regoly iptables blokuja dostep do Internetu
Matrixx
Post autor: Matrixx »
Najpierw dane:
uname -a
Linux debian2 5.10.0-18-amd64 #1 SMP Debian 5.10.140-1 (2022-09-02) x86_64 GNU/Linux
dpkg -l | grep netfilter-persistent
ii  netfilter-persistent                  1.0.15                           all          boot-time loader for netfilter configuration
mark@debian2:~$ update-alternatives --list iptables
/usr/sbin/iptables-legacy
/usr/sbin/iptables-nft
Po zaimplementowaniu tych regol:
iptables -F
iptables -F -t nat
iptables -F INPUT
iptables -F OUTPUT
iptables -F FORWARD
iptables -X
iptables -P INPUT DROP
iptables -P OUTPUT DROP
iptables -P FORWARD DROP
# Załaduj moduły śledzące połączenia
modprobe ip_conntrack
modprobe iptable_nat
modprobe ip_conntrack_ftp
modprobe ip_nat_ftp
conntrack -F
# Błędne pakiety – tablica mangle
iptables -t mangle -A PREROUTING -m conntrack --ctstate INVALID -j DROP
iptables -t mangle -A PREROUTING -p tcp ! --syn -m conntrack --ctstate NEW -j DROP
iptables -t mangle -A PREROUTING -p tcp -m conntrack --ctstate NEW -m tcpmss ! --mss 536:65535 -j DROP
iptables -t mangle -A PREROUTING -f -j DROP
iptables -A INPUT -p icmp -m icmp --icmp-type 8 -j DROP
iptables -A INPUT -s 127.0.0.0/8 -d 127.0.0.0/8 -i lo -j ACCEPT
iptables -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -i lo -j ACCEPT
iptables -A FORWARD -m conntrack --ctstate INVALID -j DROP
iptables -A FORWARD -j REJECT --reject-with icmp-host-prohibited
iptables -A OUTPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
iptables -A OUTPUT -m state --state INVALID -j LOG --log-prefix "outinvalid: "
iptables -A OUTPUT -j LOG --log-prefix "outinvalid: "
iptables -A OUTPUT -m conntrack --ctstate INVALID -j DROP
iptables -A OUTPUT -p icmp -m icmp --icmp-type 0 -j DROP
iptables -A OUTPUT -p tcp -m tcp --dport 23 -j REJECT --reject-with icmp-port-unreachable
# Drop everything else
ip6tables -P INPUT DROP
ip6tables -P FORWARD DROP
ip6tables -P OUTPUT DROP
Blokuje dostep do Internetu.
Co zlego jest w tych regolach ? :mad:
Re: regoly iptables blokuja dostep do Internetu
W regułce łańcucha output, brak akceptacji dla nowych połączeń:
Powinno być:
iptables -A OUTPUT -m conntrack --ctstate NEW,RELATED,ESTABLISHED -j ACCEPT
Matrixx
Z pelna swiadomoscia dalem DROP na OUTPUT poniewaz:
- zgodnie z definicja polityka domysla jest na ostatniej pozycji w lancuchu, czyli pakiety polaczenia ESTABLISHED powinny moc " wydostac sie" poprzez poprzedzajaca regole ESTABLISHED.
- W Internecie sa przyklady dzialajacych skryptow z domyslna polityka 3xDROP.
- Sam uzywalem takiego skrypta.
Mysle, ze tutaj jest mala niescislosc:
Moim zdaniem powinno byc "ustanowionych" polaczen.
Nowe polaczenia to bardziej na INPUT.
Zamiast teoretyzować, sprawdź na własnym firewallu.
Dawno nie bawiłem się regułkami iptables, poza tym to już historia, teraz trzeba się uczyć nftables.
Jak masz Debiana 10 lub nowszego to iptables i tak jest domyślnie konwertowane do nftables.
Różnie ta konwersja wychodzi, nie zawsze dobrze, co może mieś związek z tym twoim firewallem.
https://morfikov.github.io/post/migracj ... -debianie/
https://wiki.debian.org/nftables
Matrixx
Wlasnie dlatego szukam entuzjasty iptables, bo warto.
- nftables nie jest dojrzale "produkcyjnie" Podobnie jak cgroups.v2.
- piszac, ze konwersja jest zawodna, masz absolutna racje.
- Iptables ma opcje "legacy" co pozwala dzialac na najnowszych wersjach Debiana.
- Iptables ma teoretycznie ok 36 mln kombinacji polecen, jest szalenie elastyczne, jezeli tylko sie wie jak ...
Z mojego punktu widzenia ... wątek traci sens.
Matrixx
No ale gdyby np Morfik cos napisal to by mogl byc bardzo ciekawy.
