Mam problem z gnome-power-manager, który polega na tym, że przestał on wskazywać stan baterii.
Kilka logów:
$ gnome-power-manager
[gpm_debug_init] gpm-debug.c:236 (15:57:39): Verbose debugging enabled
[main] gpm-main.c:219 (15:57:39): GNOME Menedżer zasilania 2.22.1
[gpm_ac_adapter_init] gpm-ac-adapter.c:217 (15:57:40): using /org/freedesktop/Hal/devices/acpi_ADP1
[gpm_control_init] gpm-control.c:657 (15:57:40): Using a supressed policy timeout of 5 seconds
[coldplug_buttons] gpm-button.c:446 (15:57:40): Watching /org/freedesktop/Hal/devices/computer_logicaldev_input_1
[coldplug_buttons] gpm-button.c:446 (15:57:40): Watching /org/freedesktop/Hal/devices/computer_logicaldev_input_0
[coldplug_buttons] gpm-button.c:446 (15:57:40): Watching /org/freedesktop/Hal/devices/platform_i8042_i8042_KBD_port_logicaldev_input
[gpm_screensaver_add_throttle] gpm-screensaver.c:318 (15:57:40): adding throttle reason: 'Zasilanie z akumulatora': id 134969296
[gpm_prefs_server_set_capability] gpm-prefs-server.c:84 (15:57:40): capability now 4
*** WARNING ***
[gpm_light_sensor_get_absolute] gpm-light-sensor.c:146 (15:57:40): no hardware!
*** WARNING ***
[gpm_backlight_brightness_evaluate_and_set] gpm-backlight.c:363 (15:57:40): no dimming hardware
[gpm_backlight_sync_policy] gpm-backlight.c:159 (15:57:40): choosing sensible default
[gpm_backlight_sync_policy] gpm-backlight.c:161 (15:57:40): laptop, so use GPM_DPMS_METHOD_OFF
[gpm_backlight_sync_policy] gpm-backlight.c:193 (15:57:40): BACKLIGHT parameters 0 0 180, method '4'
[gpm_dpms_set_enabled] gpm-dpms.c:408 (15:57:40): setting DPMS enabled: 1
[x11_sync_server_dpms_settings] gpm-dpms.c:130 (15:57:40): Syncing DPMS settings enabled=1 timeouts=0 0 0
[gpm_idle_set_check_cpu] gpm-idle.c:236 (15:57:40): Setting the CPU load check to 0
[gpm_manager_init] gpm-manager.c:1765 (15:57:40): creating new inhibit instance
[gpm_manager_init] gpm-manager.c:1775 (15:57:40): creating new control instance
[gpm_manager_init] gpm-manager.c:1780 (15:57:40): creating new tray icon
[gpm_manager_init] gpm-manager.c:1789 (15:57:40): initialising info infrastructure
[gpm_profile_init] gpm-profile.c:909 (15:57:40): creating new control instance
[gpm_profile_init] gpm-profile.c:933 (15:57:40): on battery
[gpm_idle_set_system_timeout] gpm-idle.c:287 (15:57:40): Setting system idle timeout: 0
[gpm_warnings_init] gpm-warnings.c:266 (15:57:40): Using per-time notification policy
[gpm_phone_dbus_connect] gpm-phone.c:267 (15:57:40): get connection
[gpm_phone_dbus_connect] gpm-phone.c:278 (15:57:40): get proxy
*** WARNING ***
[gpm_phone_dbus_connect] gpm-phone.c:286 (15:57:40): Cannot connect, maybe the daemon is not running: Could not get owner of name 'org.gnome.phone': no such name
[gpm_check_device_key] gpm-cell-array.c:714 (15:57:40): checking primary against primary
[gpm_cell_array_add_hal_udi] gpm-cell-array.c:794 (15:57:40): adding the right kind of battery: primary
*** WARNING ***
[gpm_cell_refresh_hal_all] gpm-cell.c:157 (15:57:40): could not read your battery's remaining time
[gpm_cell_unit_print] gpm-cell-unit.c:65 (15:57:40): device Akumulator laptopa
[gpm_cell_unit_print] gpm-cell-unit.c:66 (15:57:40): present 1
[gpm_cell_unit_print] gpm-cell-unit.c:67 (15:57:40): percent 0
[gpm_cell_unit_print] gpm-cell-unit.c:68 (15:57:40): is charging 0
[gpm_cell_unit_print] gpm-cell-unit.c:69 (15:57:40): is discharging 1
[gpm_cell_unit_print] gpm-cell-unit.c:80 (15:57:40): rate 856
[gpm_cell_unit_print] gpm-cell-unit.c:92 (15:57:40): voltage 12311
[gpm_profile_set_config_id] gpm-profile.c:782 (15:57:40): config_id = 100
[gpm_profile_load_data] gpm-profile.c:733 (15:57:40): loading battery data from '/home/kuba/.gnome2/gnome-power-manager/profile-100-discharging.csv'
[gpm_profile_load_data] gpm-profile.c:733 (15:57:40): loading battery data from '/home/kuba/.gnome2/gnome-power-manager/profile-100-charging.csv'
[gpm_profile_set_config_id] gpm-profile.c:801 (15:57:40): Reference times
[gpm_profile_set_config_id] gpm-profile.c:803 (15:57:40): 99-0 0 minutes
[gpm_profile_set_config_id] gpm-profile.c:805 (15:57:40): 50-0 0 minutes
[gpm_profile_set_config_id] gpm-profile.c:808 (15:57:40): 0-99 0 minutes
[gpm_profile_set_config_id] gpm-profile.c:810 (15:57:40): 50-99 0 minutes
[gpm_cell_array_update] gpm-cell-array.c:344 (15:57:40): 1 devices of type primary
[gpm_cell_array_update] gpm-cell-array.c:391 (15:57:40): unit->percentage = 0
[gpm_cell_array_collection_changed] gpm-cell-array.c:756 (15:57:40): ** EMIT: collection-changed
[gpm_engine_recalculate_state] gpm-engine.c:644 (15:57:40): ignoring due to coldplug
[gpm_cell_array_percent_changed] gpm-cell-array.c:524 (15:57:40): printing combined new device:
[gpm_cell_array_percent_changed] gpm-cell-array.c:541 (15:57:40): enabled fully charged
*** WARNING ***
[gpm_warnings_get_state_time] gpm-warnings.c:85 (15:57:40): time zero, something's gone wrong
[gpm_cell_array_percent_changed] gpm-cell-array.c:564 (15:57:40): warning state = 1
[gpm_cell_array_percent_changed] gpm-cell-array.c:567 (15:57:40): ** EMIT: discharging
[gpm_check_device_key] gpm-cell-array.c:714 (15:57:40): checking primary against ups
[gpm_cell_array_add_hal_udi] gpm-cell-array.c:782 (15:57:40): not adding /org/freedesktop/Hal/devices/acpi_BAT0 for ups
[gpm_cell_array_update] gpm-cell-array.c:277 (15:57:40): no devices of type 1
[gpm_check_device_key] gpm-cell-array.c:714 (15:57:40): checking primary against mouse
[gpm_cell_array_add_hal_udi] gpm-cell-array.c:782 (15:57:40): not adding /org/freedesktop/Hal/devices/acpi_BAT0 for mouse
[gpm_cell_array_update] gpm-cell-array.c:277 (15:57:40): no devices of type 2
[gpm_check_device_key] gpm-cell-array.c:714 (15:57:40): checking primary against keyboard
[gpm_cell_array_add_hal_udi] gpm-cell-array.c:782 (15:57:40): not adding /org/freedesktop/Hal/devices/acpi_BAT0 for keyboard
[gpm_cell_array_update] gpm-cell-array.c:277 (15:57:40): no devices of type 3
[gpm_check_device_key] gpm-cell-array.c:714 (15:57:40): checking primary against pda
[gpm_cell_array_add_hal_udi] gpm-cell-array.c:782 (15:57:40): not adding /org/freedesktop/Hal/devices/acpi_BAT0 for pda
[gpm_cell_array_update] gpm-cell-array.c:277 (15:57:40): no devices of type 5
*** WARNING ***
[gpm_phone_coldplug] gpm-phone.c:79 (15:57:40): not connected
[gpm_cell_array_update] gpm-cell-array.c:277 (15:57:40): no devices of type 4
[gpm_prefs_server_set_capability] gpm-prefs-server.c:84 (15:57:40): capability now 12
[gpm_engine_get_icon] gpm-engine.c:391 (15:57:40): Trying CRITICAL icon: primary, ups, mouse, keyboard
*** WARNING ***
[gpm_engine_get_icon] gpm-engine.c:435 (15:57:40): Trying CHARGING icon: primary, ups
[gpm_cell_unit_get_icon] gpm-cell-unit.c:210 (15:57:40): got filename: gpm-primary-000
[gpm_engine_recalculate_state_icon] gpm-engine.c:575 (15:57:40): ** EMIT: icon-changed: gpm-primary-000
[gpm_tray_icon_set_icon] gpm-tray-icon.c:182 (15:57:40): Setting icon to gpm-primary-000
[gpm_cell_array_get_description] gpm-cell-array.c:968 (15:57:40): accuracy = 0
[gpm_engine_get_summary] gpm-engine.c:349 (15:57:40): tooltip: Komputer jest zasilany z akumulatora
Akumulator laptopa - rozładowywanie (0%)
Czas rozładowywania akumulatora jest obecnie nieznany
[gpm_engine_recalculate_state_summary] gpm-engine.c:615 (15:57:40): ** EMIT: summary-changed(1): Komputer jest zasilany z akumulatora
[gconf_key_changed_cb] gpm-conf.c:332 (15:57:40): emitting value-changed : '/apps/gnome-screensaver/power_management_delay'
[gconf_key_changed_cb] gpm-screensaver.c:181 (15:57:40): key : /apps/gnome-screensaver/power_management_delay
/proc/acpi/battery/BAT0$ cat state
present: yes
capacity state: ok
charging state: discharging
present rate: 856 mA
remaining capacity: 3879 mAh
present voltage: 12311 mV
