Google nie pokazuje mi nic na temat, więc zwracam się z prośbą o pomoc tutaj.
Problem:
Zawiesza się touchpad, czasem sam od siebie, zawsze po uruchomieniu się wygaszacza ekranu. Problem pojawił się po jednej z aktualizacji. Ponowne zalogowanie się niweluje problem.
dane o systemie i komunikaty:
Linux debian 3.2.0-4-486 #1 Debian 3.2.51-1 i686 GNU/Linux
/var/log/Xorg.0.log.old pokazuje
(!!) BUG: Device "SynPS/2 Synaptics TouchPad" received a double tracking ID 195 in slot 0.
(!!) BUG: Device "SynPS/2 Synaptics TouchPad" received a double tracking ID 196 in slot 1
cały plik wygląda tak:
[ 702.361]
X.Org X Server 1.16.0
Release Date: 2014-07-16
[ 702.361] X Protocol Version 11, Revision 0
[ 702.362] Build Operating System: Linux 3.2.0-4-amd64 i686 Debian
[ 702.362] Current Operating System: Linux debian 3.2.0-4-486 #1 Debian 3.2.51-1 i686
[ 702.362] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-486 root=UUID=010916b0-870f-4c10-a98a-0c997cfdb85e ro
[ 702.362] Build Date: 17 July 2014 11:01:50PM
[ 702.362] xorg-server 2:1.16.0-1 (http://www.debian.org/support)
[ 702.362] Current version of pixman: 0.32.6
[ 702.362] Before reporting problems, check http://wiki.x.org
[ 702.362] Markers: (--) probed, (**) from config file, (==) default setting,
[ 702.362] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 26 16:31:16 2014
[ 702.363] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 702.391] (==) No Layout section. Using the first Screen section.
[ 702.391] (==) No screen section available. Using defaults.
[ 702.391] (**) |-->Screen "Default Screen Section" (0)
[ 702.391] (**) | |-->Monitor "<default monitor>"
[ 702.391] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 702.391] (==) Automatically adding devices
[ 702.392] (==) Automatically enabling devices
[ 702.392] (==) Automatically adding GPU devices
[ 702.392] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 702.392] Entry deleted from font path.
[ 702.401] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 702.401] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 702.401] (II) The server relies on udev to provide the list of input devices.
[ 702.401] (II) Loader magic: 0xb778d700
[ 702.401] (II) Module ABI versions:
[ 702.401] X.Org ANSI C Emulation: 0.4
[ 702.402] X.Org Video Driver: 18.0
[ 702.402] X.Org XInput driver : 21.0
[ 702.402] X.Org Server Extension : 8.0
[ 702.402] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 702.405] (--) PCI:*(0:0:2:0) 8086:a011:1179:fdc0 rev 0, Mem @ 0xf0200000/524288, 0xd0000000/268435456, 0xf0000000/1048576, I/O @ 0x000018d0/8
[ 702.408] (--) PCI: (0:0:2:1) 8086:a012:1179:fdc0 rev 0, Mem @ 0xf0280000/524288
[ 702.408] (II) LoadModule: "glx"
[ 702.409] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 702.557] (II) Module glx: vendor="X.Org Foundation"
[ 702.557] compiled for 1.16.0, module version = 1.0.0
[ 702.557] ABI class: X.Org Server Extension, version 8.0
[ 702.557] (==) AIGLX enabled
[ 702.557] (==) Matched intel as autoconfigured driver 0
[ 702.557] (==) Matched intel as autoconfigured driver 1
[ 702.557] (==) Matched modesetting as autoconfigured driver 2
[ 702.557] (==) Matched fbdev as autoconfigured driver 3
[ 702.557] (==) Matched vesa as autoconfigured driver 4
[ 702.557] (==) Assigned the driver to the xf86ConfigLayout
[ 702.557] (II) LoadModule: "intel"
[ 702.558] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 702.568] (II) Module intel: vendor="X.Org Foundation"
[ 702.568] compiled for 1.15.99.904, module version = 2.21.15
[ 702.568] Module class: X.Org Video Driver
[ 702.568] ABI class: X.Org Video Driver, version 18.0
[ 702.568] (II) LoadModule: "modesetting"
[ 702.569] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 702.577] (II) Module modesetting: vendor="X.Org Foundation"
[ 702.577] compiled for 1.15.99.904, module version = 0.9.0
[ 702.577] Module class: X.Org Video Driver
[ 702.577] ABI class: X.Org Video Driver, version 18.0
[ 702.577] (II) LoadModule: "fbdev"
[ 702.578] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 702.584] (II) Module fbdev: vendor="X.Org Foundation"
[ 702.584] compiled for 1.15.99.904, module version = 0.4.4
[ 702.584] Module class: X.Org Video Driver
[ 702.584] ABI class: X.Org Video Driver, version 18.0
[ 702.585] (II) LoadModule: "vesa"
[ 702.585] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 702.586] (II) Module vesa: vendor="X.Org Foundation"
[ 702.586] compiled for 1.15.99.904, module version = 2.3.3
[ 702.586] Module class: X.Org Video Driver
[ 702.586] ABI class: X.Org Video Driver, version 18.0
[ 702.586] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43, HD Graphics,
HD Graphics 2000, HD Graphics 3000, HD Graphics 2500,
HD Graphics 4000, HD Graphics P4000, HD Graphics 4600,
HD Graphics 5000, HD Graphics P4600/P4700, Iris(TM) Graphics 5100,
HD Graphics 4400, HD Graphics 4200, Iris(TM) Pro Graphics 5200
[ 702.588] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 702.588] (II) FBDEV: driver for framebuffer: fbdev
[ 702.588] (II) VESA: driver for VESA chipsets: vesa
[ 702.588] (++) using VT number 7
[ 702.593] (WW) Falling back to old probe method for modesetting
[ 702.593] (WW) Falling back to old probe method for fbdev
[ 702.593] (II) Loading sub module "fbdevhw"
[ 702.593] (II) LoadModule: "fbdevhw"
[ 702.594] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 702.606] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 702.606] compiled for 1.16.0, module version = 0.0.2
[ 702.606] ABI class: X.Org Video Driver, version 18.0
[ 702.606] (WW) Falling back to old probe method for vesa
[ 702.606] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 702.606] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 702.606] (==) intel(0): RGB weight 888
[ 702.606] (==) intel(0): Default visual is TrueColor
[ 702.606] (--) intel(0): Integrated Graphics Chipset: Intel(R) Pineview GM
[ 702.607] (**) intel(0): Relaxed fencing enabled
[ 702.607] (**) intel(0): Wait on SwapBuffers? enabled
[ 702.607] (**) intel(0): Triple buffering? enabled
[ 702.607] (**) intel(0): Framebuffer tiled
[ 702.607] (**) intel(0): Pixmaps tiled
[ 702.607] (**) intel(0): 3D buffers tiled
[ 702.607] (**) intel(0): SwapBuffers wait enabled
[ 702.607] (==) intel(0): video overlay key set to 0x101fe
[ 702.607] (II) intel(0): Output LVDS1 has no monitor section
[ 702.608] (--) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 702.640] (II) intel(0): Output VGA1 has no monitor section
[ 702.640] (II) intel(0): EDID for output LVDS1
[ 702.640] (II) intel(0): Manufacturer: AUO Model: 30d2 Serial#: 0
[ 702.640] (II) intel(0): Year: 2008 Week: 1
[ 702.640] (II) intel(0): EDID Version: 1.3
[ 702.640] (II) intel(0): Digital Display Input
[ 702.640] (II) intel(0): Max Image Size [cm]: horiz.: 22 vert.: 13
[ 702.640] (II) intel(0): Gamma: 2.20
[ 702.640] (II) intel(0): No DPMS capabilities specified
[ 702.640] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 702.640] (II) intel(0): First detailed timing is preferred mode
[ 702.640] (II) intel(0): redX: 0.588 redY: 0.351 greenX: 0.342 greenY: 0.567
[ 702.640] (II) intel(0): blueX: 0.158 blueY: 0.123 whiteX: 0.313 whiteY: 0.329
[ 702.640] (II) intel(0): Manufacturer's mask: 0
[ 702.640] (II) intel(0): Supported detailed timing:
[ 702.640] (II) intel(0): clock: 50.4 MHz Image Size: 223 x 125 mm
[ 702.640] (II) intel(0): h_active: 1024 h_sync: 1048 h_sync_end 1184 h_blank_end 1344 h_border: 0
[ 702.641] (II) intel(0): v_active: 600 v_sync: 603 v_sync_end 604 v_blanking: 625 v_border: 0
[ 702.641] (II) intel(0): Unknown vendor-specific block f
[ 702.641] (II) intel(0): AUO
[ 702.641] (II) intel(0): B101AW03 V0
[ 702.641] (II) intel(0): EDID (in hex):
[ 702.641] (II) intel(0): 00ffffffffffff0006afd23000000000
[ 702.641] (II) intel(0): 0112010380160d780ab9a59659579128
[ 702.641] (II) intel(0): 1f505400000001010101010101010101
[ 702.641] (II) intel(0): 010101010101b0130040415819201888
[ 702.641] (II) intel(0): 3100df7d000000180000000f00000000
[ 702.641] (II) intel(0): 00000000000000000020000000fe0041
[ 702.641] (II) intel(0): 554f0a202020202020202020000000fe
[ 702.641] (II) intel(0): 004231303141573033205630200a00f0
[ 702.642] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
[ 702.642] (II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
[ 702.642] (II) intel(0): Printing probed modes for output LVDS1
[ 702.642] (II) intel(0): Modeline "1024x600"x60.0 50.40 1024 1048 1184 1344 600 603 604 625 -hsync -vsync (37.5 kHz eP)
[ 702.642] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 702.642] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 702.642] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 702.672] (II) intel(0): EDID for output VGA1
[ 702.672] (II) intel(0): Output LVDS1 connected
[ 702.672] (II) intel(0): Output VGA1 disconnected
[ 702.672] (II) intel(0): Using exact sizes for initial modes
[ 702.672] (II) intel(0): Output LVDS1 using initial mode 1024x600
[ 702.672] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 702.672] (II) intel(0): Kernel page flipping support detected, enabling
[ 702.672] (==) intel(0): DPI set to (96, 96)
[ 702.672] (II) Loading sub module "fb"
[ 702.672] (II) LoadModule: "fb"
[ 702.673] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 702.681] (II) Module fb: vendor="X.Org Foundation"
[ 702.682] compiled for 1.16.0, module version = 1.0.0
[ 702.682] ABI class: X.Org ANSI C Emulation, version 0.4
[ 702.682] (II) Loading sub module "dri2"
[ 702.682] (II) LoadModule: "dri2"
[ 702.682] (II) Module "dri2" already built-in
[ 702.682] (II) UnloadModule: "modesetting"
[ 702.682] (II) Unloading modesetting
[ 702.682] (II) UnloadModule: "fbdev"
[ 702.682] (II) Unloading fbdev
[ 702.682] (II) UnloadSubModule: "fbdevhw"
[ 702.682] (II) Unloading fbdevhw
[ 702.682] (II) UnloadModule: "vesa"
[ 702.682] (II) Unloading vesa
[ 702.682] (==) Depth 24 pixmap format is 32 bpp
[ 702.683] (II) intel(0): [DRI2] Setup complete
[ 702.683] (II) intel(0): [DRI2] DRI driver: i915
[ 702.683] (II) intel(0): Allocated new frame buffer 1024x600 stride 4096, tiled
[ 702.683] (II) UXA(0): Driver registered support for the following operations:
[ 702.683] (II) solid
[ 702.683] (II) copy
[ 702.683] (II) composite (RENDER acceleration)
[ 702.683] (II) put_image
[ 702.683] (II) get_image
[ 702.683] (==) intel(0): Backing store enabled
[ 702.683] (==) intel(0): Silken mouse enabled
[ 702.684] (II) intel(0): Initializing HW Cursor
[ 702.684] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 702.692] (==) intel(0): DPMS enabled
[ 702.692] (==) intel(0): Intel XvMC decoder disabled
[ 702.692] (II) intel(0): Set up textured video
[ 702.693] (II) intel(0): Set up overlay video
[ 702.693] (II) intel(0): direct rendering: DRI2 Enabled
[ 702.693] (==) intel(0): hotplug detection: "enabled"
[ 702.720] (--) RandR disabled
[ 702.798] (II) SELinux: Disabled on system
[ 702.854] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 702.864] (II) AIGLX: enabled GLX_ARB_create_context
[ 702.864] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 702.864] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[ 702.864] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 702.864] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 702.864] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 702.864] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 702.864] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 702.868] (II) AIGLX: Loaded and initialized i915
[ 702.868] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 702.869] (II) intel(0): Setting screen physical size to 270 x 158
[ 703.296] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 703.300] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 703.300] (II) LoadModule: "evdev"
[ 703.300] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 703.300] (II) Module evdev: vendor="X.Org Foundation"
[ 703.301] compiled for 1.15.99.904, module version = 2.8.2
[ 703.301] Module class: X.Org XInput Driver
[ 703.301] ABI class: X.Org XInput driver, version 21.0
[ 703.301] (II) Using input driver 'evdev' for 'Power Button'
[ 703.301] (**) Power Button: always reports core events
[ 703.301] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 703.301] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 703.301] (--) evdev: Power Button: Found keys
[ 703.301] (II) evdev: Power Button: Configuring as keyboard
[ 703.301] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 703.301] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 703.301] (**) Option "xkb_rules" "evdev"
[ 703.301] (**) Option "xkb_model" "pc105"
[ 703.301] (**) Option "xkb_layout" "pl"
[ 703.478] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 703.478] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 703.478] (II) Using input driver 'evdev' for 'Video Bus'
[ 703.478] (**) Video Bus: always reports core events
[ 703.478] (**) evdev: Video Bus: Device: "/dev/input/event8"
[ 703.478] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 703.479] (--) evdev: Video Bus: Found keys
[ 703.479] (II) evdev: Video Bus: Configuring as keyboard
[ 703.479] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event8"
[ 703.479] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 703.479] (**) Option "xkb_rules" "evdev"
[ 703.479] (**) Option "xkb_model" "pc105"
[ 703.479] (**) Option "xkb_layout" "pl"
[ 703.484] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 703.484] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 703.484] (II) Using input driver 'evdev' for 'Power Button'
[ 703.484] (**) Power Button: always reports core events
[ 703.484] (**) evdev: Power Button: Device: "/dev/input/event2"
[ 703.485] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 703.485] (--) evdev: Power Button: Found keys
[ 703.485] (II) evdev: Power Button: Configuring as keyboard
[ 703.485] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0C:00/input/input2/event2"
[ 703.485] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 703.485] (**) Option "xkb_rules" "evdev"
[ 703.485] (**) Option "xkb_model" "pc105"
[ 703.485] (**) Option "xkb_layout" "pl"
[ 703.487] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 703.487] (II) No input driver specified, ignoring this device.
[ 703.487] (II) This device may have been added with another device file.
[ 703.496] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event5)
[ 703.496] (II) No input driver specified, ignoring this device.
[ 703.496] (II) This device may have been added with another device file.
[ 703.497] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event6)
[ 703.497] (II) No input driver specified, ignoring this device.
[ 703.497] (II) This device may have been added with another device file.
[ 703.498] (II) config/udev: Adding input device CNF9055 (/dev/input/event10)
[ 703.498] (**) CNF9055: Applying InputClass "evdev keyboard catchall"
[ 703.498] (II) Using input driver 'evdev' for 'CNF9055'
[ 703.498] (**) CNF9055: always reports core events
[ 703.498] (**) evdev: CNF9055: Device: "/dev/input/event10"
[ 703.498] (--) evdev: CNF9055: Vendor 0x4f2 Product 0xb1d6
[ 703.499] (--) evdev: CNF9055: Found keys
[ 703.499] (II) evdev: CNF9055: Configuring as keyboard
[ 703.499] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb1/1-8/1-8:1.0/input/input10/event10"
[ 703.499] (II) XINPUT: Adding extended input device "CNF9055" (type: KEYBOARD, id 9)
[ 703.499] (**) Option "xkb_rules" "evdev"
[ 703.499] (**) Option "xkb_model" "pc105"
[ 703.499] (**) Option "xkb_layout" "pl"
[ 703.507] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 703.512] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 703.512] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 703.512] (**) AT Translated Set 2 keyboard: always reports core events
[ 703.512] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 703.512] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 703.512] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 703.512] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 703.512] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 703.512] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 703.512] (**) Option "xkb_rules" "evdev"
[ 703.512] (**) Option "xkb_model" "pc105"
[ 703.512] (**) Option "xkb_layout" "pl"
[ 703.514] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event9)
[ 703.514] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 703.514] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 703.514] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[ 703.523] (II) LoadModule: "synaptics"
[ 703.528] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 703.529] (II) Module synaptics: vendor="X.Org Foundation"
[ 703.529] compiled for 1.15.99.904, module version = 1.8.0
[ 703.529] Module class: X.Org XInput Driver
[ 703.529] ABI class: X.Org XInput driver, version 21.0
[ 703.529] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[ 703.529] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 703.529] (**) Option "Device" "/dev/input/event9"
[ 703.529] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[ 703.529] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5612 (res 62)
[ 703.530] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4618 (res 124)
[ 703.530] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 703.530] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 703.530] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[ 703.530] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 703.530] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 703.530] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 703.530] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input9/event9"
[ 703.530] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 11)
[ 703.530] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 703.530] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[ 703.530] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.038
[ 703.531] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 703.531] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 703.531] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 703.531] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 703.531] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 703.540] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 703.540] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[ 703.541] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 703.541] (II) No input driver specified, ignoring this device.
[ 703.541] (II) This device may have been added with another device file.
[ 703.543] (II) config/udev: Adding input device Toshiba input device (/dev/input/event4)
[ 703.543] (**) Toshiba input device: Applying InputClass "evdev keyboard catchall"
[ 703.543] (II) Using input driver 'evdev' for 'Toshiba input device'
[ 703.543] (**) Toshiba input device: always reports core events
[ 703.543] (**) evdev: Toshiba input device: Device: "/dev/input/event4"
[ 703.543] (--) evdev: Toshiba input device: Vendor 0 Product 0
[ 703.543] (--) evdev: Toshiba input device: Found keys
[ 703.543] (II) evdev: Toshiba input device: Configuring as keyboard
[ 703.543] (**) Option "config_info" "udev:/sys/devices/virtual/input/input4/event4"
[ 703.543] (II) XINPUT: Adding extended input device "Toshiba input device" (type: KEYBOARD, id 12)
[ 703.543] (**) Option "xkb_rules" "evdev"
[ 703.543] (**) Option "xkb_model" "pc105"
[ 703.543] (**) Option "xkb_layout" "pl"
(!!) BUG: Device "SynPS/2 Synaptics TouchPad" received a double tracking ID 196 in slot 1.
[ 714.047] (II) intel(0): EDID vendor "AUO", prod id 12498
[ 714.048] (II) intel(0): Printing DDC gathered Modelines:
[ 714.048] (II) intel(0): Modeline "1024x600"x0.0 50.40 1024 1048 1184 1344 600 603 604 625 -hsync -vsync (37.5 kHz eP)
[ 720.080] (II) intel(0): EDID vendor "AUO", prod id 12498
[ 720.084] (II) intel(0): Printing DDC gathered Modelines:
[ 720.084] (II) intel(0): Modeline "1024x600"x0.0 50.40 1024 1048 1184 1344 600 603 604 625 -hsync -vsync (37.5 kHz eP)
[ 720.117] (II) intel(0): EDID vendor "AUO", prod id 12498
[ 720.117] (II) intel(0): Printing DDC gathered Modelines:
[ 720.117] (II) intel(0): Modeline "1024x600"x0.0 50.40 1024 1048 1184 1344 600 603 604 625 -hsync -vsync (37.5 kHz eP)
[ 750.119] (EE) intel(0): Failed to submit batch buffer, expect rendering corruption: Resource deadlock avoided.
(EE) SynPS/2 Synaptics TouchPad: Read error 22
(II) evdev: Toshiba input device: Close
[ 1442.889] (II) UnloadModule: "evdev"
[ 1442.889] (II) UnloadModule: "synaptics"
[ 1442.889] (II) evdev: AT Translated Set 2 keyboard: Close
[ 1442.889] (II) evdev: CNF9055: Close
[ 1442.890] (II) evdev: Power Button: Close
[ 1442.890] (II) UnloadModule: "evdev"
[ 1442.890] (II) evdev: Video Bus: Close
[ 1443.768] (EE) Server terminated successfully (0). Closing log file.
root@debian:/home/marcin# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-486 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 Debian 3.2.51-1
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009dc00 (usable)
[ 0.000000] BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000ce000 - 00000000000d0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 00000000000e0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f5d0000 (usable)
[ 0.000000] BIOS-e820: 000000003f5d0000 - 000000003f5e0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f5e0000 - 000000003f5e3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f5e3000 - 0000000040000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: TOSHIBA TOSHIBA NB500/PBU00, BIOS V1.70 04/06/2011
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3f5d0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 0C0000000 write-back
[ 0.000000] 1 base 0FFE00000 mask 0FFE00000 write-protect
[ 0.000000] 2 base 03F600000 mask 0FFE00000 uncachable
[ 0.000000] 3 base 03F800000 mask 0FF800000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f7d50] f7d50
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 12288
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 17f8000-1800000
[ 0.000000] RAMDISK: 37a2a000 - 37d0d000
[ 0.000000] Allocated new RAMDISK: 3751b000 - 377fdbb0
[ 0.000000] Move RAMDISK from 0000000037a2a000 - 0000000037d0cbaf to 3751b000 - 377fdbaf
[ 0.000000] ACPI: RSDP 000f7cb0 00024 (v02 TOSCPL)
[ 0.000000] ACPI: XSDT 3f5d4d23 00084 (v01 TOSCPL TOSCPL00 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 3f5dfc60 000F4 (v03 TOSCPL TOSCPL00 06040000 PTL 00000002)
[ 0.000000] ACPI: DSDT 3f5d679d 0944F (v01 TOSCPL TOSCPL00 06040000 MSFT 03000000)
[ 0.000000] ACPI: FACS 3f5e2fc0 00040
[ 0.000000] ACPI: TCPA 3f5dfd54 00032 (v01 Phoeni x 06040000 TL 00000000)
[ 0.000000] ACPI: HPET 3f5dfd86 00038 (v01 TOSCPL TOSCPL00 06040000 LOHR 0000005A)
[ 0.000000] ACPI: MCFG 3f5dfdbe 0003C (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: APIC 3f5dfdfa 00068 (v01 TOSCPL TOSCPL00 06040000 LTP 00000000)
[ 0.000000] ACPI: BOOT 3f5dfe62 00028 (v01 TOSCPL TOSCPL00 06040000 LTP 00000001)
[ 0.000000] ACPI: SLIC 3f5dfe8a 00176 (v01 TOSCPL TOSCPL00 06040000 RHOL 00000000)
[ 0.000000] ACPI: SSDT 3f5d594b 0025F (v01 PmRef Cpu0Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 3f5d58a5 000A6 (v01 PmRef Cpu3Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 3f5d57ff 000A6 (v01 PmRef Cpu2Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 3f5d5759 000A6 (v01 PmRef Cpu1Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 3f5d4da7 009B2 (v02 PmRef CpuPm 00003000 INTL 20050624)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 125MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003f5d0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x0003f5d0
[ 0.000000] On node 0 totalpages: 259421
[ 0.000000] free_area_init_node: node 0, pgdat c13c5a78, node_mem_map f6d2a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 252 pages used for memmap
[ 0.000000] HighMem zone: 31958 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: NR_CPUS/possible_cpus limit of 1 reached. Processor 1/0x1 ignored.
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000ce000
[ 0.000000] PM: Registered nosave memory: 00000000000ce000 - 00000000000d0000
[ 0.000000] PM: Registered nosave memory: 00000000000d0000 - 00000000000dc000
[ 0.000000] PM: Registered nosave memory: 00000000000dc000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:a0000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257393
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-486 root=UUID=010916b0-870f-4c10-a98a-0c997cfdb85e ro
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003f5d0)
[ 0.000000] Memory: 1020876k/1038144k available (2596k kernel code, 16808k reserved, 1292k data, 452k init, 128840k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfffa1000 - 0xfffff000 ( 376 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc13cd000 - 0xc143e000 ( 452 kB)
[ 0.000000] .data : 0xc128936c - 0xc13cc6c0 (1292 kB)
[ 0.000000] .text : 0xc1000000 - 0xc128936c (2596 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f6808000 soft=f680a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1662.776 MHz processor.
[ 0.004002] Calibrating delay loop (skipped), value calculated using timer frequency.. 3325.55 BogoMIPS (lpj=6651104)
[ 0.004167] pid_max: default: 32768 minimum: 301
[ 0.004308] Security Framework initialized
[ 0.004390] AppArmor: AppArmor disabled by boot time parameter
[ 0.008028] Mount-cache hash table entries: 512
[ 0.008276] Initializing cgroup subsys cpuacct
[ 0.008360] Initializing cgroup subsys memory
[ 0.008448] Initializing cgroup subsys devices
[ 0.008528] Initializing cgroup subsys freezer
[ 0.008606] Initializing cgroup subsys net_cls
[ 0.008684] Initializing cgroup subsys blkio
[ 0.008770] Initializing cgroup subsys perf_event
[ 0.008893] using mwait in idle threads.
[ 0.008977] CPU: Intel(R) Atom(TM) CPU N455 @ 1.66GHz stepping 0a
[ 0.009717] ACPI: Core revision 20110623
[ 0.020079] Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
[ 0.020292] ... version: 3
[ 0.020368] ... bit width: 40
[ 0.020445] ... generic registers: 2
[ 0.020521] ... value mask: 000000ffffffffff
[ 0.020602] ... max period: 000000007fffffff
[ 0.020683] ... fixed-purpose events: 3
[ 0.020759] ... event mask: 0000000700000003
[ 0.021058] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.021194] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.021695] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.064003] devtmpfs: initialized
[ 0.064003] PM: Registering ACPI NVS region at 3f5e0000 (12288 bytes)
[ 0.064003] print_constraints: dummy:
[ 0.064003] NET: Registered protocol family 16
[ 0.064003] EISA bus registered
[ 0.064003] ACPI: bus type pci registered
[ 0.064003] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.064003] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.064003] PCI: Using MMCONFIG for extended config space
[ 0.064003] PCI: Using configuration type 1 for base access
[ 0.064003] bio: create slab <bio-0> at 0
[ 0.064003] ACPI: Added _OSI(Module Device)
[ 0.064003] ACPI: Added _OSI(Processor Device)
[ 0.064003] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.064003] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.066074] ACPI: EC: Look up EC in DSDT
[ 0.073954] ACPI: SSDT 3f5d631e 00203 (v02 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.074666] ACPI: Dynamic OEM Table Load:
[ 0.074818] ACPI: SSDT (null) 00203 (v02 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.075387] ACPI: SSDT 3f5d5baa 005E5 (v02 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.076069] ACPI: Dynamic OEM Table Load:
[ 0.076221] ACPI: SSDT (null) 005E5 (v02 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.077004] ACPI: Interpreter enabled
[ 0.077004] ACPI: (supports S0 S3 S4 S5)
[ 0.077004] ACPI: Using IOAPIC for interrupt routing
[ 0.125405] ACPI: EC: GPE = 0x19, I/O: command/status = 0x66, data = 0x62
[ 0.125829] ACPI: No dock devices found.
[ 0.125907] HEST: Table not found.
[ 0.125986] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.127749] ACPI Error: [CAPB] Namespace lookup failure, AE_ALREADY_EXISTS (20110623/dsfield-143)
[ 0.127988] ACPI Error: Method parse/execution failed [\_SB_.PCI0._OSC] (Node f68282f0), AE_ALREADY_EXISTS (20110623/psparse-536)
[ 0.128253] ACPI: Marking method _OSC as Serialized because of AE_ALREADY_EXISTS error
[ 0.128451] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3f])
[ 0.131545] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.131635] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.131749] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.131862] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.132015] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.132129] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.136016] pci_root PNP0A08:00: host bridge window [mem 0x40000000-0xf7ffffff]
[ 0.136133] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xfdff]
[ 0.140038] pci 0000:00:00.0: [8086:a010] type 0 class 0x000600
[ 0.140098] pci 0000:00:02.0: [8086:a011] type 0 class 0x000300
[ 0.140114] pci 0000:00:02.0: reg 10: [mem 0xf0200000-0xf027ffff]
[ 0.140124] pci 0000:00:02.0: reg 14: [io 0x18d0-0x18d7]
[ 0.140135] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.140145] pci 0000:00:02.0: reg 1c: [mem 0xf0000000-0xf00fffff]
[ 0.140195] pci 0000:00:02.1: [8086:a012] type 0 class 0x000380
[ 0.140208] pci 0000:00:02.1: reg 10: [mem 0xf0280000-0xf02fffff]
[ 0.140308] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
[ 0.140332] pci 0000:00:1b.0: reg 10: [mem 0xf0300000-0xf0303fff 64bit]
[ 0.140424] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.140462] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[ 0.140556] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.140592] pci 0000:00:1c.1: [8086:27d2] type 1 class 0x000604
[ 0.140685] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.140723] pci 0000:00:1c.2: [8086:27d4] type 1 class 0x000604
[ 0.140815] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.140854] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[ 0.140908] pci 0000:00:1d.0: reg 20: [io 0x1820-0x183f]
[ 0.140956] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[ 0.141010] pci 0000:00:1d.1: reg 20: [io 0x1840-0x185f]
[ 0.141057] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[ 0.141110] pci 0000:00:1d.2: reg 20: [io 0x1860-0x187f]
[ 0.141158] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[ 0.141210] pci 0000:00:1d.3: reg 20: [io 0x1880-0x189f]
[ 0.141269] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[ 0.141297] pci 0000:00:1d.7: reg 10: [mem 0xf0504000-0xf05043ff]
[ 0.141408] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.141441] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
[ 0.141528] pci 0000:00:1f.0: [8086:27bc] type 0 class 0x000601
[ 0.141628] pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared
[ 0.141777] pci 0000:00:1f.2: [8086:27c0] type 0 class 0x000101
[ 0.141798] pci 0000:00:1f.2: reg 10: [io 0x0000-0x0007]
[ 0.141811] pci 0000:00:1f.2: reg 14: [io 0x0000-0x0003]
[ 0.141825] pci 0000:00:1f.2: reg 18: [io 0x0000-0x0007]
[ 0.141839] pci 0000:00:1f.2: reg 1c: [io 0x0000-0x0003]
[ 0.141853] pci 0000:00:1f.2: reg 20: [io 0x18c0-0x18cf]
[ 0.141867] pci 0000:00:1f.2: reg 24: [mem 0x00000000-0x000003ff]
[ 0.141908] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.141932] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[ 0.142000] pci 0000:00:1f.3: reg 20: [io 0x18a0-0x18bf]
[ 0.142101] pci 0000:00:1c.0: PCI bridge to [bus 05-05]
[ 0.142272] pci 0000:07:00.0: [10ec:8176] type 0 class 0x000280
[ 0.142299] pci 0000:07:00.0: reg 10: [io 0x2000-0x20ff]
[ 0.142341] pci 0000:07:00.0: reg 18: [mem 0xf0100000-0xf0103fff 64bit]
[ 0.142457] pci 0000:07:00.0: supports D1 D2
[ 0.142462] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.148033] pci 0000:00:1c.1: PCI bridge to [bus 07-07]
[ 0.148121] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.148129] pci 0000:00:1c.1: bridge window [mem 0xf0100000-0xf01fffff]
[ 0.148229] pci 0000:09:00.0: [10ec:8136] type 0 class 0x000200
[ 0.148273] pci 0000:09:00.0: reg 10: [io 0x3000-0x30ff]
[ 0.148335] pci 0000:09:00.0: reg 18: [mem 0xf050c000-0xf050cfff 64bit pref]
[ 0.148381] pci 0000:09:00.0: reg 20: [mem 0xf0508000-0xf050bfff 64bit pref]
[ 0.148533] pci 0000:09:00.0: supports D1 D2
[ 0.148538] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.148664] pci 0000:00:1c.2: PCI bridge to [bus 09-09]
[ 0.148751] pci 0000:00:1c.2: bridge window [io 0x3000-0x3fff]
[ 0.148764] pci 0000:00:1c.2: bridge window [mem 0xf0500000-0xf05fffff 64bit pref]
[ 0.148849] pci 0000:00:1e.0: PCI bridge to [bus 11-11] (subtractive decode)
[ 0.148950] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.148957] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.148964] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.148971] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.148978] pci 0000:00:1e.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.148985] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.148992] pci 0000:00:1e.0: bridge window [mem 0x40000000-0xf7ffffff] (subtractive decode)
[ 0.148999] pci 0000:00:1e.0: bridge window [io 0x0d00-0xfdff] (subtractive decode)
[ 0.149026] pci_bus 0000:00: on NUMA node 0
[ 0.149035] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.149212] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP1._PRT]
[ 0.149304] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP2._PRT]
[ 0.149396] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP3._PRT]
[ 0.149493] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
[ 0.149790] ACPI Error: [CAPB] Namespace lookup failure, AE_ALREADY_EXISTS (20110623/dsfield-143)
[ 0.150029] ACPI Error: Method parse/execution failed [\_SB_.PCI0._OSC] (Node f68282f0), AE_ALREADY_EXISTS (20110623/psparse-536)
[ 0.150324] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.150546] ACPI Error: [CAPB] Namespace lookup failure, AE_ALREADY_EXISTS (20110623/dsfield-143)
[ 0.150784] ACPI Error: Method parse/execution failed [\_SB_.PCI0._OSC] (Node f68282f0), AE_ALREADY_EXISTS (20110623/psparse-536)
[ 0.151078] pci0000:00: ACPI _OSC request failed (AE_ALREADY_EXISTS), returned control mask: 0x1d
[ 0.151198] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.161052] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.161692] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.162327] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.162961] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.163607] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.164371] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.165116] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.165762] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.166488] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.166621] vgaarb: loaded
[ 0.166693] vgaarb: bridge control possible 0000:00:02.0
[ 0.166874] PCI: Using ACPI for IRQ routing
[ 0.173503] PCI: pci_cache_line_size set to 64 bytes
[ 0.173553] pci 0000:00:1d.7: address space collision: [mem 0xf0504000-0xf05043ff] conflicts with PCI Bus 0000:09 [mem 0xf0500000-0xf05fffff 64bit pref]
[ 0.173759] reserve RAM buffer: 000000000009dc00 - 000000000009ffff
[ 0.173765] reserve RAM buffer: 000000003f5d0000 - 000000003fffffff
[ 0.174006] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.174102] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.174331] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.180092] Switching to clocksource hpet
[ 0.182807] pnp: PnP ACPI init
[ 0.182921] ACPI: bus type pnp registered
[ 0.184480] pnp 00:00: [bus 00-3f]
[ 0.184488] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.184494] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.184501] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.184507] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.184513] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.184519] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.184525] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.184532] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.184538] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.184544] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.184550] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.184556] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.184562] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.184568] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.184574] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.184581] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.184587] pnp 00:00: [mem 0x40000000-0xf7ffffff window]
[ 0.184593] pnp 00:00: [io 0x0d00-0xfdff window]
[ 0.184599] pnp 00:00: [mem 0x00000000 window]
[ 0.184605] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
[ 0.184730] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.184998] pnp 00:01: [io 0x0010-0x001f]
[ 0.185005] pnp 00:01: [io 0x0024-0x0025]
[ 0.185011] pnp 00:01: [io 0x0028-0x0029]
[ 0.185016] pnp 00:01: [io 0x002c-0x002d]
[ 0.185021] pnp 00:01: [io 0x0030-0x0031]
[ 0.185027] pnp 00:01: [io 0x0034-0x0035]
[ 0.185032] pnp 00:01: [io 0x0038-0x0039]
[ 0.185037] pnp 00:01: [io 0x003c-0x003d]
[ 0.185045] pnp 00:01: [io 0x0068]
[ 0.185050] pnp 00:01: [io 0x006c]
[ 0.185055] pnp 00:01: [io 0x0072-0x0077]
[ 0.185060] pnp 00:01: [io 0x0080]
[ 0.185065] pnp 00:01: [io 0x0090-0x009f]
[ 0.185071] pnp 00:01: [io 0x00a4-0x00a5]
[ 0.185076] pnp 00:01: [io 0x00a8-0x00a9]
[ 0.185081] pnp 00:01: [io 0x00ac-0x00ad]
[ 0.185087] pnp 00:01: [io 0x00b0-0x00b5]
[ 0.185092] pnp 00:01: [io 0x00b8-0x00b9]
[ 0.185097] pnp 00:01: [io 0x00bc-0x00bd]
[ 0.185103] pnp 00:01: [io 0x0800-0x080f]
[ 0.185108] pnp 00:01: [io 0x1000-0x107f]
[ 0.185114] pnp 00:01: [io 0x1180-0x11bf]
[ 0.185119] pnp 00:01: [io 0x002e-0x002f]
[ 0.185125] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.185130] pnp 00:01: [io 0xfe00]
[ 0.185135] pnp 00:01: [io 0x164e-0x174c]
[ 0.185141] pnp 00:01: [mem 0xe0000000-0xefffffff]
[ 0.185147] pnp 00:01: [mem 0xfed14000-0xfed17fff]
[ 0.185152] pnp 00:01: [mem 0xf8000000-0xfbffffff]
[ 0.185158] pnp 00:01: [mem 0xfef00000-0xfeffffff]
[ 0.185314] system 00:01: [io 0x0800-0x080f] has been reserved
[ 0.185407] system 00:01: [io 0x1000-0x107f] has been reserved
[ 0.185495] system 00:01: [io 0x1180-0x11bf] has been reserved
[ 0.185583] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.185670] system 00:01: [io 0xfe00] has been reserved
[ 0.185755] system 00:01: [io 0x164e-0x174c] has been reserved
[ 0.185844] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.185934] system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.186025] system 00:01: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.186115] system 00:01: [mem 0xfef00000-0xfeffffff] has been reserved
[ 0.186206] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.186235] pnp 00:02: [io 0x0000-0x000f]
[ 0.186240] pnp 00:02: [io 0x0081-0x008f]
[ 0.186246] pnp 00:02: [io 0x00c0-0x00df]
[ 0.186252] pnp 00:02: [dma 4]
[ 0.186321] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.186348] pnp 00:03: [io 0x00f0-0x00fe]
[ 0.186366] pnp 00:03: [irq 13]
[ 0.186437] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.186519] pnp 00:04: [io 0x0070-0x0071]
[ 0.186531] pnp 00:04: [irq 8]
[ 0.186604] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.186630] pnp 00:05: [io 0x0061]
[ 0.186699] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.204074] pnp 00:06: [io 0x0060]
[ 0.204080] pnp 00:06: [io 0x0064]
[ 0.204093] pnp 00:06: [irq 1]
[ 0.204173] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.204206] pnp 00:07: [irq 12]
[ 0.204283] pnp 00:07: Plug and Play ACPI device, IDs TOS0100 SYN0700 SYN0002 PNP0f13 (active)
[ 0.204719] pnp: PnP ACPI: found 8 devices
[ 0.204800] ACPI: ACPI bus type pnp unregistered
[ 0.204882] PnPBIOS: Disabled by ACPI PNP
[ 0.244155] PCI: max bus depth: 1 pci_try_num: 2
[ 0.244220] pci 0000:00:1d.7: BAR 0: assigned [mem 0x40000000-0x400003ff]
[ 0.244321] pci 0000:00:1f.2: BAR 5: assigned [mem 0x40000400-0x400007ff]
[ 0.244417] pci 0000:00:1c.2: BAR 14: assigned [mem 0x40100000-0x404fffff]
[ 0.244511] pci 0000:00:1c.1: BAR 15: assigned [mem 0x40500000-0x406fffff 64bit pref]
[ 0.244632] pci 0000:00:1c.0: BAR 14: assigned [mem 0x40700000-0x408fffff]
[ 0.244727] pci 0000:00:1c.0: BAR 15: assigned [mem 0x40900000-0x40afffff 64bit pref]
[ 0.244849] pci 0000:00:1c.0: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.244938] pci 0000:00:1c.0: PCI bridge to [bus 05-05]
[ 0.245023] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.245113] pci 0000:00:1c.0: bridge window [mem 0x40700000-0x408fffff]
[ 0.245206] pci 0000:00:1c.0: bridge window [mem 0x40900000-0x40afffff 64bit pref]
[ 0.245328] pci 0000:00:1c.1: PCI bridge to [bus 07-07]
[ 0.245413] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.245503] pci 0000:00:1c.1: bridge window [mem 0xf0100000-0xf01fffff]
[ 0.245596] pci 0000:00:1c.1: bridge window [mem 0x40500000-0x406fffff 64bit pref]
[ 0.245718] pci 0000:00:1c.2: PCI bridge to [bus 09-09]
[ 0.245803] pci 0000:00:1c.2: bridge window [io 0x3000-0x3fff]
[ 0.245893] pci 0000:00:1c.2: bridge window [mem 0x40100000-0x404fffff]
[ 0.245985] pci 0000:00:1c.2: bridge window [mem 0xf0500000-0xf05fffff 64bit pref]
[ 0.246106] pci 0000:00:1e.0: PCI bridge to [bus 11-11]
[ 0.246208] pci 0000:00:1c.0: enabling device (0000 -> 0003)
[ 0.246315] pci 0000:00:1c.0: setting latency timer to 64
[ 0.246338] pci 0000:00:1c.1: setting latency timer to 64
[ 0.246357] pci 0000:00:1c.2: setting latency timer to 64
[ 0.246369] pci 0000:00:1e.0: setting latency timer to 64
[ 0.246378] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.246384] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.246390] pci_bus 0000:00: resource 6 [mem 0x000d0000-0x000d3fff]
[ 0.246397] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.246403] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.246409] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000e3fff]
[ 0.246416] pci_bus 0000:00: resource 10 [mem 0x40000000-0xf7ffffff]
[ 0.246422] pci_bus 0000:00: resource 11 [io 0x0d00-0xfdff]
[ 0.246428] pci_bus 0000:05: resource 0 [io 0x4000-0x4fff]
[ 0.246435] pci_bus 0000:05: resource 1 [mem 0x40700000-0x408fffff]
[ 0.246441] pci_bus 0000:05: resource 2 [mem 0x40900000-0x40afffff 64bit pref]
[ 0.246448] pci_bus 0000:07: resource 0 [io 0x2000-0x2fff]
[ 0.246454] pci_bus 0000:07: resource 1 [mem 0xf0100000-0xf01fffff]
[ 0.246461] pci_bus 0000:07: resource 2 [mem 0x40500000-0x406fffff 64bit pref]
[ 0.246468] pci_bus 0000:09: resource 0 [io 0x3000-0x3fff]
[ 0.246474] pci_bus 0000:09: resource 1 [mem 0x40100000-0x404fffff]
[ 0.246480] pci_bus 0000:09: resource 2 [mem 0xf0500000-0xf05fffff 64bit pref]
[ 0.246487] pci_bus 0000:11: resource 4 [io 0x0000-0x0cf7]
[ 0.246493] pci_bus 0000:11: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.246500] pci_bus 0000:11: resource 6 [mem 0x000d0000-0x000d3fff]
[ 0.246506] pci_bus 0000:11: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.246512] pci_bus 0000:11: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.246518] pci_bus 0000:11: resource 9 [mem 0x000e0000-0x000e3fff]
[ 0.246525] pci_bus 0000:11: resource 10 [mem 0x40000000-0xf7ffffff]
[ 0.246531] pci_bus 0000:11: resource 11 [io 0x0d00-0xfdff]
[ 0.246607] NET: Registered protocol family 2
[ 0.246786] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.247294] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.248389] TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.248724] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.248814] TCP reno registered
[ 0.248894] UDP hash table entries: 512 (order: 1, 8192 bytes)
[ 0.248988] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[ 0.249251] NET: Registered protocol family 1
[ 0.249369] pci 0000:00:02.0: Boot video device
[ 0.249579] PCI: CLS 32 bytes, default 64
[ 0.249698] Unpacking initramfs...
[ 0.393550] Freeing initrd memory: 2956k freed
[ 0.395846] Simple Boot Flag at 0x35 set to 0x1
[ 0.396672] audit: initializing netlink socket (disabled)
[ 0.396777] type=2000 audit(1409062773.392:1): initialized
[ 0.426152] highmem bounce pool size: 64 pages
[ 0.426244] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.426531] VFS: Disk quotas dquot_6.5.2
[ 0.426642] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.426820] msgmni has been set to 1748
[ 0.427338] alg: No test for stdrng (krng)
[ 0.427468] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.427583] io scheduler noop registered
[ 0.427660] io scheduler deadline registered
[ 0.427752] io scheduler cfq registered (default)
[ 0.428047] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.428110] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 0.428222] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.428277] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
[ 0.428380] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.428436] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
[ 0.428599] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.428727] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.428815] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.432996] ERST: Table is not found!
[ 0.433074] GHES: HEST is not enabled!
[ 0.433182] isapnp: Scanning for PnP cards...
[ 0.786811] isapnp: No Plug & Play device found
[ 0.787009] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.787929] Linux agpgart interface v0.103
[ 0.788244] agpgart-intel 0000:00:00.0: Intel GMA3150 Chipset
[ 0.788509] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 0.788819] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 0.789103] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 0.789499] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.810968] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.811060] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.811418] mousedev: PS/2 mouse device common for all mice
[ 0.813584] rtc_cmos 00:04: RTC can wake from S4
[ 0.813833] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.813947] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.814124] EISA: Probing bus 0 at eisa.0
[ 0.814202] EISA: Cannot allocate resource for mainboard
[ 0.814284] Cannot allocate resource for EISA slot 1
[ 0.814364] Cannot allocate resource for EISA slot 2
[ 0.814444] Cannot allocate resource for EISA slot 3
[ 0.814524] Cannot allocate resource for EISA slot 4
[ 0.814604] Cannot allocate resource for EISA slot 5
[ 0.814683] Cannot allocate resource for EISA slot 6
[ 0.814763] Cannot allocate resource for EISA slot 7
[ 0.814844] Cannot allocate resource for EISA slot 8
[ 0.814924] EISA: Detected 0 cards.
[ 0.815001] cpuidle: using governor ladder
[ 0.815077] cpuidle: using governor menu
[ 0.815619] TCP cubic registered
[ 0.815745] NET: Registered protocol family 10
[ 0.816859] Mobile IPv6
[ 0.816936] NET: Registered protocol family 17
[ 0.817021] Registering the dns_resolver key type
[ 0.817120] Using IPI Shortcut mode
[ 0.817424] PM: Hibernation image not present or could not be loaded.
[ 0.817445] registered taskstats version 1
[ 0.818053] rtc_cmos 00:04: setting system clock to 2014-08-26 14:19:34 UTC (1409062774)
[ 0.818310] Initializing network drop monitor service
[ 0.818574] Freeing unused kernel memory: 452k freed
[ 0.818949] Write protecting the kernel text: 2600k
[ 0.819068] Write protecting the kernel read-only data: 1032k
[ 0.840597] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.848316] systemd-udevd[42]: starting version 208
[ 0.945367] SCSI subsystem initialized
[ 0.979443] libata version 3.00 loaded.
[ 0.980251] ata_piix 0000:00:1f.2: version 2.13
[ 0.980278] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.136055] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.137152] scsi0 : ata_piix
[ 1.137546] scsi1 : ata_piix
[ 1.138962] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x18c0 irq 14
[ 1.139055] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x18c8 irq 15
[ 1.309083] ata1.00: ATA-8: ST320LT012-9WS14C, 0001SDM1, max UDMA/133
[ 1.309177] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.372353] ata1.00: configured for UDMA/133
[ 1.372613] scsi 0:0:0:0: Direct-Access ATA ST320LT012-9WS14 0001 PQ: 0 ANSI: 5
[ 1.380385] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.380507] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.380718] sd 0:0:0:0: [sda] Write Protect is off
[ 1.380802] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.380862] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.392044] Refined TSC clocksource calibration: 1662.589 MHz.
[ 1.392138] Switching to clocksource tsc
[ 1.473444] sda: sda1 sda2 sda3 < sda5 sda6 sda7 sda8 > sda4
[ 1.475166] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.311848] PM: Starting manual resume from disk
[ 2.311959] PM: Hibernation image partition 8:1 present
[ 2.311963] PM: Looking for hibernation image.
[ 2.327899] PM: Image not found (code -22)
[ 2.327903] PM: Hibernation image not present or could not be loaded.
[ 2.432087] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.191096] systemd[1]: systemd 208 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ)
[ 3.430403] systemd[1]: Inserted module 'autofs4'
[ 3.440068] systemd[1]: Set hostname to <debian>.
[ 4.821140] systemd[1]: Starting Syslog Socket.
[ 4.821754] systemd[1]: Listening on Syslog Socket.
[ 4.821889] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.822182] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.822337] systemd[1]: Starting Remote File Systems (Pre).
[ 4.822812] systemd[1]: Reached target Remote File Systems (Pre).
[ 4.822937] systemd[1]: Starting Delayed Shutdown Socket.
[ 4.823436] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.823555] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 4.824092] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.824227] systemd[1]: Starting Encrypted Volumes.
[ 4.824677] systemd[1]: Reached target Encrypted Volumes.
[ 4.824810] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 4.825038] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.825186] systemd[1]: Starting Paths.
[ 4.825638] systemd[1]: Reached target Paths.
[ 4.825775] systemd[1]: Starting udev Kernel Socket.
[ 4.826262] systemd[1]: Listening on udev Kernel Socket.
[ 4.826390] systemd[1]: Starting udev Control Socket.
[ 4.826883] systemd[1]: Listening on udev Control Socket.
[ 4.827053] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 4.827777] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.827967] systemd[1]: Starting Journal Socket.
[ 4.828556] systemd[1]: Listening on Journal Socket.
[ 4.828703] systemd[1]: Starting Syslog.
[ 4.829152] systemd[1]: Reached target Syslog.
[ 4.864611] systemd[1]: Starting Apply Kernel Variables...
[ 4.866358] systemd[1]: Starting udev Coldplug all Devices...
[ 4.875395] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.909446] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.909619] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.910967] systemd[1]: Mounting Debug File System...
[ 4.912440] systemd[1]: Starting Journal Service...
[ 4.916177] systemd[1]: Started Journal Service.
[ 5.712251] lp: driver loaded but no devices found
[ 5.795132] ppdev: user-space parallel port driver
[ 5.924232] fuse init (API version 7.17)
[ 5.995467] loop: module loaded
[ 6.171385] systemd-udevd[126]: starting version 208
[ 7.574608] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 7.614080] ACPI: Requesting acpi_cpufreq
[ 7.627976] Monitor-Mwait will be used to enter C-1 state
[ 7.627984] Monitor-Mwait will be used to enter C-2 state
[ 7.627990] Monitor-Mwait will be used to enter C-3 state
[ 7.628027] Marking TSC unstable due to TSC halts in idle
[ 7.628132] ACPI: acpi_idle registered with cpuidle
[ 7.630267] Switching to clocksource hpet
[ 7.704893] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0c/PNP0C0D:00/input/input1
[ 7.705084] ACPI: Lid Switch [LID0]
[ 7.705316] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0C:00/input/input2
[ 7.705441] ACPI: Power Button [PWRB]
[ 7.705661] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 7.705778] ACPI: Power Button [PWRF]
[ 7.738599] snd_hda_intel 0000:00:1b.0: irq 43 for MSI/MSI-X
[ 7.738634] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 7.762393] toshiba_acpi: Toshiba Laptop ACPI Extras version 0.19
[ 7.762669] input: Toshiba input device as /devices/virtual/input/input4
[ 7.791858] Registered led device: toshiba::illumination
[ 7.907192] ACPI: Battery Slot [BAT1] (battery absent)
[ 7.908032] ACPI: AC Adapter [ACAD] (on-line)
[ 7.908582] usbcore: registered new interface driver usbfs
[ 7.908797] usbcore: registered new interface driver hub
[ 7.909481] usbcore: registered new device driver usb
[ 7.939809] [drm] Initialized drm 1.1.0 20060810
[ 7.949378] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.027264] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.033124] uhci_hcd: USB Universal Host Controller Interface driver
[ 8.050622] iTCO_vendor_support: vendor-support=0
[ 8.091692] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 8.091942] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 8.096178] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 8.096187] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 8.096311] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 8.096457] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 8.096554] ehci_hcd 0000:00:1d.7: debug port 1
[ 8.100511] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 8.100976] ehci_hcd 0000:00:1d.7: irq 23, io mem 0x40000000
[ 8.122748] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 8.122920] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.123011] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.123124] usb usb1: Product: EHCI Host Controller
[ 8.123204] usb usb1: Manufacturer: Linux 3.2.0-4-486 ehci_hcd
[ 8.123289] usb usb1: SerialNumber: 0000:00:1d.7
[ 8.124937] hub 1-0:1.0: USB hub found
[ 8.125026] hub 1-0:1.0: 8 ports detected
[ 8.125298] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 8.125306] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 8.125404] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 8.125551] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001820
[ 8.125703] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 8.125792] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.125904] usb usb2: Product: UHCI Host Controller
[ 8.125985] usb usb2: Manufacturer: Linux 3.2.0-4-486 uhci_hcd
[ 8.126068] usb usb2: SerialNumber: 0000:00:1d.0
[ 8.126410] hub 2-0:1.0: USB hub found
[ 8.126494] hub 2-0:1.0: 2 ports detected
[ 8.130369] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 8.130378] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 8.130486] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 8.130646] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001840
[ 8.130804] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 8.133590] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.133703] usb usb3: Product: UHCI Host Controller
[ 8.133784] usb usb3: Manufacturer: Linux 3.2.0-4-486 uhci_hcd
[ 8.133868] usb usb3: SerialNumber: 0000:00:1d.1
[ 8.141083] hub 3-0:1.0: USB hub found
[ 8.141174] hub 3-0:1.0: 2 ports detected
[ 8.144430] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 8.144439] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 8.144541] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 8.144704] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001860
[ 8.144861] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 8.144951] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.145063] usb usb4: Product: UHCI Host Controller
[ 8.145144] usb usb4: Manufacturer: Linux 3.2.0-4-486 uhci_hcd
[ 8.145228] usb usb4: SerialNumber: 0000:00:1d.2
[ 8.155098] hub 4-0:1.0: USB hub found
[ 8.155186] hub 4-0:1.0: 2 ports detected
[ 8.155813] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 8.157109] i915 0000:00:02.0: setting latency timer to 64
[ 8.199287] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 8.199550] iTCO_wdt: Found a NM10 TCO device (Version=2, TCOBASE=0x1060)
[ 8.199843] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 8.222414] Error: Driver 'pcspkr' is already registered, aborting...
[ 8.240864] i915 0000:00:02.0: irq 44 for MSI/MSI-X
[ 8.240876] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 8.240968] [drm] Driver supports precise vblank timestamp query.
[ 8.241114] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem :o wns=io+mem
[ 8.325501] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 8.325658] r8169 0000:09:00.0: setting latency timer to 64
[ 8.325730] r8169 0000:09:00.0: irq 45 for MSI/MSI-X
[ 8.326706] r8169 0000:09:00.0: eth0: RTL8105e at 0xf8224000, b8:70:f4:59:c5:66, XID 00a00000 IRQ 45
[ 8.410496] cfg80211: Calling CRDA to update world regulatory domain
[ 8.456573] usb 1-4: new high-speed USB device number 2 using ehci_hcd
[ 8.569006] [drm] initialized overlay support
[ 8.591391] fbcon: inteldrmfb (fb0) is primary device
[ 8.848146] usb 1-4: New USB device found, idVendor=0bda, idProduct=0138
[ 8.848153] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.848158] usb 1-4: Product: USB2.0-CRW
[ 8.848162] usb 1-4: Manufacturer: Generic
[ 8.848167] usb 1-4: SerialNumber: 20090516388200000
[ 8.968734] usb 1-8: new high-speed USB device number 3 using ehci_hcd
[ 8.969003] rtl8192ce 0000:07:00.0: setting latency timer to 64
[ 9.015766] Console: switching to colour frame buffer device 128x37
[ 9.024097] fb0: inteldrmfb frame buffer device
[ 9.024101] drm: registered panic notifier
[ 9.032687] acpi device:00: registered as cooling_device1
[ 9.033040] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
[ 9.034317] ACPI: Video Device [IGD0] (multi-head: yes rom: no post: no)
[ 9.042869] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 9.048517] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 9.048525] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 9.083249] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 9.114682] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00001880
[ 9.114764] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 9.114771] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.114776] usb usb5: Product: UHCI Host Controller
[ 9.114781] usb usb5: Manufacturer: Linux 3.2.0-4-486 uhci_hcd
[ 9.114785] usb usb5: SerialNumber: 0000:00:1d.3
[ 9.116223] hub 5-0:1.0: USB hub found
[ 9.116235] hub 5-0:1.0: 2 ports detected
[ 9.152581] usb 1-8: New USB device found, idVendor=04f2, idProduct=b1d6
[ 9.156058] usb 1-8: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 9.159461] usb 1-8: Product: CNF9055
[ 9.162817] usb 1-8: Manufacturer: Sonix Technology Co., Ltd.
[ 9.537931] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 9.670670] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa40000/0xa0000
[ 9.677907] rtl8192ce 0000:07:00.0: firmware: agent loaded rtlwifi/rtl8192cfw.bin into memory
[ 9.768688] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input9
[ 10.317385] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 10.319684] rtlwifi: wireless switch is on
[ 11.119603] cfg80211: World regulatory domain updated:
[ 11.122954] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 11.126342] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 11.129724] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 11.133049] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 11.136306] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 11.139614] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 11.142797] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 11.159459] cfg80211: Calling CRDA for country: EC
[ 11.272346] cfg80211: Regulatory domain changed to country: EC
[ 11.275576] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 11.278961] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 11.282275] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 11.285521] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2400 mBm)
[ 11.288685] cfg80211: (5490000 KHz - 5730000 KHz @ 80000 KHz), (N/A, 2400 mBm)
[ 11.291729] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 11.574980] Adding 1998844k swap on /dev/sda1. Priority:-1 extents:1 across:1998844k
[ 11.874526] Linux media interface: v0.10
[ 11.898353] Linux video capture interface: v2.00
[ 11.992108] Initializing USB Mass Storage driver...
[ 11.995600] usbcore: registered new interface driver usb-storage
[ 11.998469] USB Mass Storage support registered.
[ 12.161652] uvcvideo: Found UVC 1.00 device CNF9055 (04f2:b1d6)
[ 12.174795] input: CNF9055 as /devices/pci0000:00/0000:00:1d.7/usb1/1-8/1-8:1.0/input/input10
[ 12.179774] usbcore: registered new interface driver uvcvideo
[ 12.183019] USB Video Class driver (1.1.1)
[ 12.729093] usb 1-4: USB disconnect, device number 2
[ 12.734440] scsi2 : usb-storage 1-4:1.0
[ 12.739064] usbcore: registered new interface driver ums-realtek
[ 12.775725] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 13.161344] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[ 13.495175] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[ 13.726779] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 13.898774] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[ 14.031243] systemd-journald[107]: Received request to flush runtime journal from PID 1
[ 14.677868] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 15.032169] nf_conntrack version 0.5.0 (16004 buckets, 64016 max)
[ 15.217546] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.268399] r8169 0000:09:00.0: firmware: agent loaded rtl_nic/rtl8105e-1.fw into memory
[ 15.466894] r8169 0000:09:00.0: eth0: link down
[ 15.473126] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.453388] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[ 26.804700] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 27.259997] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[ 28.592545] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[ 29.820091] wlan0: authenticate with 00:12:2a:78:a8:28 (try 1)
[ 29.829649] wlan0: authenticated
[ 29.856044] wlan0: associate with 00:12:2a:78:a8:28 (try 1)
[ 29.859461] wlan0: RX AssocResp from 00:12:2a:78:a8:28 (capab=0x431 status=0 aid=18)
[ 29.859469] wlan0: associated
[ 29.880863] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 29.887322] cfg80211: Calling CRDA for country: PL
[ 29.902136] cfg80211: Regulatory domain changed to country: PL
[ 29.902146] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 29.902153] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 29.902160] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 29.902166] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 29.902172] cfg80211: (5490000 KHz - 5710000 KHz @ 80000 KHz), (N/A, 2700 mBm)
[ 29.902178] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 193.282099] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 318.258840] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 416.006032] atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
[ 416.006042] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 416.013428] atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
[ 416.013438] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 417.696629] atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
[ 417.696639] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 417.704717] atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
[ 417.704726] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 443.243306] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 568.233211] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 593.148466] atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
[ 593.148476] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 593.153882] atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
[ 593.153898] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 594.800452] atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
[ 594.800462] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 594.809681] atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
[ 594.809691] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 598.114459] atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
[ 598.114468] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 598.119767] atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
[ 598.119777] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 600.293731] atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
[ 600.293740] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 600.299118] atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
[ 600.299128] atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
[ 624.108768] atkbd serio0: Unknown key pressed (translated set 2, code 0x9b on isa0060/serio0).
[ 624.108778] atkbd serio0: Use 'setkeycodes e01b <keycode>' to make it known.
[ 624.113702] atkbd serio0: Unknown key released (translated set 2, code 0x9b on isa0060/serio0).
[ 624.113712] atkbd serio0: Use 'setkeycodes e01b <keycode>' to make it known.
[ 693.226281] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 818.221825] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 896.918608] systemd-udevd[3200]: starting version 208
[ 929.454464] systemd-journald[107]: Received SIGTERM
[ 929.795153] systemd-journald[6745]: Received request to flush runtime journal from PID 1
[ 1068.217527] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1443.211503] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1693.190546] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:00:12:2a:78:a8:21:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Nie chcę tworzyć off-topic, ale ktoś może ma kryształową kulę i wie co to jest to coś, to UFW ciągle blokuje - neta mam z netii z ich wlasnym routerem. Trzeba się tym przejmować?
Z góry dzięki!
