Zainstalowałem sobie dzisiaj VMware w wersji takiej jak w tytule, zgodnie z sugestiami instalatora uruchomiłem skrypt konfiguracyjny. Niestety po zakończeniu jego prazy próba uruchomienia programu z menu KDE skończyła się tylko napisaem wczytywanie programu na pasku zadań, który znikł po około 30sec. Z konsoli natomiast dostałem informację o nieprawidłowej konfiguracji.
Zamieszczam tekst z konsoli (skrypt konfiguracyjny)
PrEZeS:~# /usr/bin/vmware-config.pl
Making sure services for VMware Workstation are stopped.
Stopping VMware services:
Virtual machine monitor done
Blocking file system: done
Bridged networking on /dev/vmnet0 done
Host network detection done
DHCP server on /dev/vmnet1 done
Host-only networking on /dev/vmnet1 done
Bridged networking on /dev/vmnet2 done
DHCP server on /dev/vmnet8 done
NAT service on /dev/vmnet8 done
Host-only networking on /dev/vmnet8 done
Virtual ethernet done
Configuring fallback GTK+ 2.4 libraries.
In which directory do you want to install the theme icons?
[/usr/share/icons]
What directory contains your desktop menu entry files? These files have a
.desktop file extension. [/usr/share/applications]
In which directory do you want to install the application's icon?
[/usr/share/pixmaps]
Trying to find a suitable vmmon module for your running kernel.
None of the pre-built vmmon modules for VMware Workstation is suitable for your
running kernel. Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.18-4-k7/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Wejście do katalogu `/tmp/vmware-config0/vmmon-only'
make -C /lib/modules/2.6.18-4-k7/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Wejście do katalogu `/usr/src/linux-headers-2.6.18-4-k7'
CC [M] /tmp/vmware-config0/vmmon-only/linux/driver.o
CC [M] /tmp/vmware-config0/vmmon-only/linux/hostif.o
CC [M] /tmp/vmware-config0/vmmon-only/common/comport.o
CC [M] /tmp/vmware-config0/vmmon-only/common/cpuid.o
CC [M] /tmp/vmware-config0/vmmon-only/common/hash.o
CC [M] /tmp/vmware-config0/vmmon-only/common/memtrack.o
CC [M] /tmp/vmware-config0/vmmon-only/common/phystrack.o
CC [M] /tmp/vmware-config0/vmmon-only/common/task.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciContext.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciDatagram.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciDriver.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciDs.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciGroup.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciHashtable.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciProcess.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciResource.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmciSharedMem.o
CC [M] /tmp/vmware-config0/vmmon-only/common/vmx86.o
CC [M] /tmp/vmware-config0/vmmon-only/vmcore/moduleloop.o
LD [M] /tmp/vmware-config0/vmmon-only/vmmon.o
Building modules, stage 2.
MODPOST
CC /tmp/vmware-config0/vmmon-only/vmmon.mod.o
LD [M] /tmp/vmware-config0/vmmon-only/vmmon.ko
make[1]: Opuszczenie katalogu `/usr/src/linux-headers-2.6.18-4-k7'
cp -f vmmon.ko ./../vmmon.o
make: Opuszczenie katalogu `/tmp/vmware-config0/vmmon-only'
The module loads perfectly in the running kernel.
This program previously created the file /dev/vmmon, and was about to remove
it. Somebody else apparently did it already.
Extracting the sources of the vmblock module.
Building the vmblock module.
make: Wejście do katalogu `/tmp/vmware-config0/vmblock-only'
CC [M] /tmp/vmware-config0/vmblock-only/linux/block.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/control.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/dbllnklst.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/dentry.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/file.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/filesystem.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/inode.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/module.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/stubs.o
CC [M] /tmp/vmware-config0/vmblock-only/linux/super.o
LD [M] /tmp/vmware-config0/vmblock-only/vmblock.o
MODPOST
CC /tmp/vmware-config0/vmblock-only/vmblock.mod.o
LD [M] /tmp/vmware-config0/vmblock-only/vmblock.ko
cp -f vmblock.ko ./../vmblock.o
make: Opuszczenie katalogu `/tmp/vmware-config0/vmblock-only'
You have already setup networking.
Would you like to skip networking setup and keep your old settings as they are?
(yes/no) [yes] no
Do you want networking for your virtual machines? (yes/no/help) [yes]
Would you prefer to modify your existing networking configuration using the
wizard or the editor? (wizard/editor/help) [wizard]
The following bridged networks have been defined:
. vmnet0 is bridged to eth0
. vmnet2 is bridged to ath0
Do you wish to configure another bridged network? (yes/no) [no]
Do you want to be able to use NAT networking in your virtual machines? (yes/no)
[yes] no
Removing a NAT network for vmnet8.
Do you want to be able to use host-only networking in your virtual machines?
[no]
Removing a host-only network for vmnet1.
Extracting the sources of the vmnet module.
Building the vmnet module.
make: Wejście do katalogu `/tmp/vmware-config0/vmnet-only'
CC [M] /tmp/vmware-config0/vmnet-only/driver.o
CC [M] /tmp/vmware-config0/vmnet-only/hub.o
CC [M] /tmp/vmware-config0/vmnet-only/userif.o
CC [M] /tmp/vmware-config0/vmnet-only/netif.o
CC [M] /tmp/vmware-config0/vmnet-only/bridge.o
CC [M] /tmp/vmware-config0/vmnet-only/filter.o
CC [M] /tmp/vmware-config0/vmnet-only/procfs.o
CC [M] /tmp/vmware-config0/vmnet-only/smac_compat.o
SHIPPED /tmp/vmware-config0/vmnet-only/smac_linux.x386.o
LD [M] /tmp/vmware-config0/vmnet-only/vmnet.o
MODPOST
CC /tmp/vmware-config0/vmnet-only/vmnet.mod.o
LD [M] /tmp/vmware-config0/vmnet-only/vmnet.ko
cp -f vmnet.ko ./../vmnet.o
make: Opuszczenie katalogu `/tmp/vmware-config0/vmnet-only'
Do you want to install the Eclipse Integrated Virtual Debugger? You must have
the Eclipse IDE installed. [no]
Starting VMware services:
Bridged networking on /dev/vmnet2 failed
The configuration of VMware Workstation 6.0.0 build-45731 for Linux for this
running kernel completed successfully.
You can now run VMware Workstation by invoking the following command:
"/usr/bin/vmware".
Enjoy,
--the VMware team
vmware is installed, but it has not been (correctly) configured
for this system. To (re-)configure it, invoke the following command:
/usr/bin/vmware-config.pl.
PrEZeS:~#
[ Dodano: 2008-04-15, 15:59 ]
Halo czy nikt mi nie może pomóc?????
