Udało mi się ją zainstalować, ale nie mogę odpalić gier.
W konsoli pokazuje mi się coś takiego:
spider@debian:~$ cvscedega '/media/cdrom0/Launch.exe'
err:virtual:is_memory_manager_disabled could not retrieve the module file name (reason: 'bad module')
err:client:is_scheduler_disabled could not retrieve the module file name (reason: 'bad module')
err:win32:PE_fixup_imports Unable to change protections on import list!
err:win32:PE_fixup_imports Unable to restore protections on import list!
fixme:ver:create_version_reg_entries Need to fill in pre-win2k registry entries for OS version
err:font:WineEngInit FreeType support is not compiled in to wine, some font functionality will be disabled.
/usr/lib/cvscedega/bin/wine: binary overlaps reserved area (08048000-08051a1c)
spider@debian:~$ err:win32:PE_fixup_imports Unable to change protections on import list!
err:string:lstrcpyA ((nil), 0x465468): page fault occurred ! Caused by bug ?
err:task:GetThreadQueue16 Breaking 16 bit for tid 14
fixme :o le:CoCreateInstance no classfactory created for CLSID {e436ebb3-524f-11ce-9f53-0020af0ba770}, hres is 0x80040154
