: [    0.193426] PCI: Setting latency timer of device 0000:00:03.0 to 64
Aug 27 14:27:27 debian kernel: [    0.193434] PCI: Setting latency timer of device 0000:00:10.0 to 64
Aug 27 14:27:27 debian kernel: [    0.193458] NET: Registered protocol family 2
Aug 27 14:27:27 debian kernel: [    0.193544] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 27 14:27:27 debian kernel: [    0.193854] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Aug 27 14:27:27 debian kernel: [    0.194840] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
Aug 27 14:27:27 debian kernel: [    0.195092] TCP: Hash tables configured (established 131072 bind 65536)
Aug 27 14:27:27 debian kernel: [    0.195099] TCP reno registered
Aug 27 14:27:27 debian kernel: [    0.195295] checking if image is initramfs... it is
Aug 27 14:27:27 debian kernel: [    0.504042] Switched to high resolution mode on CPU 0
Aug 27 14:27:27 debian kernel: [    0.692960] Freeing initrd memory: 5650k freed
Aug 27 14:27:27 debian kernel: [    0.693104] Simple Boot Flag at 0x36 set to 0x1
Aug 27 14:27:27 debian kernel: [    0.693578] audit: initializing netlink socket (disabled)
Aug 27 14:27:27 debian kernel: [    0.693596] type=2000 audit(1219847137.688:1): initialized
Aug 27 14:27:27 debian kernel: [    0.693699] Total HugeTLB memory allocated, 0
Aug 27 14:27:27 debian kernel: [    0.693754] VFS: Disk quotas dquot_6.5.1
Aug 27 14:27:27 debian kernel: [    0.693787] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 27 14:27:27 debian kernel: [    0.693874] io scheduler noop registered
Aug 27 14:27:27 debian kernel: [    0.693880] io scheduler anticipatory registered
Aug 27 14:27:27 debian kernel: [    0.693885] io scheduler deadline registered
Aug 27 14:27:27 debian kernel: [    0.693899] io scheduler cfq registered (default)
Aug 27 14:27:27 debian kernel: [    0.693916] pci 0000:00:00.0: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.693950] pci 0000:00:02.0: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.693962] pci 0000:00:03.0: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.693974] pci 0000:00:05.0: Boot video device
Aug 27 14:27:27 debian kernel: [    0.693995] pci 0000:00:09.0: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.696079] pci 0000:00:0e.0: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.696092] pci 0000:00:10.0: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.696107] pci 0000:00:10.1: Enabling HT MSI Mapping
Aug 27 14:27:27 debian kernel: [    0.696218] PCI: Setting latency timer of device 0000:00:02.0 to 64
Aug 27 14:27:27 debian kernel: [    0.696243] assign_interrupt_mode Found MSI capability
Aug 27 14:27:27 debian kernel: [    0.696267] Allocate Port Service[0000:00:02.:p cie00]
Aug 27 14:27:27 debian kernel: [    0.696316] Allocate Port Service[0000:00:02.:p cie03]
Aug 27 14:27:27 debian kernel: [    0.696373] PCI: Setting latency timer of device 0000:00:03.0 to 64
Aug 27 14:27:27 debian kernel: [    0.696395] assign_interrupt_mode Found MSI capability
Aug 27 14:27:27 debian kernel: [    0.696415] Allocate Port Service[0000:00:03.:p cie00]
Aug 27 14:27:27 debian kernel: [    0.696449] Allocate Port Service[0000:00:03.:p cie03]
Aug 27 14:27:27 debian kernel: [    0.696846] vesafb: framebuffer at 0xc0000000, mapped to 0xf8880000, using 6144k, total 65536k
Aug 27 14:27:27 debian kernel: [    0.696856] vesafb: mode is 1024x768x32, linelength=4096, pages=1
Aug 27 14:27:27 debian kernel: [    0.696862] vesafb: protected mode interface info at c000:d750
Aug 27 14:27:27 debian kernel: [    0.696868] vesafb: pmi: set display start = c00cd786, set palette = c00cd7f0
Aug 27 14:27:27 debian kernel: [    0.696875] vesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
Aug 27 14:27:27 debian kernel: [    0.696892] vesafb: scrolling: redraw
Aug 27 14:27:27 debian kernel: [    0.696898] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Aug 27 14:27:27 debian kernel: [    0.750844] Console: switching to colour frame buffer device 128x48
Aug 27 14:27:27 debian kernel: [    0.804999] fb0: VESA VGA frame buffer device
Aug 27 14:27:27 debian kernel: [    0.805494] isapnp: Scanning for PnP cards...
Aug 27 14:27:27 debian kernel: [    1.115616] isapnp: No Plug & Play device found
Aug 27 14:27:27 debian kernel: [    1.118245] hpet_resources: 0xfed00000 is busy
Aug 27 14:27:27 debian kernel: [    1.118311] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Aug 27 14:27:27 debian kernel: [    1.120099] brd: module loaded
Aug 27 14:27:27 debian kernel: [    1.120487] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
Aug 27 14:27:27 debian kernel: [    1.134954] serio: i8042 KBD port at 0x60,0x64 irq 1
Aug 27 14:27:27 debian kernel: [    1.135457] serio: i8042 AUX port at 0x60,0x64 irq 12
Aug 27 14:27:27 debian kernel: [    1.136194] mice: PS/2 mouse device common for all mice
Aug 27 14:27:27 debian kernel: [    1.136840] EISA: Probing bus 0 at eisa.0
Aug 27 14:27:27 debian kernel: [    1.137248] Cannot allocate resource for EISA slot 1
Aug 27 14:27:27 debian kernel: [    1.137765] Cannot allocate resource for EISA slot 2
Aug 27 14:27:27 debian kernel: [    1.138264] Cannot allocate resource for EISA slot 3
Aug 27 14:27:27 debian kernel: [    1.138764] Cannot allocate resource for EISA slot 4
Aug 27 14:27:27 debian kernel: [    1.139290] EISA: Detected 0 cards.
Aug 27 14:27:27 debian kernel: [    1.140081] cpuidle: using governor ladder
Aug 27 14:27:27 debian kernel: [    1.140505] cpuidle: using governor menu
Aug 27 14:27:27 debian kernel: [    1.141368] TCP cubic registered
Aug 27 14:27:27 debian kernel: [    1.141699] NET: Registered protocol family 1
Aug 27 14:27:27 debian kernel: [    1.142145] NET: Registered protocol family 17
Aug 27 14:27:27 debian kernel: [    1.142598] Using IPI Shortcut mode
Aug 27 14:27:27 debian kernel: [    1.143052] registered taskstats version 1
Aug 27 14:27:27 debian kernel: [    1.143824] Freeing unused kernel memory: 320k freed
Aug 27 14:27:27 debian kernel: [    1.168247] input: AT Translated Set 2 keyboard as /class/input/input0
Aug 27 14:27:27 debian kernel: [    1.300216] ACPI: ACPI0007:00 is registered as cooling_device0
Aug 27 14:27:27 debian kernel: [    1.307359] ACPI: LNXTHERM:01 is registered as thermal_zone0
Aug 27 14:27:27 debian kernel: [    1.310621] ACPI: Thermal Zone [THRM] (39 C)
Aug 27 14:27:27 debian kernel: [    1.990637] ACPI: PCI Interrupt Link [LK1E] enabled at IRQ 11
Aug 27 14:27:27 debian kernel: [    1.992146] PCI: setting IRQ 11 as level-triggered
Aug 27 14:27:27 debian kernel: [    1.992150] ACPI: PCI Interrupt 0000:03:00.0[A] -> Link [LK1E] -> GSI 11 (level, low) -> IRQ 11
Aug 27 14:27:27 debian kernel: [    1.996133] PCI: Setting latency timer of device 0000:03:00.0 to 64
Aug 27 14:27:27 debian kernel: [    2.086001] ssb: Sonics Silicon Backplane found on PCI device 0000:03:00.0
Aug 27 14:27:27 debian kernel: [    2.098271] No dock devices found.
Aug 27 14:27:27 debian kernel: [    2.116230] usbcore: registered new interface driver usbfs
Aug 27 14:27:27 debian kernel: [    2.120159] usbcore: registered new interface driver hub
Aug 27 14:27:27 debian kernel: [    2.143707] SCSI subsystem initialized
Aug 27 14:27:27 debian kernel: [    2.158247] usbcore: registered new device driver usb
Aug 27 14:27:27 debian kernel: [    2.173896] ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 7
Aug 27 14:27:27 debian kernel: [    2.176146] PCI: setting IRQ 7 as level-triggered
Aug 27 14:27:27 debian kernel: [    2.176151] ACPI: PCI Interrupt 0000:00:0b.1[B] -> Link [LUS2] -> GSI 7 (level, low) -> IRQ 7
Aug 27 14:27:27 debian kernel: [    2.180146] PCI: Setting latency timer of device 0000:00:0b.1 to 64
Aug 27 14:27:27 debian kernel: [    2.180150] ehci_hcd 0000:00:0b.1: EHCI Host Controller
Aug 27 14:27:27 debian kernel: [    2.184278] ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
Aug 27 14:27:27 debian kernel: [    2.188171] ehci_hcd 0000:00:0b.1: debug port 1
Aug 27 14:27:27 debian kernel: [    2.192141] PCI: cache line size of 64 is not supported by device 0000:00:0b.1
Aug 27 14:27:27 debian kernel: [    2.192150] ehci_hcd 0000:00:0b.1: irq 7, io mem 0xb0005000
Aug 27 14:27:27 debian kernel: [    2.200280] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 27 14:27:27 debian kernel: [    2.244587] libata version 3.00 loaded.
Aug 27 14:27:27 debian kernel: [    2.262044] ehci_hcd 0000:00:0b.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Aug 27 14:27:27 debian kernel: [    2.264294] usb usb1: configuration #1 chosen from 1 choice
Aug 27 14:27:27 debian kernel: [    2.268172] hub 1-0:1.0: USB hub found
Aug 27 14:27:27 debian kernel: [    2.272152] hub 1-0:1.0: 8 ports detected
Aug 27 14:27:27 debian kernel: [    2.380259] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 27 14:27:27 debian kernel: [    2.384152] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 27 14:27:27 debian kernel: [    2.388164] usb usb1: Product: EHCI Host Controller
Aug 27 14:27:27 debian kernel: [    2.392153] usb usb1: Manufacturer: Linux 2.6.25-2-486 ehci_hcd
Aug 27 14:27:27 debian kernel: [    2.396155] usb usb1: SerialNumber: 0000:00:0b.1
Aug 27 14:27:27 debian kernel: [    2.400200] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
Aug 27 14:27:27 debian kernel: [    2.404448] ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 10
Aug 27 14:27:27 debian kernel: [    2.408154] PCI: setting IRQ 10 as level-triggered
Aug 27 14:27:27 debian kernel: [    2.408159] ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LMAC] -> GSI 10 (level, low) -> IRQ 10
Aug 27 14:27:27 debian kernel: [    2.412155] PCI: Setting latency timer of device 0000:00:14.0 to 64
Aug 27 14:27:27 debian kernel: [    9.219785] forcedeth 0000:00:14.0: ifname eth0, PHY OUI 0x20 @ 1, addr 00:1b:24:b1:ab:4f
Aug 27 14:27:27 debian kernel: [    9.219790] forcedeth 0000:00:14.0: highdma pwrctl timirq lnktim desc-v3
Aug 27 14:27:27 debian kernel: [    9.219836] sata_nv 0000:00:0e.0: version 3.5
Aug 27 14:27:27 debian kernel: [    9.219854] PCI: Enabling device 0000:00:0e.0 (0005 -> 0007)
Aug 27 14:27:27 debian kernel: [    9.220134] ACPI: PCI Interrupt Link [LTID] enabled at IRQ 5
Aug 27 14:27:27 debian kernel: [    9.220137] PCI: setting IRQ 5 as level-triggered
Aug 27 14:27:27 debian kernel: [    9.220142] ACPI: PCI Interrupt 0000:00:0e.0[A] -> Link [LTID] -> GSI 5 (level, low) -> IRQ 5
Aug 27 14:27:27 debian kernel: [    9.220179] PCI: Setting latency timer of device 0000:00:0e.0 to 64
Aug 27 14:27:27 debian kernel: [    9.220260] scsi0 : sata_nv
Aug 27 14:27:27 debian kernel: [    9.220310] scsi1 : sata_nv
Aug 27 14:27:27 debian kernel: [    9.220437] ata1: SATA max UDMA/133 cmd 0x30c0 ctl 0x30b4 bmdma 0x3090 irq 5
Aug 27 14:27:27 debian kernel: [    9.220440] ata2: SATA max UDMA/133 cmd 0x30b8 ctl 0x30b0 bmdma 0x3098 irq 5
Aug 27 14:27:27 debian kernel: [   11.029990] hub 1-0:1.0: unable to enumerate USB device on port 6
Aug 27 14:27:27 debian kernel: [   13.694436] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Aug 27 14:27:27 debian kernel: [   13.702699] ata1.00: ATA-7: Hitachi HTS541616J9SA00, SB4OC7BP, max UDMA/100
Aug 27 14:27:27 debian kernel: [   13.702703] ata1.00: 312581808 sectors, multi 16: LBA48
Aug 27 14:27:27 debian kernel: [   13.719164] ata1.00: configured for UDMA/100
Aug 27 14:27:27 debian kernel: [   14.799551] ata2: SATA link down (SStatus 0 SControl 300)
Aug 27 14:27:27 debian kernel: [   14.803665] scsi 0:0:0:0: Direct-Access     ATA      Hitachi HTS54161 SB4O PQ: 0 ANSI: 5
Aug 27 14:27:27 debian kernel: [   14.812932] Uniform Multi-Platform E-IDE driver
Aug 27 14:27:27 debian kernel: [   14.815556] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Aug 27 14:27:27 debian kernel: [   14.823599] NFORCE-MCP51: 0000:00:0d.0 (rev f1) UDMA133 controller
Aug 27 14:27:27 debian kernel: [   14.827558] NFORCE-MCP51: IDE controller (0x10de:0x0265 rev 0xf1) at  PCI slot 0000:00:0d.0
Aug 27 14:27:27 debian kernel: [   14.831576] NFORCE-MCP51: not 100% native mode: will probe irqs later
Aug 27 14:27:27 debian kernel: [   14.835557] NFORCE-MCP51: BIOS didn't set cable bits correctly. Enabling workaround.
Aug 27 14:27:27 debian kernel: [   14.839560] NFORCE-MCP51: IDE port disabled
Aug 27 14:27:27 debian kernel: [   14.843560]     ide0: BM-DMA at 0x3080-0x3087, BIOS settings: hda :D MA, hdb:PIO
Aug 27 14:27:27 debian kernel: [   14.847561] Probing IDE interface ide0...
Aug 27 14:27:27 debian kernel: [   16.886946] hda: TSSTcorp CDDVDW TS-L632H, ATAPI CD/DVD-ROM drive
Aug 27 14:27:27 debian kernel: [   17.627386] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
Aug 27 14:27:27 debian kernel: [   17.627386] hda: MWDMA2 mode selected
Aug 27 14:27:27 debian kernel: [   17.632679] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Aug 27 14:27:27 debian kernel: [   17.636044] ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 11
Aug 27 14:27:27 debian kernel: [   17.639394] ACPI: PCI Interrupt 0000:00:0b.0[A] -> Link [LUS0] -> GSI 11 (level, low) -> IRQ 11
Aug 27 14:27:27 debian kernel: [   17.643418] PCI: Setting latency timer of device 0000:00:0b.0 to 64
Aug 27 14:27:27 debian kernel: [   17.643421] ohci_hcd 0000:00:0b.0: OHCI Host Controller
Aug 27 14:27:27 debian kernel: [   17.647432] ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
Aug 27 14:27:27 debian kernel: [   17.651403] ohci_hcd 0000:00:0b.0: irq 11, io mem 0xb0004000
Aug 27 14:27:27 debian kernel: [   17.677829] Driver 'sd' needs updating - please use bus_type methods
Aug 27 14:27:27 debian kernel: [   17.679491] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
Aug 27 14:27:27 debian kernel: [   17.683405] sd 0:0:0:0: [sda] Write Protect is off
Aug 27 14:27:27 debian kernel: [   17.687413] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 27 14:27:27 debian kernel: [   17.687435] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 27 14:27:27 debian kernel: [   17.691442] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
Aug 27 14:27:27 debian kernel: [   17.697501] usb usb2: configuration #1 chosen from 1 choice
Aug 27 14:27:27 debian kernel: [   17.699416] hub 2-0:1.0: USB hub found
Aug 27 14:27:27 debian kernel: [   17.703411] hub 2-0:1.0: 8 ports detected
Aug 27 14:27:27 debian kernel: [   17.716899] sd 0:0:0:0: [sda] Write Protect is off
Aug 27 14:27:27 debian kernel: [   17.716902] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 27 14:27:27 debian kernel: [   17.716923] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 27 14:27:27 debian kernel: [   17.716928]  sda:<6>hda: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
Aug 27 14:27:27 debian kernel: [   17.770298] Uniform CD-ROM driver Revision: 3.20
Aug 27 14:27:27 debian kernel: [   17.779545] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Aug 27 14:27:27 debian kernel: [   17.779548] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 27 14:27:27 debian kernel: [   17.779551] usb usb2: Product: OHCI Host Controller
Aug 27 14:27:27 debian kernel: [   17.779553] usb usb2: Manufacturer: Linux 2.6.25-2-486 ohci_hcd
Aug 27 14:27:27 debian kernel: [   17.779555] usb usb2: SerialNumber: 0000:00:0b.0
Aug 27 14:27:27 debian kernel: [   18.054001]  sda1 sda2 < sda5<6>usb 2-6: new low speed USB device using ohci_hcd and address 2
Aug 27 14:27:27 debian kernel: [   18.079736]  sda6 sda7 > sda3 sda4
Aug 27 14:27:27 debian kernel: [   18.124548] sd 0:0:0:0: [sda] Attached SCSI disk
Aug 27 14:27:27 debian kernel: [   18.265288] usb 2-6: configuration #1 chosen from 1 choice
Aug 27 14:27:27 debian kernel: [   18.272499] usb 2-6: New USB device found, idVendor=09da, idProduct=000a
Aug 27 14:27:27 debian kernel: [   18.272503] usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 27 14:27:27 debian kernel: [   18.272506] usb 2-6: Product: PS/2+USB Mouse
Aug 27 14:27:27 debian kernel: [   18.272508] usb 2-6: Manufacturer: A4Tech
Aug 27 14:27:27 debian kernel: [   18.360259] usbcore: registered new interface driver hiddev
Aug 27 14:27:27 debian kernel: [   18.377234] input: A4Tech PS/2+USB Mouse as /class/input/input1
Aug 27 14:27:27 debian kernel: [   18.383305] input,hidraw0: USB HID v1.10 Mouse [A4Tech PS/2+USB Mouse] on usb-0000:00:0b.0-6
Aug 27 14:27:27 debian kernel: [   18.385370] usbcore: registered new interface driver usbhid
Aug 27 14:27:27 debian kernel: [   18.389306] drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
Aug 27 14:27:27 debian kernel: [   18.635022] PM: Starting manual resume from disk
Aug 27 14:27:27 debian kernel: [   18.706438] ReiserFS: sda3: found reiserfs format "3.6" with standard journal
Aug 27 14:27:27 debian kernel: [   18.709718] ReiserFS: sda3: using ordered data mode
Aug 27 14:27:27 debian kernel: [   18.745325] ReiserFS: sda3: journal params: device sda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Aug 27 14:27:27 debian kernel: [   18.746543] ReiserFS: sda3: checking transaction log (sda3)
Aug 27 14:27:27 debian kernel: [   58.228571] ReiserFS: sda3: replayed 28 transactions in 39 seconds
Aug 27 14:27:27 debian kernel: [   58.228931] ReiserFS: sda3: Using r5 hash to sort names
Aug 27 14:27:27 debian kernel: [   59.765849] udevd version 125 started
Aug 27 14:27:27 debian kernel: [   61.551619] input: Power Button (FF) as /class/input/input2
Aug 27 14:27:27 debian kernel: [   61.590408] ACPI: Power Button (FF) [PWRF]
Aug 27 14:27:27 debian kernel: [   61.591118] input: Power Button (CM) as /class/input/input3
Aug 27 14:27:27 debian kernel: [   61.647929] ACPI: Power Button (CM) [PWRB]
Aug 27 14:27:27 debian kernel: [   61.651123] input: Sleep Button (CM) as /class/input/input4
Aug 27 14:27:27 debian kernel: [   61.742879] ACPI: Sleep Button (CM) [SLPB]
Aug 27 14:27:27 debian kernel: [   61.743127] input: Lid Switch as /class/input/input5
Aug 27 14:27:27 debian kernel: [   61.808192] ACPI: Lid Switch [LID]
Aug 27 14:27:27 debian kernel: [   61.816071] ACPI: AC Adapter [ACAD] (on-line)
Aug 27 14:27:27 debian kernel: [   62.256131] ACPI: Battery Slot [BAT0] (battery present)
Aug 27 14:27:27 debian kernel: [   62.259214] ACPI: WMI: Mapper loaded
Aug 27 14:27:27 debian kernel: [   62.897384] ACPI: device:24 is registered as cooling_device1
Aug 27 14:27:27 debian kernel: [   62.899300] input: Video Bus as /class/input/input6
Aug 27 14:27:27 debian kernel: [   62.943190] ACPI: Video Device [UVGA] (multi-head: yes  rom: no  post: no)
Aug 27 14:27:27 debian kernel: [   62.989378] ACPI: device:2a is registered as cooling_device2
Aug 27 14:27:27 debian kernel: [   62.991306] input: Video Bus as /class/input/input7
Aug 27 14:27:27 debian kernel: [   63.032612] ACPI: Video Device [VGA] (multi-head: yes  rom: no  post: no)
Aug 27 14:27:27 debian kernel: [   63.231011] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x3040
Aug 27 14:27:27 debian kernel: [   63.231173] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x3000
Aug 27 14:27:27 debian kernel: [   63.265080] b43-phy0: Broadcom 4311 WLAN found
Aug 27 14:27:27 debian kernel: [   63.335600] phy0: Selected rate control algorithm 'pid'
Aug 27 14:27:27 debian kernel: [   63.527021] Broadcom 43xx driver loaded [ Features: PMLR, Firmware-ID: FW13 ]
Aug 27 14:27:27 debian kernel: [   63.810524] input: PC Speaker as /class/input/input8
Aug 27 14:27:27 debian kernel: [   64.052340] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 10
Aug 27 14:27:27 debian kernel: [   64.055205] ACPI: PCI Interrupt 0000:00:10.1[B] -> Link [LAZA] -> GSI 10 (level, low) -> IRQ 10
Aug 27 14:27:27 debian kernel: [   64.059218] PCI: Setting latency timer of device 0000:00:10.1 to 64
Aug 27 14:27:27 debian kernel: [   64.256346] rtc_cmos 00:09: rtc core: registered rtc_cmos as rtc0
Aug 27 14:27:27 debian kernel: [   64.259250] rtc0: alarms up to one year, y3k
Aug 27 14:27:27 debian kernel: [   64.538467] Synaptics Touchpad, model: 1, fw: 6.3, id: 0x1a0b1, caps: 0xa04713/0x200000
Aug 27 14:27:27 debian kernel: [   64.596988] input: SynPS/2 Synaptics TouchPad as /class/input/input9
Aug 27 14:27:27 debian kernel: [   72.694802] Adding 498004k swap on /dev/sda4.  Priority:-1 extents:1 across:498004k
Aug 27 14:27:27 debian kernel: [   87.955775] loop: module loaded
Aug 27 14:27:27 debian kernel: [   92.485554] NTFS driver 2.1.29 [Flags: R/W MODULE].
Aug 27 14:27:27 debian kernel: [   92.589097] NTFS volume version 3.1.
Aug 27 14:27:27 debian kernel: [   92.669427] NTFS volume version 3.1.
Aug 27 14:27:27 debian kernel: [   92.669434] NTFS-fs warning (device sda1): load_system_files(): Unsupported volume flags 0x4000 encountered.
Aug 27 14:27:27 debian kernel: [   92.673431] NTFS-fs warning (device sda1): load_system_files(): Volume has unsupported flags set.  Will not be able to remount read-write.  Run chkdsk and mount in Windows.
Aug 27 14:27:27 debian kernel: [   92.794537] NTFS volume version 3.1.
Aug 27 14:27:27 debian kernel: [   92.865120] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Aug 27 14:27:27 debian rsyslogd: [origin software="rsyslogd" swVersion="3.18.1" x-pid="2184" x-info="http://www.rsyslog.com"] restart
Aug 27 14:27:30 debian dhcdbd: Started up.
Aug 27 14:27:31 debian acpid: client connected from 2619[105:108]
Aug 27 14:27:32 debian NetworkManager: <info>  starting...
Aug 27 14:27:32 debian kernel: [  112.942313] input: b43-phy0 as /class/input/input10
Aug 27 14:27:32 debian /usr/sbin/cron[2693]: (CRON) INFO (pidfile fd = 3)
Aug 27 14:27:32 debian /usr/sbin/cron[2695]: (CRON) STARTUP (fork ok)
Aug 27 14:27:32 debian /usr/sbin/cron[2695]: (CRON) INFO (Running @reboot jobs)
Aug 27 14:27:32 debian kernel: [  113.345084] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
Aug 27 14:27:33 debian acpid: client connected from 2709[0:0]
Aug 27 14:27:34 debian kernel: [  114.762418] Registered led device: b43-phy0::tx
Aug 27 14:27:34 debian kernel: [  114.762418] Registered led device: b43-phy0::rx
Aug 27 14:27:34 debian kernel: [  114.762418] Registered led device: b43-phy0::radio
Aug 27 14:27:34 debian kernel: [  114.762418] b43-phy0 ERROR: PHY transmission error
Aug 27 14:27:34 debian NetworkManager: <info>  wlan0: Device is fully-supported using driver 'b43-pci-bridge'.
Aug 27 14:27:34 debian NetworkManager: <info>  wlan0: driver supports SSID scans (scan_capa 0x01).
Aug 27 14:27:34 debian NetworkManager: <info>  nm_device_init(): waiting for device's worker thread to start
Aug 27 14:27:34 debian NetworkManager: <info>  nm_device_init(): device's worker thread started, continuing.
Aug 27 14:27:34 debian NetworkManager: <info>  Now managing wireless (802.11) device 'wlan0'.
Aug 27 14:27:34 debian NetworkManager: <info>  Deactivating device wlan0.
Aug 27 14:27:34 debian NetworkManager: <debug> [1219840054.409758] nm_hal_device_added(): New device added (hal udi is '/org/freedesktop/Hal/devices/computer_logicaldev_input_5').
Aug 27 14:27:35 debian kernel: [  116.415915] Linux agpgart interface v0.103
Aug 27 14:27:36 debian kernel: [  116.700001] nvidia: module license 'NVIDIA' taints kernel.
Aug 27 14:27:36 debian kernel: [  116.953577] ACPI: PCI Interrupt Link [LK3E] enabled at IRQ 11
Aug 27 14:27:36 debian kernel: [  116.953583] ACPI: PCI Interrupt 0000:00:05.0[A] -> Link [LK3E] -> GSI 11 (level, low) -> IRQ 11
Aug 27 14:27:36 debian kernel: [  116.953593] PCI: Setting latency timer of device 0000:00:05.0 to 64
Aug 27 14:27:36 debian kernel: [  116.953876] NVRM: loading NVIDIA UNIX x86 Kernel Module  173.08  Tue Apr  1 23:46:53 PST 2008
Aug 27 14:27:36 debian acpid: client connected from 2709[0:0]
Aug 27 14:27:36 debian kernel: [  117.594033] spurious 8259A interrupt: IRQ15.
Aug 27 14:27:55 debian NetworkManager: <info>  Updating allowed wireless network lists.
Aug 27 14:27:55 debian NetworkManager: <WARN>  nm_dbus_get_networks_cb(): error received: org.freedesktop.NetworkManagerInfo.NoNetworks - org.freedesktop.NetworkManagerInfo.NoNetworks.
Aug 27 14:28:11 debian kernel: [  152.568371] NET: Registered protocol family 10
Aug 27 14:28:11 debian kernel: [  152.568975] lo: Disabled Privacy Extensions
Aug 27 14:28:11 debian kernel: [  152.570509] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Aug 27 14:28:22 debian kernel: [  163.153413] eth0: no IPv6 routers presentKod: Zaznacz cały
Will now restartKod: Zaznacz cały
[sda]synchronizing SCSI cache---EDIT.
problem rozwiązany, pomogło botowanie z opcją
acpi=off
