Nie moge zainstalowa
cc
Nie moge zainstalować najnowszego klienta citrixa 64-bit
Post autor: cc »
Mam zainstalowanego Debiana Wheezy 64-bit i nie mogę zainstalować najnowszego klienta citrixa 64-biticaclient_12.1.0_amd64.deb.
Czu komuś udalo sie zainstalować?
# [B]dpkg -i icaclient_12.1.0_amd64.deb[/B]
Selecting previously unselected package icaclient.
(Reading database ... 60503 files and directories currently installed.)
Unpacking icaclient (from icaclient_12.1.0_amd64.deb) ...
dpkg: dependency problems prevent configuration of icaclient:
 icaclient depends on ia32-libs; however:
  Package ia32-libs is not installed.
 icaclient depends on nspluginwrapper; however:
  Package nspluginwrapper is not installed.
dpkg: error processing icaclient (--install):
 dependency problems - leaving unconfigured
Processing triggers for menu ...
Errors were encountered while processing:
 icaclient
Zainstaluj to o co prosi i po problemie.
cc
Post autor: cc »
LordRuthwen pisze:Zainstaluj to o co prosi i po problemie.
A skąd go wziąść, skoro nspluginwrapper dla Weezy nie istnieje?
# apt-cache search nspluginwrapper
Szukałeś w ogóle?
To jest drugi link po wpisaniu w wyszukiwarce frazy: wheezy citrix, ludzie odrobinę wysiłku.
cc
Post autor: cc »
Naturalnie, że szukałem i znalazłem nspluginwrapper od testing, zainstalowalem ale mimo to dpkg -i icaclient_12.1.0_amd64.deb nie dał sie zainstalować.
kodama
Post autor: kodama »
Zrób może
sudo apt-get install -f
cc
Post autor: cc »
kodama pisze:Zrób może
# apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  lib32asound2 lib32gcc1 lib32z1 libc6-i386 libcurl3-gnutls librtmp0 libssh2-1
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  lib32asound2 lib32z1 libc6-i386
The following packages will be REMOVED:
  icaclient
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/4,519 kB of archives.
After this operation, 74.8 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 60412 files and directories currently installed.)
Removing icaclient ...
Selecting previously unselected package libc6-i386.
(Reading database ... 60191 files and directories currently installed.)
Unpacking libc6-i386 (from .../libc6-i386_2.13-38_amd64.deb) ...
Selecting previously unselected package lib32asound2.
Unpacking lib32asound2 (from .../lib32asound2_1.0.25-4_amd64.deb) ...
Selecting previously unselected package lib32z1.
Unpacking lib32z1 (from .../lib32z1_1%3a1.2.7.dfsg-13_amd64.deb) ...
Setting up libc6-i386 (2.13-38) ...
Setting up lib32asound2 (1.0.25-4) ...
Setting up lib32z1 (1:1.2.7.dfsg-13) ...
ShinnRa
Post autor: ShinnRa »
to jest pierwszy błąd jaki złasza... Ja bym najpierw zainstalował ia32-libs a potem ponownie spróbował zainstalować tego deb'a. Czyli tzw metoda małych kroczków, gdyż kolejne błędy najczęściej są powodowane przez pierwszy błąd, którym w tym przypadku jest brak ia32-libs XD
cc
Post autor: cc »
ShinnRa pisze:
Probowa[font=&amp]łem wcześniej [/font]X razy na różne sposoby i nie działa:
# [B]apt-get install libc6-i386 ia32-libs lib32z1 lib32asound2 nspluginwrapper[/B]
You might want to run 'apt-get -f install' to correct these:
 ia32-libs : Depends: ia32-libs-i386 but it is not installable
 nspluginwrapper : Depends: ia32-libs-gtk but it is not going to be installed
                   Depends: lib32gcc1 (>= 1:4.1.1) but it is not going to be installed
                   Depends: libcurl3-gnutls (>= 7.16.2-1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
#[B] apt-get -f install[/B]
  icaclient
 icaclient
cc
Post autor: cc »
Zainstaluję wersje 32-bitową, bo już na prawdę nie mam czasu i nerwów.
