[+]bardzo wolno dzialajacy internet
korbielow
Post autor: korbielow »
Witam!
Mam problem w sieci w pracy bardzo wolno mi dziala internet. Na speedtest wyciaga ledwo 0,2Mb/s.
Jak przelacze na Windows na tym samym laptopie to internet dziala szybko 40 Mb/s.
W mojej sieci domowej ten sam laptop nie ma tych problemow i na debianie dziala
Przypuszczam ze jakis problem ze strownikami lub kernel ?
Mam laptop Dell Latitude e6410.
Czy ktos moze pomoc ?
root@debian:/home/rafal# cat /etc/debian_version
bullseye/sid
root@debian:/home/rafal# ifconfig
eno1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 5c:26:0a:3f:ff:7c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf6900000-f6920000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 36  bytes 2748 (2.6 KiB)
        TX packets 36  bytes 2748 (2.6 KiB)
vmnet1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.16.1.1  netmask 255.255.255.0  broadcast 172.16.1.255
        inet6 fe80::250:56ff:fec0:1  prefixlen 64  scopeid 0x20<link>
        ether 00:50:56:c0:00:01  txqueuelen 1000  (Ethernet)
        TX packets 74  bytes 0 (0.0 B)
vmnet8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.16.22.1  netmask 255.255.255.0  broadcast 172.16.22.255
        inet6 fe80::250:56ff:fec0:8  prefixlen 64  scopeid 0x20<link>
        ether 00:50:56:c0:00:08  txqueuelen 1000  (Ethernet)
        TX packets 73  bytes 0 (0.0 B)
wlp2s0b1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.57.48  netmask 255.255.240.0  broadcast 192.168.63.255
        inet6 fe80::26ec:be94:92f0:36c9  prefixlen 64  scopeid 0x20<link>
        ether c0:cb:38:80:63:2e  txqueuelen 1000  (Ethernet)
        RX packets 13620  bytes 5959384 (5.6 MiB)
        TX packets 52094  bytes 71098494 (67.8 MiB)
root@debian:/home/rafal# lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 02)
00:19.0 Ethernet controller: Intel Corporation 82577LM Gigabit Network Connection (rev 05)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 05)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation QM57 Chipset LPC Interface Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 05)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43224 802.11a/b/g/n (rev 01)
03:00.0 SD Host controller: Ricoh Co Ltd MMC/SD Host Controller (rev 03)
03:00.4 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 PCIe IEEE 1394 Controller (rev 03)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
3f:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
3f:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
3f:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
root@debian:/home/rafal# cat /etc/network/interfaces
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
root@debian:/home/rafal# cat /etc/apt/sources.list
# Debian 9 "stretch"
# deb http://deb.debian.org/debian/ stretch main contrib non-free
# Buster
deb http://ftp.pl.debian.org/debian/ testing main contrib non-free
deb http://security.debian.org/ testing/updates main contrib non-free
## deb-multimedia - dodatkowe kodeki, odtwarzacze, etc.
deb http://www.deb-multimedia.org/ testing main non-free
## przeglądarka Opera
deb http://deb.opera.com/opera/ stable non-free
## przeglądarka Google Chrome
deb http://dl.google.com/linux/chrome/deb/ stable main
##TOR
deb https://deb.torproject.org/torproject.org buster main
deb-src https://deb.torproject.org/torproject.org buster main
root@debian:/home/rafal# ping -c5 google.com
PING google.com (216.58.201.110) 56(84) bytes of data.
64 bytes from prg03s02-in-f110.1e100.net (216.58.201.110): icmp_seq=1 ttl=55 time=7.77 ms
64 bytes from prg03s02-in-f110.1e100.net (216.58.201.110): icmp_seq=2 ttl=55 time=7.76 ms
64 bytes from prg03s02-in-f110.1e100.net (216.58.201.110): icmp_seq=3 ttl=55 time=7.70 ms
64 bytes from prg03s02-in-f110.1e100.net (216.58.201.110): icmp_seq=4 ttl=55 time=7.88 ms
64 bytes from prg03s02-in-f110.1e100.net (216.58.201.110): icmp_seq=5 ttl=55 time=7.89 ms
Ostatnio zmieniony 24 listopada 2019, 16:33 przez korbielow, łącznie zmieniany 1 raz.
Re: bardzo wolno dzialajacy internet
Porównaj sobie te sterowniki, kernele.
Czy adres IP jest ten sam?
korbielow
IP sa identyczne zarowno na WIN jak na Debian
root@debian:/home/rafal# uname -a
Linux debian 4.16.0-1-amd64 #1 SMP Debian 4.16.5-1 (2018-04-29) x86_64 GNU/Linux
Moje wifi to chyba bedzie to 2:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43224 802.11a/b/g/n (rev 01)
Mam wrazenie ze to sie stalo po upgrade debian bo wczesniej mi to dzialalo dobrze.
Te same kernele, te same paczki firmware?
korbielow
To rozwiazalo moj problem.
Installation
Add a "non-free" component to /etc/apt/sources.list for your Debian version, for example:
# Debian 9 "Stretch"
deb http://deb.debian.org/debian stretch-backports main contrib non-free
# Debian 10 "Buster"
deb http://deb.debian.org/debian buster-backports main contrib non-free
Update the list of available packages. Install the relevant/latest linux-image, linux-headers and broadcom-sta-dkms packages:
# apt-get update
# apt-get install linux-image-$(uname -r|sed 's,[^-]*-[^-]*-,,') linux-headers-$(uname -r|sed 's,[^-]*-[^-]*-,,') broadcom-sta-dkms
This will also install the recommended wireless-tools package. DKMS will build the wl module for your system.
Unload conflicting modules:
# modprobe -r b44 b43 b43legacy ssb brcmsmac bcma
Load the wl module:
# modprobe wl
https://wiki.debian.org/wl
Jednak bardzo mnie zastanawia czemu w domu mi wfi dzialalo normalnie, a w pracy wolno.
W kazdym badz razie po zastosowaniu tej instrukcji problem znikl.
Swoja droga ten Broadcom BCM4311 bardzo problematyczna karta sieciowa.
Ostatnio zmieniony 24 listopada 2019, 20:09 przez korbielow, łącznie zmieniany 3 razy.
Re: [+]bardzo wolno dzialajacy internet
Nie bardzo wiadomo co ostatecznie zrobiłeś.
hsurim
Post autor: hsurim »
Pewnie lepszy sterownik do broadcom
