VMware-workstation problem
frik
Post autor: frik »
takie cos mi wywala ;-)
Extracting the sources of the vmnet module.
Building the vmnet module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config1/vmnet-only'
make -C /lib/modules/2.6.22-1-686/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.22-1-686'
  CC [M]  /tmp/vmware-config1/vmnet-only/driver.o
  CC [M]  /tmp/vmware-config1/vmnet-only/hub.o
  CC [M]  /tmp/vmware-config1/vmnet-only/userif.o
/tmp/vmware-config1/vmnet-only/userif.c: In function ‘VNetCopyDatagramToUser’:
/tmp/vmware-config1/vmnet-only/userif.c:630: error: ‘const struct sk_buff’ has no member named ‘h’
/tmp/vmware-config1/vmnet-only/userif.c:630: error: ‘const struct sk_buff’ has no member named ‘nh’
/tmp/vmware-config1/vmnet-only/userif.c:636: error: ‘const struct sk_buff’ has no member named ‘h’
make[2]: *** [/tmp/vmware-config1/vmnet-only/userif.o] Error 1
make[1]: *** [_module_/tmp/vmware-config1/vmnet-only] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.22-1-686'
make: *** [vmnet.ko] Error 2
make: Leaving directory `/tmp/vmware-config1/vmnet-only'
Unable to build the vmnet module.
i nie wiem co z tym zrobic
ściagnij najnowszego vmware workstation to jakas tam wersja 6.x
zainstaluj pakiety
 apt-get install linux-headers-'uname -r' libx11-6 libx1-dev x-window-system-core x-window-system xspecs libxtst6 psmisc build-essentioal
z tymi pakietami spokojnie mi się skąpilowały moduły vmware. mojeg distro to etch wiec dla sida mogą być nowsze wersje pakietów. sprawdź
frik
Post autor: frik »
Couldn't find any package whose name or description matched "libx1-dev"
Couldn't find any package whose name or description matched "build-essentioal"
reszta poszla ale to i tak nic nie zmienia
a vmware sciagnolem ze stronki wczoraj
sorki
libx11-dev libx11-6
miało byc build-essential
frik
Post autor: frik »
nadal ten sam blad ;-)
dosc dziwne bo kiedys instalowalem to bez problemu
u mnie na etchu hulało
zobacz czy masz jeszcze zainstalowany pakiet
linux-kbuild
frik
Post autor: frik »
Yampress pisze: zobacz czy masz jeszcze zainstalowany pakiet
linux-kbuild
tak mam
btw. moja wersja to VMware Workstation v6.0.0.45731
Kaudi
Post autor: Kaudi »
Mam rowniez problem z configuracja Vmware a raczej z kompilacja modulow ponizej to co wyrzuca consola moze ktos ma jakis pomysl jak sie z tym uporac
Kaudii:/home/sebastian# cd /home/sebastian/Vmware/vmware-distribKaudii:/home/sebastian/Vmware/vmware-distrib# ./vmware-install.plCreating a new VMware Workstation installer database using the tar4 format.
Installing VMware Workstation.  This may take from several minutes to over an
hour depending upon its size.
In which directory do you want to install the binary files?
[/usr/bin]
What is the directory that contains the init directories (rc0.d/ to rc6.d/)?
[/etc]
What is the directory that contains the init scripts?
[/etc/init.d]
In which directory do you want to install the daemon files?
[/usr/sbin]
In which directory do you want to install the library files?
[/usr/lib/vmware]
The path "/usr/lib/vmware" does not exist currently. This program is going to
create it, including needed parent directories. Is this what you want?
[yes]
In which directory do you want to install the manual files?
[/usr/share/man]
In which directory do you want to install the documentation files?
[/usr/share/doc/vmware]
The path "/usr/share/doc/vmware" does not exist currently. This program is
going to create it, including needed parent directories. Is this what you want?
[yes]
The installation of VMware Workstation 6.0.0 build-45731 for Linux completed
successfully. You can decide to remove this software from your system at any
time by invoking the following command: "/usr/bin/vmware-uninstall.pl".
Before running VMware Workstation for the first time, you need to configure it
by invoking the following command: "/usr/bin/vmware-config.pl". Do you want
this program to invoke the command for you now? [yes]
Making sure services for VMware Workstation are stopped.
Stopping VMware services:
   Virtual machine monitor                                             done
Configuring fallback GTK+ 2.4 libraries.
In which directory do you want to install the theme icons?
[/usr/share/icons]
What directory contains your desktop menu entry files? These files have a
.desktop file extension. [/usr/share/applications]
In which directory do you want to install the application's icon?
[/usr/share/pixmaps]
Trying to find a suitable vmmon module for your running kernel.
None of the pre-built vmmon modules for VMware Workstation is suitable for your
running kernel.  Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.22-2-686/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
make: Wejście do katalogu `/tmp/vmware-config0/vmmon-only'
make -C /lib/modules/2.6.22-2-686/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Wejście do katalogu `/usr/src/linux-headers-2.6.22-2-686'
  CC [M]  /tmp/vmware-config0/vmmon-only/linux/driver.o
  CC [M]  /tmp/vmware-config0/vmmon-only/linux/hostif.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/comport.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/cpuid.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/hash.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/memtrack.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/phystrack.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/task.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciContext.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciDatagram.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciDriver.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciDs.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciGroup.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciHashtable.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciProcess.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciResource.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmciSharedMem.o
  CC [M]  /tmp/vmware-config0/vmmon-only/common/vmx86.o
  CC [M]  /tmp/vmware-config0/vmmon-only/vmcore/moduleloop.o
  LD [M]  /tmp/vmware-config0/vmmon-only/vmmon.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/vmware-config0/vmmon-only/vmmon.mod.o
  LD [M]  /tmp/vmware-config0/vmmon-only/vmmon.ko
make[1]: Opuszczenie katalogu `/usr/src/linux-headers-2.6.22-2-686'
cp -f vmmon.ko ./../vmmon.o
make: Opuszczenie katalogu `/tmp/vmware-config0/vmmon-only'
The module loads perfectly in the running kernel.
Extracting the sources of the vmblock module.
Building the vmblock module.
make: Wejście do katalogu `/tmp/vmware-config0/vmblock-only'
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/block.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/control.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/dbllnklst.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/dentry.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/file.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/filesystem.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/inode.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/module.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/stubs.o
  CC [M]  /tmp/vmware-config0/vmblock-only/linux/super.o
  LD [M]  /tmp/vmware-config0/vmblock-only/vmblock.o
  MODPOST 1 modules
  CC      /tmp/vmware-config0/vmblock-only/vmblock.mod.o
  LD [M]  /tmp/vmware-config0/vmblock-only/vmblock.ko
cp -f vmblock.ko ./../vmblock.o
make: Opuszczenie katalogu `/tmp/vmware-config0/vmblock-only'
Do you want networking for your virtual machines? (yes/no/help) [yes]
Configuring a bridged network for vmnet0.
The following bridged networks have been defined:
. vmnet0 is bridged to eth0
All your ethernet interfaces are already bridged.
Do you want to be able to use NAT networking in your virtual machines? (yes/no)
[yes]
Configuring a NAT network for vmnet8.
Do you want this program to probe for an unused private subnet? (yes/no/help)
[yes]
Probing for an unused private subnet (this can take some time)...
The subnet 192.168.148.0/255.255.255.0 appears to be unused.
The following NAT networks have been defined:
. vmnet8 is a NAT network on private subnet 192.168.148.0.
Do you wish to configure another NAT network? (yes/no) [no]
Do you want to be able to use host-only networking in your virtual machines?
[yes]
Configuring a host-only network for vmnet1.
[yes]
The subnet 192.168.138.0/255.255.255.0 appears to be unused.
The following host-only networks have been defined:
. vmnet1 is a host-only network on private subnet 192.168.138.0.
Do you wish to configure another host-only network? (yes/no) [no]
make: Wejście do katalogu `/tmp/vmware-config0/vmnet-only'
  CC [M]  /tmp/vmware-config0/vmnet-only/driver.o
  CC [M]  /tmp/vmware-config0/vmnet-only/hub.o
  CC [M]  /tmp/vmware-config0/vmnet-only/userif.o
/tmp/vmware-config0/vmnet-only/userif.c: In function ‘VNetCopyDatagramToUser’:
/tmp/vmware-config0/vmnet-only/userif.c:630: error: ‘const struct sk_buff’ has no member named ‘h’
/tmp/vmware-config0/vmnet-only/userif.c:630: error: ‘const struct sk_buff’ has no member named ‘nh’
/tmp/vmware-config0/vmnet-only/userif.c:636: error: ‘const struct sk_buff’ has no member named ‘h’
make[2]: *** [/tmp/vmware-config0/vmnet-only/userif.o] Błąd 1
make[1]: *** [_module_/tmp/vmware-config0/vmnet-only] Błąd 2
make: *** [vmnet.ko] Błąd 2
make: Opuszczenie katalogu `/tmp/vmware-config0/vmnet-only'
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
Kaudii:/home/sebastian/Vmware/vmware-distrib# cd /home/sebastian/Vmware/vmware-any-any-update114
Kaudii:/home/sebastian/Vmware/vmware-any-any-update114# ./runme.plUpdating /usr/bin/vmware ... No patch needed/available
Updating /usr/bin/vmnet-bridge ... No patch needed/available
Updating /usr/lib/vmware/bin/vmware-vmx ... No patch needed/available
Updating /usr/lib/vmware/bin-debug/vmware-vmx ... No patch needed/available
VMware modules in "/usr/lib/vmware/modules/source" has been updated.
Before running VMware for the first time after update, you need to configure it
for your running kernel by invoking the following command:
"/usr/bin/vmware-config.pl". Do you want this script to invoke the command for
you now? [yes]
   Blocking file system:                                               done
   Bridged networking on /dev/vmnet0                                   done
   Host network detection                                              done
   DHCP server on /dev/vmnet1                                          done
   Host-only networking on /dev/vmnet1                                 done
   DHCP server on /dev/vmnet8                                          done
   NAT service on /dev/vmnet8                                          done
   Host-only networking on /dev/vmnet8                                 done
   Virtual ethernet                                                    done
[/usr/share/icons]
Building for VMware Workstation 6.0.0.
make: Wejście do katalogu `/tmp/vmware-config1/vmmon-only'
  CC [M]  /tmp/vmware-config1/vmmon-only/linux/driver.o
  CC [M]  /tmp/vmware-config1/vmmon-only/linux/hostif.o
  CC [M]  /tmp/vmware-config1/vmmon-only/common/comport.o
  CC [M]  /tmp/vmware-config1/vmmon-only/common/cpuid.o
  CC [M]  /tmp/vmware-config1/vmmon-only/common/hash.o
  CC [M]  /tmp/vmware-config1/vmmon-only/common/memtrack.o
  CC [M]  /tmp/vmware-config1/vmmon-only/common/phystrack.o
  CC [M]  /tmp/vmware-config1/vmmon-only/common/task.o
gcc-4.1: error trying to exec 'cc1plus': execvp: Nie ma takiego pliku ani katalogu
make[2]: *** [/tmp/vmware-config1/vmmon-only/common/task.o] Błąd 1
make[1]: *** [_module_/tmp/vmware-config1/vmmon-only] Błąd 2
make: *** [vmmon.ko] Błąd 2
make: Opuszczenie katalogu `/tmp/vmware-config1/vmmon-only'
Unable to build the vmmon module.
Execution aborted.
