Debian po instalacji nie uruchamia si
pcpl2
Debian po instalacji nie uruchamia się
Post autor: pcpl2 »
Dzisiaj zainstalowałem Debiana 6 z płyty netinstall obok Windowsa XP ale po instalacji Debian się nie uruchamia, a dokładnej monitory wchodzą w stan spoczynku.
Proszę o pomoc
Dostałem się do Xorg.0.log oto jego zawartość:
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Linux 2.6.32-5-amd64 i686 Debian
Current Operating System: Linux (none) 2.6.32-5-486 #1 Sun May 6 03:29:22 UTC 2012 i686
Kernel command line: video=vesa:ywrap,mtrr vga=788 initrd=/install.386/gtk/initrd.gz -- quiet  BOOT_IMAGE=/install.386/vmlinuz
Build Date: 30 October 2011  08:56:48PM
xorg-server 2:1.7.7-14 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.16.4
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jun  8 21:37:49 2012
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) No Layout section.  Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) |   |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
(==) FontPath set to:
	built-ins
(II) The server relies on udev to provide the list of input devices.
(II) Loader magic: 0x81ca8a0
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.4
	X.Org Video Driver: 6.0
	X.Org XInput driver : 7.0
	X.Org Server Extension : 2.0
(--) using VT number 5
(--) PCI:*(0:1:0:0) 1002:9495:1043:0028 ATI Technologies Inc RV730 Pro AGP [Radeon HD 4600 Series] rev 0, Mem @ 0xb0000000/268435456, 0xcfef0000/65536, I/O @ 0x0000b800/256, BIOS @ 0x????????/131072
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
	compiled for 1.7.7, module version = 1.0.0
	ABI class: X.Org Server Extension, version 2.0
(II) Loading extension DPMS
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(==) Matched ati as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "ati"
(WW) Warning, couldn't open module ati
(II) UnloadModule: "ati"
(EE) Failed to load module "ati" (module does not exist, 0)
(II) LoadModule: "vesa"
(WW) Warning, couldn't open module vesa
(II) UnloadModule: "vesa"
(EE) Failed to load module "vesa" (module does not exist, 0)
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
	compiled for 1.7.6.901, module version = 0.4.2
	ABI class: X.Org Video Driver, version 6.0
(II) FBDEV: driver for framebuffer: fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
	compiled for 1.7.7, module version = 0.0.2
(**) FBDEV(0): claimed PCI slot 1@0:0:0
(II) FBDEV(0): using default device
(II) FBDEV(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 16/16
(==) FBDEV(0): Depth 16, (==) framebuffer bpp 16
(==) FBDEV(0): RGB weight 565
(==) FBDEV(0): Default visual is TrueColor
(==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) FBDEV(0): hardware: VESA VGA (video memory: 1875kB)
(II) FBDEV(0): checking modes against framebuffer device...
(II) FBDEV(0): checking modes against monitor...
(--) FBDEV(0): Virtual size is 800x600 (pitch 800)
(**) FBDEV(0):  Built-in mode "current": 48.0 MHz, 46.9 kHz, 75.1 Hz
(II) FBDEV(0): Modeline "current"x0.0   48.00  800 832 928 1024  600 604 608 624 -hsync -vsync -csync (46.9 kHz)
(==) FBDEV(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
	ABI class: X.Org ANSI C Emulation, version 0.4
(**) FBDEV(0): using shadow framebuffer
(II) Loading sub module "shadow"
(II) LoadModule: "shadow"
(II) Loading /usr/lib/xorg/modules/libshadow.so
(II) Module shadow: vendor="X.Org Foundation"
	compiled for 1.7.7, module version = 1.1.0
(EE) FBDEV(0): FBIOBLANK: Invalid argument
(==) FBDEV(0): Backing store disabled
(==) FBDEV(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
(**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
	compiled for 1.7.6.901, module version = 2.3.2
	ABI class: X.Org XInput driver, version 7.0
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "evdev"
(**) Option "xkb_layout" "us"
(II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/event1)
(**) ImPS/2 Generic Wheel Mouse: Applying InputClass "evdev pointer catchall"
(**) ImPS/2 Generic Wheel Mouse: always reports core events
(**) ImPS/2 Generic Wheel Mouse: Device: "/dev/input/event1"
(II) ImPS/2 Generic Wheel Mouse: Found 3 mouse buttons
(II) ImPS/2 Generic Wheel Mouse: Found scroll wheel(s)
(II) ImPS/2 Generic Wheel Mouse: Found relative axes
(II) ImPS/2 Generic Wheel Mouse: Found x and y relative axes
(II) ImPS/2 Generic Wheel Mouse: Configuring as mouse
(**) ImPS/2 Generic Wheel Mouse: YAxisMapping: buttons 4 and 5
(**) ImPS/2 Generic Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "ImPS/2 Generic Wheel Mouse" (type: MOUSE)
(II) ImPS/2 Generic Wheel Mouse: initialized for relative axes.
(II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/mouse0)
(II) No input driver/identifier specified (ignoring)
(WW) config/udev: device ImPS/2 Generic Wheel Mouse already added. Ignoring.
(WW) config/udev: device AT Translated Set 2 keyboard already added. Ignoring.
sqrtek
Post autor: sqrtek »
Miałem podobny problem gdy instalowałem Debiana u SIebie, lecz u mnie ten problem pojawił się po zainstalowaniu sterowników Nvidii, a rozwiązaniem okazało się ustawienie odpowiedniej rozdzielczości w pliku xorg.conf, możliwe że ty też musisz w tym pliku pozmieniać coś :) .
Hyphen
Post autor: Hyphen »
Osobiście zrobiłbym kopię pliku xorg.conf, następnie usuną go i spróbował uruchomić komputer. Nie wiem, czy by coś to pomogło, ale jeśli tak to bez dobrej rozdzielczości byś miał, a potem już by Ci było łatwiej. Jaką wersję jądra masz?
poogi
Post autor: poogi »
Usunąć plik xorg.conf potem:
/etc/init.d/gdm stop
Wpisać polecenie:
X -configure
i skopiować z katalogu /root/xorg.conf.new do /etc/X11/xorg.conf, spróbuj może coś da.
&quot pisze:
Wszystkie informacje są w logu. Dlaczego udzielacie takich archaicznych porad odnośnie pliku xorg.conf.
Sterownik karty graficznej nie zainstalowany, jądro zainstalowane z jakimiś dziwnymi parametrami i w dziwnej wersji. Nie wiadomo, czy płyta instalacyjna została poprawnie nagrana i system zainstalował się poprawnie, przynajmniej w podstawowej formie.
Pasowałoby najpierw rozpoznać ten komputer, z pomocą jakiejś dystrybucji narzędziowej Linuksa.
http://debian.linux.pl/threads/9479-Dys ... #post61503
pcpl2, potrzebny jest wynik poleceń:
lspci -n
uname -r
z poziomu dowolnego Linuksa.
