Debian 9 Problem z instalacją samby 4.7.5
staneks
Post autor: staneks »
Podczas instalacji samby. Pobrałem wersję 4.7.5. Rozpakowałem. Gdy daję komendę: ./configure –-enable-selftest na końcu pokazuje mi się taki komunikat:
 /usr/src/samba-4.7.5/source3/wscript:955: error: PAM support is enabled but prerequisite libraries or headers not found. Use --without-pam to disable PAM support
Próbowałem z innymi wersjami samby -- to samo
Pomóżcie, poniżej cały proces configure wraz z błędem:
root@test:/usr/src/samba-4.7.5# ./configure –-enable-selftest
Checking for program gcc or cc           : /usr/bin/gcc
Checking for program cpp                 : /usr/bin/cpp
Checking for program ar                  : /usr/bin/ar
Checking for program ranlib              : /usr/bin/ranlib
Checking for gcc                         : ok
Checking for program git                 : not found
Check for -MD                            : yes
Checking for program gdb                 : /usr/bin/gdb
Checking build system                    : Linux test 4.9.0-4-amd64 #1 SMP Debian 4.9.65-3+deb9u1 (2017-12-23) x86_64 GNU/Linux
Checking for header sys/utsname.h        : yes
Checking uname sysname type              : Linux
Checking uname machine type              : x86_64
Checking uname release type              : 4.9.0-4-amd64
Checking uname version type              : #1 SMP Debian 4.9.65-3+deb9u1 (2017-12-23)
Checking for header stdio.h              : yes
Checking simple C program                : ok
Checking compiler accepts ['-Werror']    : yes
Checking linker accepts ['-Wl,-rpath,.'] : yes
Checking for rpath library support       : ok
Checking for -Wl,--version-script support  : ok
Checking compiler accepts ['-fvisibility=hidden', '-Werror'] : yes
Checking for HAVE_VISIBILITY_ATTR                            : ok
Checking for library constructor support                     : ok
Checking for library destructor support                      : ok
Checking for __attribute__                                   : ok
Checking for program perl                                                         : /usr/bin/perl
Checking for perl 5.0.0                                                           : ok 5.24.1
Checking for perl $Config{vendorprefix}:                                          : '/usr'
PERL_ARCH_INSTALL_DIR:                                                            : '${LIBDIR}/perl5'
PERL_LIB_INSTALL_DIR:                                                             : '${DATADIR}/perl5'
PERL_INC:        : ['/etc/perl', '/usr/local/lib/x86_64-linux-gnu/perl/5.24.1', '/usr/local/share/perl/5.24.1', '/usr/lib/x86_64-linux-gnu/perl5/5.24', '/usr/share/perl5', '/usr/lib/x86_64-linux-gnu/perl/5.24', '/usr/share/perl/5.24', '/usr/local/lib/site_perl', '/usr/lib/x86_64-linux-gnu/perl-base']
Checking for header linux/falloc.h                                                : yes
Checking for header linux/ioctl.h                                                 : yes
Checking for getcwd                                                               : ok
Checking for fchown                                                               : ok
Checking for chmod        : ok
Checking for fchmod                                                               : ok
Checking for mknod        : ok
Checking for strtol                                                               : ok
Checking for strchr                                                               : ok
Checking for strupr                                                               : not found
Checking for macro strupr                                                         : not found
Checking for chflags                                                              : not found
Checking for macro chflags                                                        : not found
Checking for getrlimit                                                            : ok
Checking for fsync        : ok
Checking for setpgid                                                              : ok
Checking for glob        : ok
Checking for strpbrk                                                              : ok
Checking for crypt16                                                              : not found
Checking for macro crypt16                                                        : not found
Checking for getauthuid                                                           : not found
Checking for macro getauthuid                                                     : not found
Checking for innetgr                                                              : ok
Checking for select                                                               : ok
Checking for rdchk        : not found
Checking for macro rdchk                                                          : not found
Checking for getgrnam                                                             : ok
Checking for getgrent                                                             : ok
Checking for pathconf                                                             : ok
Checking for setpriv                                                              : not found
Checking for macro setpriv                                                        : not found
Checking for setgidx                                                              : not found
Checking for macro setgidx                                                        : not found
Checking for setuidx                                                              : not found
Checking for macro setuidx                                                        : not found
Checking for sysconf                                                              : ok
Checking for grantpt                                                              : ok
Checking for posix_openpt                                                         : ok
Checking for fallocate                                                            : ok
Checking for posix_fallocate                                                      : ok
Checking for fseeko                                                               : ok
Checking for setluid                                                              : not found
Checking for macro setluid                                                        : not found
Checking for getpwnam                                                             : ok
Checking for fdopendir                                                            : ok
Checking for fstatat                                                              : ok
Checking for clearenv                                                             : ok
Checking for strcasecmp                                                           : ok
Checking for fcvt        : ok
Checking for fcvtl        : not found
Checking for macro fcvtl                                                          : not found
Checking for setlocale                                                            : ok
Checking for library rt                                                           : yes
Checking for nanosleep                                                            : ok
Checking for lutimes                                                              : ok
Checking for futimes                                                              : ok
Checking for utimensat                                                            : ok
Checking for futimens                                                             : ok
Checking for mlock        : ok
Checking for munlock                                                              : ok
Checking for mlockall                                                             : ok
Checking for munlockall                                                           : ok
Checking for shmget                                                               : ok
Checking for shm_open                                                             : not found
Checking for macro shm_open                                                       : not found
Checking for shm_open                                                             : ok
Checking for yp_get_default_domain                                                : ok
Checking for _dn_expand                                                           : not found
Checking for macro _dn_expand                                                     : not found
Checking for __dn_expand                                                          : ok
Checking for declaration of fdatasync                                             : yes
Checking for declaration of readahead                                             : yes
Checking for HAVE_LINUX_SPLICE                                                    : yes
Checking for declaration of splice                                                : yes
Checking for kernel change notify support                                         : yes
Checking for Linux kernel oplocks                                                 : yes
Checking for IRIX kernel oplock types                                             : no
Checking for kernel share modes                                                   : yes
Checking for header fam.h                                                         : no
no suitable FAM library found
Checking for libarchive existence
Checking for header archive.h                                                     : no
Checking for DMAPI library existence
Checking for library dm                                                           : not found
Checking for dm_get_eventlist                                                     : not found
Checking for macro dm_get_eventlist                                               : not found
Checking for library jfsdm                                                        : not found
Checking for library dmapi                                                        : not found
Checking for library xdsm                                                         : not found
Building without DMAPI support: no suitable DMAPI library found
Checking for member st_blocks in struct stat                                      : yes
Checking for member st_blksize in struct stat                                     : yes
Checking for member st_flags in struct stat                                       : no
Checking for header replace.h                                                     : no
Checking whether blkcnt_t is 32 bit                                               : no
Checking whether blkcnt_t is 64 bit                                               : yes
Checking for library cap                                                          : not found
Checking for header sys/capability.h                                              : no
Checking for cap_get_proc                                                         : not found
Checking for macro cap_get_proc                                                   : not found
Checking for broken nisplus include files                                         : yes
Checking if the compiler will optimize out functions                              : yes
Checking for LL suffix on long long integers                                      : yes
Checking for _acl        : not found
Checking for macro _acl                                                           : not found
Checking for __acl        : not found
Checking for macro __acl                                                          : not found
Checking for _chdir                                                               : not found
Checking for macro _chdir                                                         : not found
Checking for __chdir                                                              : not found
Checking for macro __chdir                                                        : not found
Checking for _close                                                               : not found
Checking for macro _close                                                         : not found
Checking for __close                                                              : ok
Checking for _closedir                                                            : not found
Checking for macro _closedir                                                      : not found
Checking for __closedir                                                           : not found
Checking for macro __closedir                                                     : not found
Checking for devnm        : not found
Checking for macro devnm                                                          : not found
Checking for DNSServiceRegister                                                   : not found
Checking for macro DNSServiceRegister                                             : not found
Checking for _dup        : not found
Checking for macro _dup                                                           : not found
Checking for __dup        : not found
Checking for macro __dup                                                          : not found
Checking for _dup2        : not found
Checking for macro _dup2                                                          : not found
Checking for __dup2                                                               : ok
Checking for endmntent                                                            : ok
Checking for execl        : ok
Checking for _facl        : not found
Checking for macro _facl                                                          : not found
Checking for __facl                                                               : not found
Checking for macro __facl                                                         : not found
Checking for _fchdir                                                              : not found
Checking for macro _fchdir                                                        : not found
Checking for __fchdir                                                             : not found
Checking for macro __fchdir                                                       : not found
Checking for _fcntl                                                               : not found
Checking for macro _fcntl                                                         : not found
Checking for __fcntl                                                              : ok
Checking for _fork        : not found
Checking for macro _fork                                                          : not found
Checking for __fork                                                               : ok
Checking for _fstat                                                               : not found
Checking for macro _fstat                                                         : not found
Checking for __fstat                                                              : ok
Checking for __fxstat                                                             : ok
Checking for _getcwd                                                              : not found
Checking for macro _getcwd                                                        : not found
Checking for __getcwd                                                             : not found
Checking for macro __getcwd                                                       : not found
Checking for getdents                                                             : not found
Checking for macro getdents                                                       : not found
Checking for __getdents                                                           : not found
Checking for macro __getdents                                                     : not found
Checking for getgrset                                                             : not found
Checking for macro getgrset                                                       : not found
Checking for getmntent                                                            : ok
Checking for getpwanam                                                            : not found
Checking for macro getpwanam                                                      : not found
Checking for llseek                                                               : ok
Checking for _llseek                                                              : not found
Checking for macro _llseek                                                        : not found
Checking for __llseek                                                             : not found
Checking for macro __llseek                                                       : not found
Checking for _lseek                                                               : not found
Checking for macro _lseek                                                         : not found
Checking for __lseek                                                              : ok
Checking for _lstat                                                               : not found
Checking for macro _lstat                                                         : not found
Checking for __lstat                                                              : ok
Checking for __lxstat                                                             : ok
Checking for _open        : not found
Checking for macro _open                                                          : not found
Checking for __open                                                               : ok
Checking for _opendir                                                             : not found
Checking for macro _opendir                                                       : not found
Checking for __opendir                                                            : not found
Checking for macro __opendir                                                      : not found
Checking for _pread                                                               : not found
Checking for macro _pread                                                         : not found
Checking for __pread                                                              : not found
Checking for macro __pread                                                        : not found
Checking for _pwrite                                                              : not found
Checking for macro _pwrite                                                        : not found
Checking for __pwrite                                                             : not found
Checking for macro __pwrite                                                       : not found
Checking for _read        : not found
Checking for macro _read                                                          : not found
Checking for __read                                                               : ok
Checking for _readdir                                                             : not found
Checking for macro _readdir                                                       : not found
Checking for __readdir                                                            : not found
Checking for macro __readdir                                                      : not found
Checking for _seekdir                                                             : not found
Checking for macro _seekdir                                                       : not found
Checking for __seekdir                                                            : not found
Checking for macro __seekdir                                                      : not found
Checking for setmntent                                                            : ok
Checking for _stat        : not found
Checking for macro _stat                                                          : not found
Checking for __stat                                                               : ok
Checking for statvfs                                                              : ok
Checking for strsignal                                                            : ok
Checking for sysctl                                                               : ok
Checking for sysctlbyname                                                         : not found
Checking for macro sysctlbyname                                                   : not found
Checking for __sys_llseek                                                         : not found
Checking for macro __sys_llseek                                                   : not found
Checking for _telldir                                                             : not found
Checking for macro _telldir                                                       : not found
Checking for __telldir                                                            : not found
Checking for macro __telldir                                                      : not found
Checking for _write                                                               : not found
Checking for macro _write                                                         : not found
Checking for __write                                                              : ok
Checking for __xstat                                                              : ok
Checking if can we convert from CP850 to UCS-2LE                                  : yes
Checking if can we convert from UTF-8 to UCS-2LE                                  : yes
building on linux2
Checking for library acl                                                          : yes
Checking for acl_get_file                                                         : ok
Checking for POSIX ACL support                                                    : yes
Checking whether acl_get_perm_np() is available                                   : no
Checking for variable ACL_EVERYONE                                                : no
vfs_fileid checking for statfs() and struct statfs.f_fsid                         : yes
Checking whether the Linux 'fallocate' function is available                      : yes
Checking whether Linux 'fallocate' supports hole-punching                         : yes
Checking whether lseek supports hole/data seeking                                 : yes
Checking whether Linux readahead is available                                     : yes
Checking for openat                                                               : yes
Checking for library aio                                                          : not found
Checking for io_submit                                                            : not found
Checking for macro io_submit                                                      : not found
Checking for header libaio.h                                                      : no
Checking for linux kernel asynchronous io support                                 : no
Checking if we can use msg_control for passing file descriptors                   : yes
Checking if we can use msg_accrights for passing file descriptors                 : no
Checking for program awk                                                          : /usr/bin/awk
Checking for header asm/types.h                                                   : yes
Checking for major macro                                                          : yes
Checking for minor macro                                                          : yes
Checking for member d_off in struct dirent                                        : yes
Checking for setnetgrent                                                          : ok
Checking for getnetgrent                                                          : ok
Checking for endnetgrent                                                          : ok
Checking compiler accepts -Werror-implicit-function-declaration                   : yes
Checking for setnetgrent prototype                                                : yes
Checking for getnetgrent prototype                                                : yes
Checking for endnetgrent prototype                                                : yes
Checking for program cups-config                                                  : /usr/bin/cups-config
Checking for /usr/bin/cups-config                                                 : yes
Checking for header cups/cups.h                                                   : yes
Checking for header cups/language.h                                               : yes
Checking for library cups                                                         : yes
Checking for httpConnect                                                          : ok
Checking for httpConnectEncrypt                                                   : ok
Checking for header ldap.h                                                        : yes
Checking for header lber.h                                                        : yes
Checking for header ldap_pvt.h                                                    : no
Checking for ber_tag_t                                                            : yes
Checking for library lber                                                         : yes
Checking for ber_scanf                                                            : ok
Checking for ber_sockbuf_add_io                                                   : ok
Checking for variable LDAP_OPT_SOCKBUF                                            : yes
Checking for variable LBER_OPT_LOG_PRINT_FN                                       : yes
Checking for library ldap                                                         : yes
Checking for ldap_init                                                            : ok
Checking for ldap_init_fd                                                         : ok
Checking for ldap_initialize                                                      : ok
Checking for ldap_set_rebind_proc                                                 : ok
Checking for ldap_add_result_entry                                                : ok
Checking whether ldap_set_rebind_proc takes 3 arguments                           : yes
Building with Active Directory support.
Checking for pututline                                                            : ok
Checking for pututxline                                                           : ok
Checking for updwtmp                                                              : ok
Checking for updwtmpx                                                             : ok
Checking for getutmpx                                                             : ok
Checking for getutxent                                                            : ok
Checking for member ut_name in struct utmp                                        : yes
Checking for member ut_user in struct utmp                                        : yes
Checking for member ut_id in struct utmp                                          : yes
Checking for member ut_host in struct utmp                                        : yes
Checking for member ut_time in struct utmp                                        : yes
Checking for member ut_tv in struct utmp                                          : yes
Checking for member ut_type in struct utmp                                        : yes
Checking for member ut_pid in struct utmp                                         : yes
Checking for member ut_exit.e_exit in struct utmp                                 : yes
Checking for member ut_syslen in struct utmpx                                     : no
Checking whether pututline returns pointer                                        : yes
Checking if size of ((struct utmp *)NULL)->ut_line == 1                           : no
Checking if size of ((struct utmp *)NULL)->ut_line == 2                           : no
Checking if size of ((struct utmp *)NULL)->ut_line == 4                           : no
Checking if size of ((struct utmp *)NULL)->ut_line == 8                           : no
Checking if size of ((struct utmp *)NULL)->ut_line == 16                          : no
Checking if size of ((struct utmp *)NULL)->ut_line == 32                          : yes
Checking for header avahi-common/watch.h                                          : no
Checking for header avahi-client/client.h                                         : no
Checking for library avahi-client                                                 : not found
Checking for avahi_client_new                                                     : not found
Checking for macro avahi_client_new                                               : not found
Checking for library avahi-common                                                 : not found
Checking for avahi_strerror                                                       : not found
Checking for macro avahi_strerror                                                 : not found
Checking for header pam/pam_appl.h                                                : no
--with-pam=yes but pam_appl.h not found
Checking for library pam                                                          : not found
Checking for pam_get_data                                                         : not found
Checking for macro pam_get_data                                                   : not found
--with-pam=yes but pam_modules.h not found
Checking for header security/pam_ext.h                                            : no
Checking for header security/_pam_macros.h                                        : no
Checking for header pam/pam_ext.h                                                 : no
Checking for header pam/_pam_macros.h                                             : no
Checking for pam_vsyslog                                                          : not found
Checking for macro pam_vsyslog                                                    : not found
Checking whether PAM_RHOST is available                                           : no
Checking whether PAM_TTY is available                                             : no
Checking whether PAM_RADIO_TYPE is available                                      : no
/usr/src/samba-4.7.5/source3/wscript:955: error: PAM support is enabled but prerequisite libraries or headers not found. Use --without-pam to disable PAM support.
Ostatnio zmieniony 05 marca 2018, 21:03 przez dedito, łącznie zmieniany 2 razy.
Re: DEBIAN 9 Problem z instalacją samby 4.7.5
Czemu nie zainstalujesz samby z repozytoriów?
staneks
Instaluje się 4.5.xx.
Konfiguruje active directory. Postępuję zgodnie z instrukcją : https://www.it-adamczyk.pl/warsztaty/do ... acja-2017/
Ok udało się :)
W takim razie proszę o krótkie podsumowanie i oznaczenie wątku.
staneks
dałem komendę: ./configure --enable-debug --enable-selftest. Nie wiem czemu w /etc nie ma katalogu samba
To co się w takim razie udało?
staneks
Dałem komendę: dałem komendę: ./configure --enable-debug --enable-selftest
Potem make
Potem make install. Na żadnym etapie nie było błędów a w /etc samby brak
No teraz pojawiło się jakieś make i make install.
Jakie jest powód wyboru akurat tej wersji?
Korzystanie z Debiana jest proste tylko trzeba stosować się do paru prostych zasad (zwłaszcza gdy jest się początkującym):
1. Używaj repozytoriów zgodnych z dokumentacją Debiana, inne można używać tylko jeśli jasno jest stwierdzone, że są przeznaczone dla Debiana w konkretnej edycji. Jakiekolwiek inne mieszanie repozytoriów "niedebianowych" bez odpowiedniej wiedzy to proszenie się o uszkodzenie systemu.
2. Korzystaj z opisów na wiki Debiana (czasem są przestarzałe)
3. Programy instaluj za pośrednictwem repozytoriów.
4. Aktualizuj regularnie system.
5. Przeczytaj chociaż raz w życiu Debian reference, poradnik instalacji, a jak chcesz więcej to poradnik dla administratorów.
To chyba tyle.
staneks
Jest najnowsza, ale nie ma to znaczenia. Jak próbowałem z starszymi to problem ten sam.
Skoro nie ma znaczenia zainstaluj z repozytoriów Debiana.
