Przesyłam informację poprzez port USB z Arduino UNO R3 do komputera z Linux'em x86, noi raz działa, a raz nie.
PC LINUX x86 [C++ KOD]:
//C++ (LINUX PC x86)
#include <unistd.h>
#include <sstream>
#include <string>
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <termios.h>
/* My Arduino is on /dev/ttyACM0 */
char *portname = "/dev/ttyACM0";
char buf[256];
int main(int argc, char *argv[])
    while(true)
        int fd;
        /* Open the file descriptor in non-blocking mode */
        fd = open(portname, O_RDWR | O_NOCTTY);
        /* Set up the control structure */
        struct termios toptions;
        /* Get currently set options for the tty */
        tcgetattr(fd, &toptions);
        /* Set custom options */
        /* 9600 baud */
        cfsetispeed(&toptions, B9600);
        cfsetospeed(&toptions, B9600);
        /* 8 bits, no parity, no stop bits */
        toptions.c_cflag &= ~PARENB;
        toptions.c_cflag &= ~CSTOPB;
        toptions.c_cflag &= ~CSIZE;
        toptions.c_cflag |= CS8;
        /* no hardware flow control */
        toptions.c_cflag &= ~CRTSCTS;
        /* enable receiver, ignore status lines */
        toptions.c_cflag |= CREAD | CLOCAL;
        /* disable input/output flow control, disable restart chars */
        toptions.c_iflag &= ~(IXON | IXOFF | IXANY);
        /* disable canonical input, disable echo,
        disable visually erase chars,
        disable terminal-generated signals */
        toptions.c_iflag &= ~(ICANON | ECHO | ECHOE | ISIG);
        /* disable output processing */
        toptions.c_oflag &= ~OPOST;
        /* wait for 24 characters to come in before read returns */
        toptions.c_cc[VMIN] = 5;
        /* no minimum time to wait before read returns */
        toptions.c_cc[VTIME] = 0;
        /* commit the options */
        tcsetattr(fd, TCSANOW, &toptions);
        /* Wait for the Arduino to reset */
        usleep(1000*1000);
        /* Flush anything already in the serial buffer */
        tcflush(fd, TCIFLUSH);
        /* read up to 128 bytes from the fd */
        int n = read(fd, buf, 5);
        /* print how many bytes read */
        printf("%i bytes got read...\n", n);
        /* print what's in the buffer */
        printf("Buffer contains... \n%s\n", buf);
        //std::string str(buf);
        //std::cout << str << std::endl;
    return 0;
}Kod: Zaznacz cały
//(Arduino UNO)
void setup()
        Serial.begin(9600);
void loop()
        Serial.print("12345");
        delay(1000);
//Wyniki
5 bytes got read...
Buffer contains...
12345
5 bytes got read...
Buffer contains...
51234
5 bytes got read...
Buffer contains...
45123
5 bytes got read...
Buffer contains...
34512
5 bytes got read...
Buffer contains...
23451
5 bytes got read...
Buffer contains...
23451
5 bytes got read...
Buffer contains...
12345
