Problem z zamontowaniem partycji
apolloart
Problem z zamontowaniem partycji - Już brak pomysłów
Post autor: apolloart »
Cześć,
Problem z zamontowanie partycji RAID /dev/md1.
polecenie mount:
mount -o ro,loop /dev/md0 /mirror/
mount: wrong fs type, bad option, bad superblock on /dev/loop0
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try dmesg | tail or so.
polecenie parted:
parted -l /dev/sda
Model: ATA WDC WD20EARX-00P (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name  Flags
 1      17,4kB  20,0GB  20,0GB  ext4               msftdata
 2      20,0GB  46,0GB  26,0GB  ext4               msftdata
 3      50,0GB  150GB   99,9GB                     raid
 4      150GB   2000GB  1850GB                     raid
Disk /dev/sdb: 2000GB
Disk Flags:
1      1049kB  20,0GB  20,0GB  ext4
2      20,0GB  50,0GB  30,0GB  ext4
 3      50,0GB  150GB   100GB   ext4
 4      150GB   2000GB  1850GBError: /dev/md1: unrecognised disk label
Model: Linux Software RAID Array (md)
Disk /dev/md1: 1850GB
Partition Table: unknown
Disk Flags:
plik /proc/mdstat:
cat /proc/mdstat
Personalities : [raid1]
md1 : active raid1 sdb4[0]
      1807028224 blocks super 1.2 [2/1] [U_]
      bitmap: 0/14 pages [0KB], 65536KB chunk
polecenie testdisk:
testdisk -l /dev/sda
TestDisk 6.14, Data Recovery Utility, July 2013
Christophe GRENIER <grenier@cgsecurity.org>
[URL]http://www.cgsecurity.org[/URL]
Please wait...
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
Sector size:512
Model: WDC WD20EARX-00PASB0, S/N:WD-WMAZA7661879, FW:51.0AB51
     Partition                  Start        End    Size in sectors
 1 P MS Data                       34   39059489   39059456
     ext4 blocksize=4096 Large file Sparse superblock
 2 P MS Data                 39064583   89804798   50740216
 3 P Linux Raid              97656286  292835301  195179016 [robot:0]
     md 1.x L.Endian Raid 1 - Array Slot : 0 (0, failed, failed, failed, failed)
 4 P Linux Raid             292968787 3906764634 3613795848 [robot:1]
polecenie mdamd -E:
mdadm -E /dev/sda4
/dev/sda4:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Array UUID : 6a57d8b3:ad2c289a:b95d0b20:e452d85e
           Name : robot:1  (local to host robot)
  Creation Time : Sat Jan  2 13:51:49 2016
     Raid Level : raid1
   Raid Devices : 2
 Avail Dev Size : 3613795876 (1723.19 GiB 1850.26 GB)
     Array Size : 1806897920 (1723.19 GiB 1850.26 GB)
  Used Dev Size : 3613795840 (1723.19 GiB 1850.26 GB)
    Data Offset : 262144 sectors
   Super Offset : 8 sectors
   Unused Space : before=262056 sectors, after=18446744073709289480 sectors
          State : clean
    Device UUID : fe1dda88:49bc489e:27594892:32e1494c
Internal Bitmap : 8 sectors from superblock
    Update Time : Sat Jan  2 18:53:46 2016
  Bad Block Log : 512 entries available at offset 72 sectors
       Checksum : 4c0c6892 - correct
         Events : 33
   Device Role : Active device 0
   Array State : A. ('A' == active, '.' == missing, 'R' == replacing)
Już nie wiem co mogę więcej zrobić.
Pozdrawiam,
Dawid
pasman
Post autor: pasman »
co się stanie jak usuniesz opcję loop ?
apolloart
Próbowałem bez loop, a również z -t ext4 i jest ten sam komunikat niestety.
Proszę używać tagów CODE.
apolloart
Dzięki Marcin za upomnienie publiczne. Mój wpis wygląda lepiej, ale problem niestety stoi w tym samym miejscu.
