Deinstalacja Pi-Hole i utrata dostepu do Internetu.
Matrixx
Post autor: Matrixx »
Czesc wszystkim.
Zainstalowalem na Debianie Jessie blokera reklam - Pi-Hole, pobawilem sie, nastepnie odinstalowalem, i stracilem kontakt z Internetem. Zmarnowalem kilka godzin szukajac rozwiazania w Googlach, ale nadaremnie.
Aktualnie mam takie konfigi (ustawilem z konsoli):
hostname
station1.example.com
ifconfig
eth0      Link encap:Ethernet  HWaddr 60:a4:4c:64:a8:bd
          inet addr:192.168.100.100  Bcast:192.168.0.255  Mask:255.255.255.0
          RX packets:50 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:23176 (22.6 KiB)  TX bytes:342 (342.0 B)
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:8422 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8422 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:736956 (719.6 KiB)  TX bytes:736956 (719.6 KiB)
cat /etc/network/interfaces
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet dhcp
dns-nameservers 8.8.8.8
dns-nameservers 8.8.4.4
cat /etc/hosts
127.0.0.1	localhost
127.0.1.1	debian
192.168.100.100   station1.example.com
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.0.1
search home
systemctl status networking.service
● networking.service - LSB: Raise network interfaces.
   Loaded: loaded (/etc/init.d/networking)
  Drop-In: /run/systemd/generator/networking.service.d
           └─50-insserv.conf-$network.conf
        /lib/systemd/system/networking.service.d
           └─network-pre.conf
   Active: active (running) since Tue 2019-03-19 17:34:43 GMT; 12min ago
  Process: 1886 ExecStop=/etc/init.d/networking stop (code=exited, status=0/SUCCESS)
  Process: 1902 ExecStart=/etc/init.d/networking start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/networking.service
           └─1969 dhclient -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dh...
Nie moge pingowac do nikad tzn: zwrotnie, do karty, do bramy, na zewnatrz.
Nie mam proxy a firewall wylaczony.
Zalezy mi na naprawie polaczenia sieciowego, ktos pomoze?
Re: Deinstalacja Pi-Hole i utrata dostepu do Internetu.
 ip r s
 iptables -L
 iptables -L -t raw
 iptables -L -t filter
 iptables -L -t mangle
Matrixx
ip r s
default via 192.168.0.1 dev eth0
192.168.0.0/24 dev eth0  proto kernel  scope link  src 192.168.100.100
 iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
 iptables -L -t raw
Chain PREROUTING (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
Siedzialem dlugo w nocy i czesciowo uruchomilem dostep (wchodzi do Internetu i otwiera strony), nie dzialaja niektore skladowe transferu.
Dla przykladu; nie dzialaja przyciski na aliexpress.com albo albo nie moge doprowadzic netinstal do konca
bo w punkcie wskazania zrodlowego mirroru dla instalowanego oprogramowania pojawia sie komunikat na czerwono: "Bad archive mirror" - i tak dla wszystkich mirrorow z listy.
Inny problem jest kiedy wchodze w systemowe Settings a nastepnie Network to pojawia sie komunikat "The system network services are not compatible with this version"
W mojej opini nie jest to problem blokady dostepu do Sieci przez proxy czy iptables, a bardziej nieskonfigurowany Network Manager gnome oraz brak apletu sieci w gornym pasku.
dpkg -l |grep network-manager
ii  network-manager                       0.9.10.0-7                                 amd64        network management framework (daemon and userspace tools)
ii  network-manager-dev:amd64             0.9.10.0-7                                 amd64        network management framework (development files)
ii  network-manager-gnome                 0.9.10.0-2                                 amd64        network management framework (GNOME frontend)
systemctl status network-manager
● NetworkManager.service - Network Manager
   Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled)
   Active: active (running) since Wed 2019-03-20 11:07:06 GMT; 3min 30s ago
 Main PID: 651 (NetworkManager)
   CGroup: /system.slice/NetworkManager.service
           └─651 /usr/sbin/NetworkManager --no-daemon
