[+] Conky - nie jest przezroczysty i powiela tapet
CLDiM
[+] Conky - nie jest przezroczysty i powiela tapetę
Post autor: CLDiM »
Mam mały problem z conky. Debian Wheezy uruchomiony na starym leciwym laptopie z Xfce / 32bit. Zamiast przeźroczystego tła wyświetla mi część obecnej tapety.
Moja obecna konfiguracja conky.rc:
http://pastebin.com/B1HWdRZw
# - Text settings - #
use_xft yes
use_spacer yes
xftfont Ubuntu:size=8
override_utf8_locale yes
text_buffer_size 2048
# - Window specifications - #
own_window_class Conky
#own_window_color white
own_window yes
own_window_type conky
own_window_transparent yes
own_window_hints undecorated,sticky,skip_taskbar,skip_pager,below
#own_window_argb_visual no
#own_window_argb_value 0
border_inner_margin 0
border_outer_margin 0
falignment br
background no
alignment top_right
gap_x 20
gap_y 40
minimum_size 200 750
maximum_width 190
#default_bar_size 60 8
# - Graphics settings - #
draw_shades no
draw_outline no
draw_borders no
default_color cccccc
color0 white
color1 CE5C00
color2 white
color3 CE5C00
Linux 3.2.0.4-686-pae #1 SMP Debian 3.2.41-2 i686 Gnu/Linux
lspci -a
http://pastebin.com/uKFQeih8
    00:00.0 Host bridge: Advanced Micro Devices [AMD] nee ATI Device 5a31 (rev 01)
            Subsystem: Advanced Micro Devices [AMD] nee ATI Device 5a31
    00:01.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RS480 PCI Bridge
    00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB Host Controller (rev 80)
            Subsystem: ASUSTeK Computer Inc. Device 1397
            Kernel driver in use: ohci_hcd
    00:13.1 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB Host Controller (rev 80)
    00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB2 Host Controller (rev 80)
    00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI IXP SB400 SMBus Controller (rev 82)
            Kernel driver in use: piix4_smbus
    00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI IXP SB400 IDE Controller (rev 80)
            Kernel driver in use: pata_atiixp
    00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI IXP SB4x0 High Definition Audio Controller (rev 01)
            Subsystem: ASUSTeK Computer Inc. Device 1393
    00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI IXP SB400 PCI-ISA Bridge (rev 80)
    00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI IXP SB400 PCI-PCI Bridge (rev 80)
    01:05.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RC410 [Radeon Xpress 200M]
            Subsystem: ASUSTeK Computer Inc. Device 1392
            Kernel driver in use: radeon
    02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
            Subsystem: ASUSTeK Computer Inc. L8400B or L3C/S notebook
            Kernel driver in use: 8139too
    02:01.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev b3)
            Kernel driver in use: yenta_cardbus
    02:01.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 17)
            Kernel driver in use: sdhci-pci
    02:01.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 08)
            Kernel driver in use: r592
    02:03.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
            Subsystem: ASUSTeK Computer Inc. A6U notebook embedded card
            Kernel driver in use: b43-pci-bridge
    03:00.0 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
            Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
            Kernel driver in use: uhci_hcd
    03:00.1 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
    03:00.2 USB controller: VIA Technologies, Inc. USB 2.0 (rev 63)
            Subsystem: VIA Technologies, Inc. USB 2.0
Wygląda to następująco:
Obrazek1
Co mogę zmienić aby tło było całkowicie przezroczyste?
entries/187-Przezroczysty-conky-w-xfce-4-8
entries/164-Tak-stało-się-Czyli-xfce-4- ... -Rewolucja
A jakiego sterownika karty grafiki używasz?
Sprawdź, czy conky nie jest dwa razy uruchomiony.
Usuń wszystko dotyczące xfce, z katalogu .cache.
pr0t
Post autor: pr0t »
Zmień:
na:
onw_window_type desktop
A jeśli to nie zadziała to wypróbuj jeszcze z opcją ,,override''.
spawroc
Post autor: spawroc »
Ustawienie opcji ,,override'' u mnie pomogło. Dziękuję.
CLDiM
Post autor: CLDiM »
Nie wiem co pomogło, przepisałem konfig Yampressa z artykułu na blogu: Przezroczysty conky w xfce 4.8 i działa.
Dziękuję.
No cóż. Mogę Ci polecić jeszcze jedynie: http://conky.pl/ -> Kolekcja
CLDiM
Post autor: CLDiM »
Yampress56550 pisze:...
Podziękował. Na pewno się przyda. Jak wygląda kwestia ikon (grafik/ obrazków), czy mogę używać swoich? To pewnie ma być transparentny *.png lub *.gif
AdamiPL
Post autor: AdamiPL »
Mam ten sam problem.
Wklejam poniżej konfig:
background no
#pozycja
gap_x 590
gap_y 6
maximum_width 1280
# Use Xft?
use_xft yes
xftfont Tahoma:size=8
xftalpha 0.8
update_interval 1.0
total_run_times 0
own_window yes
own_window_type override
#own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
# If own_window_transparent is set to no, you can set the background colour here
#own_window_colour hotpink
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
draw_shades no
draw_outline no
draw_borders no
stippled_borders 8
border_margin 4
border_width 0
default_color white
default_shade_color black
default_outline_color black
own_window_hints undecorated,below,skip_taskbar,sticky,skip_pager
alignment top_left
no_buffers yes
uppercase no
cpu_avg_samples 2
net_avg_samples 2
use_spacer yes
TEXT
${font Sans\ Serif:size=8:weight:bold}${color #FFFFFF}${exec whoami}@${exec uname -n} >> ${exec uname -s} ${exec uname -m} ($kernel) | CPU: ${font Sans\ Serif:size=8}${cpu cpu1}% (${hwmon temp 2} °C) | ${font Sans\ Serif:size=8:weight:bold}RAM: ${font Sans\ Serif:size=8}$mem/$memmax | ${font Sans\ Serif:size=8:weight:bold}fs: ${font Sans\ Serif:size=8}${color #FFFFFF}${fs_used /}/${fs_size /} | ${font Sans\ Serif:size=8:weight:bold}home: ${font Sans\ Serif:size=8}${fs_used /home}/${fs_size /home} | ${font Sans\ Serif:size=8:weight: bold}Up: ${font Sans\ Serif:size=8}${upspeedf eth0}kB/s | ${font Sans\ Serif:size=8:weight: bold}Down: ${font Sans\ Serif:size=8}${downspeedf eth0}kB/s
Kopiuję domyślną tapetę jako tło.
Mnie pomogło wstawienie:
 own_window_argb_visual yes
Ale w kde4, jak ktoś by miał jeszcze problemy z przezroczystością, szukałem tego z godzinę. Dlatego powielam dla potomnych, może się komuś przyda.
A tu więcej:
https://wiki.archlinux.org/index.php/Co ... .28KDE4.29
