phpmyadmin brak dost
super_xxxl
phpmyadmin brak dostępu z innego komputera
Post autor: super_xxxl »
witam
Zainstalowałem phpMyAdmina. plik config.inc.php wygląda następująco:
<?php
 * Debian local configuration file
 * This file overrides the settings made by phpMyAdmin interactive setup
 * utility.
 * For example configuration see /usr/share/doc/phpmyadmin/examples/config.default.php.gz
 * NOTE: do not add security sensitive data to this file (like passwords)
 * unless you really know what you're doing. If you do, any user that can
 * run PHP or CGI on your webserver will be able to read them. If you still
 * want to do this, make sure to properly secure the access to this file
 * (also on the filesystem level).
 * Server(s) configuration
$i = 0;
// The $cfg['Servers'] array starts with $cfg['Servers'][1].  Do not use $cfg['Servers'][0].
// You can disable a server config entry by setting host to ''.
$i++;
// Uncomment to override the default configuration
//$cfg['PmaAbsoluteUri'] = (!empty($_SERVER['HTTPS']) ? 'https' : 'http') . '://'
                       . $_SERVER['HTTP_HOST']
                       . (!empty($_SERVER['SERVER_PORT']) ? ':' . $_SERVER['SERVER_PORT'] : '')
                       . substr($_SERVER['PHP_SELF'], 0, strrpos($_SERVER['PHP_SELF'], '/')+1);
//$cfg['Servers'][$i]['host']          = 'localhost'; // MySQL hostname or IP address
//$cfg['Servers'][$i]['port']          = '';          // MySQL port - leave blank for default port
//$cfg['Servers'][$i]['socket']        = '';          // Path to the socket - leave blank for default socket
//$cfg['Servers'][$i]['connect_type']  = 'socket';    // How to connect to MySQL server ('tcp' or 'socket')
//$cfg['Servers'][$i]['extension']     = 'mysql';     // The php MySQL extension to use ('mysql' or 'mysqli')
//$cfg['Servers'][$i]['compress']      = FALSE;       // Use compressed protocol for the MySQL connection
//                                                    // (requires PHP >= 4.3.0)
//$cfg['Servers'][$i]['controluser']   = '';          // MySQL control user settings
//                                                    // (this user must have read-only
//$cfg['Servers'][$i]['controlpass']   = '';          // access to the "mysql/user"
//                                                    // and "mysql/db" tables).
//                                                    // The controluser is also
//                                                    // used for all relational
//                                                    // features (pmadb)
//$cfg['Servers'][$i]['auth_type']     = 'cookie';    // Authentication method (config, http or cookie based)?
//$cfg['Servers'][$i]['user']          = 'root';      // MySQL user
//$cfg['Servers'][$i]['password']      = '';          // MySQL password (only needed
//                                                    // with 'config' auth_type)
//$cfg['Servers'][$i]['only_db']       = '';          // If set to a db-name, only
//                                                    // this db is displayed in left frame
//                                                    // It may also be an array of db-names, where sorting order is relevant.
//$cfg['Servers'][$i]['verbose']       = '';          // Verbose name for this host - leave blank to show the hostname
//$cfg['Servers'][$i]['pmadb']         = 'phpmyadmin';// Database used for Relation, Bookmark and PDF Features
//                                                    // (see scripts/create_tables.sql)
//                                                    //   - leave blank for no support
//                                                    //     DEFAULT: 'phpmyadmin'
//$cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark';// Bookmark table
//                                                    //   - leave blank for no bookmark support
//                                                    //     DEFAULT: 'pma_bookmark'
//$cfg['Servers'][$i]['relation']      = 'pma_relation';// table to describe the relation between links (see doc)
//                                                    //   - leave blank for no relation-links support
//                                                    //     DEFAULT: 'pma_relation'
//$cfg['Servers'][$i]['table_info']    = 'pma_table_info';// table to describe the display fields
//                                                    //   - leave blank for no display fields support
//                                                    //     DEFAULT: 'pma_table_info'
//$cfg['Servers'][$i]['table_coords']  = 'pma_table_coords';// table to describe the tables position for the PDF schema
//                                                    //   - leave blank for no PDF schema support
//                                                    //     DEFAULT: 'pma_table_coords'
//$cfg['Servers'][$i]['pdf_pages']     = 'pma_pdf_pages';// table to describe pages of relationpdf
//                                                    //   - leave blank if you don't want to use this
//                                                    //     DEFAULT: 'pma_pdf_pages'
//$cfg['Servers'][$i]['column_info']   = 'pma_column_info';// table to store column information
//                                                    //   - leave blank for no column comments/mime types
//                                                    //     DEFAULT: 'pma_column_info'
//$cfg['Servers'][$i]['history']       = 'pma_history';// table to store SQL history
//                                                    //   - leave blank for no SQL query history
//                                                    //     DEFAULT: 'pma_history'
//$cfg['Servers'][$i]['verbose_check'] = TRUE;        // set to FALSE if you know that your pma_* tables
//                                                    // are up to date. This prevents compatibility
//                                                    // checks and thereby increases performance.
//$cfg['Servers'][$i]['AllowRoot']     = TRUE;        // whether to allow root login
//$cfg['Servers'][$i]['AllowDeny']['order']           // Host authentication order, leave blank to not use
//$cfg['Servers'][$i]['AllowDeny']['rules']           // Host authentication rules, leave blank for defaults
//                                     = array();
Nie potrafię wejść z innego komputera na tego phpmyadmina, nie wiem czy mój mysql działa. Nic nie wiem o tym co się dzieje na mojej maszynie.
Co radzicie zrobić?
w apache nie robiłes żadnych blokad?
co wpisujesz chcąc polączyć sie z phpmyadmin?
jaką wersje apache masz?
