Dziękuję, zadziałało. Tylko szkoda, że nie bardzo wiem co zrobiłem?
Pojawił się drugi problem:
Próbuję instalować sterownik do grafiki od AMD a instalator się czepia:
Check if system has the tools required for installation.
fglrx installation requires that the system have kernel headers. /lib/modules/2.6.32-5-amd64/build/include/linux/version.h cannot be found on this system.
One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver.
Optionally, run the installer with --force option to install without the tools.
Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended.
Więc próbuję zainstalować linux-headers:
# aptitude install linux-headers-2.6.32-5-amd64
Reading package lists...
Building dependency tree...
Reading state information...
Reading extended state information...
Initializing package states...
Reading task descriptions...
The following NEW packages will be installed:
cpp-4.3{a} gcc-4.3{a} gcc-4.3-base{a} linux-headers-2.6.32-5-amd64
linux-headers-2.6.32-5-common{a} linux-kbuild-2.6.32{a}
0 packages upgraded, 6 newly installed, 0 to remove and 670 not upgraded.
Need to get 238 kB/10.7 MB of archives. After unpacking 35.7 MB will be used.
libstdc++6: Breaks: gcc-4.3 (< 4.3.6-1) but 4.3.5-4 is to be installed.
libgomp1: Breaks: gcc-4.3 (< 4.3.6-1) but 4.3.5-4 is to be installed.
libgcc1: Breaks: gcc-4.3 (< 4.3.6-1) but 4.3.5-4 is to be installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) gcc-4.3 [Not Installed]
2) linux-headers-2.6.32-5-amd64 [Not Installed]
Accept this solution? [Y/n/q/?]
Y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 670 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Writing extended state information...
Nie przynosi to żadnego skutku, linux headers jak nie było tak nie ma. Z tego co widzę mam wersję 2.6 i 3.2.0-3:
# aptitude search linux-headers
v linux-headers -
v linux-headers-2.6 -
i linux-headers-2.6-amd64 - Header files for Linux amd64 configuration
p linux-headers-2.6-openvz-amd64 - Header files for Linux 2.6-openvz-amd64 (m
p linux-headers-2.6-vserver-amd64 - Header files for Linux 2.6-vserver-amd64 (
p linux-headers-2.6-xen-amd64 - Header files for Linux 2.6-xen-amd64 (meta
p linux-headers-2.6.32-5-all - All header files for Linux 2.6.32 (meta-pa
p linux-headers-2.6.32-5-all-amd6 - All header files for Linux 2.6.32 (meta-pa
p linux-headers-2.6.32-5-amd64 - Header files for Linux 2.6.32-5-amd64
p linux-headers-2.6.32-5-common - Common header files for Linux 2.6.32-5
p linux-headers-2.6.32-5-common-o - Common header files for Linux 2.6.32-5-ope
p linux-headers-2.6.32-5-common-v - Common header files for Linux 2.6.32-5-vse
p linux-headers-2.6.32-5-common-x - Common header files for Linux 2.6.32-5-xen
p linux-headers-2.6.32-5-openvz-a - Header files for Linux 2.6.32-5-openvz-amd
p linux-headers-2.6.32-5-vserver- - Header files for Linux 2.6.32-5-vserver-am
p linux-headers-2.6.32-5-xen-amd6 - Header files for Linux 2.6.32-5-xen-amd64
p linux-headers-3.2.0-3-all - All header files for Linux 3.2 (meta-packa
p linux-headers-3.2.0-3-all-amd64 - All header files for Linux 3.2 (meta-packa
i A linux-headers-3.2.0-3-amd64 - Header files for Linux 3.2.0-3-amd64
i A linux-headers-3.2.0-3-common - Common header files for Linux 3.2.0-3
p linux-headers-3.2.0-3-common-rt - Common header files for Linux 3.2.0-3-rt
p linux-headers-3.2.0-3-rt-amd64 - Header files for Linux 3.2.0-3-rt-amd64
i linux-headers-amd64 - Header files for Linux amd64 configuration
p linux-headers-rt-amd64 - Header files for Linux rt-amd64 configurat
