Czy mozliwe jest zbudowanie paczki .deb
PhockouS
Post autor: PhockouS »
Witam :)
Chcialbym zbudowac paczke ze zrodla Sonaty , lecz jest ona zbudowana w pythonie i nie zabardzo wiem jak sie do tego zabrac , czy to w ogole jest mozliwe ?
Standard commands:
  build            build everything needed to install
  build_py         "build" pure Python modules (copy to build directory)
  build_ext        build C/C++ extensions (compile/link to build directory)
  build_clib       build C/C++ libraries used by Python extensions
  build_scripts    "build" scripts (copy and fixup #! line)
  clean            clean up output of 'build' command
  install          install everything from build directory
  install_lib      install all Python modules (extensions and pure Python)
  install_headers  install C/C++ header files
  install_scripts  install scripts (Python or otherwise)
  install_data     install data files
  sdist            create a source distribution (tarball, zip file, etc.)
  register         register the distribution with the Python package index
  bdist            create a built (binary) distribution
  bdist_dumb       create a "dumb" built distribution
  bdist_rpm        create an RPM distribution
  bdist_wininst    create an executable installer for MS Windows
takie komendy podaje sama Sonata , odrazu uprzedze , ze komenda 'bdist' tworzy pakiet tar.tgz :)
z gory dzieki :)
// Poprawiłem Twój post - dodałem tagi code.
Kaka'
db
Post autor: db »
