Problem z instalacj
bojawiem55
Problem z instalacją pakietów
Post autor: bojawiem55 »
Witam gdy próbuje instalować jakie kolwiek pakiety wyrzuca mi taki błąd
 libsmbclient : Depends: samba-libs (= 2:4.1.17+dfsg-2) but it is not going to be installed
 python-samba : Depends: python-crypto but it is not going to be installed
 samba : Depends: samba-common (= 2:3.5.6~dfsg-3squeeze11) but 2:4.1.17+dfsg-2 is to be installed
         Depends: libwbclient0 (= 2:3.5.6~dfsg-3squeeze11) but 2:4.1.17+dfsg-2 is to be installed
 samba-dsdb-modules : Depends: samba-libs (= 2:4.1.17+dfsg-2) but it is not going to be installed
 samba-vfs-modules : Depends: samba-libs (= 2:4.1.17+dfsg-2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Gdy wykonam komendę apt-get -f install
Mam takie błędy
[/color]
dpkg: error processing /var/cache/apt/archives/python-dnspython_1.12.0-1_all.deb (--unpack):
 parse error, in file '/var/lib/dpkg/tmp.ci/control' near line 7 package 'python-dnspython':
 `Depends' field, invalid package name `python:any': character `:' not allowed (only letters, digits and characters `-+._')
configured to not write apport reports
                                      dpkg: error processing /var/cache/apt/archives/python-crypto_2.6.1-5+b2_amd64.deb (--unpack):
 parse error, in file '/var/lib/dpkg/tmp.ci/control' near line 7 package 'python-crypto':
                                      dpkg: error processing /var/cache/apt/archives/samba-common-bin_2%3a4.1.17+dfsg-2_amd64.deb (--unpack):
 parse error, in file '/var/lib/dpkg/tmp.ci/control' near line 7 package 'samba-common-bin':
 `Depends' field, invalid package name `python2.7:any': character `:' not allowed (only letters, digits and characters `-+._')
                                      dpkg: error processing /var/cache/apt/archives/samba_2%3a4.1.17+dfsg-2_amd64.deb (--unpack):
 parse error, in file '/var/lib/dpkg/tmp.ci/control' near line 7 package 'samba':
                                      dpkg: regarding .../samba-libs_2%3a4.1.17+dfsg-2_amd64.deb containing samba-libs:
 samba-libs conflicts with samba (<< 2:4)
  samba (version 2:3.5.6~dfsg-3squeeze11) is present and installed.
dpkg: error processing /var/cache/apt/archives/samba-libs_2%3a4.1.17+dfsg-2_amd64.deb (--unpack):
 conflicting packages - not installing samba-libs
                                      Errors were encountered while processing:
