Wiec zainstalowalem zonemindera apacha mysql itd wszystko ladnie pali.Tylko ze nie ma obrazu, jest niebieski ekran (nie taki jak w Windows)
Zrobilem pliczek w folderze /etc/modprobe.d/bttv w pliczku znieniam sobie karty sposobem:
options bttv card=x,x,x,x tuner=x,x,x,x tuner zawsze na 4 czyli tuner=4 - NoTunerMoze ktos juz przerabial podobny problem? Prosze o Pomoc.
W zoneminderze oczywiscie wybieralem rozne /dev/video0 - 4 na roznych wejsciach urzadzenia.
Jądro domyslnie widzi takie cos:
[ 27.063919] bttv0: Bt878 (rev 17) at 0000:02:0c.0, irq: 18, latency: 32, mmio: 0xe6000000
[ 27.064936] bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 27.064976] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 27.066102] tveeprom 1-0050: Huh, no eeprom present (err=-121)?
[ 27.066107] bttv0: tuner type unset
[ 27.066110] bttv0: i2c: checking for MSP34xx @ 0x80... not found
[ 27.066602] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[ 27.067090] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[ 27.067643] bttv0: registered device video0
[ 27.067672] bttv0: registered device vbi0
[ 27.067718] bttv: Bt8xx card found (1).
[ 27.067747] ACPI: PCI Interrupt 0000:02:0d.0[A] -> GSI 19 (level, low) -> IRQ 16
[ 27.067760] bttv1: Bt878 (rev 17) at 0000:02:0d.0, irq: 16, latency: 32, mmio: 0xe6002000
[ 27.067793] bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 27.067814] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 27.152213] NET: Registered protocol family 10
[ 27.152487] lo: Disabled Privacy Extensions
[ 27.962889] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input6
[ 28.005528] parport_pc 00:0a: reported by Plug and Play ACPI
[ 28.005596] parport0: PC-style at 0x378 (0x77, irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 37.786004] eth1: no IPv6 routers present
[ 38.081518] eth0: no IPv6 routers present
[ 39.846634] tveeprom 2-0050: Huh, no eeprom present (err=-121)?
[ 39.846640] bttv1: tuner type unset
[ 39.846644] bttv1: i2c: checking for MSP34xx @ 0x80... not found
[ 46.236165] bttv1: i2c: checking for TDA9875 @ 0xb0... not found
[ 52.625693] bttv1: i2c: checking for TDA7432 @ 0x8a... not found
[ 59.015627] bttv1: registered device video1
[ 59.015801] bttv1: registered device vbi1
[ 59.016773] bttv: Bt8xx card found (2).
[ 59.016811] ACPI: PCI Interrupt 0000:02:0e.0[A] -> GSI 16 (level, low) -> IRQ 17
[ 59.016827] bttv2: Bt878 (rev 17) at 0000:02:0e.0, irq: 17, latency: 32, mmio: 0xe6004000
[ 59.016846] bttv2: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 59.016881] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 71.794275] tveeprom 3-0050: Huh, no eeprom present (err=-121)?
[ 71.794283] bttv2: tuner type unset
[ 71.794286] bttv2: i2c: checking for MSP34xx @ 0x80... not found
[ 78.183806] bttv2: i2c: checking for TDA9875 @ 0xb0... not found
[ 84.573332] bttv2: i2c: checking for TDA7432 @ 0x8a... not found
[ 90.963274] bttv2: registered device video2
[ 90.963456] bttv2: registered device vbi2
[ 90.963503] bttv: Bt8xx card found (3).
[ 90.963543] ACPI: PCI Interrupt 0000:02:0f.0[A] -> GSI 17 (level, low) -> IRQ 19
[ 90.963558] bttv3: Bt878 (rev 17) at 0000:02:0f.0, irq: 19, latency: 32, mmio: 0xe6006000
[ 90.963581] bttv3: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 90.963614] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 103.741915] tveeprom 4-0050: Huh, no eeprom present (err=-121)?
[ 103.741923] bttv3: tuner type unset
[ 103.741927] bttv3: i2c: checking for MSP34xx @ 0x80... not found
[ 110.131446] bttv3: i2c: checking for TDA9875 @ 0xb0... not found
[ 116.520971] bttv3: i2c: checking for TDA7432 @ 0x8a... not found
[ 122.910920] bttv3: registered device video3
[ 122.911114] bttv3: registered device vbi3
[ 122.941396] bt878: AUDIO driver version 0.0.0 loaded
[ 122.941462] bt878: Bt878 AUDIO function found (0).
[ 122.941491] ACPI: PCI Interrupt 0000:02:0c.1[A] -> GSI 18 (level, low) -> IRQ 18
[ 122.941499] bt878_probe: card id=[0x0], Unknown card.
[ 122.941501] Exiting..
[ 122.941506] ACPI: PCI interrupt for device 0000:02:0c.1 disabled
[ 122.941515] bt878: probe of 0000:02:0c.1 failed with error -22
[ 122.941524] bt878: Bt878 AUDIO function found (0).
[ 122.941537] ACPI: PCI Interrupt 0000:02:0d.1[A] -> GSI 19 (level, low) -> IRQ 16
[ 122.941542] bt878_probe: card id=[0x0], Unknown card.
[ 122.941544] Exiting..
[ 122.941548] ACPI: PCI interrupt for device 0000:02:0d.1 disabled
[ 122.941551] bt878: probe of 0000:02:0d.1 failed with error -22
[ 122.941559] bt878: Bt878 AUDIO function found (0).
[ 122.941572] ACPI: PCI Interrupt 0000:02:0e.1[A] -> GSI 16 (level, low) -> IRQ 17
[ 122.941578] bt878_probe: card id=[0x0], Unknown card.
[ 122.941579] Exiting..
[ 122.941583] ACPI: PCI interrupt for device 0000:02:0e.1 disabled
[ 122.941586] bt878: probe of 0000:02:0e.1 failed with error -22
[ 122.941594] bt878: Bt878 AUDIO function found (0).
[ 122.941607] ACPI: PCI Interrupt 0000:02:0f.1[A] -> GSI 17 (level, low) -> IRQ 19
[ 122.941613] bt878_probe: card id=[0x0], Unknown card.
[ 122.941614] Exiting..
[ 122.941618] ACPI: PCI interrupt for device 0000:02:0f.1 disabled
[ 122.941621] bt878: probe of 0000:02:0f.1 failed with error -22
[ 123.428453] lp0: using parport0 (interrupt-driven).
[ 123.523268] Adding 497972k swap on /dev/sda6. Priority:-1 extents:1 across:4
