Ogólne zak
rob.cioo
Ogólne zakłopotanie z mpc, mod...?
Post autor: rob.cioo »
Postanowiłem się zabrać za mpc (Music Player Daemon) wgrałem mpd i mpc hmm no i co dalej zacząłem od konfiguracji /etc/mpd.conf na początek zmieniłem
playlist_directory
na "/mnt/sdb6/music"
potem chciałem zacząć zmianę play listy ale jak wpisuje:
xorbie@Xorbie:~$ mpd
problem opening error file "/var/log/mpd/errors.log" (config line 12) for writing
xorbie@Xorbie:~$ mpc
MPD_HOST and/or MPD_PORT environment variables are not set
error: problems getting a response from "localhost" on port 6600 : Connection refused
xorbie@Xorbie:~$
To właśnie mam coś takiego.
Moje mpc.conf wygląda tak:
An example configuration file for MPD
# See the mpd.conf man page for a more detailed description of each parameter.
### REQUIRED PATHS ##
# You can put symlinks in here, if you like. Make sure that
# the user that mpd runs as (see the 'user' config parameter)
# can read the files in this directory.
music_directory         "/ver/lib/mpd/music"
playlist_directory      "/var/lib/mpd/playlists"
db_file                 "/var/lib/mpd/tag_cache"
log_file                "/var/log/mpd/mpd.log"
error_file              "/var/log/mpd/errors.log"
pid_file                "/var/run/mpd/pid"
#### OPTIONAL PATHS ##
# If specified, MPD will save its current state (playlist,
# current song, playing/paused, etc.) at exit.  This will be
# used to restore the session the next time it is run.
state_file              "/var/lib/mpd/state"
#### DAEMON OPTIONS ###
# If started as root, MPD will drop root privileges and run as
# this user instead.  Otherwise, MPD will run as the user it was
# started by.  If left unspecified, MPD will not drop root
# privileges at all (not recommended).
user                            "xorbie"
# The address and port to listen on.
bind_to_address                 "localhost"
#bind_to_address                "any"
#port                            "6600"
# Controls the amount of information that is logged.  Can be
# "default", "secure", or "verbose".
#log_level                       "default"
### PERMISSIONS ####
 MPD can require that users specify a password before using it.
# You may specify one ore more here, along with what users who
# log in with that password are allowed to do.
#password                        "password@read,add,control,admin"
# Specifies what permissions a user who has not logged in with a
# password has.  By default, all users have full access to MPD
# if no password is specified above, or no access if one or
# more passwords are specified.
#default_permissions             "read,add,control,admin"
#### AUDIO OUTPUT ###
# MPD supports many audio output types, as well as playing
# through multiple audio outputs at the same time.  You can
# specify one or more here.  If you don't specify any, MPD will
# automatically scan for a usable audio output.
# See <http://mpd.wikia.com/wiki/Configuration#Audio_Outputs>
# for examples of other audio outputs.
# An example of an ALSA output:
#audio_output {
#        type                    "alsa"
#        name                    "My ALSA Device"
#        device                  "hw:0,0"     # optional
#        format                  "44100:16:2" # optional
# An example of an OSS output:
#audio_output {
#        type                    "oss"
#        name                    "My OSS Device"
#        device                  "/dev/dsp"   # optional
# An example of a shout output (for streaming to Icecast):
#audio_output {
#        type                    "shout"
#        name                    "My Shout Stream"
#        host                    "localhost"
#        port                    "8000"
#        mount                   "/mpd.ogg"
#        password                "hackme"
#        quality                 "5.0"
#        bitrate                 "128"
#        format                  "44100:16:1"
#        user                    "source"                # optional
#        description             "My Stream Description" # optional
#        genre                   "jazz"                  # optional
#        public                  "no"                    # optional
# Force all decoded audio to be converted to this format before
# being passed to the audio outputs.
#audio_output_format             "44100:16:2"
#### MIXER ###
# MPD needs to know what mixer settings to change when you
# adjust the volume.  If you don't specify one here, MPD will
# pick one based on which ones it was compiled with support for.
# An example for controlling an ALSA mixer:
#mixer_type                      "alsa"
#mixer_device                    "default"
#mixer_control                   "VOL"
# An example for controlling an OSS mixer:
#mixer_type                      "oss"
#mixer_device                    "/dev/mixer"
#mixer_control                   "PCM"
# If you want MPD to adjust the volume of audio sent to the
# audio outputs, you can tell it to use the software mixer:
#mixer_type                      "software"
#### NORMALIZATION ###
# Specifies the type of ReplayGain to use.  Can be "album" or
# "track".  ReplayGain will not be used if not specified.  See
# <http://www.replaygain.org> for more details.
#replaygain                      "album"
# Sets the pre-amp used for files that have ReplayGain tags.
#replaygain_preamp               "0"
# Enable on the fly volume normalization.  This will cause the
# volume of all songs played to be adjusted so that they sound
# as though they are of equal loudness.
#volume_normalization            "no"
#### BUFFERING ####
# The size of the buffer containing decoded audio.  You probably
# shouldn't change this.
#audio_buffer_size               "2048"
# How much of the buffer to fill before beginning to play.
#buffer_before_play              "0%"
# Similar options for the HTTP stream buffer.  If you hear
# skipping while playing HTTP streams, you may wish to increase
# these.
#http_buffer_size                "128"
#http_prebuffer_size             "25%"
#### HTTP PROXY ####
# Specifies the HTTP proxy to use for playing HTTP streams.
#http_proxy_host                 "proxy.isp.com"
#http_proxy_port                 "8080"
#http_proxy_user                 "user"
#http_proxy_password             "password"
#### LIMITS ###
# These are various limits to prevent MPD from using too many
# resources.  You should only change them if they start
# restricting your usage of MPD.
#connection_timeout              "60"
#max_connections                 "5"
#max_playlist_length             "16384"
#max_command_list_size           "2048"
#max_output_buffer_size          "8192"
####CHARACTER ENCODINGS ###
# If file or directory names do not display correctly, then you
# may need to change this.  In most cases it should be either
# "ISO-8859-1" or "UTF-8".  You must recreate your database
# after changing this (use mpd --create-db).
filesystem_charset              "UTF-8"
# The encoding that ID3v1 tags should be converted from.
id3v1_encoding                  "UTF-8"
#### OTHER OPTIONS ###
# The metadata types MPD will recognize.
#metadata_to_use                  "artist,album,title,track,name,genre,date,composer,performer,disc"
# Enable this if you wish to use your MPD created playlists in
# other music players.
#save_absolute_paths_in_playlists "no"
# these.
##### HTTP PROXY ######
Prosiłbym o jakieś szczegółowe wskazówki. Przeczytałem kilka poradników ale za dużo mi to nie pomogło, a po za tym lamie z angielskim to utrudnia mi to sprawę w jakimkolwiek się dowiedzeniu.
Z góry thx.
meal
Post autor: meal »
to mówi samo za siebie dlaczego mpd nie chodzi.
