edit: dzis zauwarzylem ze to jakas forma usypiania calego kompa bo jak otworze matryce i ja wlacze rusze myszka wszystko sie wlancza spowrotem
logi z kern.log
Jul 28 21:39:14 lca kernel: [ 0.171672] ACPI: Link isn't initialized
Jul 28 21:39:14 lca kernel: [ 0.171717] pci 0000:00:10.3: PCI INT D disabled
Jul 28 21:39:14 lca kernel: [ 0.171730] pci 0000:01:00.0: Boot video device
Jul 28 21:39:14 lca kernel: [ 0.171804] Unpacking initramfs...
Jul 28 21:39:14 lca kernel: [ 0.551081] Freeing initrd memory: 8501k freed
Jul 28 21:39:14 lca kernel: [ 0.562210] audit: initializing netlink socket (disabled)
Jul 28 21:39:14 lca kernel: [ 0.562240] type=2000 audit(1343504335.559:1): initialized
Jul 28 21:39:14 lca kernel: [ 0.568987] HugeTLB registered 4 MB page size, pre-allocated 0 pages
Jul 28 21:39:14 lca kernel: [ 0.571054] VFS: Disk quotas dquot_6.5.2
Jul 28 21:39:14 lca kernel: [ 0.571135] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jul 28 21:39:14 lca kernel: [ 0.571245] msgmni has been set to 877
Jul 28 21:39:14 lca kernel: [ 0.571620] alg: No test for stdrng (krng)
Jul 28 21:39:14 lca kernel: [ 0.571697] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Jul 28 21:39:14 lca kernel: [ 0.571702] io scheduler noop registered
Jul 28 21:39:14 lca kernel: [ 0.571705] io scheduler anticipatory registered
Jul 28 21:39:14 lca kernel: [ 0.571707] io scheduler deadline registered
Jul 28 21:39:14 lca kernel: [ 0.571756] io scheduler cfq registered (default)
Jul 28 21:39:14 lca kernel: [ 0.572038] isapnp: Scanning for PnP cards...
Jul 28 21:39:14 lca kernel: [ 0.926096] isapnp: No Plug & Play device found
Jul 28 21:39:14 lca kernel: [ 0.927927] Linux agpgart interface v0.103
Jul 28 21:39:14 lca kernel: [ 0.928087] agpgart: Detected VIA PM800/PN800/PM880/PN880 chipset
Jul 28 21:39:14 lca kernel: [ 0.937858] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xa0000000
Jul 28 21:39:14 lca kernel: [ 0.937897] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jul 28 21:39:14 lca kernel: [ 0.938428] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jul 28 21:39:14 lca kernel: [ 0.949400] i8042.c: Detected active multiplexing controller, rev 1.1.
Jul 28 21:39:14 lca kernel: [ 0.955174] serio: i8042 KBD port at 0x60,0x64 irq 1
Jul 28 21:39:14 lca kernel: [ 0.955191] serio: i8042 AUX0 port at 0x60,0x64 irq 12
Jul 28 21:39:14 lca kernel: [ 0.955235] serio: i8042 AUX1 port at 0x60,0x64 irq 12
Jul 28 21:39:14 lca kernel: [ 0.955264] serio: i8042 AUX2 port at 0x60,0x64 irq 12
Jul 28 21:39:14 lca kernel: [ 0.955292] serio: i8042 AUX3 port at 0x60,0x64 irq 12
Jul 28 21:39:14 lca kernel: [ 0.955415] mice: PS/2 mouse device common for all mice
Jul 28 21:39:14 lca kernel: [ 0.955548] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Jul 28 21:39:14 lca kernel: [ 0.955603] rtc0: alarms up to one year, y3k, 242 bytes nvram
Jul 28 21:39:14 lca kernel: [ 0.955619] cpuidle: using governor ladder
Jul 28 21:39:14 lca kernel: [ 0.955622] cpuidle: using governor menu
Jul 28 21:39:14 lca kernel: [ 0.955629] No iBFT detected.
Jul 28 21:39:14 lca kernel: [ 0.956113] TCP cubic registered
Jul 28 21:39:14 lca kernel: [ 0.956321] NET: Registered protocol family 10
Jul 28 21:39:14 lca kernel: [ 0.957350] Mobile IPv6
Jul 28 21:39:14 lca kernel: [ 0.957355] NET: Registered protocol family 17
Jul 28 21:39:14 lca kernel: [ 0.957386] Using IPI No-Shortcut mode
Jul 28 21:39:14 lca kernel: [ 0.957475] PM: Resume from disk failed.
Jul 28 21:39:14 lca kernel: [ 0.957492] registered taskstats version 1
Jul 28 21:39:14 lca kernel: [ 0.957891] rtc_cmos 00:03: setting system clock to 2012-07-28 19:38:56 UTC (1343504336)
Jul 28 21:39:14 lca kernel: [ 0.957949] Initalizing network drop monitor service
Jul 28 21:39:14 lca kernel: [ 0.957982] Freeing unused kernel memory: 380k freed
Jul 28 21:39:14 lca kernel: [ 0.958257] Write protecting the kernel text: 2508k
Jul 28 21:39:14 lca kernel: [ 0.958286] Write protecting the kernel read-only data: 920k
Jul 28 21:39:14 lca kernel: [ 0.964014] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Jul 28 21:39:14 lca kernel: [ 0.983707] udev[46]: starting version 164
Jul 28 21:39:14 lca kernel: [ 1.214282] SCSI subsystem initialized
Jul 28 21:39:14 lca kernel: [ 1.237184] usbcore: registered new interface driver usbfs
Jul 28 21:39:14 lca kernel: [ 1.237389] usbcore: registered new interface driver hub
Jul 28 21:39:14 lca kernel: [ 1.269237] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
Jul 28 21:39:14 lca kernel: [ 1.269576] ACPI: PCI Interrupt Link [ALKB] BIOS reported IRQ 11, using IRQ 23
Jul 28 21:39:14 lca kernel: [ 1.269581] ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 23
Jul 28 21:39:14 lca kernel: [ 1.269597] via-rhine 0000:00:12.0: PCI INT A -> Link[ALKB] -> GSI 23 (level, low) -> IRQ 23
Jul 28 21:39:14 lca kernel: [ 1.273626] usbcore: registered new device driver usb
Jul 28 21:39:14 lca kernel: [ 1.274829] eth0: VIA Rhine II at 0x1e200, 00:40:d0:85:d7:5f, IRQ 23.
Jul 28 21:39:14 lca kernel: [ 1.275547] eth0: MII PHY found at address 1, status 0x7869 advertising 05e1 Link 45e1.
Jul 28 21:39:14 lca kernel: [ 1.284109] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jul 28 21:39:14 lca kernel: [ 1.284285] ACPI Error (uteval-0307): Return object type is incorrect [\_SB_.PCI0.ALKD._CRS] (Node db816648), AE_TYPE
Jul 28 21:39:14 lca kernel: [ 1.284299] ACPI Error: Type returned from _CRS was incorrect: Integer, expected Btypes: 4 (20090903/uteval-313)
Jul 28 21:39:14 lca kernel: [ 1.284307] ACPI Exception: AE_TYPE, Evaluating _CRS (20090903/pci_link-282)
Jul 28 21:39:14 lca kernel: [ 1.284314] ACPI: Unable to set IRQ for PCI Interrupt Link [ALKD]. Try pci=noacpi or acpi=off
Jul 28 21:39:14 lca kernel: [ 1.284371] ehci_hcd 0000:00:10.3: PCI INT D: no GSI - using IRQ 10
Jul 28 21:39:14 lca kernel: [ 1.284405] ehci_hcd 0000:00:10.3: EHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.284448] ehci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 1
Jul 28 21:39:14 lca kernel: [ 1.284531] ehci_hcd 0000:00:10.3: irq 10, io mem 0x24011000
Jul 28 21:39:14 lca kernel: [ 1.284554] libata version 3.00 loaded.
Jul 28 21:39:14 lca kernel: [ 1.296020] ehci_hcd 0000:00:10.3: USB 2.0 started, EHCI 1.00
Jul 28 21:39:14 lca kernel: [ 1.296063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 28 21:39:14 lca kernel: [ 1.296067] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 28 21:39:14 lca kernel: [ 1.296072] usb usb1: Product: EHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.296075] usb usb1: Manufacturer: Linux 2.6.32-5-686 ehci_hcd
Jul 28 21:39:14 lca kernel: [ 1.296078] usb usb1: SerialNumber: 0000:00:10.3
Jul 28 21:39:14 lca kernel: [ 1.296274] usb usb1: configuration #1 chosen from 1 choice
Jul 28 21:39:14 lca kernel: [ 1.296373] hub 1-0:1.0: USB hub found
Jul 28 21:39:14 lca kernel: [ 1.296386] hub 1-0:1.0: 6 ports detected
Jul 28 21:39:14 lca kernel: [ 1.300089] pata_via 0000:00:11.1: version 0.3.4
Jul 28 21:39:14 lca kernel: [ 1.300216] ACPI: PCI Interrupt Link [ALKA] disabled and referenced, BIOS bug
Jul 28 21:39:14 lca kernel: [ 1.300304] ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 0, using IRQ 20
Jul 28 21:39:14 lca kernel: [ 1.300308] ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
Jul 28 21:39:14 lca kernel: [ 1.300323] pata_via 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
Jul 28 21:39:14 lca kernel: [ 1.300545] scsi0 : pata_via
Jul 28 21:39:14 lca kernel: [ 1.300813] uhci_hcd: USB Universal Host Controller Interface driver
Jul 28 21:39:14 lca kernel: [ 1.300848] scsi1 : pata_via
Jul 28 21:39:14 lca kernel: [ 1.304691] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x1100 irq 14
Jul 28 21:39:14 lca kernel: [ 1.304696] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x1108 irq 15
Jul 28 21:39:14 lca kernel: [ 1.304826] ACPI Error (uteval-0307): Return object type is incorrect [\_SB_.PCI0.ALKD._CRS] (Node db816648), AE_TYPE
Jul 28 21:39:14 lca kernel: [ 1.304839] ACPI Error: Type returned from _CRS was incorrect: Integer, expected Btypes: 4 (20090903/uteval-313)
Jul 28 21:39:14 lca kernel: [ 1.304848] ACPI Exception: AE_TYPE, Evaluating _CRS (20090903/pci_link-282)
Jul 28 21:39:14 lca kernel: [ 1.304854] ACPI: Unable to set IRQ for PCI Interrupt Link [ALKD]. Try pci=noacpi or acpi=off
Jul 28 21:39:14 lca kernel: [ 1.304910] uhci_hcd 0000:00:10.0: PCI INT A: no GSI - using IRQ 11
Jul 28 21:39:14 lca kernel: [ 1.304923] uhci_hcd 0000:00:10.0: UHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.304942] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
Jul 28 21:39:14 lca kernel: [ 1.304993] uhci_hcd 0000:00:10.0: irq 11, io base 0x00001200
Jul 28 21:39:14 lca kernel: [ 1.305047] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Jul 28 21:39:14 lca kernel: [ 1.305052] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 28 21:39:14 lca kernel: [ 1.305055] usb usb2: Product: UHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.305059] usb usb2: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Jul 28 21:39:14 lca kernel: [ 1.305062] usb usb2: SerialNumber: 0000:00:10.0
Jul 28 21:39:14 lca kernel: [ 1.305248] usb usb2: configuration #1 chosen from 1 choice
Jul 28 21:39:14 lca kernel: [ 1.305339] hub 2-0:1.0: USB hub found
Jul 28 21:39:14 lca kernel: [ 1.305350] hub 2-0:1.0: 2 ports detected
Jul 28 21:39:14 lca kernel: [ 1.305498] ACPI Error (uteval-0307): Return object type is incorrect [\_SB_.PCI0.ALKD._CRS] (Node db816648), AE_TYPE
Jul 28 21:39:14 lca kernel: [ 1.305509] ACPI Error: Type returned from _CRS was incorrect: Integer, expected Btypes: 4 (20090903/uteval-313)
Jul 28 21:39:14 lca kernel: [ 1.305517] ACPI Exception: AE_TYPE, Evaluating _CRS (20090903/pci_link-282)
Jul 28 21:39:14 lca kernel: [ 1.305524] ACPI: Unable to set IRQ for PCI Interrupt Link [ALKD]. Try pci=noacpi or acpi=off
Jul 28 21:39:14 lca kernel: [ 1.305576] uhci_hcd 0000:00:10.1: PCI INT B: no GSI - using IRQ 7
Jul 28 21:39:14 lca kernel: [ 1.305588] uhci_hcd 0000:00:10.1: UHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.305599] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
Jul 28 21:39:14 lca kernel: [ 1.305647] uhci_hcd 0000:00:10.1: irq 7, io base 0x00001220
Jul 28 21:39:14 lca kernel: [ 1.305690] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Jul 28 21:39:14 lca kernel: [ 1.305695] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 28 21:39:14 lca kernel: [ 1.305698] usb usb3: Product: UHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.305702] usb usb3: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Jul 28 21:39:14 lca kernel: [ 1.305705] usb usb3: SerialNumber: 0000:00:10.1
Jul 28 21:39:14 lca kernel: [ 1.305856] usb usb3: configuration #1 chosen from 1 choice
Jul 28 21:39:14 lca kernel: [ 1.305949] hub 3-0:1.0: USB hub found
Jul 28 21:39:14 lca kernel: [ 1.305962] hub 3-0:1.0: 2 ports detected
Jul 28 21:39:14 lca kernel: [ 1.306107] ACPI Error (uteval-0307): Return object type is incorrect [\_SB_.PCI0.ALKD._CRS] (Node db816648), AE_TYPE
Jul 28 21:39:14 lca kernel: [ 1.306118] ACPI Error: Type returned from _CRS was incorrect: Integer, expected Btypes: 4 (20090903/uteval-313)
Jul 28 21:39:14 lca kernel: [ 1.306126] ACPI Exception: AE_TYPE, Evaluating _CRS (20090903/pci_link-282)
Jul 28 21:39:14 lca kernel: [ 1.306133] ACPI: Unable to set IRQ for PCI Interrupt Link [ALKD]. Try pci=noacpi or acpi=off
Jul 28 21:39:14 lca kernel: [ 1.306184] uhci_hcd 0000:00:10.2: PCI INT C: no GSI - using IRQ 5
Jul 28 21:39:14 lca kernel: [ 1.306197] uhci_hcd 0000:00:10.2: UHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.306208] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
Jul 28 21:39:14 lca kernel: [ 1.306256] uhci_hcd 0000:00:10.2: irq 5, io base 0x00001240
Jul 28 21:39:14 lca kernel: [ 1.306300] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Jul 28 21:39:14 lca kernel: [ 1.306304] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 28 21:39:14 lca kernel: [ 1.306308] usb usb4: Product: UHCI Host Controller
Jul 28 21:39:14 lca kernel: [ 1.306311] usb usb4: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Jul 28 21:39:14 lca kernel: [ 1.306314] usb usb4: SerialNumber: 0000:00:10.2
Jul 28 21:39:14 lca kernel: [ 1.306466] usb usb4: configuration #1 chosen from 1 choice
Jul 28 21:39:14 lca kernel: [ 1.306551] hub 4-0:1.0: USB hub found
Jul 28 21:39:14 lca kernel: [ 1.306563] hub 4-0:1.0: 2 ports detected
Jul 28 21:39:14 lca kernel: [ 1.484637] ata1.00: ATA-6: FUJITSU MHT2040AT, 0022, max UDMA/100
Jul 28 21:39:14 lca kernel: [ 1.484644] ata1.00: 78140160 sectors, multi 16: LBA
Jul 28 21:39:14 lca kernel: [ 1.516504] ata1.00: configured for UDMA/100
Jul 28 21:39:14 lca kernel: [ 1.516708] scsi 0:0:0:0: Direct-Access ATA FUJITSU MHT2040A 0022 PQ: 0 ANSI: 5
Jul 28 21:39:14 lca kernel: [ 1.672188] ata2.01: NODEV after polling detection
Jul 28 21:39:14 lca kernel: [ 1.680609] ata2.00: ATAPI: PHILIPS DVD+/-RW SDVD8431, LX51, max UDMA/33
Jul 28 21:39:14 lca kernel: [ 1.696512] ata2.00: configured for UDMA/33
Jul 28 21:39:14 lca kernel: [ 1.700129] scsi 1:0:0:0: CD-ROM PHILIPS DVD+-RW SDVD8431 LX51 PQ: 0 ANSI: 5
Jul 28 21:39:14 lca kernel: [ 1.728338] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
Jul 28 21:39:14 lca kernel: [ 1.728413] sd 0:0:0:0: [sda] Write Protect is off
Jul 28 21:39:14 lca kernel: [ 1.728418] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jul 28 21:39:14 lca kernel: [ 1.728449] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 28 21:39:14 lca kernel: [ 1.728654] sda:sr0: scsi3-mmc drive: 12x/24x writer cd/rw xa/form2 cdda tray
Jul 28 21:39:14 lca kernel: [ 1.735099] Uniform CD-ROM driver Revision: 3.20
Jul 28 21:39:14 lca kernel: [ 1.735490] sr 1:0:0:0: Attached scsi CD-ROM sr0
Jul 28 21:39:14 lca kernel: [ 1.772609] sda1 sda2 < sda5 >
Jul 28 21:39:14 lca kernel: [ 1.805937] sd 0:0:0:0: [sda] Attached SCSI disk
Jul 28 21:39:14 lca kernel: [ 1.823518] sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 28 21:39:14 lca kernel: [ 1.824337] sr 1:0:0:0: Attached scsi generic sg1 type 5
Jul 28 21:39:14 lca kernel: [ 2.241383] PM: Starting manual resume from disk
Jul 28 21:39:14 lca kernel: [ 2.241390] PM: Resume from partition 8:5
Jul 28 21:39:14 lca kernel: [ 2.241392] PM: Checking hibernation image.
Jul 28 21:39:14 lca kernel: [ 2.241662] PM: Error -22 checking image file
Jul 28 21:39:14 lca kernel: [ 2.241665] PM: Resume from disk failed.
Jul 28 21:39:14 lca kernel: [ 2.267843] EXT3-fs: INFO: recovery required on readonly filesystem.
Jul 28 21:39:14 lca kernel: [ 2.267848] EXT3-fs: write access will be enabled during recovery.
Jul 28 21:39:14 lca kernel: [ 6.021955] kjournald starting. Commit interval 5 seconds
Jul 28 21:39:14 lca kernel: [ 6.021980] EXT3-fs: recovery complete.
Jul 28 21:39:14 lca kernel: [ 6.022306] EXT3-fs: mounted filesystem with ordered data mode.
Jul 28 21:39:14 lca kernel: [ 8.836980] udev[267]: starting version 164
Jul 28 21:39:14 lca kernel: [ 9.423218] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input1
Jul 28 21:39:14 lca kernel: [ 9.423232] ACPI: Video Device [VGA0] (multi-head: yes rom: no post: no)
Jul 28 21:39:14 lca kernel: [ 9.766621] ACPI: AC Adapter [AC] (on-line)
Jul 28 21:39:14 lca kernel: [ 9.767385] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
Jul 28 21:39:14 lca kernel: [ 9.767562] Marking TSC unstable due to TSC halts in idle
Jul 28 21:39:14 lca kernel: [ 9.768952] processor LNXCPU:00: registered as cooling_device0
Jul 28 21:39:14 lca kernel: [ 9.770779] ACPI: Lid Switch [LID]
Jul 28 21:39:14 lca kernel: [ 9.770872] Switching to clocksource acpi_pm
Jul 28 21:39:14 lca kernel: [ 9.875465] ACPI: Battery Slot [BAT0] (battery present)
Jul 28 21:39:14 lca kernel: [ 9.875637] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
Jul 28 21:39:14 lca kernel: [ 9.875730] ACPI: Sleep Button [SBTN]
Jul 28 21:39:14 lca kernel: [ 9.875806] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
Jul 28 21:39:14 lca kernel: [ 9.875842] ACPI: Power Button [PBTN]
Jul 28 21:39:14 lca kernel: [ 9.875922] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
Jul 28 21:39:14 lca kernel: [ 9.875957] ACPI: Power Button [PWRF]
Jul 28 21:39:14 lca kernel: [ 10.228556] NET: Registered protocol family 23
Jul 28 21:39:14 lca kernel: [ 10.235196] input: PC Speaker as /devices/platform/pcspkr/input/input6
Jul 28 21:39:14 lca kernel: [ 10.343433] cfg80211: Using static regulatory domain info
Jul 28 21:39:14 lca kernel: [ 10.343438] cfg80211: Regulatory domain: US
Jul 28 21:39:14 lca kernel: [ 10.343440] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jul 28 21:39:14 lca kernel: [ 10.343445] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
Jul 28 21:39:14 lca kernel: [ 10.343449] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Jul 28 21:39:14 lca kernel: [ 10.343454] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Jul 28 21:39:14 lca kernel: [ 10.343458] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Jul 28 21:39:14 lca kernel: [ 10.343462] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Jul 28 21:39:14 lca kernel: [ 10.343466] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
Jul 28 21:39:14 lca kernel: [ 10.343803] cfg80211: Calling CRDA for country: US
Jul 28 21:39:14 lca kernel: [ 10.674765] Synaptics Touchpad, model: 1, fw: 6.2, id: 0xa5a0b1, caps: 0xa04713/0x0/0x0
Jul 28 21:39:14 lca kernel: [ 10.711395] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jul 28 21:39:14 lca kernel: [ 10.728799] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio3/input/input7
Jul 28 21:39:14 lca kernel: [ 10.801247] ACPI: I/O resource vt596_smbus [0x1400-0x1407] conflicts with ACPI region SM06 [0x1406-0x1406]
Jul 28 21:39:14 lca kernel: [ 10.801324] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jul 28 21:39:14 lca kernel: [ 11.476963] ath5k 0000:00:06.0: enabling device (0000 -> 0002)
Jul 28 21:39:14 lca kernel: [ 11.476985] ath5k 0000:00:06.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Jul 28 21:39:14 lca kernel: [ 11.477052] ath5k 0000:00:06.0: registered as 'phy0'
Jul 28 21:39:14 lca kernel: [ 12.097674] ath: EEPROM regdomain: 0x30
Jul 28 21:39:14 lca kernel: [ 12.097679] ath: EEPROM indicates we should expect a direct regpair map
Jul 28 21:39:14 lca kernel: [ 12.097684] ath: Country alpha2 being used: AM
Jul 28 21:39:14 lca kernel: [ 12.097686] ath: Regpair used: 0x30
Jul 28 21:39:14 lca kernel: [ 12.261783] phy0: Selected rate control algorithm 'minstrel'
Jul 28 21:39:14 lca kernel: [ 12.262717] ath5k phy0: Atheros AR2413 chip found (MAC: 0x78, PHY: 0x45)
Jul 28 21:39:14 lca kernel: [ 12.263072] cfg80211: Calling CRDA for country: AM
Jul 28 21:39:14 lca kernel: [ 12.263141] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Jul 28 21:39:14 lca kernel: [ 12.263599] yenta_cardbus 0000:00:09.0: CardBus bridge found [1734:10ab]
Jul 28 21:39:14 lca kernel: [ 12.263625] yenta_cardbus 0000:00:09.0: Using CSCINT to route CSC interrupts to PCI
Jul 28 21:39:14 lca kernel: [ 12.263629] yenta_cardbus 0000:00:09.0: Routing CardBus interrupts to PCI
Jul 28 21:39:14 lca kernel: [ 12.263636] yenta_cardbus 0000:00:09.0: TI: mfunc 0x01001002, devctl 0x44
Jul 28 21:39:14 lca kernel: [ 12.310933] Error: Driver 'pcspkr' is already registered, aborting...
Jul 28 21:39:14 lca kernel: [ 12.492657] yenta_cardbus 0000:00:09.0: ISA IRQ mask 0x0058, PCI irq 17
Jul 28 21:39:14 lca kernel: [ 12.492663] yenta_cardbus 0000:00:09.0: Socket status: 30000006
Jul 28 21:39:14 lca kernel: [ 12.493479] ACPI: PCI Interrupt Link [ALKC] disabled and referenced, BIOS bug
Jul 28 21:39:14 lca kernel: [ 12.493696] ACPI: PCI Interrupt Link [ALKC] BIOS reported IRQ 5, using IRQ 22
Jul 28 21:39:14 lca kernel: [ 12.493701] ACPI: PCI Interrupt Link [ALKC] enabled at IRQ 22
Jul 28 21:39:14 lca kernel: [ 12.493716] VIA 82xx Modem 0000:00:11.6: PCI INT C -> Link[ALKC] -> GSI 22 (level, low) -> IRQ 22
Jul 28 21:39:14 lca kernel: [ 12.496063] VIA 82xx Modem 0000:00:11.6: setting latency timer to 64
Jul 28 21:39:14 lca kernel: [ 12.840455] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
Jul 28 21:39:14 lca kernel: [ 12.842614] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
Jul 28 21:39:14 lca kernel: [ 12.843535] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
Jul 28 21:39:14 lca kernel: [ 12.844319] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
Jul 28 21:39:14 lca kernel: [ 12.845278] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
Jul 28 21:39:14 lca kernel: [ 13.005095] VIA 82xx Audio 0000:00:11.5: power state changed by ACPI to D0
Jul 28 21:39:14 lca kernel: [ 13.005127] VIA 82xx Audio 0000:00:11.5: power state changed by ACPI to D0
Jul 28 21:39:14 lca kernel: [ 13.005147] VIA 82xx Audio 0000:00:11.5: PCI INT C -> Link[ALKC] -> GSI 22 (level, low) -> IRQ 22
Jul 28 21:39:14 lca kernel: [ 13.005298] VIA 82xx Audio 0000:00:11.5: setting latency timer to 64
Jul 28 21:39:14 lca kernel: [ 14.254380] Adding 878584k swap on /dev/sda5. Priority:-1 extents:1 across:878584k
Jul 28 21:39:14 lca kernel: [ 14.695442] EXT3 FS on sda1, internal journal
Jul 28 21:39:14 lca kernel: [ 14.856960] loop: module loaded
Jul 28 21:39:14 lca kernel: [ 16.763399] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Jul 28 21:39:14 lca kernel: [ 17.673128] RPC: Registered udp transport module.
Jul 28 21:39:14 lca kernel: [ 17.673133] RPC: Registered tcp transport module.
Jul 28 21:39:14 lca kernel: [ 17.673135] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jul 28 21:39:14 lca kernel: [ 17.837975] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Jul 28 21:39:14 lca kernel: [ 18.339526] svc: failed to register lockdv1 RPC service (errno 97).
Jul 28 21:39:14 lca kernel: [ 18.340829] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Jul 28 21:39:14 lca kernel: [ 18.384440] NFSD: starting 90-second grace period
Jul 28 21:39:22 lca kernel: [ 27.440017] eth0: no IPv6 routers present
