OMV problem z zapisywaniem ustawień
Mefu
Post autor: Mefu »
Od dłuższego czasu walczę z Openmediavault 2.2.14 64 bit. Problem jest w dodatku OwnCloud podaje katalog danych i certyfikat zapisuje, system prosi mnie o zatwierdzenie danych. Zaraz po zapisywaniu pojawia się błąd
Błąd #4000:
exception 'OMVException' with message 'Failed to execute command 'export LANG=C; setfacl --recursive --modify default:user:www-data:rwx,user:www-data:rwx -- '/media/CA842B92842B8055/chmurka/' 2>&1': setfacl: /media/CA842B92842B8055/chmurka/: Operation not supported
setfacl: /media/CA842B92842B8055/chmurka//mount.json: Operation not supported
setfacl: /media/CA842B92842B8055/chmurka//owncloud.log: Operation not supported
setfacl: /media/CA842B92842B8055/chmurka//tmp: Operation not supported' in /usr/share/openmediavault/engined/module/owncloud.inc:232
Stack trace:
#0 [internal function]: OMVModuleOwnCloud->setSharedFolderFacl(Array)
#1 /usr/share/php/openmediavault/module.inc(146): call_user_func_array(Array, Array)
#2 /usr/share/openmediavault/engined/module/owncloud.inc(65): OMVModuleAbstract->execTasks('setfacl')
#3 /usr/share/openmediavault/engined/rpc/config.inc(180): OMVModuleOwnCloud->applyConfig()
#4 [internal function]: OMVRpcServiceConfig->applyChanges(Array, Array)
#5 /usr/share/php/openmediavault/rpcservice.inc(125): call_user_func_array(Array, Array)
#6 /usr/share/php/openmediavault/rpcservice.inc(158): OMVRpcServiceAbstract->callMethod('applyChanges', Array, Array)
#7 /usr/share/openmediavault/engined/rpc/config.inc(224): OMVRpcServiceAbstract->callMethodBg('applyChanges', Array, Array)
#8 [internal function]: OMVRpcServiceConfig->applyChangesBg(Array, Array)
#9 /usr/share/php/openmediavault/rpcservice.inc(125): call_user_func_array(Array, Array)
#10 /usr/share/php/openmediavault/rpc.inc(79): OMVRpcServiceAbstract->callMethod('applyChangesBg', Array, Array)
#11 /usr/sbin/omv-engined(500): OMVRpc::exec('Config', 'applyChangesBg', Array, Array, 1)
#12 {main}
Po powrocie do poprzednich ustawień wszystko działa prawie
Usługa uwłacza się jednak pojawia się komunikat
Data directory (/media/CA842B92842B8055/chmurka/) is readable for other users
Please change the permissions to 0770 so that the directory cannot be listed by other users.
Przy czym to ostatnie nie zawsze się pojawia i niekiedy usługa działa normalnie.
Ponowna instalacja OwnCloud-a uniemożliwia konfiguracje usługi wyskakuje powyższy błąd.
Przeglądałem fora ale jak na razie tylko pogarszałem sytuacje.
podejrzewam że jest jakiś problem z zapisem ustawień, ma ktoś jakieś pomysły ??
Re: OMV problem z zapisywaniem ustawień
https://wiki.debian.org/Permissions#Sec ... ermissions
acl zainstalowane?
apt-cache policy acl
chmurka zamontowana z atrybutem acl?
mount
uprawnienia zgodnie z komunikatem ustawione?
ls -l /media/CA842B92842B8055/chmurka
Mefu
Post autor: Mefu »
acl:
Zainstalowana: 2.2.51-8
Kandydująca: 2.2.51-8
Tabela wersji:
*** 2.2.51-8 0
500 http://ftp.pl.debian.org/debian/ wheezy/main amd64 Packages
100 /var/lib/dpkg/status.
Dysk instalowałem w panelu administracyjnym do pierwszego zapisu nie było problemów.
W katalogu współdzielonym w po kliknięciu na folder nie da się włączyć acl
co do uprawnień właśnie nie wychodzi że jest 0777 i jakoś nie bardzo chce się zmienić
Dałem Ci tam linka do wiki odnośnie acl.
Co do uprawnień to musisz rozwinąć myśl "nie wychodzi", "nie bardzo chce się zmienić".
Mefu
Post autor: Mefu »
Uprawnień nie zmienia pozostają takie same.
Samego Owncloud-a nie da się nawet wyłączyć, jedynie odinstalować dodatek
Nie mówiąc o tym że podczas formatowania dysku również jest ten sam błąd
Błąd #4000:
exception 'OMVException' with message 'Failed to execute command 'export LANG=C; blockdev --rereadpt '/dev/sdi' 2>&1': BLKRRPART: Device or resource busy' in /usr/share/openmediavault/engined/rpc/diskmgmt.inc:328
Stack trace:
#0 [internal function]: OMVRpcServiceDiskMgmt->wipe(Array, Array)
#1 /usr/share/php/openmediavault/rpcservice.inc(125): call_user_func_array(Array, Array)
#2 /usr/share/php/openmediavault/rpc.inc(79): OMVRpcServiceAbstract->callMethod('wipe', Array, Array)
#3 /usr/sbin/omv-engined(500): OMVRpc::exec('DiskMgmt', 'wipe', Array, Array, 1)
#4 {main}
Zastanawiam się czy to nie wina kompilacji wgrywam 64 bit na procek intela
nie podoba mi sie że polecenia
apt-get update
zaraz po linijce
Ign. https://e-tobi.net wheezy Release.gpg
100% [Pracuje]
Praktycznie się zawiesza operacja trwała ostatnio całą noc i została brutalnie przerwana reinstalacją systemu
To może czas najpierw doprowadzić system do porządku a potem wykonywać dalsze kroki.
To czekanie w nieskończoność, może wynika po prostu z tego, że te repozytorium już nie istnieje?
Mefu
Post autor: Mefu »
tylko nie wiem które. A system do momentu aktualizacji z pozycji panela działał poprawnie
Spójrz w którym miejscu zatrzymuje się aktualizacja.
Nie wiem co to jest aktualizacja z poziomu panela, może dotyczy tylko omv, a to nie jest aktualizacja systemu na którym stoi omv.
Mefu
Post autor: Mefu »
Z panelu administracyjnego ładowały się wszystkie poprawki samego systemu OMV było ich sporo więc nie wymienię ich.
Problem prawie rozwiązany . Instalowałem OMV-EXTRAS ze strony http://omv-extras.org/joomla/index.php/guides
i wybierałem
openmediavault-omvextrasorg_latest_all.deb
problem zniknął gdy zainstalowałem wersje omvextrasorg 2.13.9. System działa jak powinien jednak mam inny problem wydaje mi się że nie związany z dodatkiem i systemem
Sam owncloud działa przez przeglądarkę jednak wersja na androida po potwierdzeniu certyfikatu wyświetla komunikat
Uszkodzona konfiguracja systemu
