GRUB nie widzi dysku po aktualizacji jądra 5.10.0-8-amd64
Re: GRUB nie widzi dysku po aktualizacji jądra 5.10.0-8-amd64
Przedstaw jeszcze wyniki:
cat /etc/fstab
blkid
ls -la /etc/grub.d/
ls -la /etc/default/grub.d/
cat /etc/default/grub
Tarna
Post autor: Tarna »
root@MIR-LAP:/home/tarna# cat /etc/fstab
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# / was on /dev/sda2 during installation
UUID=76ad448d-b574-4398-84fc-10c22654f8e0 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/nvme0n1p2 during installation
UUID=528F-9706  /boot/efi       vfat    umask=0077      0       1
# /home was on /dev/sda3 during installation
UUID=e8e81abe-9258-49ba-a5f8-421674b391f7 /home           ext4    defaults        0       2
# swap was on /dev/nvme0n1p7 during installation
UUID=894208a1-9001-461e-aad6-b9b3461d07a3 none            swap    sw              0       0
root@MIR-LAP:/home/tarna# /usr/sbin/blkid
/dev/nvme0n1p1: LABEL="Odzyskiwanie" BLOCK_SIZE="512" UUID="FA868F16868ED295" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="fa56802f-8a9d-4960-bb8f-7432c707e2b6"
/dev/nvme0n1p2: UUID="528F-9706" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="3c2b4095-1fd1-4797-8052-b24256f5e4f6"
/dev/nvme0n1p3: PARTLABEL="Microsoft reserved partition" PARTUUID="5c25ef46-3ffa-4652-a2d6-1c7b5421df0b"
/dev/nvme0n1p4: BLOCK_SIZE="512" UUID="B8A4893EA489005C" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="4a63f6dc-6720-480e-8c0f-66d0870266ed"
/dev/nvme0n1p5: BLOCK_SIZE="512" UUID="429862539862458F" TYPE="ntfs" PARTUUID="7c8577e7-9af5-429c-8eef-000b59b1e88f"
/dev/nvme0n1p6: BLOCK_SIZE="512" UUID="26C08548C0851EE5" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="274705fe-91a0-4d5e-aef2-1d443850139e"
/dev/nvme0n1p7: UUID="894208a1-9001-461e-aad6-b9b3461d07a3" TYPE="swap" PARTUUID="803206e3-f146-4c6c-a0e4-372578ed9b73"
/dev/nvme0n1p8: LABEL="DELLSUPPORT" BLOCK_SIZE="512" UUID="FE2296AE22966C01" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="54ccc38a-4121-49e9-db8d-f0c80acf9cd6"
/dev/sda1: PARTUUID="50b9ef63-b29c-4b26-acb4-f771139ef469"
/dev/sda2: UUID="76ad448d-b574-4398-84fc-10c22654f8e0" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="e36a4b1e-ed28-40c3-92ec-832f0c2be5f8"
/dev/sda3: UUID="e8e81abe-9258-49ba-a5f8-421674b391f7" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="115c4557-b246-4579-ba64-3f8c869387cd"
root@MIR-LAP:/home/tarna# ls -la /etc/grub.d/
razem 96
drwxr-xr-x   2 root root  4096 10-01 07:48 .
drwxr-xr-x 134 root root 12288 10-04 11:20 ..
-rwxr-xr-x   1 root root 10046 07-11 01:37 00_header
-rwxr-xr-x   1 root root  6260 07-11 01:37 05_debian_theme
-rwxr-xr-x   1 root root 13664 07-11 01:37 10_linux
-rwxr-xr-x   1 root root 13726 07-11 01:37 20_linux_xen
-rwxr-xr-x   1 root root 12059 2020-07-30  30_os-prober
-rwxr-xr-x   1 root root  1416 07-11 01:37 30_uefi-firmware
-rwxr-xr-x   1 root root   214 2020-07-30  40_custom
-rwxr-xr-x   1 root root   216 2020-07-30  41_custom
-rw-r--r--   1 root root   483 2020-07-30  README
root@MIR-LAP:/home/tarna# ls -la /etc/default/grub.d/
razem 12
drwxr-xr-x 3 root root 4096 10-01 07:48 ..
-rw-r--r-- 1 root root  274 2020-07-30  init-select.cfg
root@MIR-LAP:/home/tarna# cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Jak to było fajnie kiedy był tylko bios? Wiem gdzie może być problem? Zapędziliśmy się trochę w kozi róg. Musimy się trochę dokształcić, zanim spróbujemy to naprawić.
Najpierw musimy przejrzeć takie materiały:
https://github.com/linux-nvme/nvme-cli
https://wiki.archlinux.org/title/NVMe
https://wiki.debian.org/SSDOptimization
https://forums.debian.net/viewtopic.php ... &p=743501&
https://forums.debian.net/viewtopic.php ... &p=743775&
https://metebalci.com/blog/a-quick-tour ... ress-nvme/
https://ubuntuforums.org/showthread.php?t=2147295
Jak więcej coś znajdziesz to podrzuć na forum.
Tarna
Post autor: Tarna »
Zrobiłem eksperyment tzn. zainstalowałem Windows 11 i Debiana 11 całkowicie przebudowując partycje (efi poszło na drugi dysk) i nic to nie pomogło. Najbardziej bym stawiał na coś z GRUB.
Czy próbowałeś samego Debiana zainstalować?
Tarna
Post autor: Tarna »
Nie. Bardziej odpuszczę i poczekam na aktualizacje pakietów. Ewidentne widać, że coś nie dogaduje się z tą konfiguracja 2 inne komputery chodzą bez zarzutu, z czego jeden tez z Windows.
Spróbujmy tego rozwiązania z forum angielskojęzycznego Debiana.
Zainstaluj:
apt install boot-info-script
Przedstaw wynik polecenia:
/usr/sbin/bootinfoscript
Tarna
Post autor: Tarna »
Tym razem będziesz musiał bardziej mnie poprowadzić :( tzn. nie mam podlinkowanych ścieżek (i za bardzo nie wiem jak to zrobić - wiem, że od któregoś wydania już zmienne do su nie są automatycznie przypisywane) zatem otrzymuję komunikat:
root@mirek:/home/mir# /usr/sbin/bootinfoscript
Boot Info Script 0.78      [09 October 2019]
"blkid" could not be found.
"fdisk" could not be found.
"filefrag" could not be found.
"losetup" could not be found.
Please install the missing program(s) and run Boot Info Script again.
root@mirek:/home/mir# /usr/sbin/blkid
/dev/nvme0n1p1: UUID="201B-CF8F" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="1f641a3d-cf0d-4bf0-a31a-6577c30eeb02"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="983ac963-55b3-441b-bb6e-c6fe05ef8f41"
/dev/nvme0n1p3: BLOCK_SIZE="512" UUID="BADE1CC8DE1C7EB7" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="9ca645f5-7b3e-409b-adf5-1dbc9de81bff"
/dev/nvme0n1p4: UUID="3ee4e107-165a-4b1b-91c1-22dc4aef2f13" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="/" PARTUUID="69e9447e-5b3e-4abc-8a1f-dc5e8a35b7d9"
/dev/nvme0n1p5: BLOCK_SIZE="512" UUID="A6A069F3A069C9FF" TYPE="ntfs" PARTUUID="050c00f7-5af7-48c7-ac97-f81ef8200a86"
/dev/nvme0n1p6: UUID="54d712b4-d9b6-4eef-bf15-b62733036fad" TYPE="swap" PARTUUID="d61df083-ae26-4c42-bc3c-219d7854b1ca"
/dev/sda1: UUID="5a82ef3b-d381-467c-abda-38df9e5699c4" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="68d6c079-b9b3-4904-bb4d-2195509f27a4"
/dev/sda2: LABEL="Dane" BLOCK_SIZE="512" UUID="D48A1FF08A1FCE3C" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="3abd1608-b3af-4493-94f6-5bd7ec0d9863"
root@mirek:/home/mir# /usr/sbin/fdisk
fdisk: błędna składnia
'fdisk --help' wyświetli więcej informacji.
root@mirek:/home/mir# /usr/sbin/filefrag
Usage: /usr/sbin/filefrag [-b{blocksize}[KMG]] [-BeEksvxX] file ...
root@mirek:/home/mir# /usr/sbin/losetup
Musisz użyć:
su -
W Debian-referens jest o tym.
Tarna
Post autor: Tarna »
Dziękuję:
============================= Boot Info Summary: ===============================
 => No boot loader is installed in the MBR of /dev/sda.
sda1: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sda2: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 8/2012: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Dysk /dev/sda: 465,76 GiB, bajtów: 500107862016, sektorów: 976773168
Model dysku: CT500MX500SSD1
Jednostki: sektorów, czyli 1 * 512 = 512 bajtów
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1                   1   976,773,167   976,773,167  ee GPT
GUID Partition Table detected.
Partition  Attrs   Start Sector    End Sector  # of Sectors System
/dev/sda1                 2,048   488,384,511   488,382,464 Data partition (Linux)
/dev/sda2           488,384,512   976,771,071   488,386,560 Data partition (Windows/Linux)
Attributes: R=Required, N=No Block IO, B=Legacy BIOS Bootable, +=More bits set
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/nvme0n1p1   201B-CF8F                              vfat
/dev/nvme0n1p2
/dev/nvme0n1p3   BADE1CC8DE1C7EB7                       ntfs
/dev/nvme0n1p4   3ee4e107-165a-4b1b-91c1-22dc4aef2f13   ext4
/dev/nvme0n1p5   A6A069F3A069C9FF                       ntfs
/dev/nvme0n1p6   54d712b4-d9b6-4eef-bf15-b62733036fad   swap
/dev/sda1        5a82ef3b-d381-467c-abda-38df9e5699c4   ext4
/dev/sda2        D48A1FF08A1FCE3C                       ntfs       Dane
========================= "ls -l /dev/disk/by-id" output: ======================
razem 0
lrwxrwxrwx 1 root root  9 10-07 07:19 ata-CT500MX500SSD1_2003E282D83B -> ../../sda
lrwxrwxrwx 1 root root 10 10-07 07:19 ata-CT500MX500SSD1_2003E282D83B-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 10-07 07:19 ata-CT500MX500SSD1_2003E282D83B-part2 -> ../../sda2
lrwxrwxrwx 1 root root 13 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E -> ../../nvme0n1
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E-part1 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E-part2 -> ../../nvme0n1p2
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E-part3 -> ../../nvme0n1p3
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E-part4 -> ../../nvme0n1p4
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E-part5 -> ../../nvme0n1p5
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-BC511_NVMe_SK_hynix_256GB_SS9BN62141090BF5E-part6 -> ../../nvme0n1p6
lrwxrwxrwx 1 root root 13 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001 -> ../../nvme0n1
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001-part1 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001-part2 -> ../../nvme0n1p2
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001-part3 -> ../../nvme0n1p3
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001-part4 -> ../../nvme0n1p4
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001-part5 -> ../../nvme0n1p5
lrwxrwxrwx 1 root root 15 10-07 07:19 nvme-nvme.1c5c-535339424e363231343130393042463545-4243353131204e564d6520534b2068796e6978203235364742-00000001-part6 -> ../../nvme0n1p6
lrwxrwxrwx 1 root root  9 10-07 07:19 wwn-0x500a0751e282d83b -> ../../sda
lrwxrwxrwx 1 root root 10 10-07 07:19 wwn-0x500a0751e282d83b-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 10-07 07:19 wwn-0x500a0751e282d83b-part2 -> ../../sda2
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/nvme0n1p1   /boot/efi                vfat       (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
/dev/nvme0n1p4   /                        ext4       (rw,relatime,errors=remount-ro)
/dev/sda1        /home                    ext4       (rw,relatime)
