Mój Debian: 6.0.6 (Squeeze)
Jądro Linux2.6.32-5-amd64
Mplayer daje wyniki:
mplayer dvd://41 -dvd-device /dev/dvd
MPlayer SVN-r31918 (C) 2000-2010 MPlayer Team
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing dvd://41.
libdvdread: Using libdvdcss version 1.2.10 for DVD access
There are 99 titles on this DVD.
There are 2 angles in this DVD title.
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x000001d5
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_06_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_11_0.VOB at 0x00000600
libdvdread: Get key for /VIDEO_TS/VTS_11_1.VOB at 0x00010d9e
libdvdread: Get key for /VIDEO_TS/VTS_12_1.VOB at 0x0028989c
libdvdread: Get key for /VIDEO_TS/VTS_13_1.VOB at 0x00305d22
libdvdread: Get key for /VIDEO_TS/VTS_14_1.VOB at 0x00325465
libdvdread: Get key for /VIDEO_TS/VTS_15_1.VOB at 0x003462b3
libdvdread: Get key for /VIDEO_TS/VTS_16_1.VOB at 0x00355250
libdvdread: Get key for /VIDEO_TS/VTS_17_1.VOB at 0x0035d2de
libdvdread: Get key for /VIDEO_TS/VTS_18_1.VOB at 0x00361548
libdvdread: Get key for /VIDEO_TS/VTS_19_0.VOB at 0x00365a50
libdvdread: Get key for /VIDEO_TS/VTS_19_1.VOB at 0x00365c7a
libdvdread: Found 19 VTS's
audio stream: 0 format: ac3 (5.1) language: en aid: 128.
audio stream: 1 format: ac3 (5.1) language: nl aid: 129.
audio stream: 2 format: ac3 (5.1) language: pl aid: 130.
audio stream: 3 format: ac3 (5.1) language: nl aid: 131.
number of audio channels on disk: 4.
subtitle ( sid ): 1 language: en
subtitle ( sid ): 3 language: en
subtitle ( sid ): 5 language: nl
subtitle ( sid ): 7 language: pl
subtitle ( sid ): 9 language: nl
subtitle ( sid ): 11 language: pl
number of subtitles on disk: 6
MPEG-PS file format detected.
MPEG: No audio stream found -> no sound.
VIDEO:  MPEG2  720x576  (aspect 3)  25.000 fps  9800.0 kbps (1225.0 kbyte/s)
open: No such file or directory
[MGA] Couldn't open: /dev/mga_vid
[VO_TDFXFB] Can't open /dev/fb0: No such file or directory.
s3fb: can't open /dev/fb0: No such file or directory
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
[vdpau] Error when calling vdp_device_create_x11: 1
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffmpeg2] vfm: ffmpeg (FFmpeg MPEG-2)
Audio: no sound
Starting playback...
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [xv] 720x576 => 1024x576 Planar YV12
[mpeg2video @ 0xe81720]ac-tex damaged at 37 7
[mpeg2video @ 0xe81720]Warning MVs not available
[mpeg2video @ 0xe81720]concealing 1305 DC, 1305 AC, 1305 MV errors
V:   1.1  58/ 58  9%  0%  0.0% 0 0
Exiting... (End of file)
totem dvd://
Cannot connect to server socket err = Nie ma takiego pliku ani katalogu
jack server is not running or cannot be started
libdvdnav: Using dvdnav version 4.1.3
libdvdnav: DVD Title: BOLT_BLX
libdvdnav: DVD Serial Number: 3A5A7A4E
libdvdnav: DVD Title (Alternative): BOLT_BLX
libdvdnav: Unable to find map file '/home/czarek/.dvdnav/BOLT_BLX.map'
libdvdnav: DVD disk reports itself with Region mask 0x00fd0000. Regions: 2
libdvdread: Error cracking CSS key for /VIDEO_TS/VIDEO_TS.VOB (0x000001d5)
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_12_1.VOB (0x0028989c)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_13_1.VOB (0x00305d22)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_14_1.VOB (0x00325465)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_15_1.VOB (0x003462b3)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_16_1.VOB (0x00355250)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_18_1.VOB (0x00361548)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_19_0.VOB (0x00365a50)
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_19_1.VOB (0x00365c7a)!!
No accelerated IMDCT transform found
libdvdnav: RANDOM or SHUFFLE titles are NOT handled yet.
vlc dvd://
VLC media player 1.1.3 The Luggage (revision exported)
Warning: call to srand(1360402472)
Warning: call to rand()
Blocked: call to unsetenv("DBUS_ACTIVATION_ADDRESS")
Blocked: call to unsetenv("DBUS_ACTIVATION_BUS_TYPE")
Warning: call to signal(13, 0x1)
Blocked: call to setlocale(6, "")
Blocked: call to sigaction(17, 0x7f4044d6cb50, 0x7f4044d6cab0)
(process:3008): Gtk-WARNING **: Locale not supported by C library.
    Using the fallback 'C' locale.
libdvdread: Could not open /dev/dvd with libdvdcss.
libdvdread: Can't open /dev/dvd for reading
libdvdnav: vm: failed to open/read the DVD
[0x1f9f000] dvdread demux error: DVDRead cannot open source: /dev/dvd
[0x1f9e6e0] main input error: open of `dvd://' failed: (null)
czarek@zwir03:~$ vlc dvd://
Warning: call to srand(1360402525)
Blocked: call to sigaction(17, 0x7f4f76e8fb50, 0x7f4f76e8fab0)
(process:3558): Gtk-WARNING **: Locale not supported by C library.
[swscaler @ 0x18371e0] pal8 is not supported as output pixel format
[0x1665b70] swscale scale error: could not init SwScaler and/or allocate memory
[0x1153bc0] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 300 ms)
[0x1153bc0] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 3835 ms)
[0x1153bc0] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 3846 ms)
[mpeg2video @ 0x1837640] warning: first frame is no keyframe
[0x1153bc0] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 4246 ms)
[0x1153bc0] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (jitter of 8943 ms ignored)
[0x1153bc0] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (jitter of 8960 ms ignored)
libdvdnav: chapter NOT FOUND!
libdvdnav: Suspected RCE Region Protection!!!
[mpeg2video @ 0x18d6a60] releasing zombie picture
[0x1ac8340] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (jitter of 8967 ms ignored)
[0x1ac8340] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (jitter of 16092 ms ignored)
