Startx error
pikpin
Startx error
Post autor: pikpin »
Po wpisaniu polecenia „startx”, w wierszu poleceń wypisane są błędy które załączam w poście. Mam zainstalowanego debiana z jajkiem 2-4-27-2 386. ¦rodowisko graficzne to xfce4.
user należy do grup: dialout cdrom floppy audio video plugdev.
lspci :
00:00.0 Host bridge: Intel Corporation 82810 GMCH [Graphics Memory Controller Hub] (rev 03)
00:01.0 VGA compatible controller: Intel Corporation 82810 CGC [Chipset Graphics Controller] (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801AA PCI Bridge (rev 01)
00:1f.0 ISA bridge: Intel Corporation 82801AA ISA Bridge (LPC) (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801AA IDE (rev 01)
00:1f.2 USB Controller: Intel Corporation 82801AA USB (rev 01)
01:00.0 VGA compatible controller: ATI Technologies Inc 264VT [Mach64 VT] (rev 48)
01:01.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
xorg.conf :
Section "Files"
        FontPath        "/usr/share/fonts/X11/misc"
        FontPath        "/usr/X11R6/lib/X11/fonts/misc"
        FontPath        "/usr/share/fonts/X11/cyrillic"
        FontPath        "/usr/X11R6/lib/X11/fonts/cyrillic"
        FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath        "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath        "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/Type1"
        FontPath        "/usr/X11R6/lib/X11/fonts/Type1"
        FontPath        "/usr/share/fonts/X11/100dpi"
        FontPath        "/usr/X11R6/lib/X11/fonts/100dpi"
        FontPath        "/usr/share/fonts/X11/75dpi"
        FontPath        "/usr/X11R6/lib/X11/fonts/75dpi"
        # path to defoma fonts
        FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
fontconfig.log :
/usr/share/fonts: caching, 0 fonts, 2 dirs
/usr/share/fonts/X11: caching, 0 fonts, 3 dirs
/usr/share/fonts/X11/encodings: caching, 0 fonts, 1 dirs
/usr/share/fonts/X11/encodings/large: caching, 0 fonts, 0 dirs
/usr/share/fonts/X11/misc: caching, 55 fonts, 0 dirs
/usr/share/fonts/X11/util: caching, 0 fonts, 0 dirs
/usr/share/fonts/truetype: caching, 0 fonts, 1 dirs
/usr/share/fonts/truetype/ttf-dejavu: caching, 21 fonts, 0 dirs
/usr/X11R6/lib/X11/fonts: caching, 0 fonts, 1 dirs
/usr/X11R6/lib/X11/fonts/encodings: caching, 0 fonts, 1 dirs
/usr/X11R6/lib/X11/fonts/encodings/large: caching, 0 fonts, 0 dirs
/usr/local/share/fonts: caching, 0 fonts, 0 dirs
/var/lib/defoma/fontconfig.d: caching, 0 fonts, 1 dirs
/var/lib/defoma/fontconfig.d/D: caching, 21 fonts, 0 dirs
/var/cache/fontconfig: cleaning cache directory
fc-cache: succeeded
Proba uruchomienia x'ow   Xorg.0.log :
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.4.27-2-386 #1 Mon May 16 16:47:51 JST 2005 i686
Build Date: 04 September 2007
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Jan 11 07:54:48 1999
Parse error on line 1 of section (null) in file /etc/X11/xorg.conf
	"ÐÏà¡ąá" is not a valid keyword in this section.
(EE) Problem parsing the config file
(EE) Error parsing the config file
Fatal server error:
no screens found
(WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor
(WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor
// Poprawiłem Twój post - dodałem tagi code.
Kaka'
jerryS
Post autor: jerryS »
Chodzi chyba o xorg.conf
Pokaż swój xorg.conf lub go popraw sam.
chyab masz niepełny plik konfiguracyjny
jako root
X -configure
stworzy wstępny plik xorg.conf w katalogu roota
zrobić kopię starego, skopiować ten do /etc/X11
trochę przeedytowac i powinno chodzić
pikpin
xorga mam kompletnego i w tym jest problem
xorg.conf :
# package.
Section "Files"
EndSection
Section "Module"
        Load    "bitmap"
        Load    "ddc"
        Load    "dri"
        Load    "extmod"
        Load    "freetype"
        Load    "glx"
        Load    "int10"
        Load    "vbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc105"
        Option          "XkbLayout"     "pl"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/psaux"
        Option          "Protocol"              "ImPS/2"
        Option          "Emulate3Buttons"       "true"
EndSection
Section "Device"
        Identifier      "Generic Video Card"
        Driver          "nv"
        BusID           "PCI:2:0:0"
EndSection
Section "Monitor"
        Identifier      "Generic Monitor"
        Option          "DPMS"
        HorizSync       28-64
        VertRefresh     43-60
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "Generic Video Card"
        Monitor         "Generic Monitor"
        DefaultDepth    24
        SubSection "Display"
                Depth           1
                Modes           "1280x1024" "1024x768" "800x600" "640x480"
        EndSubSection
                Depth           4
        EndSubSection
                Depth           8
        EndSubSection
                Depth           15
        EndSubSection
                Depth           16
        EndSubSection
                Depth           24
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
EndSection
Section "DRI"
        Mode    0666
EndSection
[/color]
