B
michalek115
Błąd połączenia przez vpnc
Post autor: michalek115 »
Mam nastepujacy problem:
Do laczenia z moja firma uzywam vpnc, jednak po skonfigurowaniu podczas laczenia otrzymuje komunikat:
vpnc: quick mode response rejected:  (ISAKMP_N_INVALID_PAYLOAD_TYPE)(1)
this means the concentrator did not like what we had to offer.
Possible reasons are:
  * concentrator configured to require a firewall
     this locks out even Cisco clients on any platform expect windows
     which is an obvious security improvment. There is no workaround (yet).
  * concentrator configured to require IP compression
     this is not yet supported by vpnc.
     Note: the Cisco Concentrator Documentation recommends against using
     compression, expect on low-bandwith (read: ISDN) links, because it
     uses much CPU-resources on the concentrator
Moze ktos mial podobny problem i go rozwiazal.
