Perl - parsowanie XML
Gordon1x
Post autor: Gordon1x »
Mam problem ze skryptem napisanym w języku programowania perl.
Gdy próbuję wykonać skrypt poleceniem
perl convert.pl map.osm
zwracany jest błąd:
Out of memory!
Błąd występuje zarówno przy dużym (350 MB) jak i bardzo małym (około 250 KB) pliku map.osm.
Kod skryptu convert.pl:
use XML::Parser;
my $Filename = shift();
# Temporary data
my (%MainAttr,$Type,%Tags, @WaySegments);
# Stats
my %AllTags;
# Stored data
my (@Nodes, @Segments, @Ways, %Stats);
# Processing stage
my $P = new XML::Parser(Handlers => {Start => \&DoStart, End => \&DoEnd, Char => \&DoChar});
$P->parsefile($Filename);
printf STDERR "Creating output files\n";
# Combine way data into segments
if(open(WAYS,">ways.txt")){
  foreach my $Way (@Ways){
    #printf WAYS "Way: %s,%s\n", $Way->{"segments"}, $Way->{"name"};
    my @SubSegments = split(/,/,$Way->{"segments"});
    $Stats{"empty ways"}++ if(scalar(@SubSegments) < 1);
    printf WAYS "Copying keys: %s to segments %s\n",
      join(",",keys(%$Way)),
      join(",",@SubSegments);
    # Each segment in a way inherits the way's attributes
    foreach my $Segment(@SubSegments){
      foreach my $Key(keys(%$Way)){
        $Segments[$Segment]{$Key} = $Way->{$Key}
  close WAYS;
# Main output (segments)
if(open(OSM, ">osm.txt")){
  foreach my $Segment(@Segments){
    my $From = $Segment->{"from"};
    my $To = $Segment->{"to"};
    $Stats{"segments without endpoints"}++ if($From == 0 or $To == 0);
    printf OSM "%f,%f,%f,%f,%s,%s,%s\n",
      $Nodes[$From]{"lat"},
      $Nodes[$From]{"lon"},
      $Nodes[$To]{"lat"},
      $Nodes[$To]{"lon"},
      $Segment->{"class"},
      $Segment->{"name"},
      $Segment->{"highway"};
  close OSM;
# Secondary output (named points)
if(open(POINTS, ">points.txt")){
  foreach my $Node(@Nodes){
    $Stats{"Nodes with zero lat/long"}++ if($Node->{"lat"} == 0 and $Node->{"lon"} == 0);
    if($Node->{"name"} || $Node->{"amenity"} || $Node->{"class"}){
      printf POINTS "%f,%f,%s,%s,%s\n",
        $Node->{"lat"},
        $Node->{"lon"},
        $Node->{"name"},
        $Node->{"amenity"},
        $Node->{"class"};
  close POINTS;
# Statistics output
if(open(STATS, ">stats.txt")){
  foreach(sort {$AllTags{$b} <=> $AllTags{$a}} keys(%AllTags)){
    printf STATS "* %d %s\n", $AllTags{$_}, $_;
  printf STATS "\n\nStats:\n";
  foreach(keys(%Stats)){
    printf STATS "* %d %s\n", $Stats{$_}, $_;
printf STDERR "Done\n";
exit;
# Function is called whenever an XML tag is started
sub DoStart()
  my ($Expat, $Name, %Attr) = @_;
  if($Name eq "node"){
    undef %Tags;
    %MainAttr = %Attr;
    $Type = "n";
  if($Name eq "segment"){
    undef %Tags;
    %MainAttr = %Attr;
    $Type = "s";
  if($Name eq "way"){
    undef %Tags;
    undef @WaySegments;
    %MainAttr = %Attr;
    $Type = "w";
  if($Name eq "tag"){
    # TODO: protect against id,from,to,lat,long,etc. being used as tags
    $Tags{$Attr{"k"}} = $Attr{"v"};
    $AllTags{$Attr{"k"}}++;
    $Stats{"tags"}++;
  if($Name eq "seg"){
    push(@WaySegments, $Attr{"id"});
# Function is called whenever an XML tag is ended
sub DoEnd(){
  my ($Expat, $Element) = @_;
  if($Element eq "node"){
    my $ID = $MainAttr{"id"};
    $Nodes[$ID]{"lat"} = $MainAttr{"lat"};
    $Nodes[$ID]{"lon"} = $MainAttr{"lon"};
    foreach(keys(%Tags)){
      $Nodes[$ID]{$_} = $Tags{$_};
    $Stats{"named nodes"}++ if($Nodes[$ID]{"name"});
    $Stats{"tagged nodes"}++ if($MainAttr{"tags"});
    $Stats{"nodes"}++;
    #print "Node:".join(",",keys(%Tags))."\n" if(scalar(keys(%Tags))>0);
  if($Element eq "segment"){
    $Segments[$ID]{"from"} = $MainAttr{"from"};
    $Segments[$ID]{"to"} = $MainAttr{"to"};
      $Segments[$ID]{$_} = $Tags{$_};
    $Stats{"tagged segments"}++ if($MainAttr{"tags"});
    $Stats{"segments"}++;
  if($Element eq "way"){
    $Ways[$ID]{"segments"} = join(",",@WaySegments);
      $Ways[$ID]{$_} = $Tags{$_};
    $Stats{"Ways"}++;
# Function is called whenever text is encountered in the XML file
sub DoChar(){
  my ($Expat, $String) = @_;
Wynik polecenia:
ulimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 16382
max locked memory       (kbytes, -l) 64
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 0
stack size              (kbytes, -s) 8192
cpu time               (seconds, -t) unlimited
max user processes              (-u) unlimited
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
P.S.
Skrypt służy do konwertorownia danych w formacie XML map OpenStreetMap do formatu tekstowego.
System operacyjny: Debian Squeeze i Perl5
Z góry dziękuję za pomoc.
lessmian2
Post autor: lessmian2 »
Może coś się zapętla i alokuje zbyt dużo pamięci, może plik z danymi jest nie w pełni poprawnym XML'em. Podaj przykładowy plik z danymi, to sprawdzę u siebie czy mam identyczny problem. Coś się stało, że przestało działać? Jakieś zmiany w systemie/skrypcie? Jak nic nie pomoże, to perl -d i szukasz ;)
Gordon1x
Skrypt pochodzi ze strony http://wiki.openstreetmap.org/wiki/Plan ... xt#osm.txt więc nie ma pewności, że wcześniej działał w pełni poprawnie.
Przykładowe dane znajdują się w załączniku map.osm.zip w formacie XML.
map.osm.zip
(41.46 KiB) Pobrany 179 razy
lessmian2
Dla pocieszenia - u mnie jest to samo. Skrypt, operując na podanym przez Ciebie pliku, wcina ~15GB (fizycznie jest 16) pamięci i się wywala. Albo zacznij debugować skrypt, albo poszukaj innego. Ew. napisz swój używając innego (lżejszego) modułu w perlu.
