Chciałem sobie zainstalować sterowniki karty graficznej do mojego laptopa. Ściągnąłem więc sterowniki: NVIDIA-Linux-x86_64-295.33.run. Uruchomiłem spod konta roota. Ostatecznie otrzymałem informację, że instalacja sterowników przebiegła pomyślnie, ale po ponownym uruchomieniu KDE się nie uruchamia, zatrzymuje się na czarnym ekranie.
Poniżej zamieszczam przydatne informacje:
uname -r
Linux bog 3.2.0-2-amd64 #1 SMP Tue Mar 20 18:36:37 UTC 2012 x86_64 GNU/Linux
[ 169.605]
X.Org X Server 1.11.4
Release Date: 2012-01-27
[ 169.607] X Protocol Version 11, Revision 0
[ 169.608] Build Operating System: Linux 3.2.0-1-amd64 x86_64 Debian
[ 169.609] Current Operating System: Linux bogu 3.2.0-2-amd64 #1 SMP Tue Mar 20 18:36:37 UTC 2012 x86_64
[ 169.610] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-2-amd64 root=UUID=fc2489d4-2838-46f8-8480-7e87781a9aa1 ro quiet
[ 169.611] Build Date: 04 March 2012 11:42:13PM
[ 169.612] xorg-server 2:1.11.4-1 (Cyril Brulebois <kibi@debian.org>)
[ 169.614] Current version of pixman: 0.24.4
[ 169.615] Before reporting problems, check http://wiki.x.org
[ 169.616] Markers: (--) probed, (**) from config file, (==) default setting,
[ 169.618] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Apr 2 16:58:53 2012
[ 169.618] (==) Using config file: "/etc/X11/xorg.conf"
[ 169.619] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 169.620] (==) ServerLayout "X.org Configured"
[ 169.620] (**) |-->Screen "Screen0" (0)
[ 169.620] (**) | |-->Monitor "Monitor0"
[ 169.620] (**) | |-->Device "Card0"
[ 169.620] (**) |-->Screen "Screen1" (1)
[ 169.620] (**) | |-->Monitor "Monitor1"
[ 169.620] (**) | |-->Device "Card1"
[ 169.620] (**) |-->Screen "Screen2" (2)
[ 169.620] (**) | |-->Monitor "Monitor2"
[ 169.620] (**) | |-->Device "Card2"
[ 169.620] (**) |-->Screen "Screen3" (3)
[ 169.620] (**) | |-->Monitor "Monitor3"
[ 169.620] (**) | |-->Device "Card3"
[ 169.620] (**) |-->Screen "Screen4" (4)
[ 169.620] (**) | |-->Monitor "Monitor4"
[ 169.620] (**) | |-->Device "Card4"
[ 169.620] (**) |-->Screen "Screen5" (5)
[ 169.620] (**) | |-->Monitor "Monitor5"
[ 169.621] (**) | |-->Device "Card5"
[ 169.621] (**) |-->Screen "Screen6" (6)
[ 169.621] (**) | |-->Monitor "Monitor6"
[ 169.621] (**) | |-->Device "Card6"
[ 169.621] (**) |-->Input Device "Mouse0"
[ 169.621] (**) |-->Input Device "Keyboard0"
[ 169.621] (==) Automatically adding devices
[ 169.621] (==) Automatically enabling devices
[ 169.621] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 169.621] Entry deleted from font path.
[ 169.621] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 169.621] (**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins,
built-ins
[ 169.621] (**) ModulePath set to "/usr/lib/xorg/modules"
[ 169.621] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 169.621] (WW) Disabling Mouse0
[ 169.621] (WW) Disabling Keyboard0
[ 169.621] (II) Loader magic: 0x7f6d0b5d3ae0
[ 169.621] (II) Module ABI versions:
[ 169.621] X.Org ANSI C Emulation: 0.4
[ 169.621] X.Org Video Driver: 11.0
[ 169.621] X.Org XInput driver : 13.0
[ 169.621] X.Org Server Extension : 6.0
[ 169.621] (--) PCI:*(0:0:2:0) 8086:0116:1043:1682 rev 9, Mem @ 0xdd400000/4194304, 0xb0000000/268435456, I/O @ 0x0000e000/64
[ 169.621] (--) PCI: (0:1:0:0) 10de:1050:1043:1682 rev 161, Mem @ 0xdc000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[ 169.621] (II) Open ACPI successful (/var/run/acpid.socket)
[ 169.621] (II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
[ 169.621] (II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
[ 169.621] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 169.621] (II) "record" will be loaded. This was enabled by default and also specified in the config file.
[ 169.621] (II) "dri" will be loaded by default.
[ 169.621] (II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
[ 169.621] (II) LoadModule: "dbe"
[ 169.622] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 169.622] (II) Module dbe: vendor="X.Org Foundation"
[ 169.622] compiled for 1.11.4, module version = 1.0.0
[ 169.622] Module class: X.Org Server Extension
[ 169.622] ABI class: X.Org Server Extension, version 6.0
[ 169.622] (II) Loading extension DOUBLE-BUFFER
[ 169.622] (II) LoadModule: "dri2"
[ 169.622] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 169.622] (II) Module dri2: vendor="X.Org Foundation"
[ 169.622] compiled for 1.11.4, module version = 1.2.0
[ 169.622] (II) Loading extension DRI2
[ 169.622] (II) LoadModule: "record"
[ 169.622] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 169.622] (II) Module record: vendor="X.Org Foundation"
[ 169.622] compiled for 1.11.4, module version = 1.13.0
[ 169.622] (II) Loading extension RECORD
[ 169.622] (II) LoadModule: "glx"
[ 169.622] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 169.629] (II) Module glx: vendor="NVIDIA Corporation"
[ 169.629] compiled for 4.0.2, module version = 1.0.0
[ 169.629] Module class: X.Org Server Extension
[ 169.629] (II) NVIDIA GLX Module 295.33 Sat Mar 17 15:16:17 PDT 2012
[ 169.629] (II) Loading extension GLX
[ 169.629] (II) LoadModule: "extmod"
[ 169.629] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 169.629] (II) Module extmod: vendor="X.Org Foundation"
[ 169.629] compiled for 1.11.4, module version = 1.0.0
[ 169.629] ABI class: X.Org Server Extension, version 6.0
[ 169.629] (II) Loading extension SELinux
[ 169.629] (II) Loading extension MIT-SCREEN-SAVER
[ 169.629] (II) Loading extension XFree86-VidModeExtension
[ 169.629] (II) Loading extension XFree86-DGA
[ 169.629] (II) Loading extension DPMS
[ 169.629] (II) Loading extension XVideo
[ 169.629] (II) Loading extension XVideo-MotionCompensation
[ 169.629] (II) Loading extension X-Resource
[ 169.629] (II) LoadModule: "dri"
[ 169.629] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 169.629] (II) Module dri: vendor="X.Org Foundation"
[ 169.629] (II) Loading extension XFree86-DRI
[ 169.629] (II) LoadModule: "nvidia"
[ 169.629] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 169.630] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 169.630] compiled for 4.0.2, module version = 1.0.0
[ 169.630] Module class: X.Org Video Driver
[ 169.729] (II) NVIDIA dlloader X Driver 295.33 Sat Mar 17 14:57:21 PDT 2012
[ 169.729] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 169.730] (--) using VT number 7
[ 169.755] (II) Loading sub module "fb"
[ 169.755] (II) LoadModule: "fb"
[ 169.756] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 169.770] (II) Module fb: vendor="X.Org Foundation"
[ 169.770] compiled for 1.11.4, module version = 1.0.0
[ 169.770] ABI class: X.Org ANSI C Emulation, version 0.4
[ 169.770] (II) Loading sub module "wfb"
[ 169.770] (II) LoadModule: "wfb"
[ 169.770] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 169.783] (II) Module wfb: vendor="X.Org Foundation"
[ 169.783] compiled for 1.11.4, module version = 1.0.0
[ 169.783] ABI class: X.Org ANSI C Emulation, version 0.4
[ 169.783] (II) Loading sub module "ramdac"
[ 169.783] (II) LoadModule: "ramdac"
[ 169.783] (II) Module "ramdac" already built-in
[ 169.783] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 169.783] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 169.783] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 169.784] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 169.784] (==) NVIDIA(0): RGB weight 888
[ 169.784] (==) NVIDIA(0): Default visual is TrueColor
[ 169.784] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 169.784] (**) NVIDIA(0): Enabling 2D acceleration
[ 170.768] (WW) NVIDIA(GPU-0): Unable to read EDID for display device CRT-0
[ 170.770] (II) NVIDIA(0): NVIDIA GPU GeForce GT 520M (GF119) at PCI:1:0:0 (GPU-0)
[ 170.770] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 170.770] (--) NVIDIA(0): VideoBIOS: 75.19.32.00.fe
[ 170.770] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 170.770] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[ 170.774] (--) NVIDIA(0): Connected display device(s) on GeForce GT 520M at PCI:1:0:0
[ 170.774] (--) NVIDIA(0): CRT-0
[ 170.774] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 170.778] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 170.778] (**) NVIDIA(0): device CRT-0 (Using EDID frequencies has been enabled on
[ 170.778] (**) NVIDIA(0): all display devices.)
[ 170.779] (II) NVIDIA(0): Assigned Display Device: CRT-0
[ 170.779] (==) NVIDIA(0):
[ 170.779] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 170.779] (==) NVIDIA(0): will be used as the requested mode.
[ 170.779] (II) NVIDIA(0): Validated modes:
[ 170.779] (II) NVIDIA(0): "nvidia-auto-select"
[ 170.779] (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
[ 170.781] (WW) NVIDIA(0): Unable to get display device CRT-0's EDID; cannot compute DPI
[ 170.781] (WW) NVIDIA(0): from CRT-0's EDID.
[ 170.781] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 170.781] (--) Depth 24 pixmap format is 32 bpp
[ 170.781] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[ 170.781] (II) NVIDIA: access.
[ 170.786] (II) NVIDIA(0): Setting mode "nvidia-auto-select"
[ 170.817] (II) Loading extension NV-GLX
[ 170.840] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 170.840] (==) NVIDIA(0): Backing store disabled
[ 170.840] (==) NVIDIA(0): Silken mouse enabled
[ 170.841] (==) NVIDIA(0): DPMS enabled
[ 170.841] (II) Loading extension NV-CONTROL
[ 170.841] (II) Loading extension XINERAMA
[ 170.841] (II) Loading sub module "dri2"
[ 170.841] (II) LoadModule: "dri2"
[ 170.841] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 170.841] (II) Module dri2: vendor="X.Org Foundation"
[ 170.841] compiled for 1.11.4, module version = 1.2.0
[ 170.841] ABI class: X.Org Server Extension, version 6.0
[ 170.841] (II) NVIDIA(0): [DRI2] Setup complete
[ 170.841] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 170.841] (==) RandR enabled
[ 170.841] (II) Initializing built-in extension Generic Event Extension
[ 170.841] (II) Initializing built-in extension SHAPE
[ 170.841] (II) Initializing built-in extension MIT-SHM
[ 170.841] (II) Initializing built-in extension XInputExtension
[ 170.841] (II) Initializing built-in extension XTEST
[ 170.841] (II) Initializing built-in extension BIG-REQUESTS
[ 170.841] (II) Initializing built-in extension SYNC
[ 170.841] (II) Initializing built-in extension XKEYBOARD
[ 170.841] (II) Initializing built-in extension XC-MISC
[ 170.841] (II) Initializing built-in extension SECURITY
[ 170.841] (II) Initializing built-in extension XINERAMA
[ 170.841] (II) Initializing built-in extension XFIXES
[ 170.841] (II) Initializing built-in extension RENDER
[ 170.841] (II) Initializing built-in extension RANDR
[ 170.841] (II) Initializing built-in extension COMPOSITE
[ 170.841] (II) Initializing built-in extension DAMAGE
[ 170.842] (II) Initializing extension GLX
[ 170.842] (II) SELinux: Disabled on system
[ 171.186] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[ 171.186] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 171.186] (II) LoadModule: "evdev"
[ 171.187] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.206] (II) Module evdev: vendor="X.Org Foundation"
[ 171.206] compiled for 1.11.0, module version = 2.6.0
[ 171.206] Module class: X.Org XInput Driver
[ 171.206] ABI class: X.Org XInput driver, version 13.0
[ 171.206] (II) Using input driver 'evdev' for 'Power Button'
[ 171.206] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.206] (**) Power Button: always reports core events
[ 171.206] (**) Power Button: Device: "/dev/input/event6"
[ 171.206] (--) Power Button: Found keys
[ 171.206] (II) Power Button: Configuring as keyboard
[ 171.206] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event6"
[ 171.206] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 171.206] (**) Option "xkb_rules" "evdev"
[ 171.206] (**) Option "xkb_model" "pc105"
[ 171.206] (**) Option "xkb_layout" "pl"
[ 171.263] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 171.263] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 171.263] (II) Using input driver 'evdev' for 'Video Bus'
[ 171.263] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.263] (**) Video Bus: always reports core events
[ 171.263] (**) Video Bus: Device: "/dev/input/event11"
[ 171.263] (--) Video Bus: Found keys
[ 171.263] (II) Video Bus: Configuring as keyboard
[ 171.264] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input11/event11"
[ 171.264] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 171.264] (**) Option "xkb_rules" "evdev"
[ 171.264] (**) Option "xkb_model" "pc105"
[ 171.264] (**) Option "xkb_layout" "pl"
[ 171.265] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 171.265] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 171.265] (II) Using input driver 'evdev' for 'Video Bus'
[ 171.265] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.265] (**) Video Bus: always reports core events
[ 171.265] (**) Video Bus: Device: "/dev/input/event10"
[ 171.265] (--) Video Bus: Found keys
[ 171.265] (II) Video Bus: Configuring as keyboard
[ 171.265] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input10/event10"
[ 171.265] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 171.265] (**) Option "xkb_rules" "evdev"
[ 171.265] (**) Option "xkb_model" "pc105"
[ 171.265] (**) Option "xkb_layout" "pl"
[ 171.266] (II) config/udev: Adding input device Lid Switch (/dev/input/event4)
[ 171.266] (II) No input driver specified, ignoring this device.
[ 171.266] (II) This device may have been added with another device file.
[ 171.267] (II) config/udev: Adding input device Sleep Button (/dev/input/event5)
[ 171.267] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 171.267] (II) Using input driver 'evdev' for 'Sleep Button'
[ 171.267] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.267] (**) Sleep Button: always reports core events
[ 171.267] (**) Sleep Button: Device: "/dev/input/event5"
[ 171.267] (--) Sleep Button: Found keys
[ 171.267] (II) Sleep Button: Configuring as keyboard
[ 171.267] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input5/event5"
[ 171.267] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 171.267] (**) Option "xkb_rules" "evdev"
[ 171.267] (**) Option "xkb_model" "pc105"
[ 171.267] (**) Option "xkb_layout" "pl"
[ 171.268] (II) config/udev: Adding input device USB 2.0 UVC VGA WebCam (/dev/input/event9)
[ 171.268] (**) USB 2.0 UVC VGA WebCam: Applying InputClass "evdev keyboard catchall"
[ 171.268] (II) Using input driver 'evdev' for 'USB 2.0 UVC VGA WebCam'
[ 171.268] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.268] (**) USB 2.0 UVC VGA WebCam: always reports core events
[ 171.268] (**) USB 2.0 UVC VGA WebCam: Device: "/dev/input/event9"
[ 171.268] (--) USB 2.0 UVC VGA WebCam: Found keys
[ 171.268] (II) USB 2.0 UVC VGA WebCam: Configuring as keyboard
[ 171.268] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input9/event9"
[ 171.268] (II) XINPUT: Adding extended input device "USB 2.0 UVC VGA WebCam" (type: KEYBOARD, id 10)
[ 171.268] (**) Option "xkb_rules" "evdev"
[ 171.268] (**) Option "xkb_model" "pc105"
[ 171.268] (**) Option "xkb_layout" "pl"
[ 171.269] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event12)
[ 171.269] (II) No input driver specified, ignoring this device.
[ 171.269] (II) This device may have been added with another device file.
[ 171.270] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[ 171.270] (II) No input driver specified, ignoring this device.
[ 171.270] (II) This device may have been added with another device file.
[ 171.270] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[ 171.271] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event1)
[ 171.271] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 171.271] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[ 171.271] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.271] (**) Logitech USB Receiver: always reports core events
[ 171.271] (**) Logitech USB Receiver: Device: "/dev/input/event1"
[ 171.271] (--) Logitech USB Receiver: Found 20 mouse buttons
[ 171.271] (--) Logitech USB Receiver: Found scroll wheel(s)
[ 171.272] (--) Logitech USB Receiver: Found relative axes
[ 171.272] (--) Logitech USB Receiver: Found x and y relative axes
[ 171.272] (II) Logitech USB Receiver: Configuring as mouse
[ 171.272] (II) Logitech USB Receiver: Adding scrollwheel support
[ 171.272] (**) Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 171.272] (**) Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 171.272] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input1/event1"
[ 171.272] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 11)
[ 171.272] (II) Logitech USB Receiver: initialized for relative axes.
[ 171.272] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 171.272] (**) Logitech USB Receiver: (accel) acceleration profile 0
[ 171.272] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 171.272] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 171.273] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 171.273] (II) No input driver specified, ignoring this device.
[ 171.273] (II) This device may have been added with another device file.
[ 171.274] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event2)
[ 171.274] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 171.274] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[ 171.274] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.274] (**) Logitech USB Receiver: always reports core events
[ 171.274] (**) Logitech USB Receiver: Device: "/dev/input/event2"
[ 171.274] (--) Logitech USB Receiver: Found 1 mouse buttons
[ 171.274] (--) Logitech USB Receiver: Found scroll wheel(s)
[ 171.274] (--) Logitech USB Receiver: Found relative axes
[ 171.274] (--) Logitech USB Receiver: Found absolute axes
[ 171.274] (--) Logitech USB Receiver: Found keys
[ 171.274] (II) Logitech USB Receiver: Configuring as mouse
[ 171.274] (II) Logitech USB Receiver: Configuring as keyboard
[ 171.274] (II) Logitech USB Receiver: Adding scrollwheel support
[ 171.274] (**) Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[ 171.274] (**) Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 171.274] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/input/input2/event2"
[ 171.274] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 12)
[ 171.274] (**) Option "xkb_rules" "evdev"
[ 171.274] (**) Option "xkb_model" "pc105"
[ 171.274] (**) Option "xkb_layout" "pl"
[ 171.274] (EE) Logitech USB Receiver: failed to initialize for relative axes.
[ 171.275] (II) Logitech USB Receiver: initialized for absolute axes.
[ 171.275] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[ 171.275] (**) Logitech USB Receiver: (accel) acceleration profile 0
[ 171.275] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 171.275] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 171.275] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event7)
[ 171.276] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 171.276] (II) Using input driver 'evdev' for 'Asus WMI hotkeys'
[ 171.276] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.276] (**) Asus WMI hotkeys: always reports core events
[ 171.276] (**) Asus WMI hotkeys: Device: "/dev/input/event7"
[ 171.276] (--) Asus WMI hotkeys: Found keys
[ 171.276] (II) Asus WMI hotkeys: Configuring as keyboard
[ 171.276] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input7/event7"
[ 171.276] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 13)
[ 171.276] (**) Option "xkb_rules" "evdev"
[ 171.276] (**) Option "xkb_model" "pc105"
[ 171.276] (**) Option "xkb_layout" "pl"
[ 171.277] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 171.277] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 171.277] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 171.277] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.277] (**) AT Translated Set 2 keyboard: always reports core events
[ 171.277] (**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 171.277] (--) AT Translated Set 2 keyboard: Found keys
[ 171.277] (II) AT Translated Set 2 keyboard: Configuring as keyboard
[ 171.277] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 171.277] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14)
[ 171.277] (**) Option "xkb_rules" "evdev"
[ 171.277] (**) Option "xkb_model" "pc105"
[ 171.277] (**) Option "xkb_layout" "pl"
[ 171.278] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event8)
[ 171.278] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 171.278] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad catchall"
[ 171.278] (II) LoadModule: "synaptics"
[ 171.279] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 171.280] (II) Module synaptics: vendor="X.Org Foundation"
[ 171.280] compiled for 1.11.2.902, module version = 1.5.0
[ 171.280] Module class: X.Org XInput Driver
[ 171.280] ABI class: X.Org XInput driver, version 13.0
[ 171.280] (II) Using input driver 'synaptics' for 'ETPS/2 Elantech Touchpad'
[ 171.280] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 171.280] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 171.280] (**) Option "Device" "/dev/input/event8"
[ 171.464] (--) synaptics: ETPS/2 Elantech Touchpad: x-axis range 0 - 2508
[ 171.464] (--) synaptics: ETPS/2 Elantech Touchpad: y-axis range 0 - 1320
[ 171.464] (--) synaptics: ETPS/2 Elantech Touchpad: pressure range 0 - 255
[ 171.464] (--) synaptics: ETPS/2 Elantech Touchpad: finger width range 0 - 0
[ 171.464] (--) synaptics: ETPS/2 Elantech Touchpad: buttons: left right double triple
[ 171.464] (--) synaptics: ETPS/2 Elantech Touchpad: Vendor 0x2 Product 0xe
[ 171.472] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[ 171.472] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 171.480] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input8/event8"
[ 171.480] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 15)
[ 171.480] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[ 171.480] (**) synaptics: ETPS/2 Elantech Touchpad: MaxSpeed is now 1.75
[ 171.480] (**) synaptics: ETPS/2 Elantech Touchpad: AccelFactor is now 0.071
[ 171.480] (**) ETPS/2 Elantech Touchpad: (accel) keeping acceleration scheme 1
[ 171.480] (**) ETPS/2 Elantech Touchpad: (accel) acceleration profile 1
[ 171.480] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 171.480] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 171.481] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[ 171.481] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse1)
[ 171.481] (**) ETPS/2 Elantech Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
[ 171.482] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 171.482] (II) No input driver specified, ignoring this device.
[ 171.482] (II) This device may have been added with another device file.
[ 171.483] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event15)
[ 171.483] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[ 171.483] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[ 171.483] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 171.483] (**) ACPI Virtual Keyboard Device: always reports core events
[ 171.483] (**) ACPI Virtual Keyboard Device: Device: "/dev/input/event15"
[ 171.483] (--) ACPI Virtual Keyboard Device: Found keys
[ 171.483] (II) ACPI Virtual Keyboard Device: Configuring as keyboard
[ 171.483] (**) Option "config_info" "udev:/sys/devices/virtual/input/input15/event15"
[ 171.483] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 16)
[ 171.483] (**) Option "xkb_rules" "evdev"
[ 171.483] (**) Option "xkb_model" "pc105"
[ 171.483] (**) Option "xkb_layout" "pl"
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 295.33 (buildmeister@swio-display-x86-rhel47-08.nvidia.com) Sat Mar 17 15:58:33 PDT 2012
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
Screen 2 "Screen2" RightOf "Screen1"
Screen 3 "Screen3" RightOf "Screen2"
Screen 4 "Screen4" RightOf "Screen3"
Screen 5 "Screen5" RightOf "Screen4"
Screen 6 "Screen6" RightOf "Screen5"
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "built-ins"
EndSection
Section "Module"
Load "dbe"
Load "dri2"
Load "record"
Load "glx"
Load "extmod"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Monitor"
Identifier "Monitor1"
EndSection
Section "Monitor"
Identifier "Monitor2"
EndSection
Section "Monitor"
Identifier "Monitor3"
EndSection
Section "Monitor"
Identifier "Monitor4"
EndSection
Section "Monitor"
Identifier "Monitor5"
EndSection
Section "Monitor"
Identifier "Monitor6"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
### <percent>: "<f>%"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "VideoKey" # <i>
#Option "WrappedFB" # [<bool>]
#Option "GLXVBlank" # [<bool>]
#Option "ZaphodHeads" # <str>
#Option "PageFlip" # [<bool>]
Identifier "Card0"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "Card1"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Device"
#Option "DRI" # [<bool>]
#Option "ColorKey" # <i>
#Option "FallbackDebug" # [<bool>]
#Option "Tiling" # [<bool>]
#Option "LinearFramebuffer" # [<bool>]
#Option "Shadow" # [<bool>]
#Option "SwapbuffersWait" # [<bool>]
#Option "TripleBuffer" # [<bool>]
#Option "XvMC" # [<bool>]
#Option "XvPreferOverlay" # [<bool>]
#Option "DebugFlushBatches" # [<bool>]
#Option "DebugFlushCaches" # [<bool>]
#Option "DebugWait" # [<bool>]
#Option "HotPlug" # [<bool>]
#Option "RelaxedFencing" # [<bool>]
#Option "BufferCache" # [<bool>]
Identifier "Card2"
Driver "nvidia"
BusID "PCI:0:2:0"
EndSection
Section "Device"
#Option "Rotate" # <str>
#Option "fbdev" # <str>
#Option "debug" # [<bool>]
Identifier "Card3"
Driver "nvidia"
BusID "PCI:0:2:0"
EndSection
Section "Device"
Identifier "Card4"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Device"
#Option "DefaultRefresh" # [<bool>]
#Option "ModeSetClearScreen" # [<bool>]
Identifier "Card5"
Driver "nvidia"
BusID "PCI:0:2:0"
EndSection
Section "Device"
Identifier "Card6"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card1"
Monitor "Monitor1"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Card2"
Monitor "Monitor2"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen3"
Device "Card3"
Monitor "Monitor3"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen4"
Device "Card4"
Monitor "Monitor4"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen5"
Device "Card5"
Monitor "Monitor5"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen6"
Device "Card6"
Monitor "Monitor6"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Dziękuję, pozdrawiam.
