[+] Dell E5440 karta WIFI nie działa
ww71
Post autor: ww71 »
Mam Della E5440 , i nie działą wifi. Proszę o wskazówkę jaki sterownik potrzebny.
root@debian:/home/ww# lspci
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:16.3 Serial controller: Intel Corporation 8 Series HECI KT (rev 04)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I218-LM (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4)
00:1c.5 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 6 (rev e4)
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
01:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
02:00.0 Network controller: Intel Corporation Wireless 7260 (rev 73)
03:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1
Karta wifi to:
Wgrałem:
apt-get install firmware-iwlwifi
i nie widzi wifi wcale
root@debian:/home/ww# iwconfig
eno1      no wireless extensions.
wlp2s0    IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:on
root@debian:/home/ww# ifconfig wlp2s0 up
SIOCSIFFLAGS: Operacja niemożliwa ze względu na RF-kill
Ostatnio zmieniony 05 stycznia 2018, 14:08 przez ww71, łącznie zmieniany 1 raz.
Re: Dell E5440 karta WIFI nie działa
Sprawdź:
1. jak to w Debianie: https://wiki.debian.org/iwlwifi
2. firmware (jeśli byłby potrzebny do pobrania ręcznie): https://www.intel.com/content/www/us/en ... rking.html
3. ogólne info: https://wireless.wiki.kernel.org/en/use ... rs/iwlwifi
Przyda Ci się też pakiet wpa_supplicant do skonfigurowania połączenia.
ww71
Post autor: ww71 »
Tak wgrałem pakiet:
firmware-iwlwifi
nie wiem czy dobrze zrozumiałem, ale ściągnałem paczkę:
iwlwifi-7260-ucode-16.242414.0.tgz
z mojej karty 7260
i wgrałem:
/home/ww# cp iwlwifi-7260-16.ucode /lib/firmware
Nie ma efektu, ale kontrolka się świeci od wifi.
Wpisałem w pliku: /etc/network/interfaces :
iface wlp2s0 inet dhcp
wireless nazwa mojej sieci
wireless-key s: moj klucz
I działa. Dzięki za pomoc. Pozdrawiam
Re: [+] Dell E5440 karta WIFI nie działa
Jak masz jakiegoś menadżera połączeń to możesz mieć problemy z powodu dopisania tego do /etc/network/interfaces.
Połączeniami zarządzaj albo z poziomu /etc/network/interfaces albo z poziomu menażdżera (przykładowo najbardziej popularne: Network Menager lub WICD)
ww71
Post autor: ww71 »
Zawsze używałem WICD, ale tym razem był problem. Network Manager odinstalowałem.
Wykasowałem ten wpis z /etc/network/interfaces
i działa. Więc jest już ok. Dzięki. Pozdrawiam.
