roz
eldruto
rozłączanie się*internetu po starcie systemu
Post autor: eldruto »
Hej! Mam prośbę o wyjaśnienie problemu i ew. pomoc.
Sytuacja na komputerze stacjonarnym w domowej sieci wifi.
System:
Linux debian 3.2.0-4-686-pae #1 SMP Debian 3.2.51-1 i686 GNU/Linux
karta wifi:
01:00.0 Network controller: Ralink corp. RT2561/RT61 802.11g PCI
do łączenia NetworkManager
podczas startu dzieje się tak:
21.494874] rt61pci 0000:01:00.0: firmware: agent loaded rt2561s.bin into memory
[   21.537472] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   21.547512] r8169 0000:01:05.0: eth0: link down
[   21.547519] r8169 0000:01:05.0: eth0: link down
[   21.547696] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   24.677158] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   24.678624] wlan0: authenticated
[   24.697229] wlan0: associate with 00:23:cd:fb:74:94 (try 1)
[   24.698731] wlan0: deauthenticated from 00:23:cd:fb:74:94 (Reason: 6)
[   25.943882] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   25.945340] wlan0: authenticated
[   25.945566] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   27.174625] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   27.185274] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   27.186658] wlan0: authenticated
[   27.187030] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   28.178080] lp0: using parport0 (interrupt-driven).
[   28.212818] ppdev: user-space parallel port driver
[   28.414655] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   28.425299] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   28.624030] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   28.625457] wlan0: authenticated
[   28.625715] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   29.950087] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   29.961059] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   30.164061] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   30.165531] wlan0: authenticated
[   30.165780] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   31.619254] systemd-logind[2747]: New seat seat0.
[   31.634075] systemd-logind[2747]: Watching system buttons on /dev/input/event2 (Power Button)
[   31.634184] systemd-logind[2747]: Watching system buttons on /dev/input/event1 (Power Button)
[   31.635262] systemd-logind[2747]: New session 1 of user Debian-gdm.
[   31.640222] systemd-logind[2747]: Linked /tmp/.X11-unix/X0 to /run/user/111/X11-display.
[   31.954614] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   31.965075] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   31.968798] wlan0: authenticated
[   31.969142] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   32.245065] usblp0: removed
[   32.256160] usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x04F9 pid 0x0253
[   33.186848] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   33.201285] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   33.400033] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   33.401486] wlan0: authenticated
[   33.403267] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   34.946616] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   34.957258] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   34.958663] wlan0: authenticated
[   34.958861] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   36.178676] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   36.189279] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   36.191351] wlan0: authenticated
[   36.191569] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   37.410582] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   37.421268] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   37.422693] wlan0: authenticated
[   37.422933] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   38.642327] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   38.654503] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   38.660886] wlan0: authenticated
[   38.661106] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   39.874619] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   39.885356] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   39.886992] wlan0: authenticated
[   39.887190] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   41.106614] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   41.117355] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   41.316033] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   41.318333] wlan0: authenticated
[   41.318583] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   42.934531] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   42.945254] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   42.946720] wlan0: authenticated
[   42.948433] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   44.170528] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   44.181199] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   44.380035] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   44.381778] wlan0: authenticated
[   44.382341] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   45.934626] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   45.945156] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   45.946602] wlan0: authenticated
[   45.946810] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   47.170513] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   47.181246] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   47.380037] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   47.381615] wlan0: authenticated
[   47.383473] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   48.962221] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   48.973260] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   49.172030] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   49.173642] wlan0: authenticated
[   50.946421] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   50.957245] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   50.958899] wlan0: authenticated
[   50.959116] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   52.104965] systemd-logind[2747]: New session 2 of user debian.
[   52.120170] systemd-logind[2747]: Linked /tmp/.X11-unix/X0 to /run/user/1000/X11-display.
[   52.178323] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   52.189164] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   52.190615] wlan0: authenticated
[   52.190982] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   53.418558] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   53.429268] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   53.430608] wlan0: authenticated
[   53.430816] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   54.650621] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   54.661269] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   54.860057] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   54.861620] wlan0: authenticated
[   54.861856] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   55.998623] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   56.009252] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   56.016695] wlan0: authenticated
[   56.016907] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   57.230548] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   57.241269] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   57.245946] wlan0: authenticated
[   57.246170] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   58.462618] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   58.473260] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   58.474751] wlan0: authenticated
[   58.475097] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   59.694625] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   59.705153] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   59.707377] wlan0: authenticated
[   59.707739] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   60.926619] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   60.937356] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   60.938960] wlan0: authenticated
[   60.939156] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   62.158634] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   62.169362] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   62.170857] wlan0: authenticated
[   62.171168] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   63.390614] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   63.401326] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   63.402727] wlan0: authenticated
[   63.402956] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   64.622241] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   64.633263] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   64.832029] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   64.833434] wlan0: authenticated
[   64.833685] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   65.970604] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   65.981350] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   65.983636] wlan0: authenticated
[   65.983853] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   67.206502] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   67.217263] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   67.218678] wlan0: authenticated
[   67.218899] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   68.438424] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   68.449247] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   68.450661] wlan0: authenticated
[   68.450880] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   69.670416] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   69.681050] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   69.880026] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   69.882336] wlan0: authenticated
[   69.882618] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   71.022428] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   71.033240] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   71.232032] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   71.233508] wlan0: authenticated
[   71.233791] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   72.946424] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   72.957237] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   73.156026] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   73.157634] wlan0: authenticated
[   73.157919] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   74.950617] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   74.961266] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   74.964200] wlan0: authenticated
[   74.964410] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   76.182431] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   76.193154] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   76.194757] wlan0: authenticated
[   76.195014] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   77.414419] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   77.425246] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   77.426895] wlan0: authenticated
[   77.427175] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   78.646415] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   78.659803] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   78.661356] wlan0: authenticated
[   78.661582] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   79.878332] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   79.889168] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   79.890715] wlan0: authenticated
[   79.890988] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   80.301766] usb 5-1: usbfs: interface 0 claimed by usblp while 'scan-thread' sets config #1
[   81.110423] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   81.121147] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   81.122671] wlan0: authenticated
[   81.122939] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   81.406525] usb 5-1: usbfs: interface 0 claimed by usblp while 'scan-thread' sets config #1
[   81.406547] usb 5-1: usbfs: process 3382 (scan-thread) did not claim interface 1 before use
[   82.342316] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   82.353164] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   82.355252] wlan0: authenticated
[   82.355507] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   83.574424] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   83.585247] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   83.586645] wlan0: authenticated
[   83.586866] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   84.806418] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   84.817146] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   84.818713] wlan0: authenticated
[   84.818933] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   86.038278] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   86.049072] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   86.248031] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   86.255376] wlan0: authenticated
[   86.257236] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   87.946334] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   87.957058] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   87.958515] wlan0: authenticated
[   87.958771] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   89.178134] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   89.189162] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   89.190643] wlan0: authenticated
[   89.190902] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   90.406231] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   90.417053] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   90.616034] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   90.617677] wlan0: authenticated
[   90.617985] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   91.946423] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   91.957237] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   91.960073] wlan0: authenticated
[   91.960308] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   93.178139] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   93.189153] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   93.191714] wlan0: authenticated
[   93.191963] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   94.406634] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   94.417176] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   94.421278] wlan0: authenticated
[   94.421526] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   95.638307] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   95.649145] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   95.650571] wlan0: authenticated
[   95.650814] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   96.870217] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   96.881246] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   96.882653] wlan0: authenticated
[   96.882904] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   98.110336] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   98.121248] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   98.122717] wlan0: authenticated
[   98.122960] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   99.342324] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   99.353047] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   99.552033] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[   99.553368] wlan0: authenticated
[   99.553649] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  100.950432] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  100.961153] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  100.962506] wlan0: authenticated
[  100.962758] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  102.185046] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  102.197282] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  102.200674] wlan0: authenticated
[  102.200882] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  103.418618] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  103.429270] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  103.446549] wlan0: authenticated
[  103.446838] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  104.650430] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  104.661107] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  104.665326] wlan0: authenticated
[  104.665684] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  105.882426] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  105.893246] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  105.896534] wlan0: authenticated
[  105.896788] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  107.114424] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  107.125149] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  107.126709] wlan0: authenticated
[  107.126985] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  108.346526] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  108.361267] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  108.365443] wlan0: authenticated
[  108.365661] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  109.578431] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  109.589248] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  109.590712] wlan0: authenticated
[  109.591063] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  110.810412] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  110.821169] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  110.822752] wlan0: authenticated
[  110.822980] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  112.042322] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  112.053148] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  112.054603] wlan0: authenticated
[  112.054991] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  113.270338] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  113.281172] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  113.283343] wlan0: authenticated
[  113.283588] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  114.506633] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  114.517259] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  114.519017] wlan0: authenticated
[  114.519216] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  115.742525] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  115.753154] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  115.754577] wlan0: authenticated
[  115.754795] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  116.974619] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  116.985272] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  116.986945] wlan0: authenticated
[  116.987155] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  118.206429] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  118.217260] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  118.222245] wlan0: authenticated
[  118.222577] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  119.438423] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  119.449249] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  119.450598] wlan0: authenticated
[  119.450886] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  120.674425] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  120.685178] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  120.687014] wlan0: authenticated
[  120.687315] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  121.906242] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  121.917072] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  122.116032] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[  122.117529] wlan0: authenticated
[  122.119090] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  123.946280] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  123.957156] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  124.156028] wlan0: authenticate with 00:23:cd:fb:74:94 (try 2)
[  124.356034] wlan0: authenticate with 00:23:cd:fb:74:94 (try 3)
[  124.556038] wlan0: authentication with 00:23:cd:fb:74:94 timed out
[  125.957141] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  125.959840] wlan0: authenticated
[  125.960110] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  127.190260] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  127.201070] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  127.203397] wlan0: authenticated
[  127.203900] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  128.422319] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  128.433245] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  128.434714] wlan0: authenticated
[  128.434946] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  129.658424] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[  129.669245] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  129.670626] wlan0: authenticated
[  129.670865] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[  130.664322] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=3)
[  133.029560] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  135.341152] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  135.342499] wlan0: authenticated
[  135.343154] wlan0: associate with 00:23:cd:fb:74:94 (try 1)
[  135.345422] wlan0: RX AssocResp from 00:23:cd:fb:74:94 (capab=0x431 status=0 aid=1)
[  135.345428] wlan0: associated
[  135.346029] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  145.632018] wlan0: no IPv6 routers present
[  345.072117] systemd-logind[2747]: Removed session 1.
Połączenie na krótką chwilę się pojawia (raport pogodowy z xfce zlapie dane pogodowe) ale już ikonka NM juz wskazuje brak internetu (szukanie). Pomaga albo ponwne kliknięcie połącz/wlac/wylącz wifi lub rmmod/modprobe rt61pci.
Ktoś może dać jakieś wskazówki? (zrozumaiłe dla hobbysty, nie-informatyka)
Dzięki
eldruto
Co ciekawe, na moim laptopie (system ten sam, karta
07:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter (rev 01) )
dzieje się tak samo:
 [   17.931232] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   20.029331] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   20.040233] wlan0: authenticated
[   20.075794] wlan0: associate with 00:23:cd:fb:74:94 (try 1)
[   20.081001] wlan0: deauthenticated from 00:23:cd:fb:74:94 (Reason: 6)
[   20.183889] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   21.385044] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   21.390984] wlan0: authenticated
[   21.401444] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   21.504289] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   22.710188] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   22.728047] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   22.743126] wlan0: authenticated
[   22.753638] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   22.813772] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   24.008200] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   24.021703] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   24.032797] wlan0: authenticated
[   24.043258] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   24.111452] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   25.304193] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   25.317874] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   25.323577] wlan0: authenticated
[   25.340406] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   25.407669] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   26.620152] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   26.633560] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   26.646231] wlan0: authenticated
[   26.656736] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   26.723134] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   27.928230] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   27.942843] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   27.948422] wlan0: authenticated
[   27.958906] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   28.031371] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   29.224144] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   29.239093] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   29.244825] wlan0: authenticated
[   29.245155] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   29.327125] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   30.519533] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   30.533752] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   30.539401] wlan0: authenticated
[   30.550275] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   30.623588] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   31.825705] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   31.845653] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   31.852586] wlan0: authenticated
[   31.863436] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   31.928721] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   33.136152] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   33.149852] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   33.167041] wlan0: authenticated
[   33.188755] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   33.239207] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   34.520218] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   34.536056] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   34.542414] wlan0: authenticated
[   34.568418] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   34.623426] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   35.824651] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   35.848570] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   35.861816] wlan0: authenticated
[   35.872308] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   35.928037] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   37.128122] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   37.140582] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   37.146211] wlan0: authenticated
[   37.157100] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   37.231125] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   38.424226] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   38.438134] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   38.443673] wlan0: authenticated
[   38.454801] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   38.527616] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   39.720959] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   39.734680] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   39.740801] wlan0: authenticated
[   39.751830] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   39.824217] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   41.012975] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   41.026729] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   41.032270] wlan0: authenticated
[   41.043304] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   41.116453] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   42.312966] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   42.326717] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   42.332257] wlan0: authenticated
[   42.343287] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   42.416301] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   43.629104] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   43.641545] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   43.655958] wlan0: authenticated
[   43.666527] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   43.732125] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   55.630687] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   56.832302] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   56.846669] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   56.853648] wlan0: authenticated
[   56.868408] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   56.935551] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   58.152222] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   58.172857] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   58.178592] wlan0: authenticated
[   58.178924] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   58.255435] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   59.464212] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   59.478088] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   59.483587] wlan0: authenticated
[   59.502551] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   59.567532] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   60.772681] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   60.790513] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   60.806103] wlan0: authenticated
[   60.816621] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   60.875665] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   62.084072] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   62.097781] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   62.103517] wlan0: authenticated
[   62.103859] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   62.187289] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   63.392494] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   63.405720] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   63.411444] wlan0: authenticated
[   63.422474] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   63.495523] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   64.704212] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   64.717989] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   64.725093] wlan0: authenticated
[   64.735582] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   64.807442] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   66.016228] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   66.029946] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   66.035596] wlan0: authenticated
[   66.056084] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   66.119547] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   67.424812] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   67.444063] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   67.449779] wlan0: authenticated
[   67.460548] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   67.527910] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   68.736835] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   68.752560] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   68.766128] wlan0: authenticated
[   68.794716] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   68.840196] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   70.036977] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   70.050671] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   70.059708] wlan0: authenticated
[   70.070615] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   70.140406] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   71.338128] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   71.352768] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   71.358421] wlan0: authenticated
[   71.368944] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   71.442178] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   72.650323] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   72.667029] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   72.681192] wlan0: authenticated
[   72.692356] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   72.753537] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   73.957230] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   73.969857] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   73.977676] wlan0: authenticated
[   73.988634] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   74.060349] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   75.257773] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   75.272164] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   75.277784] wlan0: authenticated
[   75.296067] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   75.360979] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   76.559476] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   76.583411] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   76.589859] wlan0: authenticated
[   76.590188] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   76.664863] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   77.869001] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   77.883832] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   77.890648] wlan0: authenticated
[   77.901452] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   77.972413] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   79.176966] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   79.192194] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   79.198221] wlan0: authenticated
[   79.208747] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   79.280400] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   80.476982] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=2)
[   80.490684] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[   80.496186] wlan0: authenticated
[   80.507219] wlan0: failed to insert Dummy STA entry for the AP (error -17)
[   80.580593] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[   92.067107] wlan0: deauthenticating from 00:23:cd:fb:74:94 by local choice (reason=3)
[  100.814039] rtl8192ce 0000:07:00.0: setting latency timer to 64
[  100.830110] rtl8192ce 0000:07:00.0: firmware: agent loaded rtlwifi/rtl8192cfw.bin into memory
[  100.830813] ieee80211 phy1: Selected rate control algorithm 'rtl_rc'
[  100.835302] rtlwifi: wireless switch is on
[  100.868703] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[  101.220589] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  107.805931] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cfw.bin
[  109.020540] wlan0: authenticate with 00:23:cd:fb:74:94 (try 1)
[  109.026486] wlan0: authenticated
[  109.027170] wlan0: associate with 00:23:cd:fb:74:94 (try 1)
[  109.029110] wlan0: RX AssocResp from 00:23:cd:fb:74:94 (capab=0x431 status=0 aid=5)
[  109.029117] wlan0: associated
[  109.051549] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sterowniki kiepskie? Debian ma jakiś problem? Sieć w domu nie halo?
O ile ja nie mam problemu z tym, żeby sobie na laptopie cos w konsoli wpisać, o tyle moja mama już może mieć, stad chciałbym, żeby na stacjonarnym internet działał bez problemu
hucul
Post autor: hucul »
Może spróbujcie zainstalowac sterowniki do tej karty sieciowej z backportów weeziego. Znajduje się tak nowsza wersja firmware'u niż w weezim.
Jeśli to nie da rady to spróbowałbym jeszcze zainstalować kernela z backportów.
mati75
Post autor: mati75 »
1. Aktualizacja jądra do 3.12 z backportów.
2. Instalacja nowszego firmware, też jest w backportach.
3. Zamienienie network-manager na coś innego, bo jak wiadomo network-manager to jeden wielki niewypał.
