mam działający virtual host forum.emisjecyfrowe.pl
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin webmaster@localhost
ServerName emisjecyfrowe.pl
ServerAlias forum.emisjecyfrowe.pl
DocumentRoot /var/www/html/forum/
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
RewriteEngine on
RewriteCond %{SERVER_NAME} =hostdomowy.pl [OR]
RewriteCond %{SERVER_NAME} =sp5smy.hostdomowy.pl
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
certbotem tworzę sertyfikat ssl i virtual host
sudo certbot --apache -d forum.emisjecyfrowe.pl -d emisjecyfrowe.pl
i zamiast otwierać emisjecyfrowe.pl otwiera się forum
co robię nie tak
Apache i virtual host
Re: Apache i virtual host
A jaka jest scieżka do katalogu o który Ci chodzi?
A ten wpis co daje?ServerName emisjecyfrowe.pl
tak się dzieje jak daję https;//emisjecyfrowe.pl jak wchodzę na https;//www.emisjecyfrowe.pl linki działają prawidłowo.
- LordRuthwen
to co wkleiłeś dotyczy http://emisjecyfrowe.pl i forum.emisjecyfrowe.pl www.emisjecyfrowe.pl będą w innym pliku, https też.
