Wy
Wyświetlanie apache w przeglądarce
Dziwny problem. Wczesniej instalowalem apache php i mysql z paczek i po wpisaniu localhost, 127.0.0.1 czy mojego IP strona ladowala sie kilka minut i wkoncu odpowiadala ze nie mozna polaczyc. Probowalem kilka razy... W akcie desperacji (;p) zainstalowalem xampp'a. Przy uruchamianiu wszystko pisze ze jest ok a w przegladarce nadal sie nie wyswietla. Zarowno w operze jak i w iceweasyl. Co moze byc przyczyna? Bym cos podal jeszcze w temacie ale nie wiem co wiec pytac.
Mi to nie mowi za wiele...
[Sat May 10 12:09:22 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 10 12:09:23 2008] [notice] Graceful restart requested, doing restart
[Sat May 10 12:09:23 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
[Sat May 10 12:09:23 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 10 19:44:37 2008] [notice] Apache/2.2.8 (Debian) PHP/5.2.5-3 with Suhosin-Patch configured -- resuming normal operations
[Sat May 10 23:20:02 2008] [warn] (101)Network is unreachable: connect to listener on [::]:80
[Sat May 10 23:20:02 2008] [notice] caught SIGWINCH, shutting down gracefully
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20060613+lfs/gd.so' - /usr/lib/php5/20060613+lfs/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20060613+lfs/mcrypt.so' - /usr/lib/php5/20060613+lfs/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0
[Sun May 11 09:28:17 2008] [notice] Apache/2.2.8 (Debian) PHP/5.2.5-3 with Suhosin-Patch configured -- resuming normal operations
[Sun May 11 10:51:02 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:51:13 2008] [error] [client 83.25.71.130] File does not exist: /var/www/~rtgn
[Sun May 11 10:52:47 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:52:48 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:54:02 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:54:26 2008] [error] [client 83.25.71.130] File does not exist: /var/www/tndex.htm
[Sun May 11 10:55:24 2008] [error] [client 83.25.71.130] File does not exist: /var/www/index.htm
[Sun May 11 10:56:27 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/index.html[/url]
[Sun May 11 10:56:29 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/index.html[/url]
[Sun May 11 10:56:30 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/index.html[/url]
[Sun May 11 10:56:47 2008] [error] [client 83.25.71.130] File does not exist: /var/www/phpmyadmin
[Sun May 11 10:58:05 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:58:06 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:58:29 2008] [error] [client 83.25.71.130] File does not exist: /var/www/~
[Sun May 11 10:58:59 2008] [error] [client 83.25.71.130] Invalid method in request index.html
[Sun May 11 10:59:54 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 10:59:55 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:03:40 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:06:39 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:06:40 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:09 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:10 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:11 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:12 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:13 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:14 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:15 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:30 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:31 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:32 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:32 2008] [warn] (101)Network is unreachable: connect to listener on [::]:80
[Sun May 11 11:07:32 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sun May 11 11:07:33 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:34 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:35 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:35 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:37 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:37 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:43 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:44 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:44 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:45 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:45 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:46 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:07:46 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:08:00 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:08:00 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:08:01 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:08:01 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/[/url]
[Sun May 11 11:08:03 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=N;O=D[/url]
[Sun May 11 11:08:04 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=M;O=A[/url]
[Sun May 11 11:08:06 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=M;O=D[/url]
[Sun May 11 11:08:07 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=S;O=A[/url]
[Sun May 11 11:08:08 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=D;O=A[/url]
[Sun May 11 11:08:09 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=N;O=A[/url]
[Sun May 11 11:08:12 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=N;O=A[/url]
[Sun May 11 11:08:13 2008] [error] [client 83.25.71.130] File does not exist: /var/www/favicon.ico, referer: [url]http://87.205.255.35/?C=N;O=A[/url]
[Sun May 11 11:08:13 2008] [error] [client 83.25.71.130] File does not exist: /usr/share/apache2, referer: [url]http://87.205.255.35/?C=N;O=A[/url]
[Sat May 17 17:21:25 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:21:27 2008] [notice] Graceful restart requested, doing restart
[Sat May 17 17:21:27 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 17:21:27 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:23:26 2008] [notice] Graceful restart requested, doing restart
[Sat May 17 17:23:26 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 17:23:26 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:23:26 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sat May 17 17:32:27 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:39:54 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 17:39:55 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sat May 17 17:40:05 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:41:24 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 17:41:24 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sat May 17 17:41:34 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:42:11 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 17:42:11 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sat May 17 17:45:03 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 17:49:17 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 17:49:17 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sat May 17 18:43:13 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 18:58:20 2008] [warn] (101)Network is unreachable: connect to listener on [::]:80
[Sat May 17 18:58:20 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sat May 17 18:58:30 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sat May 17 19:09:29 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sat May 17 19:09:29 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sun May 18 19:01:22 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sun May 18 19:01:52 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sun May 18 19:01:52 2008] [notice] caught SIGWINCH, shutting down gracefully
[Sun May 18 19:02:02 2008] [notice] Apache/2.2.8 (Debian) configured -- resuming normal operations
[Sun May 18 19:08:45 2008] [warn] (22)Invalid argument: connect to listener on 0.0.0.0:80
[Sun May 18 19:08:45 2008] [notice] caught SIGWINCH, shutting down gracefullyKod: Zaznacz cały
[Sun May 18 19:08:45 2008] [notice] caught SIGWINCH, shutting down gracefullyA który to plik? Jeśli httpd.conf (/etc/apache2/httpd.conf) to mam tam ustawione
Ja się w tym nie orientuje dlatego takie pytania...
HostnameLookups Off
ServerName localhost
ServerName 127.0.0.1
