Problem z resovl.conf
amator
Post autor: amator »
Mam taki problem, a dokładnie do wydaniu komendy "apt-get update" otrzymuje coś takiego:
KDZ001:~# apt-get update
Err http://security.debian.org etch/updates Release.gpg
Temporary failure resolving 'security.debian.org'
Err http://ftp2.de.debian.org etch Release.gpg
Temporary failure resolving 'ftp2.de.debian.org'
Failed to fetch http://ftp2.de.debian.org/debian/dists/etch/Release.gpg Temporary failure resolving 'ftp2.de.debian.org'
Failed to fetch http://security.debian.org/dists/etch/u ... elease.gpg Temporary failure resolving 'security.debian.org'
Reading package lists... Done
W: Couldn't stat source package list http://ftp2.de.debian.org etch/main Packages (/var/lib/apt/lists/ftp2.de.debian.org_debian_dists_etch_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.debian.org etch/updates/main Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.debian.org etch/updates/contrib Packages (/var/lib/apt/lists/security.debian.org_dists_etch_updates_contrib_binary-i386_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Some index files failed to download, they have been ignored, or old ones used instead.
Ktoś wie jak to naprawić? Wszystko "popsuło się" jak chciałem usunąć BINDa.
Drugie pytanie, jak można ustawić język polski?
