Sprawa wygląda tak.
Jest sobie macierz FUJITSU ETERNUS_DXL na której stożony jest zasób do wykorzystania przeze mnie na serwerze. Zasób udostępnionych jest przez multipatch.
Serwer to też Fujitsu z kartami Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03), macierz podłączona jet do serwera po sas-ie.
No i kicha ni cholery nie wiidzę dysków w multipathu nijak.
Debian 7.3
lsscsi pokazuje:
[0:2:0:0] disk LSI RAID SAS 6G 0/1 2.13 /dev/sda
[1:0:0:0] disk FUJITSU ETERNUS_DXL 0000 -
[2:0:0:0] cd/dvd TSSTcorp CDDVDW SN-208DN FT00 /dev/sr0
[8:0:0:0] disk FUJITSU ETERNUS_DXL 0000 -
blkid:
/dev/sda5: UUID="3b7c61d6-109a-49de-9c7a-367e7141c2a1" TYPE="swap"
/dev/sda1: UUID="1535c900-d8a7-495f-b6cc-8e6bbfc32355" TYPE="ext4"
scsi2ircu 0 display:
LSI Corporation SAS2 IR Configuration Utility. Version 16.00.00.00 (2013.03.01)
Copyright (c) 2009-2013 LSI Corporation.
All rights reserved.
Read configuration has been initiated for controller 0
Controller information
Controller type : SAS2008
BIOS version : 7.19.00.00
Firmware version : 10.00.00.00
Channel description : 1 Serial Attached SCSI
Initiator ID : 0 Maximum physical devices : 511
Concurrent commands supported : 3440
Slot : Unknown
Segment : 0
Bus : 3
Device : 0
Function : 0
RAID Support : No
IR Volume information
Physical device information
Initiator at ID #0
Device is a Hard disk Enclosure # : 2
Slot # : 20
SAS Address : 500000e-0-d030-ca06
State : Available (AVL)
Manufacturer : FUJITSU
Model Number : ETERNUS_DXL
Firmware Revision : 0000
Serial No : 0030CA
GUID : 600000e00d000000000030ca00000000
Protocol : SAS Drive
Type : SAS_HDD
Enclosure information
Enclosure# : 1
Logical ID : 500605b0:064c20d0
Numslots : 8
StartSlot : 0
Enclosure# : 2
Logical ID : 500000e0:d030ca7f
Numslots : 25
StartSlot : 0
SAS2IRCU: Command DISPLAY Completed Successfully.
SAS2IRCU: Utility Completed Successfully.
multipatch.conf wygląda tak:
defaults {
user_friendly_names yes
blacklist {
devnode "sda"
devices {
device {
vendor "FUJITSU"
product "ETERNUS_DXL"
prio alua
path_grouping_policy group_by_prio
path_selector "round-robin 0"
failback immediate
no_path_retry 0
path_checker tur
dev_loss_tmo 2097151
fast_io_fail_tmo 1
A niestety multipatch -ll jest całkowicie pusty
multipathd wystartowany.
Albo coś totalnie rozbię źle, albo coś nie tak z eksportem z macierzy :| tutaj na razie nie mogę nic zbadać, nie wiem jak to jest zrobione. Wiem tylko, że "udostępnione po multipath-ach" :|
Jako, że sprawa dla mnie mocno i dosłownie gardłowa - prosze nakierujcie mnie co jeszcze zbadać.
Torin
