Kalkulator KDE
kuleczek
Kalkulator KDE
Post autor: kuleczek »
¦ciągnąłem źródła kalkulatora z tej strony.
Przy ,/configure wywaliło taki błąd:
checking for Qt... configure: error: Qt (>= Qt 3.0.2) (headers and libraries) not found. Please check your installation! For more details about this problem, look at the end of config.log.
Końcówka config.log wygląda tak:
configure:6705: checking for Qt
configure: 6769: /usr/lib/qt3/include/qstyle.h
configure: 6769: /usr/lib/qt3/qstyle.h
configure: 6769: /usr/lib/qt/include/qstyle.h
configure: 6769: /usr/lib/qt/qstyle.h
configure: 6769: /usr/local/qt/include/qstyle.h
configure: 6769: /usr/include/qt/qstyle.h
configure: 6769: /usr/include/qstyle.h
configure: 6769: /usr/X11R6/include/X11/qt/qstyle.h
configure: 6769: /usr/X11R6/include/qt/qstyle.h
configure: 6769: /usr/X11R6/include/qt2/qstyle.h
configure: 6769: ./qstyle.h
tried NO
tried /usr/lib/qt3/lib
tried /usr/lib/qt3
tried /usr/lib/qt/lib
tried /usr/lib/qt
tried /usr/X11R6/lib
configure:6881: rm -rf SunWS_cache; c++ -o conftest -O2 -fno-exceptions -fno-check-new -INO -I.  -DQT_THREAD_SUPPORT  -D_REENTRANT  -L/usr/lib -L/usr/lib  $
conftest.C:2:21: error: qglobal.h: No such file or directory
conftest.C:3:26: error: qapplication.h: No such file or directory
conftest.C:4:21: error: qcursor.h: No such file or directory
conftest.C:5:27: error: qstylefactory.h: No such file or directory
conftest.C:6:34: error: private/qucomextra_p.h: No such file or directory
conftest.C:8:2: error: #error 1
conftest.C: In function 'int main()':
conftest.C:12: error: 'QStyleFactory' was not declared in this scope
conftest.C:12: error: expected `;' before '::' token
conftest.C:13: error: 'QCursor' was not declared in this scope
conftest.C:13: error: expected `;' before 'c'
configure: failed program was:
#include "confdefs.h"
#include <qglobal.h>
#include <qapplication.h>
#include <qcursor.h>
#include <qstylefactory.h>
#include <private/qucomextra_p.h>
#if ! (QT_VERSION >= 302)
#error 1
#endif
int main() {
    (void)QStyleFactory::create(QString::null);
    QCursor c(Qt::WhatsThisCursor);
    return 0;
aptitude search qt wywalilo, że mam już zainstalowane następujące pakity:
(nie wiem co oznacza "A")
i A libavahi-qt3-1                                                        - Avahi Qt 3 integration library
i A libdbus-qt-1-1c2                                                      - simple interprocess messaging system (Qt-based shared library)
i A libqt3-compat-headers                                                 - Qt 1.x and 2.x compatibility includes
i A libqt3-headers                                                        - Qt3 header files
i A libqt3-mt                                                             - Qt GUI Library (Threaded runtime version), Version 3
i A libqt3-mt-dev                                                         - Qt development files (Threaded)
i   python-qt3                                                            - Qt3 bindings for Python
i   qt3-apps-dev                                                          - Qt3 Developer applications development files
i A qt3-dev-tools                                                         - Qt3 development tools
Proszę o jakąś wskazówkę. Jestem początkującym użytkownikiem. Oprócz kadu wszystko instalowałem przez aptitude..
3ndriu
Post autor: 3ndriu »
Masz qt w wersji większej niż 3.0.2. Program do kompilacji potrzebuje qt w wersji niższej niż 3.0.2
Bodzio
Post autor: Bodzio »
ejejej, jak masz KDE to masz i kalkulator systemowy do dyspozycji.
Naciśnij kombinację klawiszy: Alt + F2 i wpisz kcalc
kuleczek
Dzieki za odp. kcalc nie mialem, bo instalowalem najlzejsza wersje kde. Zainstalowalem z repo i jest. Nie bede downgrade'owal tych bilbliotek qt3.
