Gdy próbuje zainstalowac mysql otrzymuje taki komunikat
apt-get install mysql-server
Reading Package Lists... Done
Building Dependency Tree... Done
The following extra packages will be installed:
libdbd-mysql-perl libmysqlclient12 mysql-client mysql-common
Suggested packages:
mysql-doc
The following NEW packages will be installed:
libdbd-mysql-perl libmysqlclient12 mysql-client mysql-common mysql-server
0 upgraded, 5 newly installed, 0 to remove and 18 not upgraded.
Need to get 0B/4525kB of archives.
After unpacking 10.5MB of additional disk space will be used.
Do you want to continue? [Y/n]
Preconfiguring packages ...
Selecting previously deselected package mysql-common.
(Reading database ... 27352 files and directories currently installed.)
Unpacking mysql-common (from .../mysql-common_4.0.24-10sarge2_all.deb) ...
Selecting previously deselected package libmysqlclient12.
Unpacking libmysqlclient12 (from .../libmysqlclient12_4.0.24-10sarge2_i386.deb)
Selecting previously deselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from .../libdbd-mysql-perl_2.9006-1_i386.deb) ...
Selecting previously deselected package mysql-client.
Unpacking mysql-client (from .../mysql-client_4.0.24-10sarge2_i386.deb) ...
Selecting previously deselected package mysql-server.
Unpacking mysql-server (from .../mysql-server_4.0.24-10sarge2_i386.deb) ...
find: /var/lib/mysql/mysql.sock: No such file or directory
Setting up mysql-common (4.0.24-10sarge2) ...
Setting up libmysqlclient12 (4.0.24-10sarge2) ...
Setting up libdbd-mysql-perl (2.9006-1) ...
Setting up mysql-client (4.0.24-10sarge2) ...
Setting up mysql-server (4.0.24-10sarge2) ...
Stopping MySQL database server: mysqld.
WARNING: /etc/mysql/my.cnf cannot be read. See README.Debian.
Starting MySQL database server: mysqld...failed.
Please take a look at the syslog.
/usr/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysq
ld.sock' (2)'
Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock'
exists!
Pozdrawiam Marcin
