Ubuntu 11.10 conky nic nie wy
malinkalive
Ubuntu 11.10 conky nic nie wyświetla
Post autor: malinkalive »
P
o aktualizacji systemu (Ubuntu 11.10) conky przestał być wyświetlany na pulpicie. Nadal się uruchamia, po starcie systemu, ale nic nie pokazuje. Poniżej plik conkyrc
background yes
#prawy dolny rog
gap_x 800
gap_y 20
maximum_width 200
# X font when Xft is disabled, you can pick one with program xfontsel
#font -*-*-*-r-normal--14-*-*-*-c-*-iso8859-2
font -xos4-terminus-*-r-normal-*-12-100-*-*-c-*-iso10646-1
# Use Xft? tutaj bylo yes deeflaudowo
use_xft yes
#xftfont Bitstream Vera Sans Mono:size=8
xftfont Terminus:encoding=utf-8:size=9
xftalpha 0.9
update_interval 1.0
total_run_times 0
own_window yes
#own_window_type desktop
#own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_transparent yes
# If own_window_transparent is set to no, you can set the background colour here
own_window_colour hotpink
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
draw_shades yes
draw_outline no
draw_borders no
stippled_borders 8
border_margin 4
border_width 1
default_color white
default_shade_color black
default_outline_color white
alignment top_left
no_buffers yes
uppercase no
cpu_avg_samples 2
net_avg_samples 2
override_utf8_locale yes
use_spacer yes
own_window yes
own_window_type override
format_human_readable yes
TEXT
#${color #ddaa00}${font Terminus:encoding=iso8859-2:size=15}${time %A}
${font :encoding=iso8859-2:size=9}$alignc${color #ddaa00}
#${time %e %B %G} do określenia daty
${color white}
${color red}Kernel:
$alignc${color }$kernel
${color slate grey}UpTime:
$alignc${color }$uptime
${color slate grey}Load:
$alignc${color }$loadavg
${color slate grey}Poczta:
$alignc${color }${execi 60 ~/.conkygmail}
${color slate grey}Core 1 ${color white}${alignr}${cpu cpu1}%
${color #42AE4A}${cpugraph cpu1 25,200 42AE4A eeeeee} ${color #42AE4A}
${color slate grey}Core 2 ${color white}${alignr}${cpu cpu2}%
${color #42AE4A}${cpugraph cpu2 25,200 42AE4A eeeeee}
${color }${color slate grey}CPU:    $color%${color #ddaa00}$cpu$alignr$color$running_processes/ $processes
${font :size=8}${color lightgrey}${top name 1}$alignr${top cpu 1}
${color lightgrey}${top name 2}$alignr${top cpu 2}
${color lightgrey}${top name 3}$alignr${top cpu 3}
${font :size=9}${color slate grey} /home :${alignr}${color }${fs_free /home}
${fs_bar 5,200 /home}
${font :size=9}${color slate grey} / :${alignr}${color }${fs_free /}
${fs_bar 5,200 /}
${color slate grey}RAM:   $color%$memperc ${alignr}$mem
${membar 5,200}
${font :size=8}${color #ddaa00}${top_mem name 1}$alignr${top_mem mem 1}
${color lightgrey}${top_mem name 2}$alignr${top_mem mem 2}
${font :size=9}
${color slate grey}INTERNET:
##orginalnie bez eth0 ${color}DL:${color #ddaa00}${downspeed wlan0}${color}UP:${color #ddaa00}${upspeed wlan0}${color}${alignr}KiB/s
${color}DL:${color #ddaa00}${downspeed wlan0}${color}VOIP:${color #ddaa00}${downspeed wlan2}${color}${alignr}KiB/s
${offset 10}${color}Total: ${color white}${totaldown wlan0}
${offset 10}${color}VOIPtotal: ${color white}${totaldown wlan2}
${color slate grey}${downspeedgraph wlan0 25,200 000000 00ff00}
${color slate grey}${downspeedgraph wlan2 25,200 000000 000ff}
${offset 0}${font :size=9}LOGI:${color white}
${font :size=8}${voffset -5}$hr
${color}${exec tail -n6 /var/log/syslog | cut -d: -f5 }
Używam compiza i gnome-shell. Poniżej (w załaczniku) xsession-errors.txt. Zmiana parametru ,,own_window_type'' na wartość ,,normal'' wyświetliła conky na pulpicie ale pokazuje się brzydka ramka (zdjęcie w załączniku). Ustawienia cieni w compizi na wartość:
 (any) & !(class=)
nie przynosi efektu.
Zrzut ekranu 2012-03-07 09:45:36.jpg
Przecież masz napisane co należy zrobić?
Conky: /home/karol/.conkyrc: 40: no such configuration: 'border_margin'
Conky: use_spacer should have an argument of left, right, or none.  'yes' seems to be some form of 'true', so defaulting to right.
Conky: forked to background, pid is 3194
Conky: desktop window (1a00004) is subwindow of root window (154)
Conky: window type - normal
Conky: drawing to created window (0x3c00001)
Conky: drawing to double buffer
xdg-settings: unexpected/missing argument
Try 'xdg-settings --help' for more information.
http://debian.linux.pl/threads/5676-Prz ... -napiszesz
http://debian.linux.pl/threads/827-conk ... ddtemp-itd.
http://debian.linux.pl/threads/4589-Con ... propozycje
