Wyse 5060 debian 11 brak dostępu do usb0
walus
Post autor: walus »
jak w temacie, zainstalowałem debiana 11 NA WYSE 5060, ma on 4 usb z tył, i 2 z przodu, wszystko działa oprócz USB1, USB2, USB3 itd pod oscam
root@debian:~# ls /dev/serial/by-id/
ls: cannot access '/dev/serial/by-id/': No such file or directory
dsmeg część odpowiedzi
[    5.377919] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/00        00:00:14.2/sound/card1/input10
[    5.390522] kvm: Nested Virtualization enabled
[    5.390536] SVM: kvm: Nested Paging enabled
[    5.396484] MCE: In-kernel MCE decoding enabled.
[    5.401279] EDAC amd64: F16h_M30h detected (node 0).
[    5.401318] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.439038] EDAC amd64: F16h_M30h detected (node 0).
[    5.439080] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.473622] EDAC amd64: F16h_M30h detected (node 0).
[    5.473662] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.513565] EDAC amd64: F16h_M30h detected (node 0).
[    5.513604] EDAC amd64: Node 0: DRAM ECC disabled.
[    6.155507] input: BRLTTY 6.3 Linux Screen Driver Keyboard as /devices/virtua        l/input/input11
[    6.658995] r8169 0000:04:00.0: firmware: failed to load rtl_nic/rtl8168h-2.f        w (-2)
[    6.659062] firmware_class: See https://wiki.debian.org/Firmware for informat        ion about missing firmware
[    6.659116] r8169 0000:04:00.0: Direct firmware load for rtl_nic/rtl8168h-2.f        w failed with error -2
[    6.659125] r8169 0000:04:00.0: Unable to load firmware rtl_nic/rtl8168h-2.fw        (-2)
[    6.685363] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver [Ge        neric FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-400:00, irq=IGNORE)
[    6.809212] r8169 0000:04:00.0 enp4s0: Link is Down
[    6.924405] usb 2-1: usbfs: interface 0 claimed by ftdi_sio while 'brltty' se        ts config #1
[    6.935749] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnect        ed from ttyUSB0
[    6.935781] ftdi_sio 2-1:1.0: device disconnected
[   10.541594] r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control        rx/tx
[   10.541619] IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
[   13.816550] rfkill: input handler disabled
[   24.174890] rfkill: input handler enabled
[   29.852398] rfkill: input handler disabled
lsusb po odłaczeniu klawiatury
Bus 003 Device 002: ID 0438:7900 Advanced Micro Devices, Inc. Root Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc. Root Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
po wpisaniu w device: 002:002 nie działa, dodam, że przy pierwszej instalacji debiana /dev/ttyUSB0 oscam czytał normalnie kartę, później się coś popieprzyło, tylko nie wiem co, reinstalacja nic nie dała
Re: Wyse 5060 debian 11 brak dostępu do usb0
logi dmesg są ucięte, wklej pełne.
Czy to jest czytnik kart?
walus
Post autor: walus »
Tak, to czytnik kart
root@debian:~# dmesg
[    0.000000] Linux version 5.10.0-12-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP Debian 5.10.103-1 (2022-03-07)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-12-amd64 root=UUID=27ee5140-925e-43cb-b270-ef44c0c585dd ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bba36fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bba37000-0x00000000be936fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000be937000-0x00000000bea56fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bea57000-0x00000000bead6fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bead7000-0x00000000bfbfffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bfc00000-0x00000000bfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fecfffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: WYSE Dell Wyse Thin Client Desktop 5060/0VKXH3, BIOS 1.0E 03/20/2017
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2395.606 MHz processor
[    0.001029] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001034] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001044] last_pfn = 0x11f000 max_arch_pfn = 0x400000000
[    0.001051] MTRR default type: uncachable
[    0.001053] MTRR fixed ranges enabled:
[    0.001056]   00000-9FFFF write-back
[    0.001058]   A0000-BFFFF uncachable
[    0.001061]   C0000-FFFFF write-protect
[    0.001062] MTRR variable ranges enabled:
[    0.001065]   0 base 0000000000 mask FF80000000 write-back
[    0.001068]   1 base 0080000000 mask FFC0000000 write-back
[    0.001070]   2 base 00FF800000 mask FFFF800000 write-protect
[    0.001073]   3 base 00FED80000 mask FFFFFFF000 uncachable
[    0.001074]   4 disabled
[    0.001076]   5 disabled
[    0.001077]   6 disabled
[    0.001078]   7 disabled
[    0.001080] TOM2: 000000011f000000 aka 4592M
[    0.001629] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001798] last_pfn = 0xbfc00 max_arch_pfn = 0x400000000
[    0.009046] Using GB pages for direct mapping
[    0.009949] RAMDISK: [mem 0x33027000-0x3580afff]
[    0.009954] ACPI: Early table checksum verification disabled
[    0.009960] ACPI: RSDP 0x00000000000F0120 000024 (v02 WYSE  )
[    0.009968] ACPI: XSDT 0x00000000BEAD6200 000094 (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.009979] ACPI: FACP 0x00000000BEAD5000 00010C (v05 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.009990] ACPI: DSDT 0x00000000BEACC000 005AF2 (v01 WYSE   AMD      00001000 INTL 20110316)
[    0.009996] ACPI: FACS 0x00000000BEA18000 000040
[    0.010002] ACPI: HPET 0x00000000BEAD4000 000038 (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010009] ACPI: APIC 0x00000000BEAD3000 000090 (v02 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010015] ACPI: MCFG 0x00000000BEAD2000 00003C (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010021] ACPI: FPDT 0x00000000BEACB000 000044 (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010027] ACPI: UEFI 0x00000000BEACA000 000042 (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010033] ACPI: POAT 0x00000000BEA14000 000055 (v03 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010039] ACPI: BATB 0x00000000BEAC9000 000046 (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010045] ACPI: SSDT 0x00000000BEAC8000 000FFC (v01 AMD    AGESA    00000001 AMD  00000001)
[    0.010051] ACPI: SSDT 0x00000000BEAC3000 0048A6 (v02 AMD    AGESA    00000002 MSFT 04000000)
[    0.010058] ACPI: UEFI 0x00000000BEAC2000 00027E (v01 WYSE   WYSEACPI 00000002 PTL  00000002)
[    0.010064] ACPI: SSDT 0x00000000BEAC0000 0013C2 (v01 AMD    CPMDFIGP 00000001 INTL 20110316)
[    0.010070] ACPI: SSDT 0x00000000BEABE000 001138 (v01 AMD    CPMCMN   00000001 INTL 20110316)
[    0.010076] ACPI: SSDT 0x00000000BEABC000 000BD2 (v01 AMD    CPMZPODD 00000001 INTL 20110316)
[    0.010082] ACPI: Reserving FACP table memory at [mem 0xbead5000-0xbead510b]
[    0.010084] ACPI: Reserving DSDT table memory at [mem 0xbeacc000-0xbead1af1]
[    0.010086] ACPI: Reserving FACS table memory at [mem 0xbea18000-0xbea1803f]
[    0.010088] ACPI: Reserving HPET table memory at [mem 0xbead4000-0xbead4037]
[    0.010089] ACPI: Reserving APIC table memory at [mem 0xbead3000-0xbead308f]
[    0.010091] ACPI: Reserving MCFG table memory at [mem 0xbead2000-0xbead203b]
[    0.010093] ACPI: Reserving FPDT table memory at [mem 0xbeacb000-0xbeacb043]
[    0.010094] ACPI: Reserving UEFI table memory at [mem 0xbeaca000-0xbeaca041]
[    0.010096] ACPI: Reserving POAT table memory at [mem 0xbea14000-0xbea14054]
[    0.010097] ACPI: Reserving BATB table memory at [mem 0xbeac9000-0xbeac9045]
[    0.010099] ACPI: Reserving SSDT table memory at [mem 0xbeac8000-0xbeac8ffb]
[    0.010101] ACPI: Reserving SSDT table memory at [mem 0xbeac3000-0xbeac78a5]
[    0.010102] ACPI: Reserving UEFI table memory at [mem 0xbeac2000-0xbeac227d]
[    0.010104] ACPI: Reserving SSDT table memory at [mem 0xbeac0000-0xbeac13c1]
[    0.010106] ACPI: Reserving SSDT table memory at [mem 0xbeabe000-0xbeabf137]
[    0.010107] ACPI: Reserving SSDT table memory at [mem 0xbeabc000-0xbeabcbd1]
[    0.010122] ACPI: Local APIC address 0xfee00000
[    0.010190] No NUMA configuration found
[    0.010192] Faking a node at [mem 0x0000000000000000-0x000000011effffff]
[    0.010211] NODE_DATA(0) allocated [mem 0x11efd6000-0x11effffff]
[    0.011003] Zone ranges:
[    0.011005]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.011008]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.011011]   Normal   [mem 0x0000000100000000-0x000000011effffff]
[    0.011014]   Device   empty
[    0.011016] Movable zone start for each node
[    0.011020] Early memory node ranges
[    0.011022]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.011024]   node   0: [mem 0x0000000000100000-0x00000000bba36fff]
[    0.011026]   node   0: [mem 0x00000000bead7000-0x00000000bfbfffff]
[    0.011028]   node   0: [mem 0x0000000100000000-0x000000011effffff]
[    0.011031] Initmem setup node 0 [mem 0x0000000000001000-0x000000011effffff]
[    0.011034] On node 0 totalpages: 899837
[    0.011036]   DMA zone: 64 pages used for memmap
[    0.011038]   DMA zone: 21 pages reserved
[    0.011039]   DMA zone: 3997 pages, LIFO batch:0
[    0.011041]   DMA32 zone: 12014 pages used for memmap
[    0.011043]   DMA32 zone: 768864 pages, LIFO batch:63
[    0.011044]   Normal zone: 1984 pages used for memmap
[    0.011046]   Normal zone: 126976 pages, LIFO batch:31
[    0.011052] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.011125] On node 0, zone DMA: 98 pages in unavailable ranges
[    0.026556] On node 0, zone DMA32: 12448 pages in unavailable ranges
[    0.027249] On node 0, zone Normal: 1024 pages in unavailable ranges
[    0.027350] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.027547] ACPI: PM-Timer IO Port: 0x808
[    0.027552] ACPI: Local APIC address 0xfee00000
[    0.027563] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.027565] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.027566] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.027567] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.027579] IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
[    0.027584] IOAPIC[1]: apic_id 5, version 33, address 0xfec01000, GSI 24-55
[    0.027588] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.027591] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.027593] ACPI: IRQ0 used by override.
[    0.027595] ACPI: IRQ9 used by override.
[    0.027598] Using ACPI (MADT) for SMP configuration information
[    0.027601] ACPI: HPET id: 0x43538210 base: 0xfed00000
[    0.027611] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.027641] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.027644] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.027646] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.027647] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.027650] PM: hibernation: Registered nosave memory: [mem 0xbba37000-0xbe936fff]
[    0.027651] PM: hibernation: Registered nosave memory: [mem 0xbe937000-0xbea56fff]
[    0.027653] PM: hibernation: Registered nosave memory: [mem 0xbea57000-0xbead6fff]
[    0.027655] PM: hibernation: Registered nosave memory: [mem 0xbfc00000-0xbfffffff]
[    0.027657] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xfebfffff]
[    0.027658] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfecfffff]
[    0.027659] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed7ffff]
[    0.027660] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
[    0.027662] PM: hibernation: Registered nosave memory: [mem 0xfed81000-0xff7fffff]
[    0.027663] PM: hibernation: Registered nosave memory: [mem 0xff800000-0xffffffff]
[    0.027666] [mem 0xc0000000-0xfebfffff] available for PCI devices
[    0.027667] Booting paravirtualized kernel on bare hardware
[    0.027672] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.033918] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.034547] percpu: Embedded 58 pages/cpu s200536 r8192 d28840 u524288
[    0.034567] pcpu-alloc: s200536 r8192 d28840 u524288 alloc=1*2097152
[    0.034569] pcpu-alloc: [0] 0 1 2 3
[    0.034629] Built 1 zonelists, mobility grouping on.  Total pages: 885754
[    0.034630] Policy zone: Normal
[    0.034633] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-12-amd64 root=UUID=27ee5140-925e-43cb-b270-ef44c0c585dd ro quiet
[    0.035842] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.036402] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.036450] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.076569] Memory: 3080920K/3599348K available (12295K kernel code, 2545K rwdata, 7568K rodata, 2412K init, 3680K bss, 206376K reserved, 0K cma-reserved)
[    0.076585] random: get_random_u64 called from __kmem_cache_create+0x2a/0x4d0 with crng_init=0
[    0.076809] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.076833] ftrace: allocating 36451 entries in 143 pages
[    0.094865] ftrace: allocated 143 pages with 5 groups
[    0.095105] rcu: Hierarchical RCU implementation.
[    0.095107] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[    0.095109] 	Rude variant of Tasks RCU enabled.
[    0.095110] 	Tracing variant of Tasks RCU enabled.
[    0.095111] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.095113] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.103079] NR_IRQS: 524544, nr_irqs: 1000, preallocated irqs: 16
[    0.103543] random: crng done (trusting CPU's manufacturer)
[    0.103577] spurious 8259A interrupt: IRQ7.
[    0.105702] Console: colour VGA+ 80x25
[    0.105725] printk: console [tty0] enabled
[    0.105755] ACPI: Core revision 20200925
[    0.105946] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.105966] APIC: Switch to symmetric I/O mode setup
[    0.106527] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.125965] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2288006d0e8, max_idle_ns: 440795226336 ns
[    0.125973] Calibrating delay loop (skipped), value calculated using timer frequency.. 4791.21 BogoMIPS (lpj=9582424)
[    0.125977] pid_max: default: 32768 minimum: 301
[    0.126022] LSM: Security Framework initializing
[    0.126040] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.126089] AppArmor: AppArmor initialized
[    0.126093] TOMOYO Linux initialized
[    0.126134] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.126153] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.126570] BIOS may not properly restore RDRAND after suspend, hiding RDRAND via CPUID. Use rdrand=force to reenable.
[    0.126590] LVT offset 1 assigned for vector 0xf9
[    0.126596] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 4
[    0.126597] Last level dTLB entries: 4KB 512, 2MB 256, 4MB 128, 1GB 0
[    0.126602] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.126604] Spectre V2 : Mitigation: Retpolines
[    0.126606] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.126608] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.126776] Freeing SMP alternatives memory: 32K
[    0.242137] smpboot: CPU0: AMD GX-424CC SOC with Radeon(TM) R5E Graphics (family: 0x16, model: 0x30, stepping: 0x1)
[    0.242509] Performance Events: AMD PMU driver.
[    0.242516] ... version:                0
[    0.242517] ... bit width:              48
[    0.242518] ... generic registers:      4
[    0.242520] ... value mask:             0000ffffffffffff
[    0.242521] ... max period:             00007fffffffffff
[    0.242522] ... fixed-purpose events:   0
[    0.242523] ... event mask:             000000000000000f
[    0.242653] rcu: Hierarchical SRCU implementation.
[    0.243237] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.243364] smp: Bringing up secondary CPUs ...
[    0.243583] x86: Booting SMP configuration:
[    0.243585] .... node  #0, CPUs:      #1
[    0.245968] TSC synchronization [CPU#0 -> CPU#1]:
[    0.245968] Measured 79442144 cycles TSC warp between CPUs, turning off TSC clock.
[    0.245968] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[    0.246228]  #2 #3
[    0.246443] smp: Brought up 1 node, 4 CPUs
[    0.246443] smpboot: Max logical packages: 1
[    0.246443] smpboot: Total of 4 processors activated (19164.84 BogoMIPS)
[    0.247410] node 0 deferred pages initialised in 0ms
[    0.250054] devtmpfs: initialized
[    0.250060] x86/mm: Memory block size: 128MB
[    0.250791] PM: Registering ACPI NVS region [mem 0xbe937000-0xbea56fff] (1179648 bytes)
[    0.250791] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.250791] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.250791] pinctrl core: initialized pinctrl subsystem
[    0.250791] NET: Registered protocol family 16
[    0.250791] audit: initializing netlink subsys (disabled)
[    0.250794] audit: type=2000 audit(1647445347.144:1): state=initialized audit_enabled=0 res=1
[    0.250794] thermal_sys: Registered thermal governor 'fair_share'
[    0.250794] thermal_sys: Registered thermal governor 'bang_bang'
[    0.250794] thermal_sys: Registered thermal governor 'step_wise'
[    0.250794] thermal_sys: Registered thermal governor 'user_space'
[    0.250794] thermal_sys: Registered thermal governor 'power_allocator'
[    0.250794] cpuidle: using governor ladder
[    0.250794] cpuidle: using governor menu
[    0.250794] ACPI: bus type PCI registered
[    0.250794] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.250794] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.250794] PCI: not using MMCONFIG
[    0.250794] PCI: Using configuration type 1 for base access
[    0.250794] PCI: Using configuration type 1 for extended access
[    0.250794] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.250794] mtrr: probably your BIOS does not setup all CPUs.
[    0.250794] mtrr: corrected configuration.
[    0.254344] Kprobes globally optimized
[    0.254351] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.254351] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.550140] ACPI: Added _OSI(Module Device)
[    0.550143] ACPI: Added _OSI(Processor Device)
[    0.550145] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.550146] ACPI: Added _OSI(Processor Aggregator Device)
[    0.550149] ACPI: Added _OSI(Linux-Dell-Video)
[    0.550151] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.550152] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.562356] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.564408] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.567149] ACPI: Interpreter enabled
[    0.567177] ACPI: (supports S0 S3 S4 S5)
[    0.567180] ACPI: Using IOAPIC for interrupt routing
[    0.567410] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.567990] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources
[    0.568004] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.568465] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.579860] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.579870] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.580140] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[    0.580394] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.580410] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.581280] acpi PNP0A08:00: ignoring host bridge window [mem 0x000ce000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000ce7ff])
[    0.581556] pci 0000:00:00.0: [1022:1566] type 00 class 0x060000
[    0.581684] pci 0000:00:01.0: [1002:9851] type 00 class 0x030000
[    0.581699] pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.581709] pci 0000:00:01.0: reg 0x18: [mem 0xf0000000-0xf07fffff 64bit pref]
[    0.581715] pci 0000:00:01.0: reg 0x20: [io  0x3000-0x30ff]
[    0.581722] pci 0000:00:01.0: reg 0x24: [mem 0xf0d00000-0xf0d3ffff]
[    0.581728] pci 0000:00:01.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[    0.581735] pci 0000:00:01.0: enabling Extended Tags
[    0.581781] pci 0000:00:01.0: supports D1 D2
[    0.581783] pci 0000:00:01.0: PME# supported from D1 D2 D3hot
[    0.581925] pci 0000:00:01.1: [1002:9840] type 00 class 0x040300
[    0.581938] pci 0000:00:01.1: reg 0x10: [mem 0xf0d60000-0xf0d63fff 64bit]
[    0.581964] pci 0000:00:01.1: enabling Extended Tags
[    0.582004] pci 0000:00:01.1: supports D1 D2
[    0.582099] pci 0000:00:02.0: [1022:156b] type 00 class 0x060000
[    0.582206] pci 0000:00:02.1: [1022:1439] type 01 class 0x060400
[    0.582237] pci 0000:00:02.1: enabling Extended Tags
[    0.582313] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[    0.582412] pci 0000:00:02.2: [1022:1439] type 01 class 0x060400
[    0.582444] pci 0000:00:02.2: enabling Extended Tags
[    0.582515] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[    0.582612] pci 0000:00:02.3: [1022:1439] type 01 class 0x060400
[    0.582644] pci 0000:00:02.3: enabling Extended Tags
[    0.582715] pci 0000:00:02.3: PME# supported from D0 D3hot D3cold
[    0.582812] pci 0000:00:02.4: [1022:1439] type 01 class 0x060400
[    0.582843] pci 0000:00:02.4: enabling Extended Tags
[    0.582914] pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
[    0.583021] pci 0000:00:02.5: [1022:1439] type 01 class 0x060400
[    0.583053] pci 0000:00:02.5: enabling Extended Tags
[    0.583125] pci 0000:00:02.5: PME# supported from D0 D3hot D3cold
[    0.583227] pci 0000:00:08.0: [1022:1537] type 00 class 0x108000
[    0.583238] pci 0000:00:08.0: reg 0x10: [mem 0xf0d40000-0xf0d5ffff 64bit pref]
[    0.583244] pci 0000:00:08.0: reg 0x18: [mem 0xf0a00000-0xf0afffff]
[    0.583250] pci 0000:00:08.0: reg 0x1c: [mem 0xf0d6c000-0xf0d6cfff]
[    0.583259] pci 0000:00:08.0: reg 0x24: [mem 0xf0d6a000-0xf0d6bfff]
[    0.583380] pci 0000:00:10.0: [1022:7814] type 00 class 0x0c0330
[    0.583401] pci 0000:00:10.0: reg 0x10: [mem 0xf0d68000-0xf0d69fff 64bit]
[    0.583499] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[    0.583638] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[    0.583652] pci 0000:00:11.0: reg 0x10: [io  0x3118-0x311f]
[    0.583661] pci 0000:00:11.0: reg 0x14: [io  0x3124-0x3127]
[    0.583669] pci 0000:00:11.0: reg 0x18: [io  0x3110-0x3117]
[    0.583677] pci 0000:00:11.0: reg 0x1c: [io  0x3120-0x3123]
[    0.583685] pci 0000:00:11.0: reg 0x20: [io  0x3100-0x310f]
[    0.583693] pci 0000:00:11.0: reg 0x24: [mem 0xf0d6d000-0xf0d6d3ff]
[    0.583735] pci 0000:00:11.0: PME# supported from D3hot
[    0.583932] pci 0000:00:12.0: [1022:7808] type 00 class 0x0c0320
[    0.583946] pci 0000:00:12.0: reg 0x10: [mem 0xf0d6d500-0xf0d6d5ff]
[    0.584012] pci 0000:00:12.0: supports D1 D2
[    0.584014] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.584129] pci 0000:00:13.0: [1022:7808] type 00 class 0x0c0320
[    0.584143] pci 0000:00:13.0: reg 0x10: [mem 0xf0d6d400-0xf0d6d4ff]
[    0.584207] pci 0000:00:13.0: supports D1 D2
[    0.584209] pci 0000:00:13.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.584317] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[    0.584482] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[    0.584499] pci 0000:00:14.2: reg 0x10: [mem 0xf0d64000-0xf0d67fff 64bit]
[    0.584554] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    0.584669] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[    0.584828] pci 0000:00:18.0: [1022:1580] type 00 class 0x060000
[    0.584920] pci 0000:00:18.1: [1022:1581] type 00 class 0x060000
[    0.585014] pci 0000:00:18.2: [1022:1582] type 00 class 0x060000
[    0.585103] pci 0000:00:18.3: [1022:1583] type 00 class 0x060000
[    0.585199] pci 0000:00:18.4: [1022:1584] type 00 class 0x060000
[    0.585295] pci 0000:00:18.5: [1022:1585] type 00 class 0x060000
[    0.585470] pci 0000:00:02.1: PCI bridge to [bus 01]
[    0.585578] pci 0000:00:02.2: PCI bridge to [bus 02-03]
[    0.585584] pci 0000:00:02.2:   bridge window [io  0x2000-0x2fff]
[    0.585587] pci 0000:00:02.2:   bridge window [mem 0xf0c00000-0xf0cfffff]
[    0.585592] pci 0000:00:02.2:   bridge window [mem 0xf0800000-0xf08fffff 64bit pref]
[    0.585721] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[    0.585740] pci 0000:04:00.0: reg 0x10: [io  0x1000-0x10ff]
[    0.585765] pci 0000:04:00.0: reg 0x18: [mem 0xf0b04000-0xf0b04fff 64bit]
[    0.585781] pci 0000:04:00.0: reg 0x20: [mem 0xf0b00000-0xf0b03fff 64bit]
[    0.585885] pci 0000:04:00.0: supports D1 D2
[    0.585887] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.586075] pci 0000:00:02.3: PCI bridge to [bus 04]
[    0.586080] pci 0000:00:02.3:   bridge window [io  0x1000-0x1fff]
[    0.586084] pci 0000:00:02.3:   bridge window [mem 0xf0b00000-0xf0bfffff]
[    0.586193] pci 0000:00:02.4: PCI bridge to [bus 05]
[    0.586303] pci 0000:00:02.5: PCI bridge to [bus 06]
[    0.587023] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587127] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587246] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587364] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587464] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587550] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587637] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.587723] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.588399] iommu: Default domain type: Translated
[    0.588434] pci 0000:00:01.0: vgaarb: setting as boot VGA device
[    0.588434] pci 0000:00:01.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.588434] pci 0000:00:01.0: vgaarb: bridge control possible
[    0.588434] vgaarb: loaded
[    0.588434] EDAC MC: Ver: 3.0.0
[    0.588434] NetLabel: Initializing
[    0.588434] NetLabel:  domain hash size = 128
[    0.588434] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.588434] NetLabel:  unlabeled traffic allowed by default
[    0.588434] PCI: Using ACPI for IRQ routing
[    0.590651] PCI: pci_cache_line_size set to 64 bytes
[    0.590726] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.590728] e820: reserve RAM buffer [mem 0xbba37000-0xbbffffff]
[    0.590730] e820: reserve RAM buffer [mem 0xbfc00000-0xbfffffff]
[    0.590732] e820: reserve RAM buffer [mem 0x11f000000-0x11fffffff]
[    0.590772] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.590778] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.592858] clocksource: Switched to clocksource hpet
[    0.611786] VFS: Disk quotas dquot_6.6.0
[    0.611817] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.612051] AppArmor: AppArmor Filesystem Enabled
[    0.612086] pnp: PnP ACPI init
[    0.612336] system 00:00: [io  0x0f50-0x0f51] has been reserved
[    0.612341] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[    0.612344] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.612347] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.612359] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613156] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.613278] system 00:02: [io  0x04d0-0x04d1] has been reserved
[    0.613282] system 00:02: [io  0x0530-0x0537] has been reserved
[    0.613284] system 00:02: [io  0x0800-0x0827] has been reserved
[    0.613287] system 00:02: [io  0x0830] has been reserved
[    0.613289] system 00:02: [io  0x0840-0x0847] has been reserved
[    0.613292] system 00:02: [io  0x0b00-0x0b1f] has been reserved
[    0.613294] system 00:02: [io  0x0b20-0x0b3f] has been reserved
[    0.613297] system 00:02: [io  0x0c00-0x0c01] has been reserved
[    0.613299] system 00:02: [io  0x0c14] has been reserved
[    0.613301] system 00:02: [io  0x0c50-0x0c52] has been reserved
[    0.613304] system 00:02: [io  0x0cd0-0x0cd1] has been reserved
[    0.613306] system 00:02: [io  0x0cd2-0x0cd3] has been reserved
[    0.613309] system 00:02: [io  0x0cd4-0x0cd5] has been reserved
[    0.613311] system 00:02: [io  0x0cd6-0x0cd7] has been reserved
[    0.613314] system 00:02: [io  0x0cd8-0x0cdf] has been reserved
[    0.613316] system 00:02: [io  0x0cf9] could not be reserved
[    0.613319] system 00:02: [io  0x8100-0x81ff window] has been reserved
[    0.613322] system 00:02: [io  0x8200-0x82ff window] has been reserved
[    0.613329] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.613463] system 00:03: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.613466] system 00:03: [mem 0xff800000-0xffffffff] has been reserved
[    0.613469] system 00:03: [mem 0xfec10000-0xfec1001f] has been reserved
[    0.613471] system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
[    0.613474] system 00:03: [mem 0xfed61000-0xfed613ff] has been reserved
[    0.613477] system 00:03: [mem 0xfed80000-0xfed80fff] has been reserved
[    0.613484] system 00:03: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.613701] pnp: PnP ACPI: found 4 devices
[    0.621346] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.621493] NET: Registered protocol family 2
[    0.621656] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.623029] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.623115] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.623324] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.623402] TCP: Hash tables configured (established 32768 bind 32768)
[    0.623513] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.623548] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.623640] NET: Registered protocol family 1
[    0.623650] NET: Registered protocol family 44
[    0.623667] pci 0000:00:01.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
[    0.623685] pci 0000:00:02.1: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    0.623690] pci 0000:00:02.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    0.623693] pci 0000:00:02.1: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[    0.623698] pci 0000:00:02.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
[    0.623701] pci 0000:00:02.4: bridge window [io  0x1000-0x0fff] to [bus 05] add_size 1000
[    0.623704] pci 0000:00:02.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
[    0.623707] pci 0000:00:02.4: bridge window [mem 0x00100000-0x000fffff] to [bus 05] add_size 200000 add_align 100000
[    0.623710] pci 0000:00:02.5: bridge window [io  0x1000-0x0fff] to [bus 06] add_size 1000
[    0.623713] pci 0000:00:02.5: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 06] add_size 200000 add_align 100000
[    0.623715] pci 0000:00:02.5: bridge window [mem 0x00100000-0x000fffff] to [bus 06] add_size 200000 add_align 100000
[    0.623744] pci 0000:00:02.1: BAR 14: assigned [mem 0xf0e00000-0xf0ffffff]
[    0.623769] pci 0000:00:02.1: BAR 15: assigned [mem 0xf1000000-0xf11fffff 64bit pref]
[    0.623792] pci 0000:00:02.3: BAR 15: assigned [mem 0xf1200000-0xf13fffff 64bit pref]
[    0.623802] pci 0000:00:02.4: BAR 14: assigned [mem 0xf1400000-0xf15fffff]
[    0.623824] pci 0000:00:02.4: BAR 15: assigned [mem 0xf1600000-0xf17fffff 64bit pref]
[    0.623834] pci 0000:00:02.5: BAR 14: assigned [mem 0xf1800000-0xf19fffff]
[    0.623857] pci 0000:00:02.5: BAR 15: assigned [mem 0xf1a00000-0xf1bfffff 64bit pref]
[    0.623868] pci 0000:00:01.0: BAR 6: assigned [mem 0xf0900000-0xf091ffff pref]
[    0.623876] pci 0000:00:02.1: BAR 13: assigned [io  0x4000-0x4fff]
[    0.623882] pci 0000:00:02.4: BAR 13: assigned [io  0x5000-0x5fff]
[    0.623887] pci 0000:00:02.5: BAR 13: assigned [io  0x6000-0x6fff]
[    0.623893] pci 0000:00:02.1: PCI bridge to [bus 01]
[    0.623897] pci 0000:00:02.1:   bridge window [io  0x4000-0x4fff]
[    0.623902] pci 0000:00:02.1:   bridge window [mem 0xf0e00000-0xf0ffffff]
[    0.623906] pci 0000:00:02.1:   bridge window [mem 0xf1000000-0xf11fffff 64bit pref]
[    0.623911] pci 0000:00:02.2: PCI bridge to [bus 02-03]
[    0.623913] pci 0000:00:02.2:   bridge window [io  0x2000-0x2fff]
[    0.623917] pci 0000:00:02.2:   bridge window [mem 0xf0c00000-0xf0cfffff]
[    0.623920] pci 0000:00:02.2:   bridge window [mem 0xf0800000-0xf08fffff 64bit pref]
[    0.623925] pci 0000:00:02.3: PCI bridge to [bus 04]
[    0.623928] pci 0000:00:02.3:   bridge window [io  0x1000-0x1fff]
[    0.623932] pci 0000:00:02.3:   bridge window [mem 0xf0b00000-0xf0bfffff]
[    0.623935] pci 0000:00:02.3:   bridge window [mem 0xf1200000-0xf13fffff 64bit pref]
[    0.623940] pci 0000:00:02.4: PCI bridge to [bus 05]
[    0.623942] pci 0000:00:02.4:   bridge window [io  0x5000-0x5fff]
[    0.623946] pci 0000:00:02.4:   bridge window [mem 0xf1400000-0xf15fffff]
[    0.623949] pci 0000:00:02.4:   bridge window [mem 0xf1600000-0xf17fffff 64bit pref]
[    0.623954] pci 0000:00:02.5: PCI bridge to [bus 06]
[    0.623957] pci 0000:00:02.5:   bridge window [io  0x6000-0x6fff]
[    0.623960] pci 0000:00:02.5:   bridge window [mem 0xf1800000-0xf19fffff]
[    0.623964] pci 0000:00:02.5:   bridge window [mem 0xf1a00000-0xf1bfffff 64bit pref]
[    0.624026] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.624028] pci_bus 0000:01: resource 1 [mem 0xf0e00000-0xf0ffffff]
[    0.624030] pci_bus 0000:01: resource 2 [mem 0xf1000000-0xf11fffff 64bit pref]
[    0.624032] pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
[    0.624034] pci_bus 0000:02: resource 1 [mem 0xf0c00000-0xf0cfffff]
[    0.624036] pci_bus 0000:02: resource 2 [mem 0xf0800000-0xf08fffff 64bit pref]
[    0.624038] pci_bus 0000:04: resource 0 [io  0x1000-0x1fff]
[    0.624040] pci_bus 0000:04: resource 1 [mem 0xf0b00000-0xf0bfffff]
[    0.624042] pci_bus 0000:04: resource 2 [mem 0xf1200000-0xf13fffff 64bit pref]
[    0.624044] pci_bus 0000:05: resource 0 [io  0x5000-0x5fff]
[    0.624045] pci_bus 0000:05: resource 1 [mem 0xf1400000-0xf15fffff]
[    0.624047] pci_bus 0000:05: resource 2 [mem 0xf1600000-0xf17fffff 64bit pref]
[    0.624050] pci_bus 0000:06: resource 0 [io  0x6000-0x6fff]
[    0.624051] pci_bus 0000:06: resource 1 [mem 0xf1800000-0xf19fffff]
[    0.624053] pci_bus 0000:06: resource 2 [mem 0xf1a00000-0xf1bfffff 64bit pref]
[    0.624180] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.624232] pci 0000:00:01.1: D0 power state depends on 0000:00:01.0
[    0.625080] pci 0000:00:12.0: PME# does not work under D3, disabling it
[    0.625410] pci 0000:00:13.0: PME# does not work under D3, disabling it
[    0.625445] PCI: CLS 32 bytes, default 64
[    0.625542] Trying to unpack rootfs image as initramfs...
[    1.616206] Freeing initrd memory: 40848K
[    1.616215] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.616218] software IO TLB: mapped [mem 0x00000000b7a37000-0x00000000bba37000] (64MB)
[    1.616280] amd_uncore: 4  amd_nb counters detected
[    1.616285] amd_uncore: 4  amd_l2 counters detected
[    1.616532] LVT offset 0 assigned for vector 0x400
[    1.616597] perf: AMD IBS detected (0x000000ff)
[    1.617291] Initialise system trusted keyrings
[    1.617309] Key type blacklist registered
[    1.617463] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[    1.619388] zbud: loaded
[    1.619725] integrity: Platform Keyring initialized
[    1.619729] Key type asymmetric registered
[    1.619731] Asymmetric key parser 'x509' registered
[    1.619744] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.619828] io scheduler mq-deadline registered
[    1.620379] pcieport 0000:00:02.1: PME: Signaling with IRQ 25
[    1.620423] pcieport 0000:00:02.1: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.620866] pcieport 0000:00:02.2: PME: Signaling with IRQ 27
[    1.620906] pcieport 0000:00:02.2: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.621299] pcieport 0000:00:02.3: PME: Signaling with IRQ 29
[    1.621343] pcieport 0000:00:02.3: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.621730] pcieport 0000:00:02.4: PME: Signaling with IRQ 31
[    1.621774] pcieport 0000:00:02.4: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.622195] pcieport 0000:00:02.5: PME: Signaling with IRQ 32
[    1.622235] pcieport 0000:00:02.5: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[    1.622471] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.622531] ACPI: \_PR_.C000: Found 2 idle states
[    1.622665] ACPI: \_PR_.C001: Found 2 idle states
[    1.622781] ACPI: \_PR_.C002: Found 2 idle states
[    1.622905] ACPI: \_PR_.C003: Found 2 idle states
[    1.623333] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.624038] Linux agpgart interface v0.103
[    1.624312] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    1.624710] i8042: PNP: No PS/2 controller found.
[    1.624811] mousedev: PS/2 mouse device common for all mice
[    1.624863] rtc_cmos 00:01: RTC can wake from S4
[    1.625073] rtc_cmos 00:01: registered as rtc0
[    1.625118] rtc_cmos 00:01: setting system clock to 2022-03-16T15:42:29 UTC (1647445349)
[    1.625158] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[    1.625253] ledtrig-cpu: registered to indicate activity on CPUs
[    1.625729] NET: Registered protocol family 10
[    1.638639] Segment Routing with IPv6
[    1.638684] mip6: Mobile IPv6
[    1.638687] NET: Registered protocol family 17
[    1.638781] mpls_gso: MPLS GSO support
[    1.638786] x86/pm: family 0x16 cpu detected, MSR saving is needed during suspending.
[    1.639174] microcode: CPU0: patch_level=0x07030105
[    1.639187] microcode: CPU1: patch_level=0x07030105
[    1.639198] microcode: CPU2: patch_level=0x07030105
[    1.639204] microcode: CPU3: patch_level=0x07030105
[    1.639209] microcode: Microcode Update Driver: v2.2.
[    1.639217] IPI shorthand broadcast: enabled
[    1.639342] registered taskstats version 1
[    1.639348] Loading compiled-in X.509 certificates
[    1.706650] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.706676] Loaded X.509 cert 'Debian Secure Boot Signer 2021 - linux: 4b6ef5abca669825178e052c84667ccbc0531f8c'
[    1.706725] zswap: loaded using pool lzo/zbud
[    1.707018] Key type ._fscrypt registered
[    1.707020] Key type .fscrypt registered
[    1.707021] Key type fscrypt-provisioning registered
[    1.707078] AppArmor: AppArmor sha1 policy hashing enabled
[    1.707827] Unstable clock detected, switching default tracing clock to "global"
               If you want to keep using the local clock, then add:
                 "trace_clock=local"
               on the kernel command line
[    1.710117] Freeing unused kernel image (initmem) memory: 2412K
[    1.742176] Write protecting the kernel read-only data: 22528k
[    1.743027] Freeing unused kernel image (text/rodata gap) memory: 2040K
[    1.743359] Freeing unused kernel image (rodata/data gap) memory: 624K
[    1.816502] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.816513] Run /init as init process
[    1.816516]   with arguments:
[    1.816517]     /init
[    1.816518]   with environment:
[    1.816519]     HOME=/
[    1.816520]     TERM=linux
[    1.816522]     BOOT_IMAGE=/boot/vmlinuz-5.10.0-12-amd64
[    1.918826] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    1.918884] ACPI: Power Button [PWRB]
[    1.919017] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    1.924517] ACPI: Video Device [VGA1] (multi-head: yes  rom: no  post: no)
[    1.925001] acpi device:3a: registered as cooling_device4
[    1.925085] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input2
[    1.934115] ACPI: Power Button [PWRF]
[    1.963917] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\_SB.PCI0.SMB.SMB0) (20200925/utaddress-204)
[    1.963934] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    1.992007] SCSI subsystem initialized
[    1.999936] r8169 0000:04:00.0 eth0: RTL8168h/8111h, 84:7b:eb:f2:24:fb, XID 541, IRQ 34
[    1.999943] r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    2.012948] ACPI: bus type USB registered
[    2.013005] usbcore: registered new interface driver usbfs
[    2.013025] usbcore: registered new interface driver hub
[    2.013052] usbcore: registered new device driver usb
[    2.021681] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.023060] ehci-pci: EHCI PCI platform driver
[    2.023418] ehci-pci 0000:00:12.0: EHCI Host Controller
[    2.023431] ehci-pci 0000:00:12.0: new USB bus registered, assigned bus number 1
[    2.023440] ehci-pci 0000:00:12.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    2.023449] ehci-pci 0000:00:12.0: debug port 2
[    2.023518] ehci-pci 0000:00:12.0: irq 18, io mem 0xf0d6d500
[    2.025829] r8169 0000:04:00.0 enp4s0: renamed from eth0
[    2.026847] libata version 3.00 loaded.
[    2.035635] ahci 0000:00:11.0: version 3.0
[    2.036037] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    2.036043] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp fbs pio slum part
[    2.037802] scsi host0: ahci
[    2.038134] ata1: SATA max UDMA/133 abar m1024@0xf0d6d000 port 0xf0d6d100 irq 35
[    2.039113] ehci-pci 0000:00:12.0: USB 2.0 started, EHCI 1.00
[    2.039328] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.039332] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.039334] usb usb1: Product: EHCI Host Controller
[    2.039336] usb usb1: Manufacturer: Linux 5.10.0-12-amd64 ehci_hcd
[    2.039339] usb usb1: SerialNumber: 0000:00:12.0
[    2.039577] hub 1-0:1.0: USB hub found
[    2.039597] hub 1-0:1.0: 2 ports detected
[    2.039862] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    2.039874] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[    2.040057] xhci_hcd 0000:00:10.0: hcc params 0x014040c3 hci version 0x100 quirks 0x0000000000000410
[    2.040433] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.040436] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.040438] usb usb2: Product: xHCI Host Controller
[    2.040440] usb usb2: Manufacturer: Linux 5.10.0-12-amd64 xhci-hcd
[    2.040442] usb usb2: SerialNumber: 0000:00:10.0
[    2.040616] hub 2-0:1.0: USB hub found
[    2.040632] hub 2-0:1.0: 2 ports detected
[    2.040832] ehci-pci 0000:00:13.0: EHCI Host Controller
[    2.040840] ehci-pci 0000:00:13.0: new USB bus registered, assigned bus number 3
[    2.040847] ehci-pci 0000:00:13.0: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    2.040858] ehci-pci 0000:00:13.0: debug port 2
[    2.040861] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    2.040866] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[    2.040883] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[    2.040904] ehci-pci 0000:00:13.0: irq 18, io mem 0xf0d6d400
[    2.043464] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.043510] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    2.043512] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.043514] usb usb4: Product: xHCI Host Controller
[    2.043516] usb usb4: Manufacturer: Linux 5.10.0-12-amd64 xhci-hcd
[    2.043517] usb usb4: SerialNumber: 0000:00:10.0
[    2.043704] hub 4-0:1.0: USB hub found
[    2.043718] hub 4-0:1.0: 2 ports detected
[    2.058017] ehci-pci 0000:00:13.0: USB 2.0 started, EHCI 1.00
[    2.058215] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.058218] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.058220] usb usb3: Product: EHCI Host Controller
[    2.058222] usb usb3: Manufacturer: Linux 5.10.0-12-amd64 ehci_hcd
[    2.058223] usb usb3: SerialNumber: 0000:00:13.0
[    2.058451] hub 3-0:1.0: USB hub found
[    2.058475] hub 3-0:1.0: 2 ports detected
[    2.131737] [drm] radeon kernel modesetting enabled.
[    2.131884] [drm:radeon_pci_probe [radeon]] *ERROR* radeon kernel modesetting for R600 or later requires firmware installed
[    2.131932] See https://wiki.debian.org/Firmware for information about missing firmware
[    2.294053] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    2.294056] usb 2-2: new full-speed USB device number 2 using xhci_hcd
[    2.338038] usb 3-1: new high-speed USB device number 2 using ehci-pci
[    2.450497] usb 1-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
[    2.450505] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.450918] hub 1-1:1.0: USB hub found
[    2.450984] hub 1-1:1.0: 4 ports detected
[    2.494385] usb 3-1: New USB device found, idVendor=0438, idProduct=7900, bcdDevice= 0.18
[    2.494390] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.494497] usb 2-2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[    2.494500] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.494502] usb 2-2: Product: FT232R USB UART
[    2.494504] usb 2-2: Manufacturer: FTDI
[    2.494506] usb 2-2: SerialNumber: AC023DYR
[    2.494800] hub 3-1:1.0: USB hub found
[    2.494869] hub 3-1:1.0: 4 ports detected
[    2.514033] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.514210] ata1.00: ATA-9: 8GB SATA Flash Drive, SFDN0B2A, max UDMA/133
[    2.514212] ata1.00: 15649200 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.514379] ata1.00: configured for UDMA/133
[    2.514667] scsi 0:0:0:0: Direct-Access     ATA      8GB SATA Flash D 0B2A PQ: 0 ANSI: 5
[    2.535034] sd 0:0:0:0: [sda] 15649200 512-byte logical blocks: (8.01 GB/7.46 GiB)
[    2.535064] sd 0:0:0:0: [sda] Write Protect is off
[    2.535067] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.535113] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.782019] usb 3-1.3: new low-speed USB device number 3 using ehci-pci
[    2.823384]  sda: sda1 sda2 < sda5 >
[    2.896354] usb 3-1.3: New USB device found, idVendor=046d, idProduct=c312, bcdDevice= 1.01
[    2.896360] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.896363] usb 3-1.3: Product: USB Multimedia Keyboard
[    2.896364] usb 3-1.3: Manufacturer: LITEON Technology
[    2.917176] hid: raw HID events driver (C) Jiri Kosina
[    2.922506] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.933258] [drm] amdgpu kernel modesetting enabled.
[    2.933450] CRAT table not found
[    2.933456] Virtual CRAT table created for CPU
[    2.933482] amdgpu: Topology: Add CPU node
[    2.933598] amdgpu 0000:00:01.0: amdgpu: CIK support provided by radeon.
[    2.933600] amdgpu 0000:00:01.0: amdgpu: Use radeon.cik_support=0 amdgpu.cik_support=1 to override.
[    2.935465] usbcore: registered new interface driver usbhid
[    2.935468] usbhid: USB HID core driver
[    2.938408] input: LITEON Technology USB Multimedia Keyboard as /devices/pci0000:00/0000:00:13.0/usb3/3-1/3-1.3/3-1.3:1.0/0003:046D:C312.0001/input/input3
[    2.978035] usb 3-1.4: new low-speed USB device number 4 using ehci-pci
[    2.998311] hid-generic 0003:046D:C312.0001: input,hidraw0: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-0000:00:13.0-1.3/input0
[    3.051035] PM: Image not found (code -22)
[    3.098055] usb 3-1.4: New USB device found, idVendor=0458, idProduct=003a, bcdDevice= 1.00
[    3.098060] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.098065] usb 3-1.4: Product: Optical Mouse
[    3.098066] usb 3-1.4: Manufacturer: Genius
[    3.102336] input: Genius Optical Mouse as /devices/pci0000:00/0000:00:13.0/usb3/3-1/3-1.4/3-1.4:1.0/0003:0458:003A.0002/input/input4
[    3.102535] hid-generic 0003:0458:003A.0002: input,hidraw1: USB HID v1.11 Mouse [Genius Optical Mouse] on usb-0000:00:13.0-1.4/input0
[    3.291615] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    3.372579] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[    3.513397] systemd[1]: Inserted module 'autofs4'
[    3.543456] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    3.562408] systemd[1]: Detected architecture x86-64.
[    3.562942] systemd[1]: Set hostname to <debian>.
[    3.617927] systemd-rc-local-generator[212]: /etc/rc.local is not marked executable, skipping.
[    3.802378] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    3.905547] systemd[1]: Finished Load Kernel Modules.
[    3.906600] systemd[1]: Finished Remount Root and Kernel File Systems.
[    3.907021] systemd[1]: Mounted Kernel Configuration File System.
[    3.907256] systemd[1]: Mounted FUSE Control File System.
[    3.908553] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    3.908646] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    3.911113] systemd[1]: Starting Load/Save Random Seed...
[    3.913012] systemd[1]: Starting Apply Kernel Variables...
[    3.915039] systemd[1]: Starting Create System Users...
[    3.953246] systemd[1]: Finished Apply Kernel Variables.
[    3.958990] systemd[1]: Finished Load/Save Random Seed.
[    3.959336] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    3.970707] systemd[1]: Finished Create System Users.
[    3.972687] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.996855] systemd[1]: Finished Create Static Device Nodes in /dev.
[    4.000031] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    4.034049] systemd[1]: Finished Coldplug All udev Devices.
[    4.036143] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    4.037944] systemd[1]: Starting Wait for udev To Complete Device Initialization...
[    4.048423] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    4.056063] systemd[1]: Finished Set the console keyboard layout.
[    4.056320] systemd[1]: Reached target Local File Systems (Pre).
[    4.056365] systemd[1]: Reached target Local File Systems.
[    4.058069] systemd[1]: Starting Load AppArmor profiles...
[    4.059769] systemd[1]: Starting Set console font and keymap...
[    4.061645] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    4.061788] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    4.061914] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    4.072013] systemd[1]: Finished Set console font and keymap.
[    4.080374] systemd[1]: Received SIGRTMIN+20 from PID 158 (plymouthd).
[    4.081708] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    4.091121] systemd[1]: Started Journal Service.
[    4.104775] systemd-journald[228]: Received client request to flush runtime journal.
[    4.120310] systemd-journald[228]: File /var/log/journal/c8cb773e23194a92b3dd426e212502a6/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    4.134744] audit: type=1400 audit(1647445352.008:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=266 comm="apparmor_parser"
[    4.135716] audit: type=1400 audit(1647445352.008:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=264 comm="apparmor_parser"
[    4.135724] audit: type=1400 audit(1647445352.008:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=264 comm="apparmor_parser"
[    4.145296] audit: type=1400 audit(1647445352.016:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=268 comm="apparmor_parser"
[    4.146006] audit: type=1400 audit(1647445352.016:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=269 comm="apparmor_parser"
[    4.152917] audit: type=1400 audit(1647445352.024:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=271 comm="apparmor_parser"
[    4.154655] audit: type=1400 audit(1647445352.028:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=270 comm="apparmor_parser"
[    4.154664] audit: type=1400 audit(1647445352.028:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=270 comm="apparmor_parser"
[    4.154669] audit: type=1400 audit(1647445352.028:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=270 comm="apparmor_parser"
[    4.355526] acpi_cpufreq: overriding BIOS provided _PSD data
[    4.469751] ccp 0000:00:08.0: 4 command queues available
[    4.472422] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.493387] input: PC Speaker as /devices/platform/pcspkr/input/input5
[    4.495095] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[    4.495246] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[    4.495414] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[    4.538315] ccp 0000:00:08.0: ccp enabled
[    4.545548] cryptd: max_cpu_qlen set to 1000
[    4.572035] usbcore: registered new interface driver usbserial_generic
[    4.572055] usbserial: USB Serial support registered for generic
[    4.616124] usbcore: registered new interface driver ftdi_sio
[    4.616148] usbserial: USB Serial support registered for FTDI USB Serial Device
[    4.616216] ftdi_sio 2-2:1.0: FTDI USB Serial Device converter detected
[    4.616273] usb 2-2: Detected FT232RL
[    4.639508] usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
[    4.641499] AVX version of gcm_enc/dec engaged.
[    4.641505] AES CTR mode by8 optimization enabled
[    4.662110] Adding 999420k swap on /dev/sda5.  Priority:-2 extents:1 across:999420k SSFS
[    4.755099] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[    4.787094] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input6
[    4.789917] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/sound/card0/input7
[    4.803224] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC231: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[    4.803232] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.803234] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    4.803236] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    4.803238] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    4.803241] snd_hda_codec_realtek hdaudioC1D0:      Mic=0x18
[    4.856340] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/sound/card1/input8
[    4.856447] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input9
[    4.856557] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input10
[    4.955119] kvm: Nested Virtualization enabled
[    4.955131] SVM: kvm: Nested Paging enabled
[    4.959214] MCE: In-kernel MCE decoding enabled.
[    4.964415] EDAC amd64: F16h_M30h detected (node 0).
[    4.964454] EDAC amd64: Node 0: DRAM ECC disabled.
[    4.998807] EDAC amd64: F16h_M30h detected (node 0).
[    4.998846] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.059084] EDAC amd64: F16h_M30h detected (node 0).
[    5.059131] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.090941] EDAC amd64: F16h_M30h detected (node 0).
[    5.090984] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.768259] input: BRLTTY 6.3 Linux Screen Driver Keyboard as /devices/virtual/input/input11
[    6.283022] r8169 0000:04:00.0: firmware: failed to load rtl_nic/rtl8168h-2.fw (-2)
[    6.283092] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[    6.283145] r8169 0000:04:00.0: Direct firmware load for rtl_nic/rtl8168h-2.fw failed with error -2
[    6.283152] r8169 0000:04:00.0: Unable to load firmware rtl_nic/rtl8168h-2.fw (-2)
[    6.314058] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-400:00, irq=IGNORE)
[    6.443264] r8169 0000:04:00.0 enp4s0: Link is Down
[    6.538553] usb 2-2: usbfs: interface 0 claimed by ftdi_sio while 'brltty' sets config #1
[    6.550079] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[    6.550113] ftdi_sio 2-2:1.0: device disconnected
[   13.476585] rfkill: input handler disabled
[   26.238425] rfkill: input handler enabled
[   31.940274] rfkill: input handler disabled
[  115.107348] r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  115.107368] IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
[  115.117962] r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control rx/tx
część i tak musiałem usunąć, bo się nie zmieściła ilość znaków.
Jak już wrzucasz pełne logi i forum ogranicza wtedy korzystaj z serwisów zewnętrznych takich jak pastebin.
Logi wskazują, że czytnik jest wykrywany, więc przyczyny szukałbym w logach oscama.
walus
Post autor: walus »
czytnik tak, nawet go oscam widzi spod scan usb
USB Devices
Bus 003 Device 004: ID 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120
iProduct 2 Optical Mouse
iSerial 0
Bus 003 Device 003: ID 046d:c312 Logitech, Inc. DeLuxe 250 Keyboard
iProduct 2 USB Multimedia Keyboard
iSerial 0
iProduct 0
iSerial 0
iProduct 2 EHCI Host Controller
iSerial 1 0000:00:13.0
iProduct 0
iSerial 0
iSerial 1 0000:00:12.0
iProduct 2 xHCI Host Controller
iSerial 1 0000:00:10.0
iProduct 2 FT232R USB UART
iSerial 3 AC023DYR
walus
Post autor: walus »
lub jak edytować brltty? i czy ma to wpływ na dostęp do usb?
/etc/brltty.conf
.. to jak już OSCAM widzi czytnik to pewnie masz coś źle skonfigurowane w OSCAMie.
walus
Post autor: walus »
nie to nie Oscam, /etc/brltty.conf jest cały ####, wystarczyło go poprawić i działa
Co tam poprawiłeś?
