Serwer Minidnla
Robik99
Serwer Minidnla
Post autor: Robik99 »
Mam problem,
Linux AOL-Debian 3.18.24_hi3798mv2x #11 SMP Thu Jan 9 15:58:38 KST 2020 armv7l GNU/Linux
serwer nie widzi plików (klienci widzą foldery bez plików)Obrazek,
moja konfiguracja:
# This is the configuration file for the MiniDLNA daemon, a DLNA/UPnP-AV media
# server.
# Unless otherwise noted, the commented out options show their default value.
# On Debian, you can also refer to the minidlna.conf(5) man page for
# documentation about this file.
# Specify the user name or uid to run as.
user=root
# Path to the directory you want scanned for media files.
# This option can be specified more than once if you want multiple directories
# scanned.
# If you want to restrict a media_dir to a specific content type, you can
# prepend the directory name with a letter representing the type (A, P or V),
# followed by a comma, as so:
#   * "A" for audio    (eg. media_dir=A,/var/lib/minidlna/music)
#   * "P" for pictures (eg. # # #media_dir=P,/var/lib/minidlna/pictures)
#   * "V" for video    (eg. media_dir=V,/var/lib/minidlna/videos)
#   * "PV" for pictures and video (eg.
media_dir=,/mnt/media_rw/sda1/FILMY/
media_dir=,/mnt/media_rw/sda1/SERIALE/
media_dir=,/mnt/media_rw/sda1/MUZYKA/
# Set this to merge all media_dir base contents into the root container
# (The default is no.)
#merge_media_dirs=no
# Path to the directory that should hold the database and album art cache.
db_dir=/var/cache/minidlna
# Path to the directory that should hold the log file.
log_dir=/var/log
# Type and minimum level of importance of messages to be logged.
# The types are "artwork", "database", "general", "http", "inotify",
# "metadata", "scanner", "ssdp" and "tivo".
# The levels are "off", "fatal", "error", "warn", "info" or "debug".
# "off" turns of logging entirely, "fatal" is the highest level of importance
# and "debug" the lowest.
# The types are comma-separated, followed by an equal sign ("="), followed by a
# level that applies to the preceding types. This can be repeated, separating
# each of these constructs with a comma.
# The default is to log all types of messages at the "warn" level.
#log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn
# Use a different container as the root of the directory tree presented to
# clients. The possible values are:
#   * "." - standard container
#   * "B" - "Browse Directory"
#   * "M" - "Music"
#   * "P" - "Pictures"
#   * "V" - "Video"
#   * Or, you can specify the ObjectID of your desired root container
#     (eg. 1$F for Music/Playlists)
# If you specify "B" and the client device is audio-only then "Music/Folders"
# will be used as root.
#root_container=.
# Network interface(s) to bind to (e.g. eth0), comma delimited.
# This option can be specified more than once.
#network_interface=
# Port number for HTTP traffic (descriptions, SOAP, media transfer).
# This option is mandatory (or it must be specified on the command-line using
# "-p").
port=8200
# URL presented to clients (e.g. http://example.com:80).
#presentation_url=/
# Name that the DLNA server presents to clients.
# Defaults to "hostname: username".
friendly_name=MiniDLNA on AOL
# Serial number the server reports to clients.
# Defaults to the MAC address of nework interface.
serial=12345678
# Model name the server reports to clients.
#model_name=Windows Media Connect compatible (MiniDLNA)
# Model number the server reports to clients.
# Defaults to the version number of minidlna.
model_number=1
# Automatic discovery of new files in the media_dir directory.
inotify=yes
# List of file names to look for when searching for album art.
# Names should be delimited with a forward slash ("/").
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg
album_art_names=AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg
album_art_names=Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# Strictly adhere to DLNA standards.
# This allows server-side downscaling of very large JPEG images, which may
# decrease JPEG serving performance on (at least) Sony DLNA products.
#strict_dlna=no
# Support for streaming .jpg and .mp3 files to a TiVo supporting HMO.
#enable_tivo=no
# SSDP notify interval, in seconds.
notify_interval=895
# Path to the MiniSSDPd socket, for MiniSSDPd support.
#minissdpdsocket=/run/minissdpd.sock
# Always set SortCriteria to this value, regardless of the SortCriteria
# passed by the client
# e.g. force_sort_criteria=+upnp:class,+upnp:originalTrackNumber,+dc:title
#force_sort_criteria=
# maximum number of simultaneous connections
# note: many clients open several simultaneous connections while streaming
max_connections=3
# set this to yes to allow symlinks that point outside user-defined media_dirs.
wide_links=yes
jakieś sugestie ?
Re: Serwer Minidnla
Kolego, nie podpinaj się pod nie swoje wątki.
Wydzielam do nowego.
