Po zainstalowaniu Truecrypt wersja 5.0 i próbie uruchomienia pojawia się następujący błąd
freeman@BlackMesa:~$ truecrypt
The program 'truecrypt' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
(Details: serial 1946 error_code 8 request_code 2 minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
ps posiadam jądro 2.6.18.-4
