Nessus configure: error: installation or configuration ...
kokoboss
Post autor: kokoboss »
Witam, chodzi o instalacje Nessusa na Debianie. Sciagnalem instalke nessus-installer.sh i teraz po kolei:
 koksik:/home/koksik/moje# sh ./nessus-installer.sh
The command 'gtk-config' was not found in your $PATH.
The nessus client will be built without its GUI...
Press ENTER to continue...
Sami widzicie juz problem, jak wiec go rozwiazac?
Ale lecimy dalej wciskam Enter i pokolei:
Welcome to the Nessus Installation Script !
This script will install Nessus 2.0.4 (STABLE) on your system.
Please note that you will need root privileges at some point so that
the installation can complete.
Nessus is released under the version 2 of the GNU General Public License
(see [url]http://www.gnu.org/licences/gpl.html[/url] for details).
To get the latest version of Nessus, visit [url]http://www.nessus.org[/url]
x - creating lock directory
x - extracting nessus.tar.gz (binary)
x - now extracting this archive
x - done
jak narazie wszystko ok a dalej nastepuje cos takiego
 Nessus installation : Ready to install
Nessus is now ready to be installed on this host.
The installation process will first compile it then install it
x - Compiling the libraries
x -- Configuring the sources for your system
configure: error: installation or configuration problem: C compiler cannot create executables.
**** An error occured :/
Do you want to save the compilation log to analyze what went wrong ? [y] y
Where should I save this file ? [/root/nessus_compilation] y
Do you want to delete /tmp/nessus-installer.6448 ? [y] y
i tu instalacja sie przerywa, nigdzie nie moge znalesc odpowiedzi na ten problem, bede wdzieczny jak ktos da mi jakas sensowna odpowiedz na ten problem. Dolaczam jeszcze koncowke loga bo caly jest bardzo dlugi a chyba na samym koncu bedzie moj problem no chyba ze sie myle :P
---------------------- LIBRARIES
creating cache ../config.cache
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... no
Na tym sie konczy, tak wiec jak juz pisalem bede bardzo wdzieczny za pomoc. Pzdr
winnetou
Post autor: winnetou »
Dziękuję.... Bye bye
nie lepiej zainstalowac z paczki?
apt-get isntall nessus
jesli masz wersję 2.0.4 to chyba jakąs starą, bo w repo etch 2.2.8-1 a na stronie nessusa 3.0.6
kokoboss
dzieki Yampress, pomoglo ... :-P jak byc cos dalej szwankowalo to jutro pewnie dopisze bo dzisiaj ide juz spac ... :-D
