Użyłem źródeł 2.6.26 do kompilacji linuxa user-mode
make defconfig ARCH=um
make ARCH=um
Problem jest taki, że nie chce wystartować mi ten Linux. Odpalam takim poleceniem:
./linux ubda=disk-image mem=128MB
Nie wiem o co chodzi. Jak to rozwiązać?Locating the bottom of the address space ... 0x0
Locating the top of the address space ... 0xc0000000
Core dump limits :
soft - 0
hard - NONE
0xc0000000
Core dump limits :
soft - 0
hard - NONE
0xc0000000
Core dump limits :
soft - 0
hard - NONE
0xc0000000
Core dump limits :
soft - 0
hard - NONE
Checking for tmpfs mount on /dev/shm...OK
Checking PROT_EXEC mmap in /dev/shm/...OK
OK
OK
OK
UML running in SKAS0 mode
Linux version 2.6.26 (root@melvin) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 Fri Aug 15 18:06:25 CEST 2008
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: ubda=disk-image mem=256MB root=98:0
PID hash table entries: 1024 (order: 10, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 255616k available
Mount-cache hash table entries: 512
Checking for host processor cmov support...Yes
Checking that host ptys support output SIGIO...Yes
Checking that host ptys support SIGIO on close...No, enabling workaround
net_namespace: 192 bytes
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
Checking host MADV_REMOVE support...OK
mconsole (version 2) initialized on /root/.uml/xBHNom/mconsole
Host TLS support detected
Detected host type: i386 (GDT indexes 6 to 9)
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
msgmni has been set to 499
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
TCP cubic registered
NET: Registered protocol family 17
Initialized stdio console driver
Console initialized on /dev/tty0
console [tty0] enabled
Initializing software serial port version 1
console [mc-1] enabled
ubda: unknown partition table
VFS: Mounted root (ext2 filesystem) readonly.
Stub registers -
0 - 0
1 - 0
2 - 0
3 - 0
4 - 0
5 - 0
6 - 0
7 - 0
8 - 0
9 - 0
10 - 0
11 - ffffffff
12 - 0
13 - 73
14 - 210202
15 - 0
16 - 7b
wait_stub_done : failed to wait for SIGTRAP, pid = 15736, n = 15736, errno = 25, status = 0x47f
Kernel panic - not syncing: Attempted to kill init!
EIP: 0073:[<b7f4e410>] CPU: 0 Not tainted ESP: 007b:bfb28274 EFLAGS: 00200246
Not tainted
EAX: 00000000 EBX: 00003d73 ECX: 00000013 EDX: 00003d73
ESI: 00003d6f EDI: 00000003 EBP: bfb2829c DS: 007b ES: 007b
17c5cb30: [<08069c77>] show_regs+0xb4/0xb9
17c5cb5c: [<08059816>] panic_exit+0x25/0x3b
17c5cb70: [<08083502>] notifier_call_chain+0x27/0x53
17c5cb98: [<08083545>] __atomic_notifier_call_chain+0x17/0x19
17c5cba8: [<0808355c>] atomic_notifier_call_chain+0x15/0x17
17c5cbc4: [<0806fbd2>] panic+0x52/0xdd
17c5cbe4: [<0807296b>] do_exit+0x5a/0x5ce
17c5cc1c: [<08072f5b>] do_group_exit+0x7c/0xa3
17c5cc38: [<0807a99f>] get_signal_to_deliver+0x288/0x2c6
17c5cc5c: [<080580cf>] do_signal+0x1e9/0x291
17c5cd1c: [<08059673>] fatal_sigsegv+0x1f/0x24
17c5cd30: [<08066da0>] wait_stub_done+0xa3/0xab
17c5cd5c: [<08066657>] do_syscall_stub+0x9e/0x186
17c5cd84: [<08066849>] run_syscall_stub+0x9c/0xa1
17c5cd98: [<08067c82>] write_ldt_entry+0xe2/0x140
17c5cde0: [<080682f1>] init_new_ldt+0x192/0x2a9
17c5ce58: [<08059b0e>] init_new_context+0xb7/0xf5
17c5ce78: [<080adaa8>] bprm_mm_init+0x3f/0x164
17c5cea8: [<080ae6a2>] do_execve+0x6d/0x198
17c5cec8: [<08056659>] execve1+0x25/0x40
17c5ceec: [<080566c5>] um_execve+0x14/0x34
17c5cef8: [<08058389>] kernel_execve+0x2c/0x36
17c5cf18: [<080563ac>] run_init_process+0x18/0x1d
17c5cf2c: [<08056457>] init_post+0xa6/0xcf
17c5cf38: [<0804953f>] kernel_init+0x1e7/0x1f1
17c5cfb4: [<08063dbb>] run_kernel_thread+0x37/0x3f
17c5cfe0: [<080576a5>] new_thread_handler+0x57/0x7e
17c5cffc: [<00000000>] 0x0
Ps. Nie wiem czy dodałem do właściwego działu ten post.
